Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: RNS 510 retrofit - MFSW not working... sort of
    Verified VCDS User Vasco Ferraz's Avatar
    Jan 2017
    Portugal
    Sorry for the dig but I want to know (please) if you solved this issue and how did you do it.
    Thank you.
    Vasco Ferraz
  2. #12
    Jun 2017
    +1 on the dig for Bluetooth MFSW button fix
  3. Likes Vasco Ferraz liked this post
  4. #13
    Jan 2017
    Portugal
    Thank you so much
    Vasco Ferraz
  5. #14
    Jun 2017
    So, apparently the problem stems from the revision number of the RNS 510 and possibly the revision number of the bluetooth module. Check and see what you have.
    This comes from BarryT82 on golfmkv forum:
    "You have to have a version E or above RNS-510 and a 9w7 with SW 27xx or above to change songs. For voice command you need SW 2902 or above on the Bluetooth module. Did you buy the voice command Bluetooth harness or non voice command? It's a simple mode to make it work."
    My bluetooth module meets these criteria but the RNS unit I bought does not. Not real happy with my purchase now
  6. #15
    Mar 2015
    Australia
    Rns firmware updates are freely available on the internet.
    Just upgrade it to latest making sure you get the appropriate version for your unit eg Europe or North America
  7. Likes Emzy liked this post
  8. #16
    Jun 2017
    I was led to believe that certain RNS510 lettered revisions are only firmware-upgradable to a certain point. I have a revision C RNS510 and I think the latest supported firmware number for C is 1140 or something, several updates behind the minimum 27xx firmware number. Am led to believe that the minimum firmware number starts to be supported at the E lettered RNS revision.
    I'm taking all of that on the word of someone else though, so I can't be sure. Maybe Vasco will upgrade his firmware and let us know if it works.
    The ability to "enable firmware downgrade" through the head unit setup menu leads me to believe that some firmware numbers are incompatible or troublesome with certain head unit revisions. This is purely speculative though.
    I wont be testing this out because I already ordered the most recent RNS 510 revision. Hoping the SSD improves the very slow boot times I'm experiencing now (after turning on the vehicle I have to wait ~90 seconds before I can put it in reverse and see the backup camera).
  9. #17
    Jan 2015
    Bosnia and Herzegovina
    you can update to 5238 modified by jossi
    https://dfiles.eu/files/5flgt1nnd
    i have personally used it on many devices including A & B revions, of course as always there is a certain risk of bricking device, so risk is all yours
  10. #18
    Mar 2015
    Australia
    The version numbers between North America and Europe are not similar.
    Version 1140 I think is the latest for NA whereas 6276 is the lastest for Europe/Rest of World.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|DAB RNS|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct
  11. Likes m87a, Uwe liked this post
  12. #19
    Jan 2017
    Portugal
    Quote Originally Posted by Emzy View Post
    I will indeed let us all know if it worked as expected.
    The problem (ok, not a problem) is that I received the radio yesterday and I am going to vacations this Thursday.
    From my experience I tend to break clips when doing something in a rush. I hate to break things just because I am in a rush or didn't do the homework.
    So I will probably just do my retrofit on the 8th/9th of July
    Vasco Ferraz
  13. Likes Uwe liked this post
  14. #20
    Jan 2017
    Portugal
    Well, I was very impatient to test it so I managed to get some free time today.
    I was able dismantle radio console without damage
    So, in short, everything worked like a charm.
    Even though knowing that the protocol used in the instruments cluster is DDP I was able to get the name of the music playing in the MFD.
    I consider this a bonus as I was not expecting to get this function working. The RCD300 was not able to transmit songs name to the cluster. Just a "Track N" was displayed.
    Also, volume, mute(star), menu, OK and up/down buttons are working as expected. The behaviour was similar when the RCD300 radio was installed.
    Telephone button is disabled because I don't have the BT module. Again, the behaviour was similar when the RCD300 radio was installed.
    I didn't test the battery drain... And I am not testing it today just by leaving the radio over night. I need the car tomorrow and I don't want to waste 100 in a new battery. So the battery drain issue will be be tested when I came back from vacations.
    Also, I can make a detailed guide with GW, radio, instruments cluster parts numbers and sw/hw revisions.
    Thank you so much for your help.
    Vasco Ferraz
  15. Likes Emzy, m87a, Uwe liked this post
