Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 77
Thread: Quantum Leap! "Hello World"
    Current-day physics doctrine says that there can be no perpetual motion, free energy, or over-unity machines. I'm not saying that your device won't work, just that you cannot explain where the energy it produces comes from within the framework of modern physics. For the sake of humanity, I truly hope that you have stumbled on a way to harness a previously-untapped energy source...such as the Earth's magnetic field, solar winds, or even Ross Perot's giant sucking sound from Mexico! It is more likely that you have merely found another way to skin the SMOT cat, which I consider to be adequately explained as un-tappable energy by now.....
    The "laws" of physics are wrong to a degree & that fail to allow for recognized forms of mechanical potential energy field manipulation.
    I find apprehension to this subject or any other being exploited with a free mind & met with such negativity, is why I work alone & choose to sometimes not share my thoughts. Laugh all you want and have a chuckle because I can tell you, you are foolish for that process & why you will be trapped in a box.
    I know what I know and what I have verified.
    Ridicule away!
    European Parts Emporium/Performance / Immobilizer Solutions LLC
  2. Likes vreihen liked this post
  3. #12
    Verified VCDS User vreihen's Avatar
    Sep 2014
    The Land of OCC, NY, USA, Earth
    You can look back at history and appreciate that Galileo had a cross to bear during the Inquisition for his scientific beliefs that challenged the status quo of those days. To wit:
    My dear Kepler, I wish that we might laugh at the remarkable stupidity of the common herd. What do you have to say about the principal philosophers of this academy who are filled with the stubbornness of an asp and do not want to look at either the planets, the moon or the telescope, even though I have freely and deliberately offered them the opportunity a thousand times? Truly, just as the asp stops its ears, so do these philosophers shut their eyes to the light of truth.
    Although he lived out the rest of his life under perpetual house arrest, history ultimately proved him to be correct.....
  5. #13
    This is not perpetual motion........
    It is subject to wear, friction, + all mechanical things that are common sense it must overcome & in order to be a PTO that is useful to create work.
    It is limited by the size of the static magnetic strength and multiplied forces being exponential + its ability to be indexed in the elliptical orbit & critical timed quadrants.
    Rotations of fields are counter active and mechanically manipulated to force the static fields to index at the elliptical basic setting base point.
    The board is not the complete picture and only a glimpse of what is to come or does it show the brake or engagement process.
    This doesn't need anything else to input or start it but it absolutely needs a way to disengage or shut it off.
    All the other ones I built were flat out dangerous due to over speed!
    You haven't heard a whine like this I can tell you that..........almost sounds like a turbine whine from a huey without the chops of the blades when it first fires up.
    http://www.bbc.com/future/story/2012...physics-change
  6. Likes Boki Ar liked this post
  7. #14
    Jun 2014
    Newcastle, England
    Any video footage of it in operation Jack? Obviously pixelated in places if you want to protect IP. I seem to remember that when I joined the forum, you had a thread on what your avatar represents - but I can't find it right now. Is this something to do with it?
  8. #15
    Yeah it is blurred......
    No videos permitted at this time & to protect the ultimate design of operation of indexing of timing, as this was the hardest thing to achieve first, further being out of round & now more recently speed control and disengagement/engagement.
    I figured out how to make the egg round per say, by a push theory I had. I did this with fluxing stuff on the bench to see the actual fields from an old way we would test for cracks in heads.
    A similar test also shows the results of fields in taking shavings to see on paper to display an orbit of F pushing inward.
    Yes this concept is from my avatar and has been in my head since HS.
    I just can't believe the amount of opposition that is out there to stuff like this, however, I can understand it based on what and how things are taught as physics laws or with peoples narrow minded understanding.
    It has always perplexed me that if a DC motor is also inverse a generator, and the outward magnets are static right?
    Than what is to stop someone from instead of using electricity to move the field forward and flipped, and just taking static magnets to be moved mechanically to commence inverse of each other within the synchronous orbit?
    DC Electric motors can be speed controlled by voltage or precisely...... Not cool when shit blows apart from these speeds I exhibited and my failure to think of some safety concerns in the past.
    Needless to say I am lucky to be here.
    Think about it everyone ( Art )
    The amount of force and energy that can be manipulated by mechanics, can be extracted by means of timed interference of static magnetic fields.
    There is no doubt that rare earth in itself is a phenomena of potential energy we think we completely understand and technically I submit we probably don't to some degree or it's denied by a conspiracy.
    This is far from perpetual...................and it isn't some stupid Johnson motor, an amplifier or parasite idea.
    My position on this is from my own testing and observations.......... MMMM is real!
    Now have a chuckle..............
    NostraJackAss Has Spoken!
  9. Likes D-Dub, vreihen, PetrolDave liked this post
  10. #16
    Sep 2014
    Having personally witnessed a UFO at close range (and having the aftermarket stereo receiver in my old Rabbit get fried during the encounter), I will be first in line to argue that there are huge energy sources that humanity has yet to discover. As I've said in the past, I sincerely hope for the sake of the human race that you have stumbled upon a way to harness one of them.....
  11. Likes D-Dub, Jack@European_Parts liked this post
  12. #17
    And to think this all started with AFX slotted cars or was it taking the trouble game apart for the popper dice mechanism?
    This book in the middle school library, called "How electric motors work" from the 50's in 6th grade.
    It had neat design projects to do, making simple DC and AC motors out of bear cans, copper wire hand wound armature, 2 paper clips, a coat hanger and piece of wood. I never see kids doing stuff like that now ..........and I felt pretty alone doing it back then!
    Man I'm just the poor sucker to believe love of mechanics and magnets while dreaming of this shit, many times failing being the loser......Not this time!
  13. #18
    Quantum Leap...........
    M.M.M.M.
    ![/I]
    "Quantum leap" is a sudden change of an electron energy state (like "valence") - of itself, it's actually a very small quantity in absolute joules - Do you mean "paradigm shift"?
    What is an M.M.M.M .............(Magnificent Magic Manipulation Machine?)? All I see is a couple of very nice tool draws, one of which is being used to hold a disc of some sort (....and a fold-up metal chair). Which part is the ground-breaking discovery and what is the input/output power ratio of the new energy form?
    VW Golf MkVII (103TSI) my13
  14. Likes Jack@European_Parts, vreihen liked this post
  15. #19
    Sep 2014
    Mechanical Magnet Manipulation Motor
    Yup it seems as if it is magic but it isn't a trick!
    What you are seeing is a sub board layer interference disk "perspective model". Part A
    Maybe both to a degree............
    quan·tum leap
    NOUN
    • a sudden, dramatic, and significant change or advance
      Paradigm shift
      A paradigm shift, as identified by American physicist Thomas Kuhn, is a fundamental change in the basic concepts and experimental practices of a scientific discipline. Kuhn contrasted these shifts, which characterize a scientific revolution, to the activity of normal science, which he described as scientific work done within a prevailing framework (or paradigm).
  17. Likes vreihen liked this post
