Golf MK7 Discover Nav Pro MIB2
Hi All
Does anyone have the Discover Nav Pro MIB2 fitted to there golf 7 5 door but without fender or dynoaudio ?, I am after the long coding for stock car speaker setup.
Thursday,04,May,2017,19:04:36:20275
VCDS Version: 17.4.1.1 (x64)
Data version: 20170413 DS270.4
VIN: WVWZZZAUZDP040852 License Plate:
Mileage: 84607km-52572mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 5F
VIN: WVWZZZAUZDP040852 Mileage: 84607km-52572miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CPTA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 AC HW: 04E 907 309 G
Component: 1.4l R4 TSI H02 5533
Revision: WKH02---
Coding: 01190032234405082000
Shop #: WSC 00028 028 00079
ASAM Dataset: EV_ECM14TFS01104E906016AC 002006
ROD: EV_ECM14TFS01104E906016AC.rod
VCID: 63CF9B1F6A1A8B5F7D-8036
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA8AA120242A6C037F060501C52980510454C0608094F3F4285028C0
Shop #: WSC 00028 028 00024
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7DFBCD67ECBE5DAF6B-8028
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 J HW: 5G0 907 426 J
Component: AC Manuell H01 0503
Revision: 00001K06
Coding: 00120004200100001000000000000000
ASAM Dataset: EV_ACManueBHBVW37X 002017
ROD: EV_ACManueBHBVW37X_002_VW37.rod
VCID: 32612E5B656052D7C6-8066
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011300801544
Coding: 03000842C241027B0FA44080B1040328100A000000000000000000000000
ROD: EV_BCMBOSCH_010.rod
VCID: 438F7B9FCADAEB5F5D-8016
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 121121 042 0551
Serial number: 130102123537
Coding: 0E4DD5
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y13M01D12H05M27S42S4
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY1233200CL
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000055758988
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231302202216
Coding: 0071051001
ASAM Dataset: EV_EPHVA18AU3700000 002016
VCID: 3A71067BBD10AA970E-806E
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-567.clb
Part No SW: 5Q0 907 567 G HW: 5Q0 907 567 G
Component: ACC3 H08 0390
Serial number: 17011375030181
Coding: 00000300FE030B
ASAM Dataset: EV_ACCBoschMQB 001021
ROD: EV_ACCBoschMQB_VW37.rod
VCID: 3F87776FA6328FBF39-806A
Part No SW: 5Q0 959 655 M HW: 5Q0 959 655 M
Component: AirbagVW20 011 0361
Serial number: 003M1R01ERAJ
Shop #: WSC 00028 028 00054
VCID: 4A9156BBEDF03A179E-801E
Belt Pretensioner left:
Component: BeltPretRevFL H35 0340
Serial number: 34169677A23011340111
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0340
Serial number: 34169676A18011340251
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 801 13
Serial number: 35767000000EFB8C4C0I
Subsystem 4 - Part No SW: ----------- HW: 480 001 801 13
Serial number: 35867000000B536D4C0/
Subsystem 5 - Part No SW: ----------- HW: 480 401 501 13
Serial number: 35165029B0CAF162B23I
Subsystem 6 - Part No SW: ----------- HW: 480 401 101 13
Serial number: 3526502B10D36085A341
Subsystem 7 - Part No SW: ----------- HW: 480 400 301 13
Serial number: 3556502BF0D5D604004B
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AG HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 24011304220324
Coding: 0D00
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 7BFFC37FF2AA539F55-802E
Part No SW: 5G0 920 960 HW: 5G0 920 960
Component: KOMBI 235 0555
Coding: 27A501002780260001887A01040000
VCID: 66C9820B9928FE779A-8032
Part No SW: 5Q0 907 530 F HW: 5Q0 907 530 F
Component: GW MQB High 125 1109
Revision: -------- Serial number: 0000263242
Coding: 030100042B086400EF00045C080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
VCID: 346D28439F745CE7D4-8060
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H13 0035
Serial number: 02120005290190010291
Coding: 2C0000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 6685808901
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000049627716
Coding: 003B0220D001028000001000
VCID: 0201BE9B9540225716-8056
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000595290
Coding: 0D0000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D7B0D67AC3E9DAF2B-8068
Address 47: Sound System
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000049258433
Coding: 003B0020DE01028000801000
VCID: 0103B1979046394F0F-8054
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000607015
Coding: 050000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 020 C HW: 3G0 035 020
Component: MU-H-ND-EU H50 0343
Serial number: A682B0GB012805
Coding: 02730001FF0000005111110100A800101F0100C601A00100B6
VCID: 1737FFCFEEC297FFD1-8042
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9PU30021A
Subsystem 2 - Part No SW: V03 959 800 QN HW: -----------
Component: ECE 2016 --- 0134
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1012
18 Faults Found:
1585 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
Voltage terminal 30: 11.9 V
1586 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1587 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1588 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1589 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1590 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1592 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1595 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1652 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1655 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1656 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1657 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1603 - invalid data record
B2005 00 [008] - -
Reset counter: 189
Mileage: 84450 km
Date: 2017.04.29
Time: 11:04:17
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 149
Mileage: 84450 km
Date: 2017.04.29
Time: 10:48:03
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Reset counter: 149
Mileage: 84450 km
Date: 2017.04.29
Time: 10:48:03
0006 - Antenna Amplifier 2 for Radio
B126E 13 [009] - Open Circuit
Reset counter: 149
Mileage: 84450 km
Date: 2017.04.29
Time: 10:48:03
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
7193 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 149
Mileage: 84450 km
Date: 2017.04.29
Time: 10:48:04
BAP-BAP_Function_ID: 02
7194 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 149
Mileage: 84450 km
Date: 2017.04.29
Time: 10:48:04
End-------------------------(Elapsed Time: 03:59)--------------------------
Reason: added code tags
Post Thanks / Like - 1 Likes
Uwe liked this post
I Have attached my scan logs, to compare the long code on the 5F with someone elses hopefully .
Sorted , Change the Startup_Display to 0000 :-)
Uwe liked this post
