Good evening. Not been here for a while,busy as........
Vehicle in today as customer fitted his own battery........oooooops!!!! Since then ABS and ESP lamps illuminated and have not gone out. Ive asked evry question o can hes playing dumb. Ive only just done a quick scan today to see whats giving the grief.
The ABS is saying control unit not coded and went to do a few bits on coding etc. It asked me to send the scan as no coding was available.
I was wondering if you could help please?
Im wondering if its anything to do with the GATEWAY module and the ABS is secondary.
The other noticeable thing is the rear fog and reverse lamps are back to front and displaying error codes. Ive not really dug deep on this at all yet.
kind regards Danners.
Tuesday,02,May,2017,16:34:28:44004
VCDS Version: 17.1.3.0 (x64)
Dealer/Shop Name: Victoria Volkswagen.
Workshop Code: 210 01843 000002
VIN: WVWZZZ3CZ9P018424 License Plate:
Mileage: 105280km-65417mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56
VIN: WVWZZZ3CZ9P018424 Mileage: 105280km-65417miles
02-Auto Trans -- Status: Sporadic communication error 1000
15-Airbags -- Status: Sporadic communication error 1000
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 CL HW: 03L 907 309
Component: R4 2.0l TDI 0001AG 9977
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 00032 210 87554
VCID: 71EE688F6802FEC916-8024
001649 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Mileage: 104795 km
Time: 18:11:31
RPM: 161 /min
Voltage: 8.59 V
Temperature: 3.6°C
Bin. Bits: 01110000
Time: 2.52 s
Temperature: 4.5°C
Part No SW: 02E 300 051 HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1818
Revision: 04843012 Serial number: 00000806130630
Shop #: WSC 00028 028 00001
VCID: 50A8CD0BC348D7C139-8004
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000785835799
Coding: 0001301
VCID: 2B52BAE78AAED4196C-807E
Reset counter: 5
Hex Value: 0x0000
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 227
Hex Value: 0x0000
Reset counter: 5
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 76E45B93016CD9F1C3-8022
00532 - Supply Voltage B+
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000005832982
Coding: 00800F0700041A00470A00000F000000000859435C000100000000000000
VCID: 326CA783AD8485D12F-8066
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 020608 022 0601
Coding: 00046997
Shop #: WSC 00028
01502 - Bulb for Rear Fog; Left (L46)
Reset counter: 5
Mileage: 104731 km
Voltage: 10.10 V
Reset counter: 5
Mileage: 104731 km
Reset counter: 30
Mileage: 104731 km
Voltage: 10.20 V
00059 - Terminal 30 for Interior Lighting
Reset counter: 30
Mileage: 104731 km
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__006 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPCV4LZO
Coding: 0012342
VCID: 3B728AA77ACE4499FC-806E
Subsystem 1 - Serial number: 6333FTS633271648
Subsystem 2 - Serial number: 6343FTS621661568
Subsystem 3 - Serial number: 6353ETS61PH2UVNH
Subsystem 4 - Serial number: 6363ETS6BC43UVNP
Part No SW: 3C0 953 549 AB HW: 3C0 953 549 AB
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AM
Coding: 0001003
VCID: 6CD079FB4F20132125-8038
Part No SW: 3C0 920 960 N HW: 3C0 920 960 N
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007405
Shop #: WSC 53179 002 1048576
VCID: 2E54B3F3B9BCA1314B-807A
Fault Frequency: 7
Reset counter: 30
Mileage: 104730 km
Time: 06:29:32
Reset counter: 30
Mileage: 104730 km
Time: 06:30:30
Reset counter: 30
Mileage: 104730 km
Time: 06:30:30
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 H HW: 3C0 907 951
Component: J533__Gateway H13 0142
Revision: H13 Serial number: 2600
Coding: FD801F06000202F100
VCID: 26444BD3914CE971B3-8072
Reset counter: 29
Mileage: 104731 km
Time: 00:00:20
Reset counter: 29
Mileage: 104731 km
Time: 00:00:20
Reset counter: 29
Mileage: 104731 km
Time: 00:03:31
Reset counter: 29
Mileage: 104731 km
Time: 00:03:31
Part No SW: 3C0 959 433 AB HW: 3C0 959 433 AB
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 6ADC7FE345D40D1157-803E
Component: ELV 027 0380
3C0905861G ELV 027 0380
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 30
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1518
Revision: 72009005 Serial number: 00000033088626
Coding: 0000565
VCID: 6FEA6EF77E36E83900-803A
Reset counter: 30
Mileage: 104730 km
Reset counter: 30
Mileage: 104730 km
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 196 3001
Revision: 00H15000
VCID: 316EA88FA882BEC956-8064
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0472
Coding: 01910A0801860E763004941570085BCE1038A1
Component: Neigungssensor 004 0611
Reset counter: 30
Mileage: 104730 km
Time: 06:01:19
Reset counter: 30
Mileage: 104730 km
Time: 06:01:19
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1518
Revision: 72009005 Serial number: 00000774688621
Coding: 0000564
VCID: 70E86D8B6308F7C119-8024
Reset counter: 30
Mileage: 104731 km
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 008 Serial number: 00000000066688
Coding: 0000057
VCID: 285845EB9B58FF0181-807C
Reset counter: 30
Mileage: 104739 km
Voltage: 12.60 V
Count: 75
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 012 0029
Revision: 00000000 Serial number: VWZ1Z2H5328887
Coding: 0500040004
VCID: 65C60CDF6CCA22697A-8030
Reset counter: 30
Mileage: 104730 km
Time: 03:08:40
Reset counter: 30
Mileage: 104730 km
Time: 03:08:40
End-------------------------(Elapsed Time: 01:50)--------------------------
Tuesday,02,May,2017,16:38:10:44004
Coding: 0000078
Coding: 0001301
Reset counter: 5
Mileage: 105283 km
Time: 16:35:11
Hex Value: 0x0000
Voltage: 12.75 V
Bin. Bits: 00011111
Count: 227
Hex Value: 0x0000
Reset counter: 5
Mileage: 105283 km
Time: 16:35:11
Coding: 00046997
Shop #: WSC 00028
Coding: 0012342
Coding: 0001003
Coding: 0007405
Coding: 0000565
Revision: 00H15000
Coding: 0000564
Coding: 0000057
Coding: 0500040004
End-------------------------(Elapsed Time: 02:14)--------------------------
