Results 1 to 9 of 9
Thread: VCDS® HEX-V2® Enthusiast capabilities?
    Verified VCDS User redrooster's Avatar
    Apr 2017
    Canada
    As I am new here, Hi everyone.
    I am considering buying the Hex-V2 and want to know if I will be able to dis-able the warning chimes for the seat belts on my 2006 VW Jetta TDI?
    Yes, I'm pretty confident you should be able to do that.
    Apr 2017
    Canada
    Well that's what I want to hear in order to justify the purchase.
    I hope I will get some more confirmation on it just the same from other users?
    May 2016
    I disabled them on my 2008 Golf with the HEX-USB so there's no reason the V2 shouldn't do it also.
    The one hesitancy I have is that 2006 NAR model Jettas used a somewhat unique/unusual instrument cluster that lacks some features that were standard in most other clusters. Unfortunately, I'm not able to find a scan from one off the cuff..
    It might be possible. Here's a coding screenshot from a very early mk5 cluster (i believe from 2006 jetta) without multifunction support.
                    Address 17: Instruments       Labels: 1K0-920-xxx-17.lbl
    Control Module Part Number: 1K0 920 953 CX
      Component and/or Version: KOMBIINSTRUMENT 3HL 4312
               Software Coding: 0000203
                Work Shop Code: WSC 00000 000 00000
                          VCID: 03464E4C42EA0459C6-8056
    8 Faults Found:
    00461 - Control Module for Seat Memory; Passenger (J521)
    00771 - Fuel Level Sensor (G)
                010 - Open or Short to Plus
                013 - Check DTC Memory
  7. Likes Eric, Uwe liked this post
    Apr 2017
    Canada
    I think this is my cluster only mine is a US car.I don't know anything about the scan details that you are showing though?
    Quote Originally Posted by Santos View Post
    8 Faults Found:
  9. #8
    Apr 2017
    Canada
    That's what I want to hear/do
    Quote Originally Posted by Ademaxx View Post
  10. #9
    US 2014 GTI Drivers Edition/DSG
    on my 2007 jetta i disabled seatbelt chimes
