particulate filter code fault code
cschlue
C?ID=303523
Hello all,
I have been searching with little luck on this one... I have a gen2 3.0TDI Q5, running Malone stage 2 software. (LOVE IT!)
Emissions code light came on, vag-com scan and the following code:
29012 - Diesel Particulate Filter (Bank 1)
P226D 00 [237] - Damaged or Substrate Missing
I cannot find any info on this... I might initiate regeneration tomorrow afternoon - just see if changes anything.
I have cleared the code, and we will see if it comes back - hoping to learn what this one is.
thanks in advance!
-Christian
FULL SCAN:
P226D 00 [237] - Damaged or Subrate Missing
Engine speed: 866.50 /min
Normed load value: 20.8 %
Vehicle speed: 12 km/h
Coolant temperature: 73 °C
Intake air temperature: 34 °C
Voltage terminal 30: 13.520 V
Particle filter: soot mass measured: 6.70 g
Particle filter: soot mass calculated: 11.67 g
Exh v PP Ds EG: 6.58 m/s
Particle sensor: soot volume in exhaust: 0.15 mg/mÑ
Particle sensor: exhaust temperature: 244.9 °C
Particle sensor: cleaning deviation reaction time: 0.734
FULL SCAN:
Uhm, hardly. ;)
I would speculate this fault means the ECU isn't seeing as much difference as it expects between from the differential pressure sensor.
I don't suppose you gutted the DPF?
cschlue
C?ID=303523
Thank you for the super fast reply!
I have not gutted the DPF. Only mod is the software.
Ref the sensors: I was thinking something along the same lines - hoping for a simple "if this, then that". But that was a dream!
I have been hunting the exploded views to find out how many sensors are on the DPF... and where. It looks like one on the top of the DPF and then another at the end of the CAT??? But then I find two O2 sensors? What sensors could be sending this info and what are they screwed into?
I had a 25k service due recently, switched from the Malone tune to the stock tune at 23.5k miles (prep and log for the dealer). All good at service and came back clear.
I put the Malone tune back on the day after the service (and cleared all software swap caused codes), and this popped up within 60 miles.
I have only driven 22 miles since my code clearing...
Thank you again for the support!
P.S.: here is the full scan of the engine module. Be great if they add the color needed to figure this out. The full engine module scan had four more codes listed:
4327 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Mileage: 42855 km
Date: 2017.05.02
Time: 17:46:05
Coolant temperature: 41 °C
Intake air temperature: 32 °C
Voltage terminal 30: 12.020 V
Unlearning counter according OBD: 32
ACC target acceleration: 0.000 m/s²
ACC control module received status-Bit 0: 3
Active brake system error status-Bit 0: 112
Status of ACC/CCS acceleration interface-Bit 0: 3
Acceleration: 0.000 m/s²
Engine status: COENG_READY
4695 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Mileage: 42855 km
Date: 2017.05.02
Time: 17:46:05
Cruise Control System (CCS): switch position-Bit 0: 0
Cruise Control System (CCS): status-Bit 0: 204
Cruise control switch-off: irreversible-Bit 0: 5
Cruise control switch-off: reversible-Bit 0: 255
Engine control module reset status-Bit 0: 0
Engine control module reset status-Bit 8: 32
Cruise control switch-off: irreversible w. brake intervention-Bit 0: 32
U1113 00 [032] - -
Mileage: 42855 km
Date: 2017.05.02
Time: 17:46:05
Diagnostic Trouble Code Report
Control Module Part Number: 8K5 907 401 AC
Page 3
U1113 00 [032] - -
Mileage: 42855 km
Date: 2017.05.02
Time: 17:46:05
Mileage: 42919 km
Date: 2017.05.03
Time: 09:03:01
Particle sensor: soot volume in exhaust: 0.15 mg/m³
Readiness: 1 1 0 0 0
m87a
Bosnia and Herzegovina
C?ID=156900
it could be that it's gutted or burned through :)
cschlue
C?ID=303523
That is interesting - and I did think about that too. But, that would have popped up with the stock tune while I ran the prior 1500 miles in stock tune to prep for dealer service. (burned through is burned through, regardless of tune)
But, that leads to another path of digging: put car back to stock tune and see what happens - see if a tune's side effect is irritating the expected values.
How do I find out how the car knows the DPF is present? is it pressure? temp? soot? other?
Similar to Uwe's thought path, but with a process to test... and isolate a condition - maybe? If it only happens in malone mode, I could deduct it isn't physical, but rather software and/or sensor.
Thoughts?
m87a
C?ID=156900
you have a lot of function restriction due to... try to clear all, drive and post full scan
also check soot level
Thoughts?
Yes, if you have the ability to revert it to stock, by all means, do so. Then clear all the faults and see what comes back.
Oh, and when you have faults like "Function Restriction due to Faults in Other Modules", it would make sense to post a complete Auto-Scan. ;)
http://forums.ross-tech.com/showthread.php?101
cschlue
C?ID=303523
Quick update so you all don't think I have fallen off the radar... I really appreciate all the support and help here.
Still in tuned mode, the emissions light came on within 30 miles of last full clear. 4 codes, similar to what I posted above. I will run a full scan in the next couple days to document more miles and see if there is more info to help. At that time, I will also swap back to stock program (clear it all out for a fresh foundation) and leave it in for a 1k mile road trip this weekend.
See what happens and update next week. (I will post the full auto scan report this time)
thanks again!!!
-C
cschlue
C?ID=303523
Hello Again.
I have been busy logging hwy miles up and down the 5 between San Francisco and LA. I do love my road trips!
I have included three scans.
- the first (scan 1) is malone tuned with CEL presented
this is the last malone tuned scan
I installed the stock program and cleared all the lights/codes immediately after this scan/before the trip = clean baseline
- scan 2 is the first time I scanned after the light came on in stock. It only took about 130 miles to present the emission CEL
I cleared these fault codes shortly before driving home = clean baseline (again)
- scan 3 is the current condition in the car, emission CEL is on. It came on about 220 miles in the return last night.
I think m87a might have nailed it. I appear to have a case of the involuntary DPF elimination. I also hear a slightly different tone in the exhaust when I push on it. I also **think** I feel slight performance improvement; isn't that why maybe people do that as a conscious upgrade. (I am not trying to do that.)
Following that path of assumptions:
- what is the normal dealer approach to solving this malfunction at this mileage? ref warranty repair path
- what type of chastity belt did I undo in the software swap process? I am back in stock, it already has a ~400km logged fault code, what do they see as it relates to the tunes I had in the past?
- do I wait until after the final 3.0TDI ruling and get included in that first (I am registered, that's all we can do so far) before I ruffle those feathers?
thanks again for the time and help!
-C
SCAN 1
CONDITION:
- Malone Tune Installed (Install Mileage: 43160km/26818miles)
- “Emission Control System” CEL: ON
o Light came on with 40 miles of Malone tune install (~26858miles)
Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: Release 17.1.3(x64) Data version: 20170320 DS267.7
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,12,May,2017,13:35:30:34655
VIN: WA1DVAFP5GAXXXXXX License Plate:
Mileage: 43510km-27035mi Repair Order:
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 69 6C 6D 72 AC
VIN: WA1DVAFP5GAXXXXXX Mileage: 43510km-27035miles
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CPNB) Labels: 059-907-401-V2.clb
Part No SW: 8K5 907 401 AC HW: 4G0 907 401 E
Component: 3.0TDI EDC17 X14 0002
Revision: 58X14---
Coding: 2A2A4012053603050000
ASAM Dataset: EV_ECM30TDI0118K5907401AC 001003
ROD: EV_ECM30TDI0118K5907401AC.rod
VCID: 71BCDC49C1216F7FD27-8024
Mileage: 43188 km
Date: 2017.05.08
Time: 09:05:00
Engine speed: 702.00 /min
Normed load value: 32.5 %
Vehicle speed: 5 km/h
Coolant temperature: 72 °C
Intake air temperature: 22 °C
Voltage terminal 30: 14.260 V
Particle filter: soot mass measured: 19.60 g
Particle filter: soot mass calculated: 19.99 g
Exh v PP Ds EG: 4.06 m/s
Particle sensor: soot volume in exhaust: 0.27 mg/m³
Particle sensor: exhaust temperature: 236.4 °C
Particle sensor: cleaning deviation reaction time: 0.597
Self-Diagnosis Log
Page 3
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H19 1003
Revision: --H19---
Coding: 000001
VCID: 4BC06EA1834D65AF88B-801E
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 239D1C03
Shop #: WSC 01831 002 1048576
VCID: 117CBCC9A1610F7FB27-8044
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0DA54040000000000000
Shop #: WSC 06335 000 00000
VCID: 084A91ADD23B4EB7659-805C
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000104892003
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01240620151423
Coding: 3621228080
VCID: 77A8E251AFC5314F1C3-8022
Self-Diagnosis Log
Page 4
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001098553301
Coding: 26000815813CAFE00101408300003D0D4F9CE708A6090221000008004000030100000034000000
VCID: 78AAE16DA2DB3E37159-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 150612 H12 0050
Serial number: 90243014150606161813
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 20386626
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000406151106
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01F54203
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: ED2805B7000000000001
Self-Diagnosis Log
Page 5
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED13Z9FU
Coding: 303635313832383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CC26DBD86436297811-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R150000QJ53
Serial number: 6334MSME523D6941G
Serial number: 6344MSME52784C2CQ
Serial number: 6352QSME57533678L
Serial number: 6362QSME06543E4CQ
Serial number: 63732SME174D1550Z
Serial number: 63832SME204D3B7EB
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OFN0018B
Coding: 000037
VCID: 48CA51AD92BB8EB7A59-801C
Component: E221 - MFL H03 0004
Self-Diagnosis Log
Page 6
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 A HW: 8R0 920 982 A
Component: KOMBIINSTR. H35 0567
Revision: 00200000 Serial number: 03K62XG6G
Coding: 93BF22000301D705020000
VCID: 392C2469D951E73F2A7-806C
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 AA HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0070
Revision: 1Z130032 Serial number: 3241Z156020948
Coding: 80CF07FF00
VCID: 7EA6F77580FF00075F5-802A
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 6148126003
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 15164000693021200410
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000153843637
Coding: 01581B00000000000000
VCID: 42DE4385B487A4E77BD-8016
Self-Diagnosis Log
Page 7
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0372088775
Coding: 010221
VCID: 3FD84A71C7F5C90F143-806A
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0371414549
Coding: 010221
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0511
Revision: Serial number: 0000155006824
Coding: 011D13215E00440004
VCID: 4FF87AB177D5598FE43-801A
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0009921662
Coding: 100000010001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45D45899A52993DF5EF-8010
Self-Diagnosis Log
Page 8
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0372234926
Coding: 01260E3820EA709587A0053600040047
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000001014386
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H04 0090
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813045735506
VCID: 2D0400391D194B9FB6F-8078
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0511
Revision: Serial number: 0000154799071
VCID: 4EC667B570DF5087EF5-801A
Self-Diagnosis Log
Page 9
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 30000000392299
ROD: EV_ParkiBrake_VW51.rod
VCID: 3A2E3B65DCD7EC2723D-806E
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156F+0F8284325
Coding: 020007010000000001
VCID: 2412E51D4ED38AD7691-8070
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 H HW: 8R1 035 746 G
Component: H-BNT-NA H43 0937
Revision: -------- Serial number: 523FW0F7563013
Coding: 160200060005A1EF5502AB5E00000403140000000000000000
VCID: 3C223D7DD663D217311-8068
Subsystem 1 - Part No: 8R0 060 884 CS
Component: NAR 2015 1201
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130FV0F3390960
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000002276814
Component: CD-Database 6208
Self-Diagnosis Log
Page 10
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000155408721
Coding: 010C13204000240004
VCID: 46D65F9598AF98C7575-8012
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00008200841194
Coding: 0200000000000000
VCID: 36362F55E84F0847C75-8062
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H09--- Serial number: 525PA8-JA4A1K4
Coding: 1030010
VCID: 3432155DF2331A57F91-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D243079CD79DB1F06F-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Self-Diagnosis Log
Page 11
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000155408720
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 151610128
ROD: EV_RDCMA00100_008.rod
VCID: 2D0400391D994B9FB6F-8078
End----------(Elapsed Time: 02:03, VBatt start/end: 12.1V/12.1V)-----------
SCAN 2
CONDITION:
- STOCK Tune Installed (Install Mileage: 43510km-27035miles)
o Light came on within 130 miles of stock tune install (~27165miles)
Dealer/Shop Name:
Self-Diagnosis Log
Sunday,14,May,2017,10:44:23:34655
Mileage: 44230km-27483mi Repair Order:
62 69 6C 6D 72 AC
VIN: WA1DVAFP5GAXXXXXX Mileage: 44230km-27483miles
Self-Diagnosis Log
Page 2
Component: 3.0TDI EDC17 H14 0002
Revision: 58H14---
P226D 00 [232] - Damaged or Subrate Missing
Mileage: 43547 km
Date: 2017.05.12
Time: 15:49:42
Engine speed: 1513.00 /min
Vehicle speed: 100 km/h
Coolant temperature: 71 °C
Intake air temperature: 21 °C
Voltage terminal 30: 14.120 V
Particle filter: soot mass measured: 21.06 g
Particle filter: soot mass calculated: 18.59 g
Exh v PP Ds EG: 22.66 m/s
Particle sensor: soot volume in exhaust: 0.00 mg/m³
Particle sensor: exhaust temperature: 255.5 °C
Particle sensor: cleaning deviation reaction time: 0.517
Self-Diagnosis Log
Page 3
Revision: --H19---
Coding: 000001
Coding: 239D1C03
Coding: 3621228080
Self-Diagnosis Log
Page 4
Coding: 01DD13
Coding: 02005C
Self-Diagnosis Log
Page 5
Coding: 000037
Self-Diagnosis Log
Page 6
Self-Diagnosis Log
Page 7
Coding: 80CF07FF00
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 148
Mileage: 44150 km
Date: 2017.05.13
Time: 01:04:01
Reset counter: 145
Mileage: 44150 km
Date: 2017.05.13
Time: 04:03:51
Bin. Bits: 00000
Voltage: 12.60 V
Count: 7
Self-Diagnosis Log
Page 8
Coding: 010221
Coding: 010221
Self-Diagnosis Log
Page 9
Self-Diagnosis Log
Page 10
Self-Diagnosis Log
Page 11
Self-Diagnosis Log
Page 12
Coding: 1030010
End----------(Elapsed Time: 02:04, VBatt start/end: 12.0V/12.1V)-----------
SCAN 3
CONDITION:
- STOCK Tune Installed (Same Install Mileage as Scan2: 43510km-27035miles)
- CEL from Scan2 was cleared at 27483miles
o Light came on within 220 miles of stock tune install (~27703miles)
- May 16th, 2017: CEL has NOT been cleared; continue to log with CEL
Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version Release 17.1.3(x64) Data version 20170320 DS267.7
Dealer/Shop Name:
Self-Diagnosis Log
Sunday,14,May,2017,20:41:12:34655
Mileage: 44880km-27887mi Repair Order:
62 69 6C 6D 72 AC
VIN: WA1DVAFP5GAXXXXXX Mileage: 44880km-27887miles
Self-Diagnosis Log
Page 2
Revision: 58H14---
VCID: 71BCDC49C1216F7FD27-8025
P226D 00 [236] - Damaged or Subrate Missing
Mileage: 44483 km
Date: 2017.05.14
Time: 16:00:22
Engine speed: 1642.00 /min
Normed load value: 99.2 %
Vehicle speed: 108 km/h
Coolant temperature: 80 °C
Intake air temperature: 29 °C
Voltage terminal 30: 13.020 V
Particle filter: soot mass measured: 5.35 g
Particle filter: soot mass calculated: 7.52 g
Exh v PP Ds EG: 24.20 m/s
Particle sensor: soot volume in exhaust: 0.89 mg/m³
Particle sensor: exhaust temperature: 282.8 °C
Particle sensor: cleaning deviation reaction time: 0.713
Self-Diagnosis Log
Page 3
Revision: --H19---
Coding: 000001
VCID: 4BC06EA1834D65AF88B-801F
Coding: 239D1C03
VCID: 117CBCC9A1610F7FB27-8045
VCID: 084A91ADD23B4EB7659-805D
Coding: 3621228080
VCID: 77A8E251AFC5314F1C3-8023
Self-Diagnosis Log
Page 4
VCID: 78AAE16DA2DB3E37159-802D
Coding: 01DD13
Coding: 02005C
Self-Diagnosis Log
Page 5
VCID: 4CC26DBD86436297811-8019
Coding: 000037
VCID: 48CA51AD92BB8EB7A59-801D
Self-Diagnosis Log
Page 6
VCID: 392C2469D951E73F2A7-806D
Coding: 80CF07FF00
VCID: 7EA6F77580FF00075F5-802B
VCID: 42DE4385B487A4E77BD-8017
Self-Diagnosis Log
Page 7
Coding: 010221
VCID: 3FD84A71C7F5C90F143-806B
Coding: 010221
VCID: 4FF87AB177D5598FE43-801B
VCID: 45D45899A52993DF5EF-8011
Self-Diagnosis Log
Page 8
VCID: 2D0400391D194B9FB6F-8079
VCID: 4EC667B570DF5087EF5-801B
Self-Diagnosis Log
Page 9
VCID: 3A2E3B65DCD7EC2723D-806F
VCID: 2412E51D4ED38AD7691-8071
VCID: 3C223D7DD663D217311-8069
Self-Diagnosis Log
Page 10
VCID: 46D65F9598AF98C7575-8013
VCID: 36362F55E84F0847C75-8063
Coding: 1030010
VCID: 3432155DF2331A57F91-8061
VCID: 3D243079CD79DB1F06F-8069
Self-Diagnosis Log
Page 11
VCID: 2D0400391D994B9FB6F-8079
End----------(Elapsed Time: 02:05, VBatt start/end: 12.1V/12.2V)-----------
m87a
C?ID=156900
if they see a tune they will try to blame it on tune no matter what :)
you did have a tune which could be putting more fuel, more ash, more regeneration which cause wear but then again it's too soon to burn dpf filter
it's up to your and dealer, hope you get it sorted
if they refuse you can always gut it and tune it out ;)
cschlue
C?ID=303523
thank you, I looked at how you modified - makes total sense now. thanks
cschlue
C?ID=303523
if they see a tune...
What would they look for or see, now that I swapped the program/tune back to stock?
What would they point to, to identify I had a tune on it in the past?
The car also went through 50% more DEF last service, they just filled it and sent me on my way.
m87a
C?ID=156900
go to Advanced ID 1A or advanced identification on 01 Engine
check
FLASH STATUS
Programming Attempts 2 (number of times how many times was module flashed)
Successful Attempts 2 (number of times how many times was module successfully flashed sometimes this is lower that attempts :p )
hmmmm.. you can use that :D
cschlue
C?ID=303523
check
FLASH STATUS
wow... clearly discoverable.
very good to know.
thank you!!!
very good to know.
thank you!!!
Except that some tuners have figured out how reset the flash counters. :eek:
wiluspyder
Canada
C?ID=205254
Did you ever find out the issue?
I have these same code showing up but for a stock car.
cschlue
C?ID=303523
Sorry for the slow reply... I have been dealing with it slowly based on shop availability.
The short answer is, negative!
I have had two visits to a local shop that sells the tune and spends plenty of time on diesels.
We have confirmed, there is a DPF and it has substrate... it's not missing the filter.
We found a clogged exhaust pipe, small metal tube around the turbo. Cleared and no change.
Car is back to fully stock 100%.
Same independent shop spent a second day debugging in stock; with no luck identifying the culprit.
More to come; I will update as I get more time debugging.
Vasco Ferraz
Portugal
C?ID=288561
I read this thread diagonally... but I assumed you flashed the ECU (for more power) with the DPF still installed.
If what I said is correct... fitting more power with a DPF still installed is not very good because it will be clogged extremely fast.
Now imagine if the tune file is for more power and assuming the DPF is removed. This means that no more regens will be performed.
So, my both hypotheses point to a blocked (or even destroyed) DPF. I believe that there is no turning back to save the DPF.
cschlue
C?ID=303523
Update: just got the car back from 2+ weeks at the dealer.
They went through a lot different de-bugging procedures, logging miles after each attempt, and in the end they replaced the DPF under warranty. They didn't seem at all surprised nor too descriptive in the matter (and I didn't ask too much). I have already noticed a weekend with less soot on the silver paint.
Not a lot more to say - wish I had a little more to share.
Thank you all for the fun conversation and help along the way.
