Wednesday,17,May,2017,15:34:43:37770
VCDS Version: 17.1.3.0
VIN: WV1ZZZ7HZ7H019025   License Plate:
Mileage: 215020km-133607mi   Repair Order:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ7H019025   Mileage: 215020km-133607miles
   Part No SW: 038 906 016 AJ    HW: 038 906 016 AJ
   Component: R4 1,9L EDC  000SG  8951
   Revision: --H02---    Serial number: VWZ7Z0F4001284
   Coding: 0000031
   Shop #: WSC 02744 790 00000
   VCID: 5CB7DB0B9CB80DA1D5-5140
Address 03: ABS Brakes        Labels: 7H0-907-37x-ABS.clb
   Part No SW: 7H0 907 379 P    HW: 7H0 907 379 P
   Component: (M)ABS MK25E        0103
   Revision: 00H12001
   Coding: 0000552
   Shop #: WSC 00012 000 00000
   VCID: 428B05731E1C5B51BF-5124
Address 09: Cent. Elect.        Labels: 7H0-937-049.lbl
   Part No: 7H0 937 049 R
   Component: BORDNETZ SGVER 1.0  1101
   Coding: 0000004
   VCID: 41890A7F1B1A4049A6-5124
00925 - Fuse (30) for Interior Lamps (S261)
            014 - Defective
01598 - Drive Battery Voltage
            002 - Lower Limit Exceeded
   Part No: 1C0 909 605 A
   Component: 3B AIRBAG VW51      0009
   Coding: 13122
   Shop #: WSC 02744
   VCID: 224BA5F3AE5C7B51DF-5124
00532 - Supply Voltage B+
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 951 M
   Component: KOMBI+WEGFAHRSP VDO V02
   Coding: 01411
   Shop #: WSC 10001
   VCID: 366369A312D4F7F103-5124
   WV1ZZZ7HZ7H019025     VWZ7Z0F4001284
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02744
   VCID: 70EF9FBB303099C119-5124
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C2L KomfortgerŠt     0004
   Coding: 00021
   Shop #: WSC 02744
   VCID: 326B55B3FEBCEBD12F-4B00
   Part No SW: 7H0 035 152 C    HW: 7H0 035 152 C
   Component: Radio BVX       009 0012
   Revision: 00009000    Serial number: VWZ1Z5F0949847
   Coding: 0020200
   Shop #: WSC 02736 790 00000
   VCID: 224BA5F3FE5C7B51DF-5124
End-------------------------(Elapsed Time: 06:53)----------------------------
Regards,
Mel
