Results 1 to 7 of 7
Thread: Air Con Lost
    Oct 2016
    Air Con Lost
    Hi Chaps,
    This was perhaps the warmest day here in England this year and my car chose today to cease breathing cool air for my comfort.
    I'd like to attach an autoscan and a adaptation map and measurement block map each for channel 9. I could not see a security code to enable me to do the same for channel 8.
    Unfortunately I seem not to be able to attach files. Is that because I'm not yet a heavy enough user?
    In Channel 8 the fault code are 00457 and 00256 and 00256 also appears in Channel 9.
    Is it just the temp sensor on top of the a/c rad or do you reckon there is something else wrong?
    Thanks in anticipation of your help.
    Audi A 4 S Line Black Edition 2.0 TDI Saloon MY 2013
    Audi A4 S Line TDI Saloon MY2009 with added cruise control and DAB (Gone at 215k miles)
    Audi A4 Avant Quattro SE Tech MY 2011 (driven by my other half)
    Lotus Elan SE Turbo 1991
    Quote Originally Posted by Boy View Post
    You don't attach them as files, you post them inline between CODE and /CODE (in square brackets) tags.
  3. Likes Uwe, Eric liked this post
    ... as explained here:
    http://forums.ross-tech.com/showthread.php?101
    Oct 2016
    UWE, Many thanks for the pointer.
    Here is my autoscan:
    Monday,22,May,2017,21:25:39:60719
    VCDS Version: 17.1.3.0 (x64)
    VIN: WAUZZZ8K79A057310   License Plate: HD08LEU
    Mileage: 338140km-210110mi   Repair Order: 22052017
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72
    VIN: WAUZZZ8K79A057310   Mileage: 338140km-210110miles
    Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
       Part No SW: 03L 906 022 JM    HW: 03L 906 022 B
       Component: R4 2,0L EDC   H01 3173
       Revision: 11H01---
       Coding: 0104002C18072118
       Shop #: WSC 06325 123 12345
       ASAM Dataset: EV_ECM20TDI03L906022JM A01005
       ROD: EV_ECM20TDI03L906022B.rod
       VCID: 79F2E125F8347D89AE-802C
    5380 - Valve for Air Filter Bypass Flap (N275)
              P1016 00 [047] - Open Circuit
                        Mileage: 294350 km
                        Date: 2015.11.30
                        Time: 18:11:28
                        Engine speed: 869.50 /min
                        Normed load value: 54.5 %
                        Coolant temperature: 15 C
                        Intake air temperature: 13 C
                        Voltage terminal 30: 11.140 V
                        Crankshaft speed (RPM): 869.5 /min
                        Vehicle speed: 0.00 km/h
                        Accelerator position: 0.00 %
                        Ambient air pressure: 1006 hPa
                        Ambient temperature: 14.0 C
                        Air mass: specified value: 532.4 mg/stroke
                        Intake air temperature: 14.0 C
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 AQ    HW: 8K0 907 379 AQ
       Component: ESP8 front    H03 0210
       Coding: 160500
       Shop #: WSC 06325 000 00000
       VCID: 081494E1BBDE1401A1-805C
       Part No SW: 8K0 907 064 BC    HW: 8K0 907 064 C
       Component: BCM2 1.1      H70 0252
       Coding: 031100
       VCID: 72E0D609AD420ED1EF-8026
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Serial number: 0508000027199019
       Component: ELVAUDIB8  H35 0039
       Serial number: 0208000026488004
       Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
       Component: KLIMA 3 ZONEN H06 0140
       Revision: D0000000    Serial number: 0116.06.080035
       Coding: 34040000
       VCID: 428046C9DD62FE51BF-8016
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 218
                        Mileage: 338075 km
                        Date: 2017.05.22
                        Time: 14:43:13
                        Reset counter: 218
                        Mileage: 338075 km
                        Date: 2017.05.22
                        Time: 14:43:13
       Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
       Component: BCM1 1.0      H22 0253
       Revision: 04022001    Serial number: 00000000068449
       Coding: 2600D0914034AF000001000000001D0D001D030800010141000000
       VCID: 2F661F7D7EF0633940-807A
       Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 180608  H05 0060
       Serial number: SWFBIE 0000556
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10162674
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000002606080460
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 218
                        Mileage: 338075 km
                        Date: 2017.05.22
                        Time: 14:43:00
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0038JD16TMKZ
       Coding: 30363434363030303030554A3052384B3053
       VCID: 3C7C3831B78688A1F5-8068
       Serial number: 6334MSME3B0266258
       Serial number: 6344MSME3B02675FN
       Serial number: 6352QSME7D232123A
       Serial number: 6362QSME6E7A246F%
       Serial number: 63732SME6426176F3
       Serial number: 63832SME6B7A341BA
       Component: Lenks.Modul   H12 0013
       Revision: --------    Serial number: 90319HFN00077
       Coding: 000016
       VCID: 3D7A3535A49C81A9C2-8068
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
       Component: KOMBIINSTR.   H16 0221
       Revision: 00200000    Serial number: 995609Y68
       Coding: 2F17080002002600010000
       VCID: 3162190568C475C956-8064
       Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0091
       Revision: GB102039    Serial number: 3900G086108161
       Coding: 000303
       VCID: 46885AD9F14AC27193-8012
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
       Serial number: 18026CE2080608
       Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007340773
       Coding: 011002204001410001
       VCID: 40844CC1D36EEC41A9-8014
       Revision: 00002001    Serial number: 0112438069
       Coding: 011B0622003904400020010000000000
       Shop #: WSC 00752 210 91076
    03532 - Left Brake / Signal Light Lamp 2
                012 - Electrical Fault in Circuit - MIL ON
                        Fault Status: 11101100
                        Reset counter: 219
                        Mileage: 338149 km
                        Date: 2017.05.22
                        Time: 21:19:36
    03554 - Left Brake Light Lamp 3
                        Reset counter: 219
                        Mileage: 338149 km
                        Date: 2017.05.22
                        Time: 21:19:36
    03389 - Data Set Implausible
                        Reset counter: 219
                        Mileage: 338149 km
                        Date: 2017.05.22
                        Time: 21:19:36
    03555 - Right Brake Light Lamp 3
                        Reset counter: 219
                        Mileage: 338149 km
                        Date: 2017.05.22
                        Time: 21:19:36
    03533 - Right Brake / Signal Light Lamp 2
                        Reset counter: 219
                        Mileage: 338149 km
                        Date: 2017.05.22
                        Time: 21:19:36
    Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
       Component: DSP STD       H07 0220
       Revision: S1900000
       Coding: 0205010101
       VCID: 6ED8C279B97A2A310B-803A
       Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000007374201
       VCID: 3F864F3DAE9093B9D0-806A
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 10000000051590
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 346C101157D640E13D-8060
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T2 035 186 Q    HW: 8T2 035 186 Q
       Component: Concert3 DAB  H07 0350
       Revision: 00000010    Serial number: AUZ5Z6K1551892
       Coding: 0302008201018D02037B050800
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
                        Reset counter: 219
                        Mileage: 272072 km
                        Date: 2015.01.31
                        Time: 09:09:10
                        Bin. Bits: 00000000
                        Bin. Bits: 00000100
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Reset counter: 219
                        Mileage: 272072 km
                        Date: 2015.01.31
                        Time: 09:09:10
       Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000100077028
       Coding: 010002204001210001
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000100087538
    End-------------------------(Elapsed Time: 02:50)--------------------------
    and here is my adaptation map for channel 09;
    Channel		Field 1	Field 2	Field 3	Field 4
    1		ERROR:	Channel 01	Not	Available
    2		ERROR:	Channel 02	Not	Available
    3	9	- 	- 	100.00%	100.00%
    4		ERROR:	Channel 04	Not	Available
    5		ERROR:	Channel 05	Not	Available
    6	1800	OFF	N/A	N/A	N/A
    7	900	OFF	N/A	N/A	N/A
    8		ERROR:	Channel 08	Not	Available
    9		ERROR:	Channel 09	Not	Available
    10		ERROR:	Channel 10	Not	Available
    11		ERROR:	Channel 11	Not	Available
    12	120	N/A	N/A	N/A	N/A
    13	60	N/A	N/A	N/A	N/A
    14		ERROR:	Channel 14	Not	Available
    15		ERROR:	Channel 15	Not	Available
    16	3	N/A	N/A	N/A	N/A
    17		ERROR:	Channel 17	Not	Available
    18	255	N/A	N/A	N/A	N/A
    19	1	N/A	N/A	N/A	N/A
    20		ERROR:	Channel 20	Not	Available
    21	1	N/A	N/A	N/A	N/A
    22	1	N/A	N/A	N/A	N/A
    23	1	N/A	N/A	N/A	N/A
    24	1	N/A	N/A	N/A	N/A
    25	2000	N/A	N/A	N/A	N/A
    26	5	N/A	N/A	N/A	N/A
    27		ERROR:	Channel 27	Not	Available
    28		ERROR:	Channel 28	Not	Available
    29		ERROR:	Channel 29	Not	Available
    30		ERROR:	Channel 30	Not	Available
    31		ERROR:	Channel 31	Not	Available
    32		ERROR:	Channel 32	Not	Available
    33		ERROR:	Channel 33	Not	Available
    34	0	N/A	N/A	N/A	N/A
    35	0	N/A	N/A	N/A	N/A
    36		ERROR:	Channel 36	Not	Available
    37	3	N/A	N/A	N/A	N/A
    38		ERROR:	Channel 38	Not	Available
    39		ERROR:	Channel 39	Not	Available
    40		ERROR:	Channel 40	Not	Available
    41		ERROR:	Channel 41	Not	Available
    42		ERROR:	Channel 42	Not	Available
    43	10	N/A	N/A	N/A	N/A
    44	1	N/A	N/A	N/A	N/A
    45	0	N/A	N/A	N/A	N/A
    46	0	N/A	N/A	N/A	N/A
    47	0	N/A	N/A	N/A	N/A
    48	120	N/A	N/A	N/A	N/A
    49	120	N/A	N/A	N/A	N/A
    50	120	N/A	N/A	N/A	N/A
    51	120	N/A	N/A	N/A	N/A
    52	120	N/A	N/A	N/A	N/A
    53	0	N/A	N/A	N/A	N/A
    54		ERROR:	Channel 54	Not	Available
    55	1	N/A	N/A	N/A	N/A
    56	1	N/A	N/A	N/A	N/A
    57		ERROR:	Channel 57	Not	Available
    58		ERROR:	Channel 58	Not	Available
    59		ERROR:	Channel 59	Not	Available
    60		ERROR:	Channel 60	Not	Available
    61		ERROR:	Channel 61	Not	Available
    62		ERROR:	Channel 62	Not	Available
    63		ERROR:	Channel 63	Not	Available
    64		ERROR:	Channel 64	Not	Available
    65		ERROR:	Channel 65	Not	Available
    66		ERROR:	Channel 66	Not	Available
    67		ERROR:	Channel 67	Not	Available
    68		ERROR:	Channel 68	Not	Available
    69		ERROR:	Channel 69	Not	Available
    70		ERROR:	Channel 70	Not	Available
    71		ERROR:	Channel 71	Not	Available
    72		ERROR:	Channel 72	Not	Available
    73		ERROR:	Channel 73	Not	Available
    74		ERROR:	Channel 74	Not	Available
    75		ERROR:	Channel 75	Not	Available
    76		ERROR:	Channel 76	Not	Available
    77		ERROR:	Channel 77	Not	Available
    78		ERROR:	Channel 78	Not	Available
    79		ERROR:	Channel 79	Not	Available
    80		ERROR:	Channel 80	Not	Available
    81		ERROR:	Channel 81	Not	Available
    82		ERROR:	Channel 82	Not	Available
    83		ERROR:	Channel 83	Not	Available
    84		ERROR:	Channel 84	Not	Available
    85		ERROR:	Channel 85	Not	Available
    86		ERROR:	Channel 86	Not	Available
    87		ERROR:	Channel 87	Not	Available
    88		ERROR:	Channel 88	Not	Available
    89		ERROR:	Channel 89	Not	Available
    90		ERROR:	Channel 90	Not	Available
    91		ERROR:	Channel 91	Not	Available
    92		ERROR:	Channel 92	Not	Available
    93		ERROR:	Channel 93	Not	Available
    94		ERROR:	Channel 94	Not	Available
    95		ERROR:	Channel 95	Not	Available
    96		ERROR:	Channel 96	Not	Available
    97		ERROR:	Channel 97	Not	Available
    98		ERROR:	Channel 98	Not	Available
    99		ERROR:	Channel 99	Not	Available
    100		ERROR:	Channel 100	Not	Available
    101		ERROR:	Channel 101	Not	Available
    102		ERROR:	Channel 102	Not	Available
    103		ERROR:	Channel 103	Not	Available
    104		ERROR:	Channel 104	Not	Available
    105		ERROR:	Channel 105	Not	Available
    106		ERROR:	Channel 106	Not	Available
    107		ERROR:	Channel 107	Not	Available
    108		ERROR:	Channel 108	Not	Available
    109		ERROR:	Channel 109	Not	Available
    110		ERROR:	Channel 110	Not	Available
    111		ERROR:	Channel 111	Not	Available
    112		ERROR:	Channel 112	Not	Available
    113		ERROR:	Channel 113	Not	Available
    114		ERROR:	Channel 114	Not	Available
    115		ERROR:	Channel 115	Not	Available
    116		ERROR:	Channel 116	Not	Available
    117		ERROR:	Channel 117	Not	Available
    118		ERROR:	Channel 118	Not	Available
    119		ERROR:	Channel 119	Not	Available
    120		ERROR:	Channel 120	Not	Available
    121		ERROR:	Channel 121	Not	Available
    122		ERROR:	Channel 122	Not	Available
    123		ERROR:	Channel 123	Not	Available
    124		ERROR:	Channel 124	Not	Available
    125		ERROR:	Channel 125	Not	Available
    126		ERROR:	Channel 126	Not	Available
    127		ERROR:	Channel 127	Not	Available
    128		ERROR:	Channel 128	Not	Available
    129		ERROR:	Channel 129	Not	Available
    130		ERROR:	Channel 130	Not	Available
    131		ERROR:	Channel 131	Not	Available
    132		ERROR:	Channel 132	Not	Available
    133		ERROR:	Channel 133	Not	Available
    134		ERROR:	Channel 134	Not	Available
    135		ERROR:	Channel 135	Not	Available
    136		ERROR:	Channel 136	Not	Available
    137		ERROR:	Channel 137	Not	Available
    138		ERROR:	Channel 138	Not	Available
    139		ERROR:	Channel 139	Not	Available
    140		ERROR:	Channel 140	Not	Available
    141		ERROR:	Channel 141	Not	Available
    142		ERROR:	Channel 142	Not	Available
    143		ERROR:	Channel 143	Not	Available
    144		ERROR:	Channel 144	Not	Available
    145		ERROR:	Channel 145	Not	Available
    146		ERROR:	Channel 146	Not	Available
    147		ERROR:	Channel 147	Not	Available
    148		ERROR:	Channel 148	Not	Available
    149		ERROR:	Channel 149	Not	Available
    150		ERROR:	Channel 150	Not	Available
    151		ERROR:	Channel 151	Not	Available
    152		ERROR:	Channel 152	Not	Available
    153		ERROR:	Channel 153	Not	Available
    154		ERROR:	Channel 154	Not	Available
    155		ERROR:	Channel 155	Not	Available
    156		ERROR:	Channel 156	Not	Available
    157		ERROR:	Channel 157	Not	Available
    158		ERROR:	Channel 158	Not	Available
    159		ERROR:	Channel 159	Not	Available
    160		ERROR:	Channel 160	Not	Available
    161		ERROR:	Channel 161	Not	Available
    162		ERROR:	Channel 162	Not	Available
    163		ERROR:	Channel 163	Not	Available
    164		ERROR:	Channel 164	Not	Available
    165		ERROR:	Channel 165	Not	Available
    166		ERROR:	Channel 166	Not	Available
    167		ERROR:	Channel 167	Not	Available
    168		ERROR:	Channel 168	Not	Available
    169		ERROR:	Channel 169	Not	Available
    170		ERROR:	Channel 170	Not	Available
    171		ERROR:	Channel 171	Not	Available
    172		ERROR:	Channel 172	Not	Available
    173		ERROR:	Channel 173	Not	Available
    174		ERROR:	Channel 174	Not	Available
    175		ERROR:	Channel 175	Not	Available
    176		ERROR:	Channel 176	Not	Available
    177		ERROR:	Channel 177	Not	Available
    178		ERROR:	Channel 178	Not	Available
    179		ERROR:	Channel 179	Not	Available
    180		ERROR:	Channel 180	Not	Available
    181		ERROR:	Channel 181	Not	Available
    182		ERROR:	Channel 182	Not	Available
    183		ERROR:	Channel 183	Not	Available
    184		ERROR:	Channel 184	Not	Available
    185		ERROR:	Channel 185	Not	Available
    186		ERROR:	Channel 186	Not	Available
    187		ERROR:	Channel 187	Not	Available
    188		ERROR:	Channel 188	Not	Available
    189		ERROR:	Channel 189	Not	Available
    190		ERROR:	Channel 190	Not	Available
    191		ERROR:	Channel 191	Not	Available
    192		ERROR:	Channel 192	Not	Available
    193		ERROR:	Channel 193	Not	Available
    194		ERROR:	Channel 194	Not	Available
    195		ERROR:	Channel 195	Not	Available
    196		ERROR:	Channel 196	Not	Available
    197		ERROR:	Channel 197	Not	Available
    198		ERROR:	Channel 198	Not	Available
    199		ERROR:	Channel 199	Not	Available
    200		ERROR:	Channel 200	Not	Available
    201		ERROR:	Channel 201	Not	Available
    202		ERROR:	Channel 202	Not	Available
    203		ERROR:	Channel 203	Not	Available
    204		ERROR:	Channel 204	Not	Available
    205		ERROR:	Channel 205	Not	Available
    206		ERROR:	Channel 206	Not	Available
    207		ERROR:	Channel 207	Not	Available
    208		ERROR:	Channel 208	Not	Available
    209		ERROR:	Channel 209	Not	Available
    210		ERROR:	Channel 210	Not	Available
    211		ERROR:	Channel 211	Not	Available
    212		ERROR:	Channel 212	Not	Available
    213		ERROR:	Channel 213	Not	Available
    214		ERROR:	Channel 214	Not	Available
    215		ERROR:	Channel 215	Not	Available
    216		ERROR:	Channel 216	Not	Available
    217		ERROR:	Channel 217	Not	Available
    218		ERROR:	Channel 218	Not	Available
    219		ERROR:	Channel 219	Not	Available
    220		ERROR:	Channel 220	Not	Available
    221		ERROR:	Channel 221	Not	Available
    222		ERROR:	Channel 222	Not	Available
    223		ERROR:	Channel 223	Not	Available
    224		ERROR:	Channel 224	Not	Available
    225		ERROR:	Channel 225	Not	Available
    226		ERROR:	Channel 226	Not	Available
    227		ERROR:	Channel 227	Not	Available
    228		ERROR:	Channel 228	Not	Available
    229		ERROR:	Channel 229	Not	Available
    230		ERROR:	Channel 230	Not	Available
    231		ERROR:	Channel 231	Not	Available
    232		ERROR:	Channel 232	Not	Available
    233		ERROR:	Channel 233	Not	Available
    234		ERROR:	Channel 234	Not	Available
    235		ERROR:	Channel 235	Not	Available
    236		ERROR:	Channel 236	Not	Available
    237		ERROR:	Channel 237	Not	Available
    238		ERROR:	Channel 238	Not	Available
    239		ERROR:	Channel 239	Not	Available
    240		ERROR:	Channel 240	Not	Available
    241		ERROR:	Channel 241	Not	Available
    242		ERROR:	Channel 242	Not	Available
    243		ERROR:	Channel 243	Not	Available
    244		ERROR:	Channel 244	Not	Available
    245		ERROR:	Channel 245	Not	Available
    246		ERROR:	Channel 246	Not	Available
    247		ERROR:	Channel 247	Not	Available
    248		ERROR:	Channel 248	Not	Available
    249		ERROR:	Channel 249	Not	Available
    250		ERROR:	Channel 250	Not	Available
    251		ERROR:	Channel 251	Not	Available
    252		ERROR:	Channel 252	Not	Available
    253		ERROR:	Channel 253	Not	Available
    254		ERROR:	Security	access	required
    255		ERROR:	Security	access	required
    I hope that is helpful.
  6. Likes Boki Ar liked this post
    16.4905 S, 151.7375 W
    - Thanks for posting the Auto-Scan, the G395 sensor can be a common cause of 'no AC' failure on these vehicles.
    If you look at the A/C condenser, the G395 should be on the outlet side line. I would suggest to disconnect the electrical connection and see if there is any evidence of refrigerant oil leaking, a common side effect when these fail.
    We suggest to consult with the Official Factory Repair Information for component locations and proper repair procedures.
    - You can use VCDS to view the G395 pressure in the Measuring Value Block group 1, field (4). This sensor should read about 1-bar of atmospheric pressure at sea level when NOT connected to the refrigerant line, so if there was no refrigerant in the system, you should at least see a reading of 1-bar. With a properly charged AC system, static system pressure could be 4 to 8 bar depending on temperature and the amount of charge in the system.
    If you end up replacing a defective G395, be sure to clear all the fault codes.
    ref: 00256 - A/C Pressure/Temperature Sensor (G395)
    Also have a look at this Ross-Tech forum post we have: Tis the HVAC Season
    Hope this helps and be careful!!! AC systems and refrigerant dangerous if not properly understood and worked on with safety in mind!
    drpeter
  8. Likes Eric, Uwe, Boy, Boki Ar liked this post
  9. #6
    Oct 2016
    Thanks Dr P.
    I have replaced one of these on my old B6 A4 and it was pretty simple, but I appreciate the warning and your guidance on the pressure readings I should expect.
  10. #7
    Nov 2016
    New Zealand
    Thank you to those who contributed to this thread. I have the same symptoms. When I attempt to look at the Measuring Value Block group 1, field (4) I get data in the first two fields, nothing in the third and "ERROR" in the fourth.
    Since the AC failure has been sudden, I'm going to assume it's a sensor issue and not a leak.
