Results 1 to 1 of 1
Thread: Retrofit Steering wheel A3 8V 2.0TDI - not working
    Pirate
    Apr 2017
    Italy
    Exclamation Retrofit Steering wheel A3 8V 2.0TDI - not working
    Dear all, This is my first massage from Sicily!
    I'm tring to install a new MFSW stering wheel with also s-tronic paddles.
    I bought a multifunctional steering wheel with pads on ebay (8U0419091AD) and airbag cable (8U0971589C).
    Basically once installed the buttons turned on for 15 minutes ... the next day they did not light up anymore ... I thought that without encoding the control unit disabled the buttons instead of the encoding following the procedure (equal to that Above) has changed nothing ...
    Resumed the airbag cable connections and unplugged the connector on the ring and rested ... always for 15 minutes ... if i turn off, the steering wheel buttons remained lit ... after 15 minutes again
    here there is a scan of the car.
    Removed.  Data from pirate copies of VCDS is not welcome here.
    here what i used for the coding:
    Select STG 16 (steering wheel)
    STG Coding -> Function 07
    Byte 0  Enable Bit 1
    Select STG 17 (panel / tachometer)
    Byte 10
    Enable Bit 7
    Select STG 19 (Diagnostic Interface / Gateway)
    Byte 1
    Enable Bit 0
    Select STG 5F (infotainment)
    Byte 24 enable Bit 1 must become 1
    STG Adjustment -> Function 10
    (1) Select list of functions -Car CAN MFL
    Adjust Enabled value
    Select the list of functions (29) of the BAP MFL_0x0F vehicle
    (77) list of BAP MFL_Jocker_0x34 Select vehicle features
    (146) of the Vehicle Select Operation Menu-menu_display_MFL_jocker
    (148) vehicle menu operation-menu_display_MFL_jocker_over_threshold_high
