Results 1 to 5 of 5
Thread: Audi S4 Electrical issues - MMI turns off
    New User
    Apr 2017
    I have a few issues with a car, I am trying to figure out what is going on with radio and entertainment system.
    MMI come up for about 5 sec and everything is working and then turns off.
    Could this be caused by bad J519 module?
    Other issues related to the engine, can this module cause them as well?
    Wednesday,19,April,2017,15:00:13:01436
    VCDS Version: 17.1.3.0 (x64)
    VIN: WAUKGAFL4DA065541   License Plate:
    Mileage: 181990km-113083mi   Repair Order:
    Chassis Type: FL (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56
              5F 62 6C 72 A9
    VIN: WAUKGAFL4DA065541   Mileage: 181990km-113083miles
    5F-Information Electr. -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CGXC)       Labels: 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0004
       Revision: --H07---
       Coding: 0A250034052600060000
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
       ROD: EV_ECM30TFS0218K5907551E.rod
       VCID: 387559F78356178111-806C
    7814 - Coolant Pump for Intercooler
              P190C 00 [037] - No Signal
                        Mileage: 181994 km
                        Date: 2016.09.22
                        Time: 00:03:46
                        Coolant temperature: 38 C
                        Intake air temperature: 31 C
                        Voltage terminal 30: 12.390 V
                        Engine speed: actual: 0 /min
                        MAF_ENVD: 0.00000 mg/stroke
                        Coolant temperature (unfiltered): 38.25 C
                        Engine: operating status: ES
                        Engine load: 0.000000 %
                        Vehicle speed: actual: 0 km/h
    7105 - Oile Pressure Regulating Valve
              P164E 00 [037] - Electrical Malfunction
                        Mileage: 181994 km
                        Date: 2016.09.22
                        Time: 00:03:48
                        Coolant temperature: 36.75 C
                        TQI_AV_ENVD: 0 Nm
                        Battery voltage: 12.390625 V
    12874 - Thermostat for Cylinder Head
              P199E 00 [037] - Open Circuit
                        Mileage: 181994 km
                        Date: 2016.09.22
                        Time: 00:03:44
    7818 - Manifold Pressure / Boost Sensor 2 (G447)
              P0241 00 [037] - Signal too Low
                        Mileage: 181994 km
                        Date: 2016.09.22
                        Time: 00:03:44
                        TIA_AM_SCHA: 31.50 C
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
       Component: 0B5 30TFSINAR H01 0006
       Revision: --H01---
       Coding: 000001
       ASAM Dataset: EV_TCMDL501021 001010
       ROD: EV_TCMDL501021_VW51.rod
       VCID: 40853117DB865F41A9-8014
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Coding: 291D1A
       VCID: 040DFD07871E8361CD-8050
       Part No SW: 8K0 907 064 FM    HW: 8K0 907 064 FM
       Component: BCM2 2.0      H10 0602
       Coding: 0D810000000000000000
       VCID: 0005F11793069F41E9-8054
       Serial number: 2312000086185009
       Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
       Component: KLIMA 3 ZONEN H04 0036
       Revision: C1000000    Serial number: 01020520120518
       Coding: 6600228000
       VCID: 336F6EDB9230F4D924-8066
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 217
                        Mileage: 181978 km
                        Date: 2016.09.20
                        Time: 01:57:25
                        Reset counter: 217
                        Mileage: 181978 km
                        Date: 2016.09.20
                        Time: 01:57:25
                        Reset counter: 217
                        Mileage: 181978 km
                        Date: 2016.09.20
                        Time: 01:57:25
                        Fault Frequency: 9
                        Reset counter: 219
                        Mileage: 181978 km
                        Date: 2016.09.20
                        Time: 01:57:30
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 AJ
       Component: BCM1 1.0      H14 0103
       Revision: 09014001    Serial number: 00000029613602
       Coding: 26000091863CAFE0210048C300003D0D0F9CD308A2090221000008000000010200020030000000
       Shop #: WSC 07408 444 105096
       VCID: 7AF183FFF5DAC591A7-802E
       Component: WWS 030512  H07 0070
       Serial number: SWF12050035775
       Coding: 00FD11
       Serial number: 20258194
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002504120817
       Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
    03020 - Local databus 2
                        Reset counter: 219
                        Mileage: 181994 km
                        Date: 2016.09.22
                        Time: 00:07:06
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
       Serial number: 003KJD906HJK
       Coding: 303844354730303030304A55304C384B3053
       Shop #: WSC 45013 001 1048576
       VCID: 4A91133FEDBA951177-801E
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R12000083HT
       Serial number: 6334MSME6F215A29N
       Serial number: 6344MSME6E72340AK
       Serial number: 6352QSME25135240%
       Serial number: 6362QSME4A114962F
       Serial number: 63732SME6B112154U
       Serial number: 63832SME0F124448
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20120426000786
       Coding: 000036
       VCID: 51A3045308ECA6C936-8004
       Component: E221 - MFL  H03 0003
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 981 F    HW: 8K0 920 981 F
       Component: KOMBIINSTR.   H35 0540
       Revision: 00000000    Serial number: NTH33715D
       Coding: 8B3709008B01D705020000
       VCID: 366957CF8142E1F103-8062
       Part No SW: 8R0 907 468 D    HW: 8R0 907 468 D
       Component: GW-BEM 5CAN-M H10 0025
       Revision: 1Z070014    Serial number: 1441Z124250038
       Coding: 00C303FF00
       VCID: 40853117D3865F41A9-8014
       Serial number: 6321347401
    00384 - Optical Databus
                        Reset counter: 217
                        Mileage: 181978 km
                        Date: 2016.09.20
                        Time: 02:01:17
                        Bin. Bits:    11111
                        Voltage: 13.20 V
                        Count: 6
                        Bin. Bits:    00000
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H13 0100
       Serial number: 002604120001018
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F6762AB7618D03940-807A
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000028708322
       Coding: 00581B00000000000000
       VCID: 3B7F46FBBA603C99FC-806E
    Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
       Part No SW: 8T0 907 566 A    HW: 8T0 907 566
       Component: SWA Master    H16 0040
       Serial number: 0175703770
       Coding: 010211
       Shop #: WSC 06324 000 00000
       VCID: 3E794FEFA17229B1DB-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
       Component: SWA Slave  H16 0040
       Serial number: 0165651631
       Coding: 010211
       Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
       Component: TSG FA        H09 0302
       Coding: 011C13204E00410001
       VCID: 4D9B182314D4822952-8018
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0018522177
       Coding: 100000010001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 346D6DC79F3EF3E13D-8060
       Revision: 00002001    Serial number: 0176190280
       Coding: 0106023A00FA400580B0013200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000515591
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS050  H08 0043
    03177 - Relay for Power Outlets (J807)
                        Fault Status: 00101011
                        Reset counter: 2
                        Mileage: 181978 km
                        Date: 2016.09.20
                        Time: 06:02:24
    Address 47: Sound System
       Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
       Component: TSG BF        H09 0302
       VCID: 4C9D1527EFCE8B2145-8018
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 00000000053834
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 366957CF8942E1F103-8062
    Address 56: Radio
       Part No SW: 8T0 959 795 H    HW: 8T0 959 795 H
       Component: TSG HL        H07 0302
       Coding: 010C13204000210001
       VCID: 50A5015703E6AFC139-8004
       Part No SW: 8T0 907 441 D    HW: 8T0 907 441 D
       Component: J772__Rearview      0140
       Revision: --H06---    Serial number: 525PA8-J2290OW
       Coding: 1000006
       VCID: 39735CF3705C0E89EE-806C
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Component: TSG HR        H07 0302
                        Reset counter: 218
                        Mileage: 181978 km
                        Date: 2016.09.20
                        Time: 03:04:13
       Part No SW: 8K0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 120418200653
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
       VCID: 72E1ABDFA5AABDD1EF-8026
    End---------------------(Elapsed Time: 03:45, udsna)-----------------------
    I doubt your MMI problem is due to a bad J519, and certainly not due the faults in the ECU. More likely one of the modules on the MOST ring. Have you run Optical Bus Diagnostics?
    New User
    Apr 2017
    Yes, thank you and it was a bad fuse in the trunk. Optical test was showing failure at the radio. Now I have cleared up all the MM issues, I need to figure out what this one is :
    P199E 00 [045] - Open Circuit
    Thank you
    Quote Originally Posted by timkl25 View Post
    Thank you
    Are the other two electrical engine faults also still present?
    New User
    Apr 2017
    There is one other one, O2 sensor with Open Circuit. I was planning on replacing it tonight and will report back
