I have a 05 Touareg V8 and when I try reading fault codes on 46: Central Conv. I get no response from controller but everything else works with out any errors. I have also tried another module and it acts the same way. When I do a full Auto Scan it hangs, waited 10 minutes, at the module and I have to exit out for it to continue. Below is the full scan anyone have any suggestions?
Sunday,30,April,2017,21:27:10:13312
VCDS Version: 17.1.3.0 (x64)
VIN: WVGMM77L95D017311 License Plate:
Mileage: 238130km-147967mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGMM77L95D017311 Mileage: 238130km-147967miles
Address 01: Engine Labels: 077-907-560-AXQ.lbl
Part No SW: 4D0 907 560 DB HW: 8E0 907 560
Component: 4.2L V8/5V G 0010
Revision: 00000000 Serial number: VWZ3Z0D7224167
Coding: 0007875
Shop #: WSC 31414 000 00000
VCID: 69D34D80434DE2095E-515A
16725 - Camshaft Position Sensor (G40)
P0341 - 004 - Implausible Signal - Intermittent
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean - Intermittent
16558 - Fuel Trim; Bank 2
P0174 - 001 - System Too Lean - Intermittent
17887 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure
Readiness: 0000 1001
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 AQ
Component: AL 750 6A 0551
Coding: 0004153
VCID: 7DFB09D027C56EA982-5178
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 E
Component: ESP ALLRAD MK25 0202
Coding: 0014594
VCID: 3B7FC7C87951A099FC-515A
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: Kessy 6400
Coding: 0131304
VCID: 2F67E398BD294C3940-5178
Component: ELV XXXX
Part No: 7L0 959 760
Component: Sitzverstellung 0701
VCID: 77F71BF805F944F9D8-5178
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0000030
VCID: 356BD1F05F7576E90A-5178
02193 - Supply Voltage for Regulator for Fresh Air Blower
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2703
Coding: 0105694
Shop #: WSC 08160 444 54690
VCID: 448DBC3404AFDF618D-5178
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00026178
Coding: 0012341
VCID: 234F1FA8E1E1F859D4-515A
Subsystem 1 - Part No: 7L0 959 339 D
Component: BF-Gewichtsens. 005 0007
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000032
VCID: 4085B02410B7C341A9-5178
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 980 M
Component: KOMBIINSTRUMENT RB8 2921
Coding: 0007231
VCID: 4281BA2C1EBBD151BF-5178
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70E520E4609713C119-5178
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
VCID: 040D7C34442F1F61CD-5178
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F07F3D82DC97CB990-5178
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000003
VCID: 66C946BC5253CD7173-513C
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 B
Component: SG-Quersperre 5018
VCID: 3777DBF8457984F918-5178
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 3669D6FC42737DF103-5178
VCID: 77F71BF805F944F9D8-515A
Address 37: Navigation Labels: 7L6-919-887-CD.lbl
Part No: 7L6 919 887 D
Component: Navigation 0628
VCID: 4797AB383599F47968-5178
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
VCID: 67D74BB85559D47948-513C
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 F
Component: 33 HSG 0300
Coding: 0000085
VCID: 3F87B3D86D49BCB9D0-FFFE
Subsystem 1 - Part No: 7L0 959 701 B
Subsystem 2 - Part No: 7L0 959 702 B
Subsystem 3 - Part No: 7L0 959 703 B
Subsystem 4 - Part No: 7L0 959 704 B
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 466
Component: 12K-AUDIOVERST 0108
VCID: 71E325E06B9D1AC916-515A
00419 - Left Front DSP Midrange Speaker (R103)
Address 56: Radio Labels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 A
Component: Radio 0628
Coding: 0005077
Shop #: WSC 00001 552 00000
VCID: 3163E5E0AB1D5AC956-5178
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 00000 000 376832
VCID: 3777DBF8457984F918-515A
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Component: J345 Anhaenger 0080
Revision: 4A009002 Serial number: 00000157181584
Coding: 0016386
Shop #: WSC 00512 001 24584
VCID: 3F87B3D86D49BCB9D0-5178
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 K
Component: DACHDISPLAY 0538
Revision: 00700538 Serial number: 2009289.06
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 3973DDC0736D9289EE-5178
End-------------------------(Elapsed Time: 39:20)--------------------------
