- Jun 27, 2016
- 22
- 15
- N Wales, UK
- C?ID=249332
Saturday,27,May,2017,16:01:23:37770
VCDS Version: 17.4.2.3
Data version: 20170505 DS270.4
VIN: WVWZZZAUZHW320408 License Plate: 2017 GOLF
Mileage: 3842km-2387mi Repair Order:
Chassis Type: AU (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZHW320408 Mileage: 3842km-2387miles
Address 01: Engine (J623-DCYA) Labels: None
Part No SW: 04L 906 026 EK HW: 04L 907 309 R
Component: R4 2.0l TDI H23 4029
Revision: B5H23---
Coding: 01250012036405082000
ASAM Dataset: EV_ECM20TDI01104L906026EK 004003
ROD: EV_ECM20TDI01104L906026EK_004_VW37.rod
VCID: 77FDA4A7CE5ECEFF3D-8022
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0GC 300 040 T HW: 0GC 927 711 G
Component: GSG DQ381 H06 0705
Revision: 00H06V07
ROD: EV_TCMDQ381061_VW37.rod
VCID: 35616EAF94D2FCEFEF-8060
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 60437000000750
Coding: 01FA8AA12422096C477B060040CB2980512490E26002947338625078C202430000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
8400 - Databus
Reset counter: 153
Mileage: 3533 km
Date: 2017.05.26
Time: 09:54:31
Extended Freeze Frames:
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 AQ HW: 5G0 907 426 AQ
Component: AC Manuell H03 1801
Revision: 00001K06
Coding: 00120104202110001000000000000002
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 7AFBBD93FD4CD39742-802E
Part No SW: 5Q0 937 084 CE HW: 5Q0 937 084 CE
Component: BCM MQBAB M H34 0236
Serial number: 02001704200061
ROD: EV_BCMBOSCH_017_VW27.rod
VCID: 7DF1B68FEC62E4AF67-8028
Component: WWS 170120 042 0551
Serial number: 170206135605
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S3Y17M02D14H06M42S19
Coding: 00A8DD
Serial number: 000000000ZY170163A84
Serial number: 00000000000068354460
197904 - Central Locking
B140A 4B [008] - Over temperature
Reset counter: 140
Mileage: 3142 km
Date: 2017.05.19
Time: 18:11:56
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617039
Coding: 0471051011
ASAM Dataset: EV_EPHVA18AU3700000 009031
VCID: 4A9B2D53ED2C831792-801E
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 3QF 907 572
Coding: 3300678151FFC728949C810580400600000000000000000000
VCID: 3C777B8BB7F82DA710-8068
0836 - Databus
Fault Frequency: 25
Reset counter: 157
Mileage: 3098 km
Date: 2017.05.19
Time: 14:29:22
Dynamic environmental data: 02 8D
Control Module temperature: 39 °C
Voltage terminal 15: 12.9 V
Velocity_vehicle_reference: 1.22 m/s
Longitudinal_acceleration_vehicle_reference: -0.30 m/s²
Status_ACC_System: ACC_Off_MainSwitch_Off
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2LPUT7
Coding: 98CCC000000000005C0000CF008800000065
VCID: 102FFF3BCBF0F9C79C-8044
Belt Pretensioner left:
Serial number: 34169677E09021740016
Coding: 333135
Belt Pretensioner right:
Serial number: 34169676E10021750562
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 402 17
Serial number: 3570000000057B8DC02U
Subsystem 4 - Part No SW: ----------- HW: 480 001 402 17
Serial number: 35800000000F5550A02F
Subsystem 5 - Part No SW: ----------- HW: 480 400 902 17
Serial number: 3510001C723E0215640N
Subsystem 6 - Part No SW: ----------- HW: 480 401 102 17
Serial number: 3520001A52439D91463.
Subsystem 7 - Part No SW: ----------- HW: 480 401 102 17
Component: FrontSensor_D 000 6149
Serial number: 3550001C923E021554E%
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 13021708490490
Coding: 0410
VCID: 020BC573959C9B571A-8056
Part No SW: 5G1 920 941 B HW: 5G1 920 941 B
Component: KOMBI 204 8311
Coding: 27A429082780060001886B011400000000000000
VCID: 285FB7DB5360910764-807C
U1110 00 [008] - -
Fault Frequency: 10
Reset counter: 157
Mileage: 3310 km
Date: 2017.05.23
Time: 09:45:07
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005897098
Coding: 030100045F086800FB00005C1C0F00010001050000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 2F6D5CC7768EC63FA5-807A
Serial number: 29170000323960097061
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 7430563004
9175296 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] - -
Fault Frequency: 109
Reset counter: 157
Mileage: 23 km
Date: 2017.04.01
Time: 16:20:10
Supply voltage: Terminal 30: 14.2 V
Terminal 15: On
Component: TSG FS 020 0041
Serial number: 150117EAE11772
Coding: 003B0220D001048000001000
VCID: 43850077CA06525F51-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013354076
Coding: 0D0000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8107
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 3A7B7D93BDCC139702-806E
Component: TSG BFS 020 0041
Serial number: 280117EAR12367
Coding: 003B0020DE01048000801000
VCID: 428B0573D51C5B575A-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013370825
Coding: 150000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0751
Coding: 02731001FF00000051110101008808001F0500C601200100CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 31695ABF60BAD0CFB3-8064
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H41 8077
Serial number: VWZ6ZET0491239
Subsystem 2 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
End---------------------(Elapsed Time: 04:33, Deb=2)-----------------------
Regards,
Mel
