Results 1 to 5 of 5
Thread: Just joined the collective!
    Oct 2016
    Hi all,
    Just bought myself a VCDS for home use, and wondered if the vehicle records how many times it has been accessed via VCDS?
    Reason being, is that it's a new vehicle and I don't want the dealer to find any kind of excuse not to deal with any warranty issues.
    Cheers!
    Verified VCDS User GaryM's Avatar
    Nov 2014
    Oxford, UK
    No, they won't know that you've been connecting VCDS to your car unless you tell them. The only thing you need to be aware of is that some setting changes require a WSC to be entered for the change to take effect, so if you enter a fictitious code then someone could possibly work out you did that but believe me, the dealers don't have the time to bother with that.
    In fact, having VCDS while your car is under warranty is an advantage because you can find out when the dealer has been lying to you or to make sure they haven't updated control module software on your car when you've told them not to.
    One thing I will say is that while VCDS does keep logs of what you do, it is always a wise move to do and save a full Auto-Scan and/or take a full backup of the adaptation map(s) of any controllers you are messing with BEFORE you start making any changes.
  3. Likes Uwe, jasons6930 liked this post
    Oct 2016
    Hi Gary and thanks for the info.
    What's a WSC?
    Nov 2014
    Oxford, UK
    Quote Originally Posted by jasons6930 View Post
    What's a WSC?
    Work Shop Code
  6. Likes Uwe, jasons6930 liked this post
    Oct 2016
    Thanks again Gary.
    I would 'like' your posts but i don't know how to!
    EDIT: just found it.
