Good day, after retrofit was made to my skoda (octavia 2) i fit speakers on the back I got this error on the radio control module: 01044 - Control Module Incorrectly Coded! What i can do to get rid of this error, to proper code the stereo. Can you please help me please?
Monday,08,May,2017,17:31:01:14813
VCDS Version: 17.1.3.0 (x64)
VIN: TMBCS41ZX62232467 License Plate:
Mileage: 442700km-275081mi Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 7D
VIN: TMBCS41ZX62232467 Mileage: 442700km-275081miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 DJ HW: 028 101 188 3
Component: R4 1,9L EDC G000SG 6250
Revision: 12345678 Serial number: SKZ7Z0F3464767
Coding: 0050071
Shop #: WSC 73430 790 00000
VCID: 6ED3BAED79AED8310B-803A
18104 - Powertrain Data Bus
P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
RPM: 2058 /min
Torque: 98.0 Nm
Speed: 73.0 km/h
Load: 35.7 %
Voltage: 14.14 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 1.0
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021633
VCID: 71E9A1916890C7C916-8024
Part No: 1Z0 820 047 D
Component: Climatic PQ35 010 0301
VCID: 346768855702B2E13D-8060
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 00000005663785
Coding: 01020E131004141C40110D000000000000297F060000000C000000000000
Shop #: WSC 73430 790 12345
Subsystem 1 - Part No: 1Z1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 07 AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR0AJVEB
Coding: 0012343
Shop #: WSC 10200 599 94742
VCID: 7DF18DA124C8B3A982-8028
Part No SW: 1K0 953 549 BK HW: 1K0 953 549 BK
Component: J0527 051 0101
Coding: 0003042
Shop #: WSC 00140 219 81286
VCID: 7CF780A53FD2BAA1B5-8028
Component: E0221 002 0010
00895 - Cruise Control Switch (E45)
Part No: 1Z0 920 841 E
Component: KOMBIINSTRUMENT VD1 0920
Coding: 0004101
Shop #: WSC 12345 012 32131
VCID: 387F5CB54B6A568111-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001062030391
Coding: 7D0F0B40071302
VCID: 2A5B76FD85C6F41197-807E
00469 - Infotainment Databus in Single Wire Operation
Fault Frequency: 26
Reset counter: 147
Mileage: 442296 km
Time: 17:09:34
Fault Frequency: 26
Reset counter: 147
Mileage: 442296 km
Time: 17:09:34
01304 - Radio
Fault Frequency: 170
Reset counter: 187
Mileage: 442296 km
Time: 17:15:18
Component: IMMO VD1 0920
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2345
Coding: 0000244
VCID: 3663528D417EA0F103-8062
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 000 3305
Revision: 00H22000
VCID: 377D5F89467459F918-8062
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 18D002407F2D0F0FC84BC61004CC
VCID: 79F999B130E08F89AE-802C
Subsystem 5 - Part No: 1Z0 951 171 A
Component: NeigungsSensor 008 4802
Coding: 00000000
Subsystem 6 - Part No: 1K0 951 605 D
Subsystem 7 - Part No: 1Z0 951 171 A
Component: Innenraumueberw.008 4802
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000244
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000007
VCID: 74E7A8851782F2E1FD-8020
Part No SW: 1Z0 035 161 B HW: 1Z0 035 161 B
Component: Radio FO3 013 0029
Revision: 00013000 Serial number: SKZ7Z3F0121543
Coding: 0000200
Shop #: WSC 10112 599 82830
VCID: 2D517DE1B428E32972-8078
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
End-------------------------(Elapsed Time: 01:39)--------------------------
