Results 1 to 5 of 5
Thread: Request: adapmap BCM and AFS Module of 2016 Touran 5T Basic Led
    Jan 2017
    Spain
    Hi team, i am searching adaptation maps from Touran 5T with basic Led for retrofit from halogen to basic led systems
    Best regards, Luis.
    Apr 2015
    Abingdon, UK
    Auto-scan pls....
    Regards
    Jocker01
    Jan 2017
    Spain
    Quote Originally Posted by jocker01 View Post
    Auto-scan pls....
    Regards
    Jocker01
    Sorry.
    Friday,26,May,2017,18:16:52:17801
    VCDS Version: 17.4.2.3  HEX-NET CB: 0.4336.4
    Data version: 20170505 DS270.4
    VIN: WVGZZZ1TZGWXXXXXX   License Plate:
    Chassis Type: 1T (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F BB BC
    VIN: WVGZZZ1TZGWXXXXXX   Mileage: 19472km-12099miles
    Address 01: Engine (J623-DFEA)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 026 EB    HW: 04L 907 309 M
       Component: R4 2,0L EDC   H23 1480
       Revision: B4H23---
       Coding: 0119001203241D082000
       ASAM Dataset: EV_ECM20TDI01104L906026EB 001003
       ROD: EV_ECM20TDI01104L906026EB_001.rod
       VCID: 6E901C1EB1D28C37EE-803A
    17158 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:01:56
                        Coolant temperature: 39 C
                        Intake air temperature: 38 C
                        Ambient air pressure: 930 mbar
                        Voltage terminal 30: 12.360 V
                        Drivetrain coordinator: ACC fault status-Bit 0: 0
                        Drivetrain coordinator: ACC fault status-Bit 8: 0
                        Drivetrain coordinator: brake fault status-Bit 0: 4
                        Drivetrain coordinator: brake function status-Bit 0: 0
                        Drivetrain coordinator: brake function status-Bit 8: 0
                        Acceleration: 0.000 m/s
              U0428 00 [039] - -
                        Time: 00:00:00
                        Intake air temperature: 37 C
                        Voltage terminal 30: 12.380 V
                        CAN status - engine control module-Bit 0: 0
                        Cruise Control System (CCS): status-Bit 0: 0
    28991 - No Communications with NOX Sensor 1
              U029D 00 [032] - -
                        Mileage: 17415 km
                        Date: 2017.04.12
                        Time: 22:13:31
                        Coolant temperature: 74 C
                        Intake air temperature: 70 C
                        Voltage terminal 30: 12.460 V
                        Unlearning counter according OBD: 5
                        CAN status - transmission control module-Bit 0: 0
                        CAN status - brake control module 1-Bit 0: 8
                        CAN status - brake control module 2-Bit 0: 0
                        selected gear-Bit 0: 0
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 62985000000125
       Coding: 0CEA6AA034228B710778060141CC2930562CD1E0608294F51060F078C002
       VCID: 79BA3F42F89CDB8F4B-802C
    0297 - Steering angle sensor
              B1168 16 [137] - Voltage Too Low
                        Reset counter: 159
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:01:56
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 159
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:02:06
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 159
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:02:06
       Part No SW: 5G0 907 044 BF    HW: 5G0 907 044 BF
       Component: Climatronic   H04 1202
       Revision: 00001K10
       Coding: 08020104200100011005104000101002
       ASAM Dataset: EV_ACClimaBHBVW37X 005137
       ROD: EV_ACClimaBHBVW37X_005_VW37.rod
       VCID: 6C94161687CE7E27C0-8038
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
       Revision: --------    Serial number: 86580711151512
       Coding: 00000842C24102FB4BC44000000403081080000000000000000000000000
       ROD: EV_BCMBOSCH_015_VW37.rod
       VCID: 004C52A69B468A470C-8054
       Subsystem 1 - Part No SW: 5TB 955 119 A    HW: 5TB 955 119
       Component: WWS    150926  043 0608
       Serial number:         151008083918
       Component: RLHS  037 0059
       Serial number: S2Y15M11D11H10M51S59
       Coding: 90A8DD
    17162 - Bulb for Left DRL and Parking Lamp
              B12EA 15 [009] - Open or Short to Plus
                        Reset counter: 159
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:08:17
    17418 - Bulb for Right DRL and Parking Lamp
              B12EB 15 [009] - Open or Short to Plus
                        Reset counter: 159
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:08:17
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391529907366
       Coding: 0071151001
       VCID: 44C49EB6CFDE566768-8010
    13637426 - Databus
                        Reset counter: 159
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:01:56
    Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
       Component: ACC BOSCH MQB H04 0192
       Coding: 2A00600111FFC428949C804D
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3424CE769F7EE6E7D8-8060
    2055 - Databus
              U1122 00 [009] - Implausible Message
                        Reset counter: 159
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:01:58
                        Control Module temperature: 24 C
                        Voltage terminal 15: 12.3 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s
    2101 - Databus
                        Reset counter: 159
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:01:57
       Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
       Component: AirbagVW21    005 0130
       Serial number: 003NSR17JZ6K
       Coding: 98CCC0C00C0000005C5450CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
       VCID: 03465DAA8A50915F11-8056
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5TB857705E0309P00508
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5TB857706E0310P01580
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 002 210 15
       Serial number: 35700000000658AC371O
       Subsystem 4 - Part No SW: -----------    HW: 480 002 210 15
       Serial number: 35800000000B59AC371V
       Subsystem 5 - Part No SW: -----------    HW: 480 411 910 15
       Component: SideSensor_Dr  003 0189
       Serial number: 351001A011BAA0B33C95
       Subsystem 6 - Part No SW: -----------    HW: 480 411 910 15
       Component: SideSensor_Pr  003 0189
       Serial number: 352001A011BBA6E50C39
       Subsystem 7 - Part No SW: -----------    HW: 480 403 110 15
       Serial number: 3550002BF1D73C62C22F
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 310 15
       Serial number: 2280002B51CF1D22D27C
       Subsystem 9 - Part No SW: -----------    HW: 480 402 310 15
       Serial number: 2290002AB1D3F973E31J
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 402 310 15
       Serial number: 2300002A31D3F975221Z
       Subsystem 11 - Part No SW: -----------    HW: 480 001 410 15
       Serial number: I0M00000000DC2491713
       Subsystem 12 - Part No SW: -----------    HW: 480 001 410 15
       Serial number: I0N000000003D249171
    1050117 - Databus
                        Reset counter: 159
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 00:01:58
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 05111504221508
       Coding: 0400
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 0D527B92DC14D72F77-8058
       Part No SW: 5TA 920 741     HW: 5TA 920 741
       Component: KOMBI         208 6421
       Coding: 07A401002380000801886B011400000000000000
       Shop #: WSC 00046 000 00000
       VCID: 014A57A2904C834F03-8054
    16777022 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 198
                        Mileage: 15994 km
                        Date: 2017.03.18
                        Time: 20:16:49
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1243
       Revision: --------    Serial number: 0004086017
       Coding: 030100041F087300FB00024C080F00010001050000000000000000000000
       Subsystem 2 - Part No SW: 5TA 959 442 A    HW: 5TA 959 442 A  Labels: 3C8-959-537.CLB
       Serial number: 2991500464100049AO2B
       Coding: 280000
       Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
       Component: J367-BDMHella  H10 9052
       Serial number: 3512708103
    131654 - No Communications with HVAC Control Module (J301)
              U0164 00 [008] - -
                        Reset counter: 198
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 08:48:30
                        Supply voltage: Terminal 30: 12.4 V
                        Terminal 15: OFF
    66052 - Infotainment CAN Bus (SAE Bus E)
              U0065 00 [008] - Performance
                        Reset counter: 163
                        Mileage: 15993 km
                        Date: 2017.03.18
                        Time: 14:05:48
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: On
              U1101 00 [008] - Active
                        Reset counter: 198
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 08:26:07
                        Terminal 15: On
       Serial number: 270715BGP12628
       Coding: 003083208000040000001000
       VCID: 43C69DAACAD0515F51-8016
    Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2033
       Revision: 00000000    Serial number: 0000483300
       Coding: 01000010005000
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
       VCID: 3B36E54AB220299F19-806E
    5262656 - Steering Angle Sensor
              B1168 F2 [137] - Not Initialized
                        Reset counter: 159
                        valid
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 040815BH115548
       Coding: 003081208000040000801000
       VCID: 40CC92A6DBC64A474C-8014
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 043 D    HW: 5G0 035 043
       Component: MU-H-N-EU     H41 0388
       Serial number: A309D0E7503993
       Coding: 02730901FF00000011110001000800001F0100D40100010057
       Shop #: WSC 13417 999 22382
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 1F0E31DA06F855BF15-804A
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9PU300QC0
       Subsystem 2 - Part No SW: V03 959 800 KF    HW: -----------
       Component: ECE 2017  --- 0157
       Component: Gracenote  --- 1008
    9 Faults Found:
              B201A 00 [009] -  -
                        Reset counter: 158
                        Mileage: 1048574 km
                        Time: 00:00:00
                        Voltage terminal 30: 12.9 V
                        Status_Software_Version_Management-SW_VersMgtInfo: MDUV101/ABT
    13697024 - Component Protection
              U1100 00 [008] - No Basic Setting
                        Reset counter: 199
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 08:36:32
                        Voltage terminal 30: 12.5 V
                        Reset counter: 199
                        Mileage: 19472 km
                        Date: 2017.05.26
                        Time: 08:26:07
                        Voltage terminal 30: 12.4 V
    0512 - Rear Right Bass Speaker
              B1067 13 [008] - Open Circuit
                        Reset counter: 199
                        Mileage: 1048574 km
                        Time: 00:00:00
    0517 - Front Right Bass Speaker
              B1062 13 [008] - Open Circuit
                        Reset counter: 199
                        Mileage: 1048574 km
                        Time: 00:00:00
                        Voltage terminal 30: 13.1 V
    0522 - Front Left Bass Speaker
              B105F 13 [008] - Open Circuit
                        Reset counter: 199
                        Mileage: 1048574 km
                        Time: 00:00:00
    0527 - Rear Left Bass Speaker
              B1065 13 [008] - Open Circuit
                        Reset counter: 199
                        Mileage: 1048574 km
                        Time: 00:00:00
    2565 - GPS Antenna
              B1054 13 [009] - Open Circuit
                        Reset counter: 59
                        Mileage: 1048574 km
                        Time: 00:00:00
    1564 - Microphone 1
              B129B 13 [008] - Open Circuit
                        Reset counter: 199
                        Mileage: 1048574 km
                        Time: 00:00:00
                        Voltage terminal 30: 13.0 V
    Address BB: Door Rear Drv (J388)       Labels: None
       Serial number: 080815BH803729
       Coding: 002081200000048000001000
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       VCID: 45C283B2C4E46F6F7F-8010
    Address BC: Door Rear Pass (J389)       Labels: None
       Serial number: 300715BGN05056
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    End----------(Elapsed Time: 01:46, VBatt start/end: 12.3V/12.3V)-----------
    Apr 2015
    Abingdon, UK
    Vru, Estonia
    What my friend is asking here is for someone else with similar car post his maps for reference. ..For Retrofitting purposes.
    Volkswagen Golf MKV 2.0TDI-8V 4MOTION MY2007Some of the work I've done and cared to make a picture.
    Our webpage and Facebook page Heads up, it's in Estonian language.
    The world is my oyster...
