Problem Reading Codes on Central Convenience Module
Kenrevo
C?ID=307577
I have a 05 Touareg V8 and when I try reading fault codes on 46: Central Conv. I get no response from controller but everything else works with out any errors. I have also tried another module and it acts the same way. When I do a full Auto Scan it hangs, waited 10 minutes, at the module and I have to exit out for it to continue. Below is the full scan anyone have any suggestions?
Sunday,30,April,2017,21:27:10:13312
VCDS Version: 17.1.3.0 (x64)
VIN: WVGMM77L95D017311   License Plate:
Mileage: 238130km-147967mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGMM77L95D017311   Mileage: 238130km-147967miles
Address 01: Engine        Labels: 077-907-560-AXQ.lbl
   Part No SW: 4D0 907 560 DB    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0010
   Revision: 00000000    Serial number: VWZ3Z0D7224167
   Coding: 0007875
   Shop #: WSC 31414 000 00000
   VCID: 69D34D80434DE2095E-515A
16725 - Camshaft Position Sensor (G40)
            P0341 - 004 - Implausible Signal - Intermittent
17538 - Fuel Trim; Bank 2 (Mult)
            P1130 - 001 - System too Lean - Intermittent
16558 - Fuel Trim; Bank 2
            P0174 - 001 - System Too Lean - Intermittent
17887 - Brake Boost Vacuum System
            P1479 - 008 - Mechanical Failure
Readiness: 0000 1001
   Part No: 09D 927 750 AQ
   Component: AL 750 6A           0551
   Coding: 0004153
   VCID: 7DFB09D027C56EA982-5178
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 E
   Component: ESP ALLRAD MK25     0202
   Coding: 0014594
   VCID: 3B7FC7C87951A099FC-515A
   Part No SW: 3D0 909 135 M    HW: 5WK 470 26
   Component:    Kessy            6400
   Coding: 0131304
   VCID: 2F67E398BD294C3940-5178
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77F71BF805F944F9D8-5178
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   Coding: 0000030
   VCID: 356BD1F05F7576E90A-5178
02193 - Supply Voltage for Regulator for Fresh Air Blower
            010 - Open or Short to Plus
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 K
   Component:                     2703
   Coding: 0105694
   Shop #: WSC 08160 444 54690
   VCID: 448DBC3404AFDF618D-5178
   Part No: 3D0 909 601 C
   Component: 05 Airbag 8.4E++H01 0352
   Revision: BB36963     Serial number: 00026178
   Coding: 0012341
   VCID: 234F1FA8E1E1F859D4-515A
   Subsystem 1 - Part No: 7L0 959 339 D
   Component: BF-Gewichtsens. 005 0007
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000032
   VCID: 4085B02410B7C341A9-5178
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 980 M
   Component: KOMBIINSTRUMENT RB8 2921
   Coding: 0007231
   VCID: 4281BA2C1EBBD151BF-5178
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70E520E4609713C119-5178
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879
   Component: JCI PathPoint       1700
   VCID: 040D7C34442F1F61CD-5178
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F07F3D82DC97CB990-5178
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: 66C946BC5253CD7173-513C
Address 32: Differential Locks        Labels: None
   Part No: 0AC 927 771 B
   Component: SG-Quersperre       5018
   VCID: 3777DBF8457984F918-5178
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 3669D6FC42737DF103-5178
   VCID: 77F71BF805F944F9D8-515A
Address 37: Navigation        Labels: 7L6-919-887-CD.lbl
   Part No: 7L6 919 887 D
   Component:      Navigation     0628
   VCID: 4797AB383599F47968-5178
   Part No: 3D0 909 158
   Coding: 0000003
   VCID: 67D74BB85559D47948-513C
   Part No: 7L0 959 933 F
   Component: 33 HSG              0300
   Coding: 0000085
   VCID: 3F87B3D86D49BCB9D0-FFFE
   Subsystem 1 - Part No: 7L0 959 701 B
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 B
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 B
   Subsystem 4 - Part No: 7L0 959 704 B
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No: 7L6 035 466
   Component: 12K-AUDIOVERST      0108
   VCID: 71E325E06B9D1AC916-515A
00419 - Left Front DSP Midrange Speaker (R103)
Address 56: Radio        Labels: 7L6-035-186-CD.lbl
   Part No: 7L6 035 186 A
   Component:        Radio        0628
   Coding: 0005077
   Shop #: WSC 00001 552 00000
   VCID: 3163E5E0AB1D5AC956-5178
Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
   Part No: 7L0 955 119 F
   Component: Front Wiper         2416
   Coding: 0000004
   Shop #: WSC 00000 000 376832
   VCID: 3777DBF8457984F918-515A
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
   Component: J345  Anhaenger     0080
   Revision: 4A009002    Serial number: 00000157181584
   Coding: 0016386
   Shop #: WSC 00512 001 24584
   VCID: 3F87B3D86D49BCB9D0-5178
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 K
   Component: DACHDISPLAY         0538
   Revision: 00700538    Serial number: 2009289.06
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 3973DDC0736D9289EE-5178
End-------------------------(Elapsed Time: 39:20)--------------------------
Strange...
You say you've swapped out CCMs?
What kind of computer are you using?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Strange...
See internal thread 4535 for identical behavior with this module's cousin in a 2004 Phaeton. We never got completely to the bottom of it; there was no urgency because I could work around it by using a HEX-NET instead of a HEX-USB+CAN, and I eventually stopped being able to reproduce it. It had something to do with timing and how many faults are stored.
Jason
Kenrevo
C?ID=307577
Strange...
Yes I have tried 2 different ones. I'm using a Microsoft Surface Pro with Windows 10 Home 64-bit.
About 2 months ago I could read codes through Auto scan but not in the specific module, I had 4 codes then. I couldn't clear the codes. I'm having issues with the trunk not unlocking with the front button and I'm trying to diagnose it, that why I want to see the codes.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I think it might be due to a known issue with VCDS. Or rather, a known issue with that family of CCMs that do a terrible job implementing the VW diagnostic protocols, which VCDS can almost always smooth over but occasionally it has trouble. That's what I was referring to above. A few people, myself included, have run into this before.
You're still showing up as a New User. Let's get you registered for support, then we can try to verify what's going on, and see if there's a way to fix it.
Jason
Moving this to Product Support.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
We'll need some VCDS debug information from your car in order to troubleshoot further. Here's what to do:
  1. Physically connect to the car
  2. Start VCDS
  3. [Options]
  4. Set Debug Level to 1024
  5. [Apply]
  6. [Select]
  7. [46-Central Conv]
  8. [Fault Codes - 02]
  9. Take note of what happens, success or fail
  10. Disconnect from that module and close VCDS
Then look in the Debug Sub-Folder; it should be in C:\Ross-Tech\VCDS\Debug\. Zip up the files you find in that directory, and email them to support@ross-tech.com. Include a link to this thread so they know what problem you're referring to.
I just checked and it looks like I can reproduce this on my 2004 Phaeton again, so I'm sending in my own debugs as well.
Jason
Kenrevo
C?ID=307577
  2. Start VCDS
  3. [Options]
  5. [Apply]
  6. [Select]
Jason
I ran it in debug mode and it reads the fault codes fine. Should I submit the debugs anyways?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Great, it's a Heisenbug. :)
I may have seen some similar behavior myself yesterday. Send debugs anyway, and if you're able, try it a bunch more times to see if you can make it fail under debugging. You don't need to restart VCDS each time, the debug file will keep growing. Also be sure to try it both manually and via Auto-Scan. The race/timing issue we seem to be hitting may behave differently when accessed different ways.
Jason
ElSupremo
San Diego area
C?ID=215154
I have almost the same configuration - Surface Pro 3 (i7 processor), but running Windows 10 Pro 64-bit. I found "flaky" results when I connected the VAGCOM com directly to the USB (3.0) port. Putting a USB 2.0 Hub in the middle solved any connection problems I had.
Just my $0.02, YMMV.
Kenrevo
C?ID=307577
I tried a couple of times yesterday and it it working perfectly fine with debug mode on and off. It's been raining for the past couple days so that might be what has changed. I'll try again when everything has dried out and see if that make a differences.
Uadi
France
C?ID=47539
Hello. I have a similar problem on two different Skoda Octavia from 2011 and 2012. Although the ccm module is listed on the installation list while I perform an auto-scan, vcds is skipping the module. When I try to connect manually I get an error each time. I post the auto-scan below. Any ideas?
Monday,01,January,2018,15:35:51:28681
VCDS Version: 17.8.1.0
VIN: TMBBT61Z0B8028028   License Plate:
Mileage: 180500km-112157mi   Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBT61Z0B8028028   Mileage: 180500km-112157miles
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LR    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 9972
   Revision: --H43---    Serial number:
   Coding: 00254016032400080000
   Shop #: WSC 73430 031 00123
   ASAM Dataset: EV_ECM16TDI02103L906023LR 003011
   ROD: EV_ECM16TDI02103L997557.rod
   VCID: 0103B3209079034E9E-8054
7332 - Mass Air Flow Sensor (G70)
          P0103 00 [165] - Signal too High
                    Mileage: 180501 km
                    Date: 2018.01.01
                    Time: 00:03:11
                    Coolant temperature: 11 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 11.633 V
                    Engine speed: 0 /min
                    Battery voltage: 11.6 V
                    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
                    Air mass: specified value-MAF_SP_MMV: 269.94 mg/stroke
                    Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
7411 - Turbocharger Boost Control Position Sensor Circuit
          P2564 00 [165] - Signal too Low
                    Mileage: 180501 km
                    Date: 2018.01.01
                    Time: 00:03:11
                    Charge Pressure Actuator: acknowledgment-ANG_BPA[0]: -11.926 %
                    Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 %
                    High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 95.001 %
                    High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 0.000 V
                    Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
                    Turbocharger boost control: offset closed-V_BPA_TOL[0]: 3.462 V
                    High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 0
14356 - Exhaust Gas Temperature Sensor 4 Bank 1
          P246E 00 [165] - Electrical Malfunction
                    Mileage: 180501 km
                    Date: 2018.01.01
                    Time: 00:03:11
Readiness: 1110 1000
   Part No SW: 0AM 300 050 G    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2321
   Revision: 00043014    Serial number: CU501206085818
   Shop #: WSC 15144 995 83705
   VCID: 2D5B3F90B461372E0A-8078
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 113B201C09240002880B04E690210041350000
   Shop #: WSC 73430 790 00123
   VCID: 76E9D0FCC1B734F6BB-8022
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 37
                    Mileage: 180501 km
                    Date: 2012.05.24
                    Time: 00:06:49
                    Count: 3
                    Count: 14
                    Count: 4608
                    Count: 397
                    Count: 41728
                    Count: 4
   Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
   Component: Climatronic   H16 0402
   Revision: 00005001
   Coding: 0000000002
   VCID: 76E9D0FCC9B734F6BB-8022
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 40000AB8E00508C04008008051000124437000AE526D85605C8440000040
   Shop #: WSC 73430 790 00999
   VCID: 38751EC48B23828669-806C
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 26111  26  0601
   Coding: 00D7B7
   Component: RLS 291110 05  54  0403
   Coding: 0730ED
8 Faults Found:
                    Fault Status: 00101110
                    Reset counter: 77
                    Mileage: 144179 km
                    Date: 2015.07.28
                    Time: 17:49:17
                    Voltage: 13.35 V
                        Term 50 Off
            000 -  -  - Intermittent
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2012.05.24
                    Time: 06:52:30
                    Voltage: 11.15 V
                        Term 50 Off
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2012.05.24
                    Time: 07:22:37
                    Voltage: 8.85 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2012.05.24
                    Time: 07:23:32
                    Voltage: 8.30 V
                        Term 50 Off
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2012.05.24
                    Time: 07:23:32
                    Voltage: 8.30 V
                        Term 50 Off
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2012.05.24
                    Time: 07:23:59
                    Voltage: 8.00 V
                        Term 50 Off
00532 - Supply Voltage B+
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2012.05.24
                    Time: 07:24:34
                    Voltage: 7.50 V
                        Term 50 Off
                    Fault Status: 01101010
                    Reset counter: 37
                    Mileage: 180501 km
                    Date: 2012.05.24
                    Time: 00:00:07
                    Voltage: 11.65 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32991033403628
   Coding: 10010E
   Shop #: WSC 13765 790 00123
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 336F29E89A4561DE5C-8066
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC21DK75
   Coding: 0020790
   VCID: 3D7B0FD06401A7AEBA-8068
   Subsystem 1 - Serial number: 6332MSME59312758B
   Subsystem 2 - Serial number: 6342MSME5754042FE
   Subsystem 3 - Serial number: 6351HSME2502090E%
   Subsystem 4 - Serial number: 6361HSME25014903Z
00589 - Airbag Igniter 1; Passenger Side (N131)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101206301519
   Coding: 1882140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EF9C8DCE1877CB6E3-802A
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2018.01.01
                    Time: 07:23:38
136194 - Supply voltage
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2018.01.01
                    Time: 07:23:44
   Part No SW: 1Z0 920 843 M    HW: 1Z0 920 843 M
   Component: KOMBI         H20 0420
   Coding: 110B01
   VCID: 42817C2CD5FFD856C7-8016
9453842 - Oil Level Thermal Sensor
          B1041 35 [009] - Signal high time > maximum
                    Reset counter: 37
                    Mileage: 180501 km
                    Date: 2018.01.01
                    Time: 00:02:59
13639427 - Please Check Fault Codes in Engine Control Module
          U101F 00 [009] - -
                    Reset counter: 37
                    Mileage: 180501 km
                    Date: 2018.01.01
                    Time: 00:02:14
13635840 - Supply voltage
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2018.01.01
                    Time: 07:24:27
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 211110F1001653
   Coding: 351302
   VCID: 306526E463535AC621-8064
00469 - Infotainment Databus in Single Wire Operation
                    Fault Status: 00101011
                    Reset counter: 75
                    Mileage: 180400 km
                    Date: 2012.05.23
                    Time: 22:31:15
                    Reset counter: 77
   Component: IMMO          H20 0420
   VCID: 6AD1F48C8D0FE0162F-803E
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Coding: 0004342
   VCID: 76E9D0FC01B734F6BB-8022
   Part No: 1K0 909 144 J
   Revision: 00H17000
   VCID: 316323E0A85953CE2E-8064
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 9.9 V
                        PD
                    Temperature: 6.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0004342
   VCID: 48956E043BC3F20619-801C
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0065
   Revision: 0I001001    Serial number: SKZ1Z2K4763608
   Coding: 0D0004000001
   VCID: 316323E0685953CE2E-8064
                    Reset counter: 77
                    Mileage: 180500 km
                    Date: 2012.05.24
                    Time: 07:22:22
03138 - Input AUX IN
                    Reset counter: 77
                    Mileage: 144043 km
                    Date: 2015.07.28
                    Time: 10:53:27
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012571
   VCID: 32612CECAD5F68D657-8066
01813 - Supply Voltage for Door Controller; Rear Left (J388)
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336F29E8524561DE5C-8066
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End-------------------------(Elapsed Time: 02:36)--------------------------
And the second auto-scan,
Monday,01,January,2018,15:00:34:28681
VIN: TMBDT61ZXC2178757   License Plate:
Mileage: 382470km-237655mi   Repair Order:
VIN: TMBDT61ZXC2178757   Mileage: 382470km-237655miles
   Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 8810
   Coding: 00114014032400080000
   Shop #: WSC 73430 031 00083
   ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
   VCID: 7F0735D8E68D75BEE8-802A
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0106
   Revision: 00H35001
   Coding: 0017665
   Shop #: WSC 73430 790 00083
   VCID: 7BFFC1C83A95699EC4-802E
   Part No SW: 3T0 820 047 AB    HW: 3T0 820 047 AB
   Component: AC Manuell    H19 0502
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ACManueBHBVW36X_SK35.rod
   VCID: 6FE7E598B6ED053E78-803A
   Part No SW: 1K0 937 085 L    HW: 1K0 937 085 L
   Component: BCM PQ35  B+  110 0651
   Revision: 00110 AC
   Coding: 40000AB8A00508B040100080110000A4430000AE520081605CC400000040
   Component: Wischer 28031  26  0601
   Coding: 00D7B7
   Revision: 05020000    Serial number: 0038PD2VZY6S
   Coding: 0020790
   Subsystem 1 - Serial number: 6332MSME6C7206149
   Subsystem 2 - Serial number: 6342MSME6B03476FO
   Subsystem 3 - Serial number: 6351HSME2B6550141
   Subsystem 4 - Serial number: 6361HSME2B66755EO
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Component: LENKS.MODUL   016 0162
   Revision: --X01---    Serial number: 20141205200487
   Coding: 0080140000
   Shop #: WSC 27293 001 1048576
   VCID: 0201BC2C957F185687-8056
   Part No SW: 1Z0 920 803 S    HW: 1Z0 920 803 S
   Component: KOMBI         H06 0608
   Coding: 110200
   VCID: 448D7A34CFEBD666F5-8010
   Revision:   H42       Serial number: 260312F2003220
   Coding: 351302
   VCID: 3A7104CCB52F90969F-806E
   Component: IMMO          H06 0608
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Coding: 0000052
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 37771DF8463D8DFE60-8062
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000052
   VCID: 47976D3836DDFD7E10-8012
   Part No SW: 1Z0 035 152 E    HW: 1Z0 035 152 E
   Component: Radio         007 0010
   Revision: R0000000    Serial number: SKZAZ5M1570301
   Coding: 000002000001
End-------------------------(Elapsed Time: 01:52)--------------------------
TBAx
C?ID=287144
The module is only listed in the Gateway installation list for compatibility reasons. It redirects to the BCM (module 09) where you should find what you search for.
Uadi
France
C?ID=47539
Like in older models where the 25-immobilizer redirects us to the 17-instruments? In this case there are no instructions.:confused:
On older models where 25-Immo "redirects" to 17, address 25 actually responds and answers with, "Bitte Adresse 17 Eingeben". However on these cars, 46 does not respond at all.
Uadi
France
C?ID=47539
Thanks a lot, i thought my interface was broken.:thumbs:
