- Joined
- Apr 27, 2017
- Messages
- 38
- Reaction score
- 35
- Location
- New Jersey USA
- VCDS Serial number
- C?ID=302889
I recently purchased a 2004 Audi S4 with only 19,000 miles! It spent most of its life at a doctors summer vacation home (always garaged). However, he only had one key. So I rented a Vagtacho cable and retrieved the immobilizer PIN. I purchased some key fobs and had the keys cut, then I used VCDS to add the immobilizer chips. Piece of cake!
Next, program the remotes. I tried every method I could find with no success. Then I realised I could use VCDS to add them. However, I can not access the CCM (46). I just keep getting "No response from controller".
One odd behaver I have with the car, when I open either door the interior light comes on for one second then turns off. Everything else on this car works perfectly (no check engine light). It does have an after market radio so of course I do get a communications fault code. I also get one other fault code. 02010 - Left Entry Assistance Control Module (J572) 79-00.
I forgot to add there is a small parasitic drain on the battery (car locked) of about 160ma. Could a bad Left Entry Assistance Control Module be the cause of all my problems?
