Results 1 to 6 of 6
Thread: 2016 VW Polo Crash Shut down mode
    May 2017
    Hi
    Hope I'm posting in the correct page:
    Iv'e just reset (44 Steering Assist) as it had shut down due to a accident after resetting the system the Dashboard is now like a Xmas tree all the lights are on Tyre pressure sensors stop start failed etc as you can see from the report bellow, does any one have the answers to the faults that have been populated.
    Thursday,18,May,2017,16:50:08:27233
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
    VIN: WVWZZZ6RZGY171087   License Plate:
    Chassis Type: 6R (6C0)
    Scan: 01 03 08 09 10 15 17 19 44 55 5F
    VIN: WVWZZZ6RZGY171087   Mileage: 16045km-9969miles
    Address 01: Engine (J000-CUSB)       Labels: 04B-907-445-V1.clb
       Part No SW: 04B 906 027 AL    HW: 04B 907 445
       Component: R3 1.4l TDI   H08 2762
       Revision: 21006001
       Coding: 01114032422501080000
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_ECM14TDI03004B906027AL 003001
       ROD: EV_ECM14TDI03004B997027B.rod
       VCID: 6B80CECBA303564FE8B-803E
    25109 - Databus
              U1123 00 [047] - Received Error Message
                        Fault Frequency: 12
                        Mileage: 16045 km
                        Date: 2017.02.22
                        Time: 02:58:22
                        Coolant temperature: 52 C
                        Intake air temperature: 47 C
                        Voltage terminal 30: 12.359 V
                        ACC variants: ACC
                        CCS Switch: CCS Switch
                        Cruise control switch actuation-Bit 0: main switch off
                        Cruise control switch actuation-Bit 1: No Cancel
                        Cruise control switch actuation-Bit 2: No tip delay
                        Cruise control switch actuation-Bit 3: No tip accelerate
                        Cruise control switch actuation-Bit 4: no setting
                        Cruise control switch actuation-Bit 5: No resumption
                        Cruise control switch actuation-Bit 6: No control malfunction
                        Cruise control switch actuation-Bit 7: main switch off
                        Cruise control switch actuation-Bit 8: Control code implausible
                        Cruise control switch actuation-Bit 9: Limiter not selected
                        ACC variants (coding): CCS
                        Acceleration: 0.000 m/s
    25110 - Cruise Control Switch (E45)
              P0568 00 [047] - Implausible Signal
                        Mileage: 16045 km
                        Date: 2017.02.22
                        Time: 02:58:23
                        ACC variants: ACC
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
       Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0004
       Serial number: 08502953151117
       Coding: 23DD2885892A33C1091410710058C41491CC90080007C9098F00
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
       VCID: 372822BBAFCB22AFDC3-8062
    0625 - Display for Tire Pressure Monitoring
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.23
                        Time: 06:54:28
    1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [137] - -
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.23
                        Time: 06:54:28
    1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [137] - -
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.23
                        Time: 06:54:29
    Address 08: Auto HVAC (J301)       Labels: 6C0-820-045.clb
       Part No SW: 6C0 820 045 C    HW: 6C0 820 045 C
       Component: AC Manuell    H03 0202
       Serial number:  1510101B-0548
       Coding: 201100001000200200
       ROD: EV_ACManueKMMValeoPQ26_VW26.rod
       VCID: 1F18EA1B273B7AEF343-804A
    262914 - Refrigerant Pressure
              B10AB F0 [013] - Too Low
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.22
                        Time: 02:58:36
    Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 C    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H08 0086
       Serial number: 001588134792
       Coding: 03000A404253005B0FA44080B10F07C800005B0257010000000000000000
       ASAM Dataset: EV_BCMA0 005005
       ROD: EV_BCMA0_005_VW26.rod
       VCID: 303A19A74AA5F5979D9-8064
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 6R0 959 802 DK    HW: 6R0 959 802 DK  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  003 0610
       Serial number: KU0KU014101552876666
       Coding: 1400A0
       Subsystem 2 - Part No SW: 6R0 959 801 DH    HW: 6R0 959 801 DH  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  003 0610
       Serial number: KU0KU021101552942958
       Coding: 0400A0
       Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY1528015V9
       Component: Sirene, DWA  005 0312
       Serial number: 00000000000033555450
       Subsystem 5 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
       Component: J389__TSG_HR  003 0610
       Serial number: KU0KU013111553171621
       Coding: 1400A0
       Subsystem 6 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
       Component: J388__TSG_HL  003 0610
       Serial number: KU0KU011111553156739
       Coding: 0400A0
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Revision: --------    Serial number: 39391532400717
       Coding: 0031151001
       ROD: EV_EPHVA18AU3700000_VW26.rod
       VCID: 43D0466BEB137E0F70B-8016
    13637426 - Databus
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.23
                        Time: 06:52:31
    Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
       Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
       Component: VW20Airbag00C 002 0380
       Revision: --------    Serial number: 003TH0008P40
       Coding: 88C0C000000000005C000000008800000000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 3A2E3B8F9CD93FC723D-806E
       Subsystem 1 - Part No SW: -----------    HW: 410 821 811 15
       Component: SideSensor_Df  151 0800
       Serial number: 3575H00C71D73C51F06X
       Subsystem 2 - Part No SW: -----------    HW: 410 821 811 15
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H00C91D73C51708U
       Subsystem 3 - Part No SW: -----------    HW: 442 152 211 15
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00B11EAED41425K
       Subsystem 4 - Part No SW: -----------    HW: 442 152 211 15
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00C11EAED4433AU
       Part No SW: 6C0 920 941 C    HW: 6C0 920 941 C
       Component: KOMBI         201 1420
       Coding: 272409002980260001082A001000000000000000
       VCID: 2514F8F30567A03F7EF-8070
    Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901     HW: 6C0 937 089
       Component: GW MQB A0     H08 0086
       Revision: --------    Serial number: 001588134792
       Coding: 030100044F0A590071000000000000010001010000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 013020
       ROD: EV_GatewA0Lear_VW26.rod
       VCID: 6594B8F345E7603FBEF-8030
       Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H03 0102
       Serial number: 29150002185020085444
       Coding: 30FFFF
       Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Component: J367-BDM  H08 0223
       Serial number: 52332G59492821168655
    8782090 - Cruise Control Switch
              B1154 96 [009] - Component internal failure
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.22
                        Time: 02:58:37
                        Terminal 15: On
    Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
       Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
       Component: EPS_TRW_ALow  322 3232
       Serial number: CFBK1587
       Coding: 000300
       ASAM Dataset: EV_SteerAssisUDSTRW 016026
       ROD: EV_SteerAssisUDSTRW_SE26.rod
       VCID: 6E86C7DF9011A367CF5-803A
    1094656 - Steering angle sensor
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.23
                        Time: 05:56:45
    1073664 - Steering End Stops Not Learned
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.23
                        Time: 05:56:45
    1073920 - Steering End Stops Not Learned
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.23
                        Time: 05:56:45
    Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
       Coding: 0D8C000001000000
       ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
       VCID: 75B4E8B3F54790BF0EF-8020
    13705992 - Databus
              U1123 00 [137] - Received Error Message
                        Reset counter: 3
                        Mileage: 16045 km
                        Date: 2017.02.23
                        Time: 06:53:25
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 842 A    HW: 3Q0 035 842 A
       Component: MU-S-D-ER     H24 0245
       Serial number: VWZAZ2R0621242
       Coding: 02620000BE00000051111101008808001F0206D60120010003
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 2B000ECB6383964FA8B-807E
       Subsystem 1 - Part No SW: 6C0 919 603 B    HW: 6C0 919 603 B
       Component: ABTm_Std2  H53 1031
       Serial number: VWZ8Z9RKW001YH
    End----------(Elapsed Time: 00:51, VBatt start/end: 13.4V/13.4V)-----------
    May 2017
    Managed to access all the errors and reset all modules, and that extinguished all the warning lights, thanks for all your help Danna 👍✅
  3. Likes Uwe, Dana, vwmiksu liked this post
    Awesome. I didn't reply to your PM because I noticed the update here. Have a great weekend.
  6. #4
    Jan 2018
    I have the same problem.
    How can I find a solution to this?
    Tuesday,09,January,2018,12:30:45:00970
    VCDS Version: 17.8.1.0 (x64)
    VIN: WVWZZZ6RZGY167831   License Plate:
    Mileage: 13651km-8482mi   Repair Order:
    Chassis Type: 6R-VW26 (6C0)
    Scan: 01 03 08 09 10 15 17 19 44 5F
    VIN: WVWZZZ6RZGY167831   Mileage: 13651km-8482miles
    Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
       Part No SW: 04C 906 057 AB    HW: 04E 907 309 CB
       Component: R3 1.0l MPI   H20 2496
       Revision: 33H20000
       Coding: 01110072022409080000
       ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
       ROD: EV_ECM10MPI01104C906057AA_VW26.rod
       VCID: 65C1478764620C6E02-8030
    17158 - Databus
                        Mileage: 13651 km
                        Date: 2017.06.28
                        Time: 23:52:18
                        Coolant temperature: 78 C
                        Intake air temperature: 33 C
                        Voltage terminal 30: 12.463 V
                        Mass flow through throttle valve: 0.0 kg/h
              U0428 00 [047] - -
                        Mileage: 13651 km
                        Date: 2017.06.28
                        Time: 23:52:18
                        CAN status - engine control module-Bit 0: 0
                        selected gear-Bit 0: 0
    Readiness: 1110 0001
       Serial number: 08502112151116
       Coding: 21DD2485492933C7091C106C0052842492CC90080005CB098F00
       VCID: 377DDDCF8E4E4EFE60-8062
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.29
                        Time: 00:40:05
              U0428 00 [137] - -
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.29
                        Time: 00:40:05
              U0428 00 [137] - -
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.29
                        Time: 00:40:05
    Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
       Part No SW: 6C0 820 045 B    HW: 6C0 820 045 B
       Serial number:  1511051B-0671
       Coding: 200000001000100000
       VCID: 1E33286B01B41FB683-804A
    Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 D    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H08 0094
       Serial number: 001588133470
       Coding: 00000850425300534F844000400F07480000590251010000000000000000
       ASAM Dataset: EV_BCMA0 006002
       ROD: EV_BCMA0_006_VW26.rod
       VCID: 3169E3D7602A90CE2E-8064
       Subsystem 1 - Part No SW: 6R0 959 801 DG    HW: 6R0 959 801 DG  Labels: 6R0-959-801.CLB
       Serial number: KU0KU003111553073384
       Coding: 0400A0
       Subsystem 2 - Part No SW: 6R0 959 802 DL    HW: 6R0 959 802 DL  Labels: 6R0-959-802.CLB
       Serial number: KU0KU003111553076829
       Coding: 1400A0
       Subsystem 3 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
       Serial number: KU0KU010111553148114
       Coding: 0400A0
       Subsystem 4 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
       Serial number: KU0KU004111553080474
       Coding: 1400A0
    8202 - Bulb for Left DRL
              B121D 15 [009] - Open or Short to Plus
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.28
                        Time: 23:52:27
    8458 - Bulb for Right DRL
              B121E 15 [009] - Open or Short to Plus
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.28
                        Time: 23:52:27
       Revision: --------    Serial number: 39391532101202
       Coding: 0011051001
       VCID: 4385B91FCA96125ECC-8016
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [009] - Open Circuit
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.28
                        Time: 23:52:18
    13637426 - Databus
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.28
                        Time: 23:52:18
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Component: VW20Airbag00N 002 0380
       Revision: --------    Serial number: 003TH00073EU
       Coding: 88C0C000000000005C0000CA000800000000
       VCID: 3A7BC4FBBD5C53969F-806E
       Subsystem 1 - Part No SW: -----------    HW: 410 821 611 15
       Serial number: 3575H00BF1D73C50F0A0
       Subsystem 2 - Part No SW: -----------    HW: 410 821 611 15
       Serial number: 3585H00BB1D73C5061F.
       Subsystem 3 - Part No SW: -----------    HW: 442 150 211 15
       Serial number: 3517A00B91E0EE90B11P
       Subsystem 4 - Part No SW: -----------    HW: 442 150 111 15
       Serial number: 3527A00BB1E0EE9212EY
       Part No SW: 6C0 920 730 D    HW: 6C0 920 730 D
       Component: KOMBI         101 1420
       Coding: 0724090021000008010808000000000000000000
       VCID: 224B1C9B35CC3B56A7-8076
    Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901 A    HW: 6C0 937 089
       Component: GW MQB A0     H08 0094
       Revision: --------    Serial number: 001588133470
       Coding: 030000046F0A640071000000000000010001010000000000000000000000
       VCID: 2643008B59E4C776CB-8072
       Subsystem 1 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Serial number: 62320G39272821074058
       Part No SW: 6C1 909 144 AJ    HW: -----------
       Component: EPS_TRW_ALow  313 3242
       Serial number: 3601973
       Coding: 000300
       Shop #: WSC 00011 888 182020
       ASAM Dataset: EV_SteerAssisUDSTRW 016134
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 70EF26D3ABA0D9C661-8024
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.29
                        Time: 00:42:03
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.29
                        Time: 00:42:03
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.29
                        Time: 00:42:03
    1081856 - Internal Fault
              B200F F0 [137] - Unknown Error Elaboration
                        Reset counter: 250
                        Mileage: 13651 km
                        Date: 2017.06.29
                        Time: 00:42:03
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 6C0 035 885 B    HW: 6C0 035 885 B
       Component: MU-E--ER      851 6490
       Serial number: 06101500012905
       Coding: 026200003C0000004011000101000000000000040000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
       VCID: 285F0EB353F0D106F9-807C
    End-------------------------(Elapsed Time: 02:15)--------------------------
    Quote Originally Posted by vwmiksu View Post
    I don't think so. In addition to the OP's fault codes, you also have:
  8. Likes Jack@European_Parts liked this post
  9. #6
    Jan 2018
    What does 1081856 tell you about?
    I forgot to tell
    Authorized vw workshop replaced "Control unit for steering column electronics 6C1909144AJ"
    Collision information was stored in the control unit.
    This collision information could not be cleared. That's why they changed the control unit.
    They failed to calibrate the system.
    Only the collision information was deleted and all other problems are the same as before the change of control unit
    And finally, sorry for my poor English language skills, I have to use a little bit of Google
