Thursday,18,May,2017,21:41:59:37770
VCDS Version: 17.1.3.0
Data version: 20170505 DS267.9
VIN: WVGZZZ7PZED055678   License Plate:
Mileage: 52116km-32383mi   Repair Order:
Chassis Type: 7P (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
          6D 72
VIN: WVGZZZ7PZED055678   Mileage: 52116km-32383miles
Address 01: Engine (J623-CRCA)       Labels: 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0007
   Revision: 53H41---
   Coding: 292A4012232601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
   ROD: EV_ECM30TDI0117P0907311C.rod
   VCID: 326B55B365BCEBD12F-8066
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [040] - Signal too High
                    Mileage: 50904 km
                    Date: 2017.04.24
                    Time: 10:48:33
                    Coolant temperature: 10 C
                    Intake air temperature: 10 C
                    Voltage terminal 30: 11.120 V
                    Unlearning counter according OBD: 19
                    Mean injection quantity: 0.00 mg/stroke
                    Control Module temperature: 20.9 C
                    EGR_governor_deviation: 1036.8 mg/stroke
                    Inj Ctl q Curr: 0.00 mg/stroke
                    Standardised airflow ratio: 3.9999
                    Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 0.0 kg/h
                    Actual charge pressure: 1011 hPa
Readiness: 0 1 0 0 0
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 BQ    HW: 0C8 927 750 BQ
   Component: AL1000 AISIN  002 2530
   Coding: 003568
   Shop #: WSC 49881 002 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7CF7BB8BF778EDA1B5-8028
Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 412340010EC818
   Coding: 5B6B13C309292558DAFAC89A90DAA450F700
   ROD: EV_ESPMK25A00800.rod
   VCID: 4A9B2D53ED2C831177-801E
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.CLB
   Part No SW: 4H0 907 064 FH    HW: 4H0 907 064 EH
   Component: BCM2 2.0      H36 0551
   Coding: 05B60016000000000000
   VCID: 74E793ABD728A5E1FD-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 0214000121732004
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 246
                    Mileage: 50865 km
                    Date: 2017.04.13
                    Time: 11:37:25
                    Reset counter: 246
                    Mileage: 50865 km
                    Date: 2017.04.13
                    Time: 11:37:25
Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: B6A6000890
   VCID: 0501DE6F84B2AC69DA-8050
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 18
                    Mileage: 50904 km
                    Date: 2017.04.24
                    Time: 10:48:37
                    Voltage terminal 30-Data: 12.0 V
                    Outside air temperature-Data: 77.50 C
                    Engine speed-Data: 902 /min
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.CLB
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001773614
   Coding: 26001010D1345D010021000300005D0C431D470807010241000000020000
   VCID: 6CD78BCB8F187D2125-8038
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    140612  033 0021
   Serial number: 90243401140617111403
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20352111
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000307140169
                    Fault Status: 00101100
                    Fault Frequency: 27
                    Reset counter: 18
                    Mileage: 50904 km
                    Date: 2017.04.23
                    Time: 16:42:00
Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28231417903292
   Coding: 108501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43850077CA065259B4-8016
          B10FC 13 [008] - Open Circuit
                    Reset counter: 18
                    Mileage: 50904 km
                    Date: 2017.04.24
                    Time: 10:48:37
Address 15: Airbags (J234)       Labels: 7P0-959-655.clb
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag00K H10 0043
   Revision: --------    Serial number: 003NK000BU45
   Coding: 00000000000000000000000000000000304B
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002.rod
   Serial number: 3575LRB404T2LFGMDPO$
   Serial number: 3585LRB404P2L7IMC13R
   Serial number: 3517ARB40592NFSGCGM1
   Serial number: 3527ARB40592NFSGHP60
   Serial number: 3557BRB405J2N220IP30
   Serial number: 3567BRB405L2N220EQ1+
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.CLB
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 01335NFT000X5
   Coding: 000C35
   VCID: 387F679B8BC0018111-806C
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0054621 TRW 20140610
Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 982 S    HW: 7P6 920 982 S
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658010714592058
   Coding: 332731002B00260001000C
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 4E9321431144AF312B-801A
16776976 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 18
                    Mileage: 50904 km
                    Date: 2017.04.24
                    Time: 10:48:37
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001456757
   Coding: 000D07AD00
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3F8D0C87A6EE36B9D0-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 41178017095701471335
   Voltage stabilizer:
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] -  -
                    Fault Frequency: 31
                    Reset counter: 35
                    Mileage: 50940 km
                    Date: 2017.05.05
                    Time: 18:22:41
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 38 C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
Address 42: Door Elect, Driver (J386)       Labels: NONE
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000108481241
   Coding: 011D1620D001451005080002
   VCID: 7AFBBD93F54CD391A7-802E
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.CLB
   Revision: 00002001    Serial number: 0339372823
   Coding: 011B1E2228B9109583200624010000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO30258451
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO30373842
   Coding: 191100
02741 - Bulb for Tail Light 2; Right
                    Reset counter: 17
                    Mileage: 50904 km
                    Date: 2017.04.23
                    Time: 16:00:37
                    Reset counter: 17
                    Mileage: 50904 km
                    Date: 2017.04.23
                    Time: 16:00:37
                    Fault Status: 00101101
                    Fault Frequency: 41
                    Reset counter: 17
                    Mileage: 50904 km
                    Date: 2017.04.23
                    Time: 16:42:38
Address 52: Door Elect, Pass. (J387)       Labels: NONE
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000108521191
   Coding: 011D1620D001451005080000
   VCID: 489F175BFB20710161-801C
Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1462700653
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 366369A389D4F7F103-8062
   Slave 3:
12656790 - Databus
                    Reset counter: 233
                    Mileage: 50904 km
                    Date: 2017.04.24
                    Time: 10:48:41
                    Voltage: 13.2 V
   Coding: 018E00000F000200
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 U008
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
Address 56: Radio (R)       Labels: REDIR FAIL!
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109AK0H2700025
   Coding: 010105020100000003
   Shop #: WSC 01414 002 1048576
   VCID: 285FB7DB5B60910181-807C
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6XX-5F.CLB
   Part No SW: 7P6 035 670 G    HW: 7P6 035 670 A
   Component: H-BNT-EU      H40 0822
   Revision: --------    Serial number: 444F+0F7514357
   Coding: 010101050040E1ED01000B0E00000003F00401030000000000
   VCID: 3979629FB0CA1889EE-806C
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H28 0045
   Serial number: VWZ8Z9PA201B7Y
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  5950
Address 62: Door, Rear Left (J388)       Labels: NONE
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000109333725
   Coding: 011814200001251005080000
   Part No SW: 7P6 907 273 K    HW: 7P6 907 273 K
   Component: RDKBERU25     H09 0009
   Serial number: 10000000144383
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 4487036BCF0855618D-8010
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 171401259
   Coding: 0533314002
   ROD: EV_HeckkTouar.rod
0079 - Pinch Protection Strip 2
          B11DC 02 [008] - Signal Failure
                    Reset counter: 18
                    Mileage: 50904 km
                    Date: 2017.04.25
                    Time: 12:27:23
                    12.38 V
Address 72: Door, Rear Right (J389)       Labels: NONE
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000109345908
End---------------------(Elapsed Time: 12:52, Deb=2)-----------------------
Regards,
Mel
