I purchased a Hex Net to use on a 2015 Lamborghini Huracan.
When I go into central electronics / coding
All the coding does not have any description
Here is a copy of my auto scan
Tuesday,23,May,2017,17:41:21:55582
VCDS Version: 17.1.0.0 (x64) HEX-NET CB: 0.4336.4
Data version: 20170106 DS267.0
VIN: ZHWUC1ZF7FLA01704 License Plate:
Chassis Type: ZF (4S0)
Scan: 01 02 03 05 08 09 11 31 14 15 16 17 19 1B 22 3B 42 44 46 52
53 55 56 5F 65 6C C2 D0
VIN: ZHWUC1ZF7FLA01704 Mileage: 25050km-15565miles
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
D0-Frt Axle Lift -- Status: OK 0000
Address 01: Engine (------CSJC) Labels: None
Part No SW: 4T0 907 552 A HW: 4T0 907 552 A
Component: 5.2l V10HDZ / H55 0004
Revision: NHH55---
Coding: 1E2500320506000D2000
Shop #: WSC 47382 001 1048576
ASAM Dataset: EV_ECM52FSI1114T0907552A 001005
ROD: EV_ECM52FSI1114T0907552A.rod
VCID: 3522C3D0949868E92C-8060
22593 - Fuel Level Sensor Circuit
P0461 00 [096] - Implausible Signal
Address 02: Auto Trans (J217) Labels: 0BH-927-711.clb
Part No SW: 4T0 927 155 A HW: 0BH 927 711 D
Component: 0BZ_52FSI_NAR H09 0813
Revision: 00H09V01
ASAM Dataset: EV_TCMDL800041 001009
ROD: EV_TCMDL800041_LB72.rod
VCID: 3620C4DC899E63F125-8062
Part No SW: 4S0 907 379 HW: 4S0 907 379
Component: ESP PREMIUM H09 0087
Coding: 218AC141845183824B00
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004041
ROD: EV_ESPPremiAU57X_AU72.rod
VCID: 7AB810ECFD06479181-802E
0004 - Brake Switch (F)
P0571 00 [008] - Implausible Signal
Reset counter: 147
Mileage: 24161 km
Date: 2017.01.25
Time: 14:51:07
VzRef: 01
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 32
Bit Info 4: 1F
F-Path: 02
F-Type: 0A
Uz: BD
29198 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 147
Mileage: 24161 km
Date: 2017.01.25
Time: 14:51:08
VzRef: 01
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 32
Bit Info 4: 1F
F-Path: 02
F-Type: 36
Uz: BD
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FD HW: 4H0 907 064 ED
Component: BCM2 2.0 H36 0560
Coding: 09803006000000000000
VCID: 70AC32C4A37A0DC13F-8024
Serial number: 3214000145060008
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 106
Mileage: 24160 km
Date: 2017.01.25
Time: 09:13:51
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4T0 820 043 A HW: 4T0 820 043 A
Component: KLIMA 1 ZONE H03 0130
Revision: A1013000 Serial number: 01061120140019
Coding: 4A02208000
VCID: 2A18E0AC45263711B1-807E
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0311
Revision: 21020001 Serial number: 00000954903101
Coding: 00E90090402001303D01C8C300202800001C47C8020602C10000081C0440100000400034010000
VCID: 76A004DCC11E23F1E5-8022
Subsystem 1 - Part No SW: 4T1 955 113 HW: 955 113
Component: WWS72x 140803 041 0015
Serial number: ????????????
Coding: 0000F7
Component: G397_RLFS H06 0002
Serial number: 23449666
Coding: 02005D
Subsystem 3 - Part No SW: 4T1 941 531 D HW: 4T1 941 531 D
Component: LCU H02 0012
Serial number: BC288A57000000000001
Address 11: Engine II (-----) Labels: None
Revision: NHH55---
ASAM Dataset: EV_ECM52FSI2114T0907552A 001005
ROD: EV_ECM52FSI2114T0907552A.rod
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 4S0 907 376 A HW: 4S0 907 376 A
Component: DAEMPFUNGS-SG H03 0043
Serial number: 051114020
ASAM Dataset: EV_AudiMagneRide 002004
ROD: EV_AudiMagneRide_AU72.rod
VCID: 383CCAE4838A958137-806C
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G0001LP5S
Coding: 303333343033303030364A55304C34543053
VCID: 3424FED49FE271E11B-8060
Serial number: 6940000Y1400017VPS0L
Serial number: 3575HRB40532MV3CEHK-
Serial number: 3585HRB40532MV3CEH4L
Serial number: 3515JRB404P32020CG8I
Serial number: 3525JRB405932020C9F4
Serial number: 3554VRB405J3201SH193
Serial number: 3564VRB405L3201SL1NO
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4T0 953 513 HW: 4T0 953 513
Component: Lenks.Modul H02 0080
Revision: C0068719 Serial number: 90815NKI0004S
VCID: 72A838CCAD763FD1C9-8026
Subsystem 1 - Part No SW: 18G 959 542 B HW: 18G 959 542 B
Component: E221__MFL-TAS H05 0012
Serial number: 0003498 TAT 20140918
Address 17: Instruments (J285) Labels: 4T0-920-xxx-17.clb
Part No SW: 4T0 920 900 B HW: 4T0 920 900 B
Component: KOMBIINSTR. 013 0159
Revision: AA001001 Serial number: 40400107013MOC
Coding: 01F80094B3B1C3F0020000
VCID: 2E10ECBC79CE5B316D-807A
03158 - Control Module for Information Electronics 1 (J794)
Fault Frequency: 181
Reset counter: 175
Mileage: 24160 km
Date: 2017.01.24
Time: 14:06:55
02750 - Switch for Display Head
Fault Status: 00101110
Reset counter: 110
Mileage: 24166 km
Date: 2017.01.28
Time: 12:29:26
Part No SW: 4S0 907 468 HW: 4S0 907 468
Revision: -------- Serial number: 00000001635556
Coding: 0009071600
ROD: EV_GatewPKOUDS_VW51.rod
VCID: 79BA0FE0F8004C8988-802C
Subsystem 1 - Part No SW: 8K0 915 181 M HW: 8K0 915 181 M
Component: J367-BDM H08 0190
Serial number: 51297K21463371983582
Voltage stabilizer:
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Reset counter: 164
Mileage: 24403 km
Date: 2017.03.17
Time: 23:29:21
Voltage terminal 30: 12.5 V
Voltage terminal 15: 0.0 V
Control Module temperature: 33 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
Component: DYNAMIKLENK. H06 0730
Revision: 52001005 Serial number: --------------
Coding: 050000
VCID: 393ACFE0B0808C89C8-806C
Address 22: AWD (J492) Labels: 4T0-907-160.clb
Part No SW: 4T0 907 160 HW: 4T0 907 160
Component: 4 Wheel Drive H02 0006
Revision: 00001002 Serial number: BBKR545
ASAM Dataset: EV_AllWheelContrBORGLB724 004010
ROD: EV_AllWheelContrBORGLB724_004.rod
VCID: 6FAE31B8B644123926-803A
0115 - Databus
U1123 00 [012] - Received Error Message
Reset counter: 147
Mileage: 24161 km
Date: 2017.01.25
Time: 14:51:07
Vehicle speed: 1.80 km/h
Steering angle: 8.30 °
Outside air temperature: 15.40 °C
Accelerator pedal travel: 18.40 %
Torque specifications: front axle: 550.00 Nm
Torque: front axle: 550 Nm
State_Of_System: not active
State_Of_System: active
Hydraulic pressure sensor 1: 27.89 bar
Hydraulic temperature sensor: 17 °C
Cooling fin temperature: 16 °C
Haldex clutch pump current: 8.50 A
Haldex clutch pump voltage: 7.00 V
Voltage terminal 30: 14.50 V
0194 - Databus
Reset counter: 147
Mileage: 24161 km
Date: 2017.01.25
Time: 14:51:07
Vehicle speed: 1.96 km/h
Steering angle: 8.80 °
Accelerator pedal travel: 17.60 %
Hydraulic pressure sensor 1: 27.99 bar
Haldex clutch pump current: 8.25 A
0196 - Databus
Reset counter: 147
Mileage: 24161 km
Date: 2017.01.25
Time: 14:51:07
0197 - Databus
Reset counter: 147
Mileage: 24161 km
Date: 2017.01.25
Time: 14:51:07
Vehicle speed: 1.85 km/h
Steering angle: 8.70 °
Hydraulic pressure sensor 1: 28.09 bar
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E018YM.
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_VW51.rod
VCID: 373EC9D88E949AF93E-8062
Part No SW: 4T0 959 793 H HW: 4T0 959 793 H
Component: TSG FA H07 0801
Revision: -------- Serial number: 0000116743510
Coding: 010C4B025000620100080102
VCID: 4AD8802CE566171151-801E
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4S0 909 144 D HW: 4S0 909 144 B
Component: EPS H12 0901
Revision: 00000000 Serial number: L00061902
Coding: 09
ASAM Dataset: EV_EPSZFAU72X 001001
ROD: EV_EPSZFAU72X_001.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0350994060
Coding: 011E029A18F20081A0B0C800008503470000000000000000000000000000
Subsystem 1 - Part No: 8J0 951 177
Component: DWA-Sensor H03 0030
Part No SW: 4T0 959 792 H HW: 4T0 959 792 H
Component: TSG BF H07 0801
Revision: -------- Serial number: 0000126793503
Coding: 010C4B825000620100080100
VCID: 49DABF20E0601C0958-801C
Part No SW: 4S0 907 801 HW: 8K0 907 801
Component: EPB-4 H02 0001
Revision: -------- Serial number: 00000000000250
ROD: EV_ParkiBrake_AU72.rod
VCID: 70AC32C4AB7A0DC13F-8024
Address 55: Headlight Range (J431) Labels: 4H4-907-357-V1.clb
Part No SW: 4T0 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0003
Serial number: 141119-0004-045
Coding: 72846F6118020200
ASAM Dataset: EV_AFSLEDHELLALB72X 006131
ROD: EV_AdvanFrontSyste_LB72.rod
Subsystem 1 - Part No SW: 7PP 941 329 S HW: 7PP 941 329 S
H01 7020
Coding: 1D0000
Subsystem 2 - Part No SW: 7PP 941 329 S HW: 7PP 941 329 S
H01 7020
Coding: 1D0000
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156K60E8115975
Coding: 020007020100000001
VCID: 24040E942702E1618B-8070
Part No SW: 4T0 035 664 HW: 4T0 035 664
Component: H-BN-NA H40 0795
Revision: -------- Serial number: 325K 0E7500717
Coding: 010200000001A16F0100820600000001FD0000020000000000
Subsystem 1 - Part No: 4T0 919 859 D
Component: NAR 2014 0801
Subsystem 3 - Part No SW: 4T0 919 609 A HW: 4T0 919 609 A
Component: E380 BDT LB2 H01 0011
Serial number: 00000000002217
Component: CD-Database 5571
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 B HW: 4H0 907 273 B
Component: RDKBERU25 H10 0820
Serial number: 10000000011490
ROD: EV_RDKBERU25_AU57.rod
VCID: 2A18E0AC4D263711B1-807E
Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
Part No SW: 4T0 907 441 HW: 5Q0 907 441 A
Component: LB72x RVC Mid H07 0030
Coding: 080004010A01000300
ASAM Dataset: EV_CamSysRearPANAAU914 002002
ROD: EV_CamSysRearPANAAU914.rod
VCID: 71AA37C0A07004C930-8024
Address C2: Auto Trans 2 (J217) Labels: None
Part No SW: 4T0 927 109 HW: 4T0 927 109
Component: DL800 ZSG H28 0006
Revision: --H28--- Serial number: 0000000098
ASAM Dataset: EV_TCMDL800421 001019
ROD: EV_TCMDL800421.rod
VCID: 74A43ED4DF6231E1DB-8020
Address D0: Frt Axle Lift (J988) Labels: None
Part No SW: 4S0 959 257 HW: 4S0 959 257
Component: Lift-VA006 1980
Revision: 00000000 Serial number: 142870038
Coding: 020607
ASAM Dataset: EV_LiftVA003 001001
ROD: EV_LiftVA003.rod
VCID: 7CB416F4F73279A193-8028
End----------(Elapsed Time: 02:01, VBatt start/end: 12.2V/12.2V)-----------
