Results 1 to 6 of 6
Thread: ADRESS 19 GETWAY COMPATIBILITY
    Jul 2014
    Greece
    Hello there , i have install today High version gw . The reason was to have Special functions as MKE .
    The part Number of gw is the above
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
    Component: J533 Gateway H56 1663
    Revision: H56 Serial number: 130314F1002214
    Coding: 351302
    VCID: 72C51697ADC183D1EF-8026
    and when i made out put tests i saw the messages above
    screenshot windows
    the NEW gw have mke function?
    regards
    vv
    Jan 2015
    Bosnia and Herzegovina
    gateway does support mke, but I think that your cluster doesn't support mke function and reason for error
    Jul 2014
    Greece
    Update
    the cluster have no problem because has sw 607 , the only think that will need was to set MKE data set to the getaway with flash tool (vcp)
    the result was to enable the mke function as you can see above
    how to capture screen
  4. Likes m87a liked this post
    Jul 2014
    Greece
    Hello there, one question in MKE function .
    I switch on the ignition , i click on MKE function, everything good as far.
    When i switch off the ignition and then turn on again MKE function is off (unclick)
    Is this usual?
    Best regards
    vv
    Verified VCDS User Vasco Ferraz's Avatar
    Jan 2017
    Portugal
    Some functions can be enabled or disabled by default when switching the ignition on.
    If I recall correctly, the "rain close" is one of them.
    Can't help any further. Sorry.
    Vasco Ferraz
    Jul 2014
    Greece
    Quote Originally Posted by Vasco Ferraz View Post
    update
    the problem was solved by reflashing getaway and data set with odis-e
    regards
    vv
