Thursday,09,April,2015,09:46:29:34655
VCDS Version: 14.10.1.1
Data version: 20150130
VIN: WAUZZZ4G0EN027408 License Plate: PR19989
Mileage: 24366km-15140mi Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 28 34 36 3B 3C 42
44 46 47 52 53 55 56 5F 62 69 6C 6D 72 82 85 8B 8E 8F 90
VIN: WAUZZZ4G0EN027408 Mileage: 24366km-15140miles
Address 01: Engine (J623-CDUD) Labels: None
Part No SW: 4G0 907 401 Q HW: 4G0 907 401
Component: 3.0TDI EDC17 H41 0002
Revision: 53H41---
Coding: 1225401A057601020000
ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
ROD: EV_ECM30TDI0114G0907401Q.rod
VCID: 3162D94F60AE05A9D1E-8064
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G2 927 156 P HW: 0B5 927 156 J
Component: 0B5 30 TDIRdW H02 0002
Revision: --H02---
Coding: 000001
ROD: EV_TCMDL501021.rod
VCID: 3B7EFB67B2E2FFF97B2-806E
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Coding: 27A6DF01E465FB80EB00
ROD: EV_ESPPremiAU57X_AU57.rod
Part No SW: 4H0 907 064 CP HW: 4H0 907 064 CP
Component: BCM2 2.0 H33 0433
Coding: 05A92F06000000000000
VCID: 79F2216FF05E0DE929E-802C
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0087
Serial number: 28061300041679
Coding: 361200B83D
ASAM Dataset: EV_AirCondiComfoUDS 002040
ROD: EV_AirCondiComfoUDS.rod
VCID: 62C0660375C8EE31184-8037
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001745597
Coding: 0907201009749FE289810083A0001800CF9CE7082E080201000108546F01
VCID: 6FE61F37BE1A535987A-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119
Component: WWS57X 130612 H36 0080
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AA HW: 4G0 941 531 AA
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Revision: 11001001 Serial number: 61061318100315
Coding: A9EB08
ROD: EV_EPHVA18AU57X0000.rod
VCID: 71E2194FA02E45A991E-8024
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X.rod
VCID: 2854342B53744461060-807D
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00DWMP1
Coding: 3032343631334E303437554A304C34473053
VCID: 3668EA5389C0229184C-8063
Serial number: 3575HRB406720N96CGK8
Serial number: 3585HRB400S50IH2B0UJ
Serial number: 3515JRB401C50JHG80O5
Serial number: 3525JRB400Q50JQ2J9S
Serial number: 3554VRB401E50K2ELGU+
Serial number: 3564VRB400I50JQ4C115
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372MFR000FK
Coding: 0000FD
VCID: 3776E75786CADB999FA-8062
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 933 B HW: 4G8 920 933 B
Component: TDieRdwAcc H80 0618
Revision: 30460230 Serial number: 658020713596038
Coding: 038F11001F550008000000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 2F66DF37769A1359C7A-807A
Address 18: Aux. Heat (J364) Labels: 8R0-265-105.clb
Part No SW: 4H0 265 105 E HW: 4H0 265 105 E
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20130604123559
Coding: 553F01
VCID: 244C201B275CA0012A8-8071
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000001001725
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_AU57.rod
Serial number: 5872830803
Voltage stabilizer:
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
VCID: 7CFC387BFF6C38C1328-8029
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0087
Serial number: 27061300040282
Coding: 21
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 3776E7578ECADB999FA-8062
Address 34: Level Control (J197) Labels: None
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008003
ROD: EV_AirSuspe_AU57.rod
VCID: 2E58C23371901A51CCC-807B
C10C8 00 [009] - -
Reset counter: 227
Mileage: 24366 km
Date: 2015.04.09
Time: 09:28:46
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000065594313
VCID: 77F62757C64A1B995FA-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA820456R3
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0060
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0010102
VCID: 3064DC4BA3A40CA1DE0-8065
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0060
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F29.06.1300H03000AMS15176ÿ
Subsystem 4 - Serial number: S15176ÿ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F16005E00628002080013
VCID: 458A9D9FCC26B9091D6-8010
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Component: RCEPS H38 0010
Revision: 00001000 Serial number: 0029630157
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 3260D64365A83EB1A84-8067
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0310129310
Coding: 013E0E20A0B93095832009842E030F470000000000000000000000000000
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.008 H02 0007
Coding: 901F00
Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Subsystem 5 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.008 H02 0007
Coding: 801F00
Subsystem 6 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B
Component: GEB.F.Heckoef H16 0810
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000011796
Coding: 030000
VCID: 1D3A15FF043691C9656-8048
Component: TSG BF H03 0507
Coding: 011F16005E00628002080002
VCID: 46889A93F120B21114C-8013
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000739785
ROD: EV_ParkiBrake_AU48.rod
VCID: 2C5CC83B478C6841E28-8079
Address 55: Headlight Range (J431) Labels: None
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 130626-0002-128
Coding: 11226F601002A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2D5AC53F7C966149F56-8078
Part No SW: 4G0 035 061 L HW: 4G0 035 061
Component: Radio U DAB H60 0133
Revision: AB001007 Serial number: 109F00D7688315
Coding: 010103010000000001
VCID: 26483A135160521134C-8073
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 K HW: 4G0 035 670 H
Component: H-BNT-EU H51 0732
Revision: -------- Serial number: 190G-0D7544109
Coding: 050100010003FFEF7DB0EB3E00000003080001000000000000
VCID: 2B5ECB274A826F79EB2-807E
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Component: CD-Database 5298
Component: TSG HL H03 0507
Coding: 010F14004000628002080002
VCID: 499291AFE03E5D69F9E-801C
Address 69: Trailer (J345) Labels: None
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H11 0100
Revision: 5G001001 Serial number: 00000193832171
Coding: 0109080000000000
VCID: 71E2194FA82E45A991E-8024
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0150
Revision: 11001001 Serial number: 82330JE0006589
Coding: 0202000001010000010102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
ROD: EV_CamerSysteTopViewAUDI.rod
VCID: 2B5ECB2742826F79EB2-807E
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 179300234
Coding: 097205C011
ROD: EV_HDSGAu571.rod
VCID: 356AED5F94C629898D6-8060
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels: 4G0-919-604.clb
Part No SW: 4G0 919 604 K HW: 4G0 919 604 K
Component: HeadUpDisplay 004 0201
Coding: C70000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7.rod
VCID: 336ED3479AB237B9A32-8066
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 26483A135960521134C-8073
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851) Labels: 4G0-907-107.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H31 0041
Serial number: 005000122106137
Coding: 04C0BB1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7_AU57.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 07:07)--------------------------
