Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: NEED HELP! Security Access Error, Controller Refused Key, Error 35
    May 2017
    Quote Originally Posted by GaryM View Post
    The buttons that appear under the "Installed" tab are controllers that have been marked as installed in your CAN Gateway. So this tab provides easy access to all of the controllers that are installed in your vehicle.
    The other tabs are categories of controllers but the buttons that appear under each of these aren't necessarily controllers that are installed in your vehicle. It is just a definitive list of ALL possible controllers. If you try and access a controller that is not present in your vehicle using a button under one of those other tabs then VCDS just won't be able to contact that non-existent controller.
    The "09-Cent. Elec." button under the "Installed" tab and the one under the "Electronics" tab both open the same controller.
    Thank you Gary!
  2. #12
    Dec 2016
    Having the car running made no difference, still getting the same error.
  3. #13
    Jul 2017
    Argentina
    Hello everyone. I have a VW Touareg T2 and I'm trying to get to access security from modul 34 Level Control using code 31564, but I'm having the same problem as you guys! The error is:
    "controller refused the key error 35: invalid key"
    I'M thinking that maybe, could be
    That I'm using the latest version from VCDS, because I'm pretty sure that in the past I was able to get in in the security access..
    HELP PLEASE!!!
    Pls, see a full scanned from my T2:
    Re: Question
    EC
    Eric Christensen
    vie 21/07/2017 07:57 p.m.
    Elementos enviados
    Para:
    support@ross-tech.com;
    Evernote
    Hello Jef.
    The problem that Im having right now is that I want to make some modifications in my suspension to solve a problem and the problem is as follows:
    Step 1) Select Control Modul
    Step 2) Select modul 34 - Level Control.
    Step 3) Security Acces - 16
    Step 4) When I put the code 31564 IS WHEN THE PROBLEM APPEARS.
    When I put that code, there is an error that does not allow me to get in to Adaptation - 10 to make the modifications. The error is:
    Please, help me with this... I need to use my Touareg as soon as possible. PLEASE, HELP ME!!!
    As you request, see a full scann of my T2:
    Friday,21,July,2017,15:47:21:47886
    VCDS Version: 17.1.3.0 (x64)
    VIN: WVGCH67L89XXXXXXXX   License Plate: 21.7
    Mileage: 118090km-73377mi   Repair Order:
    Chassis Type: 7L (6N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 28 32 34 46 55 56 68 76
    VIN: WVGCH67L89XXXXXXXX   Mileage: 118090km-73377miles
    32-Differential Locks -- Status: Malfunction 0010
    68-Wiper Electr. -- Status: OK 0000
    Address 01: Engine        Labels: 079-907-560-BAR.clb
       Part No SW: 7L0 907 560 A    HW: 7L0 907 560
       Component: 4.2l V8/4V          0070
       Revision: 75H05---    Serial number: VWX3Z0H3771107
       Coding: 04210003590F0560
       Shop #: WSC 03063 985 94024
       VCID: 2F6D15B3BDA6423940-515C
    Readiness: 0110 1101
       Part No SW: 09D 927 750 HF    HW: 09D 927 750 HF
       Component: AL 750 6A           1409
       Revision: 00H75000    Serial number:
       Coding: 0004458
       Shop #: WSC 31414 790 00001
       VCID: 79F9EBEB33625C89AE-515C
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
       Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
       Component: ESP ALLRAD MK25E1   0304
       Revision: 00H53001
       Coding: 0008578
       VCID: 46835017351CE37193-8012
                        Reset counter: 17
                        Mileage: 118092 km
                        Date: 2017.06.11
                        Time: 00:43:53
                        Count: 128
                        Count: 12545
                        Count: 294
                        Count: 5
       Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
       Component: 2G Kessy            6850
       Revision: 00H22070    Serial number: VWX3Z0H3771107
       Coding: 0147688
       VCID: 2A5B04A78144271197-807E
    Address 08: Auto HVAC        Labels: 7L6-907-044.clb
       Part No: 7L6 907 044 AH
       Component: CLIMAtronic 2+2     4334
       Coding: 0021030
       VCID: 7AFBF4E731645791A7-802E
       Subsystem 1 - Part No: 7L6 907 049 F
       Component: CLIMAtronic FOND    0503
    02599 - Rear Left Temperature Flap Motor (V313)
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V2.clb
       Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
       Component: J519                2003
       Revision: -0004---    Serial number: --------------
       Coding: 600004003B261C000000000000000000
       VCID: 000F860F57B80D41E9-8054
    Address 15: Airbags        Labels: 7L0-959-655.lbl
       Part No SW: 7L0 959 655     HW: 7L0 959 655
       Component: J234__36 VW8T       0250
       Revision: 92012025    Serial number: 0039P005BWVU
       Coding: 0013110
       Part No: 7L6 953 549 F
       Component: J527                3601
       Coding: 0010011
       VCID: 428B4C071934DF51BF-8016
    Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
       Part No SW: 7L6 920 890 B    HW: 7L6 920 890 B
       Component: J285 KOMBI-INST.    8828
       Revision: KHH06V35
       Coding: 0006101
       Shop #: WSC 00011 888 96745
       VCID: 377D2DD346F68AF918-8062
    Address 19: CAN Gateway        Labels: 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 7L6 920 890 B
       Component: J533  GW-K-CAN TP20 8828
       Coding: 7FEAE7A940046002
       VCID: 70EFD6CF63181DC119-8024
       Part No: 0AD 927 755 BG
       Component: TRANSFERCASE        0126
       VCID: 0109830B5BB20449E6-515C
    Address 28: HVAC, Rear
    Address 32: Differential Locks        Labels: None
       Part No: 0AC 927 771 D
       Component: SG-Quersperre       5023
       VCID: 39792BEB73E29C89EE-515C
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 J
       Component: LUFTFDR.-CDC- 3C3P1 3125
       Coding: 0015521
       VCID: 3A7B34E771E49791E7-806E
    00311 - Tire Filling Connection
       Part No: 7L6 959 933 A
       Component: 22 HSG              0601
       Coding: 0000081
       VCID: 408F460F1038CD41A9-4B02
       Subsystem 1 - Part No: 7L0 959 701 P
       Component: Tuersteuergeraet FS 6304
       Subsystem 2 - Part No: 7L0 959 702 P
       Component: Tuersteuergeraet BF 6304
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
       Subsystem 5 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
       Subsystem 6 - Part No: 7L6 951 171 B
       Component:    Innenraumsensor  0020
    Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
       Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
       Component: AFS-Steuergeraet    0001
       Revision:   H02       Serial number:
       Coding: 1288323
       VCID: 39792BEB74E29C89EE-806C
       Component: AFS-Lst.-Modul l    S002
       Coding: 00000019
       Component: AFS-Lst.-Modul r    S002
       Coding: 00000019
    Address 56: Radio        Labels: 7L6-035-180-56.lbl
       Part No SW: 7L6 035 180 C    HW: 7L6 035 180 C
       Component: Radio DE2           0008
       Revision: 00006000    Serial number: VWZ4Z4HN019068
       Coding: 0001402
       VCID: 2D510FBBB4AA302972-8078
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L6 955 119 B
       Component: J400__ Front Wiper  5301
       Coding: 0001397
       VCID: 39792BEB70E29C89EE-806C
       Component: RLS     050608 054  0402
       Coding: 00208941
       Shop #: WSC 31414
       Part No: 7L0 919 283 F
       Component: 0P Einparkhilfe     1108
    End-------------------------(Elapsed Time: 03:50)--------------------------
  4. #14
    I wonder if the module refuses due to the faults (like steering angle sensor) that are present?
