smirnoffandcoke
New Member
Hi, I am wanting to change the soft coding of another used ecu with an immo delete to work in my car.
The donor car is the same as mine. 02 a4 B6 1.8tq manual. The donor car is the US model while mine is Euro. The ecu part numbers are slightly different.
ORIGINAL: 8e0909518b
NEW: 8e0909518ak
I cannot successfully change the soft coding value in VCDS lite free version. I have put in the login code and that didn't help. Will the registered VCDS lite allow me to change it?
Also does the security pin/SKC need to be known and entered to change the soft coding?
I just want to know if buying this software will allow me to change the values. Currently workshop code and importer number are blocked in the soft coding tab.
Cheers
NEW: 8e0909518ak
Cheers
