I brought my 2006 A8L in for a groaning steering wheel sound... the sound only occurs when the engine is at idle. After some diagnostic work, my best guess was that the steering pump was a little weak? Purchased a used steering pump from Wolf Auto for $89 (local Audi Dealer wanted $900). Independent shop that replaced my leaking steering rack a few months back did the re & re of the steering pump and found that it did not address the groaning sound at all. So with more stethoscope type diagnostics, they determined that one of the tie-rod ends was the source of the groaning. Tell tale sign was a ripped outer boot. Ordered new part, installed, new alignment... the groaning steering sound is gone and the car drives nice.
But noticed that the ESP light was staying ON. Called the shop, they said maybe the steering angle sensor needs re-calibration... which I had to do the last time they did an alignment when they did the steering rack. I pulled out my laptop and ran a VCDS scan, the steering angle sensor seemed to be at 0.0 degrees at center, but I tried to re-calibrate it anyways, but would not allow that function to work, it was kicking out an error? Also I found a ton of new fault codes, many of which were probably due to a low battery voltage situation. So I cleared all of the codes, drove the car around the block... all of the low voltage type codes went away... but unfortunately, there were quite a handful of new codes that were not there before I brought the car in for the steering pump/tie-rod repair (I did a scan the night before I brought it in and saved the logs).
Here is what I'm seeing from VCDS now, please note some of the Engine codes were there before, including the Engine Mount Solenoid Valve codes, but all of the EVAP, MAF, Sec Air, ABS/ESP faults are new.
What I'm most concerned about is the Control Module Defective code in the 03 ABS section.
Saturday,13,May,2017,10:32:20:08168
VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4334.4
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44E26N012097 Mileage: 211470km-131401miles
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E8774746
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E0604104C16BBF78F5-807A
10 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Fault Status: 01101000
Mileage: 211472 km
RPM: 683 /min
Load: 29.0 %
Temperature: 93.0°C
Temperature: 33.0°C
Absolute Pres.: 0.0 mbar
Voltage: 14.351 V
17980 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground
Fault Status: 01100010
Mileage: 211472 km
RPM: 677 /min
Load: 28.6 %
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 14.478 V
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground
Mileage: 211472 km
RPM: 677 /min
Load: 28.6 %
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 14.478 V
17984 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground
Mileage: 211472 km
RPM: 677 /min
Load: 28.6 %
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 14.478 V
17880 - EVAP Leak Detection Pump
P1472 - 002 - Short to Ground
Mileage: 211472 km
RPM: 677 /min
Load: 28.6 %
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 14.478 V
17843 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground
Mileage: 211472 km
RPM: 677 /min
Load: 28.6 %
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 14.478 V
17829 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground
Mileage: 211472 km
RPM: 677 /min
Load: 28.6 %
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 14.478 V
17475 - Intake Air Switch-Over Valve (N335)
P1067 - 002 - Short to Ground
Mileage: 211472 km
RPM: 677 /min
Load: 28.6 %
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 14.478 V
17876 - EVAP Canister Solenoid Valve 2 (N115)
P1468 - 002 - Short to Ground
Mileage: 211472 km
RPM: 677 /min
Load: 28.6 %
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 14.478 V
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low
Mileage: 211472 km
RPM: 677 /min
Load: 28.6 %
Temperature: 93.0°C
Temperature: 33.0°C
Voltage: 14.351 V
Readiness: 0010 1101
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0068069
VCID: 2514FB3C19E0F8AF7EF-8070
009783 - Torque Management Feedback Signal A
P2637 - 000 -
Reset counter: 40
Mileage: 211472 km
Date: 2017.05.13
Time: 10:38:53
RPM: 672 /min
RPM: 640 /min
(no units): 30.0
(no units): 25.0
Temperature: 68.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
VCID: 221EE02008CE0F971BD-8076
18265 - Load Signal
P1857 - 000 - Error Message from ECU
00003 - Control Module
014 - Defective
013 - Check DTC Memory
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
Shop #: WSC 02610 444 72962
VCID: 1F18E9D43BBC227F343-804A
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Fault Status: 01111000
Reset counter: 16
Voltage: 9.11 V
Count: 61
