Results 1 to 1 of 1
Thread: 2017 Gold 2.0 TDi {DCYA}
    Jun 2016
    N Wales, UK
    Saturday,27,May,2017,16:01:23:37770
    VCDS Version: 17.4.2.3
    Data version: 20170505 DS270.4
    VIN: WVWZZZAUZHW320408   License Plate: 2017 GOLF
    Mileage: 3842km-2387mi   Repair Order:
    Chassis Type: AU (3Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZHW320408   Mileage: 3842km-2387miles
    Address 01: Engine (J623-DCYA)       Labels: None
       Part No SW: 04L 906 026 EK    HW: 04L 907 309 R
       Component: R4 2.0l TDI   H23 4029
       Revision: B5H23---
       Coding: 01250012036405082000
       ASAM Dataset: EV_ECM20TDI01104L906026EK 004003
       ROD: EV_ECM20TDI01104L906026EK_004_VW37.rod
       VCID: 77FDA4A7CE5ECEFF3D-8022
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0GC 300 040 T    HW: 0GC 927 711 G
       Component: GSG DQ381     H06 0705
       Revision: 00H06V07
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 35616EAF94D2FCEFEF-8060
       Revision: 00000000    Serial number: 60437000000750
       Coding: 01FA8AA12422096C477B060040CB2980512490E26002947338625078C202430000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
    8400 - Databus
                        Reset counter: 153
                        Mileage: 3533 km
                        Date: 2017.05.26
                        Time: 09:54:31
                        Extended Freeze Frames:
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
       Component: AC Manuell    H03 1801
       Revision: 00001K06
       Coding: 00120104202110001000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 004134
       ROD: EV_ACManueBHBVW37X_004_VW37.rod
       VCID: 7AFBBD93FD4CD39742-802E
       Part No SW: 5Q0 937 084 CE    HW: 5Q0 937 084 CE
       Component: BCM MQBAB M   H34 0236
       Serial number: 02001704200061
       ROD: EV_BCMBOSCH_017_VW27.rod
       VCID: 7DF1B68FEC62E4AF67-8028
       Component: WWS    170120  042 0551
       Serial number:         170206135605
       Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  042 0105
       Serial number: S3Y17M02D14H06M42S19
       Coding: 00A8DD
       Serial number: 000000000ZY170163A84
       Serial number: 00000000000068354460
    197904 - Central Locking
              B140A 4B [008] - Over temperature
                        Reset counter: 140
                        Mileage: 3142 km
                        Date: 2017.05.19
                        Time: 18:11:56
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Part No SW: 5QA 919 294 A    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0038
       Serial number: 000308418617039
       Coding: 0471051011
       ASAM Dataset: EV_EPHVA18AU3700000 009031
       VCID: 4A9B2D53ED2C831792-801E
    Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
       Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0620
       Coding: 3300678151FFC728949C810580400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002005
       VCID: 3C777B8BB7F82DA710-8068
    0836 - Databus
                        Fault Frequency: 25
                        Reset counter: 157
                        Mileage: 3098 km
                        Date: 2017.05.19
                        Time: 14:29:22
                        Dynamic environmental data: 02 8D
                        Control Module temperature: 39 C
                        Voltage terminal 15: 12.9 V
                        Velocity_vehicle_reference: 1.22 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.30 m/s
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0317
       Serial number: 003TDR2LPUT7
       Coding: 98CCC000000000005C0000CF008800000065
       VCID: 102FFF3BCBF0F9C79C-8044
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169677E09021740016
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169676E10021750562
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 402 17
       Serial number: 3570000000057B8DC02U
       Subsystem 4 - Part No SW: -----------    HW: 480 001 402 17
       Serial number: 35800000000F5550A02F
       Subsystem 5 - Part No SW: -----------    HW: 480 400 902 17
       Serial number: 3510001C723E0215640N
       Subsystem 6 - Part No SW: -----------    HW: 480 401 102 17
       Serial number: 3520001A52439D91463.
       Subsystem 7 - Part No SW: -----------    HW: 480 401 102 17
       Serial number: 3550001C923E021554E%
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 13021708490490
       Coding: 0410
       VCID: 020BC573959C9B571A-8056
       Part No SW: 5G1 920 941 B    HW: 5G1 920 941 B
       Component: KOMBI         204 8311
       Coding: 27A429082780060001886B011400000000000000
       VCID: 285FB7DB5360910764-807C
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Fault Frequency: 10
                        Reset counter: 157
                        Mileage: 3310 km
                        Date: 2017.05.23
                        Time: 09:45:07
       Component: GW MQB High   418 4286
       Revision: --------    Serial number: 0005897098
       Coding: 030100045F086800FB00005C1C0F00010001050000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 2F6D5CC7768EC63FA5-807A
       Serial number: 29170000323960097061
       Coding: 2DFFFF
       Serial number: 7430563004
    9175296 - Function Restriction due to Driver Fatigue Recognition
              B130E 00 [008] -  -
                        Fault Frequency: 109
                        Reset counter: 157
                        Mileage: 23 km
                        Date: 2017.04.01
                        Time: 16:20:10
                        Supply voltage: Terminal 30: 14.2 V
                        Terminal 15: On
       Serial number: 150117EAE11772
       Coding: 003B0220D001048000001000
       VCID: 43850077CA06525F51-8016
       Serial number: 00000000000013354076
       Coding: 0D0000
       Coding: 8107
       ROD: EV_SteerAssisMQB_013_VW37.rod
       VCID: 3A7B7D93BDCC139702-806E
       Serial number: 280117EAR12367
       Coding: 003B0020DE01048000801000
       VCID: 428B0573D51C5B575A-8016
       Serial number: 00000000000013370825
       Coding: 150000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
       Component: MU-S-ND-ER    840 0751
       Coding: 02731001FF00000051110101008808001F0500C601200100CF
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 31695ABF60BAD0CFB3-8064
       Component: ABT_Std-2_Nav  H41 8077
       Serial number: VWZ6ZET0491239
       Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
       Component: ECE1 2017  --- 0730
    End---------------------(Elapsed Time: 04:33, Deb=2)-----------------------
    Regards,
    Mel
    Last edited by Banjo Mel; 05-27-2017 at 10:25 AM. Reason: Correct titling shold be 2017 Golf 2.0.TDi (DCYA) !
  2. Likes Eric, Uwe, jocker01 liked this post
