Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: VCDS Beta 17.4.0 - A Speed Leap
    Jun 2016
    And this 17.1.3.
    SW:5G0-920-871   HW:5G0-920-871 ---  Instruments
    Component:KOMBI         353 2200,
    Coding:07BD0A002390000800087A00040000
    EV_DashBoardVDDMQBAB,008031
    EV_DashBoardVDDMQBAB_008_VW37.rod
    Friday,07,April,2017,22:14:43:42750
    VCDS Version: Release 17.1.3 (x64)  Data version: 20170320 DS267.7
    VCID: 67F2E1F49ECB2A7948-8032
    IDE00295-Oil temperature display,On
    IDE00301-Distance,53722 km
    IDE00342-ESI: Resetting ESI,no warning
    IDE00343-Language version,Dutch
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset
    IDE00345-ENG17917-MFA3-Reset-MFA3-Reset_automatic_electric,MFA3-Reset
    IDE00499-Display correction of consumptions and operating range,100 %
    IDE00500-Hour,22 H
    IDE00501-Minute,15 min
    IDE00502-Year,2017 yr
    IDE00503-Month,4 mon
    IDE00504-Day,7 d
    IDE00510-ESI: distance driven from inspection,6367 km
    IDE00511-ESI: time from inspection,273 d
    IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
    IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
    IDE00514-ESI: maximum value of time between inspections,730 d
    IDE00515-ESI: oil quality,good oil quality
    IDE00517-ESI: soot entry,0 km
    IDE00518-ESI: thermal load,10700 km
    IDE00711-Trip recorder,not installed
    IDE00819-Day counter,1617 d
    IDE00820-Activating and deactivating all development messages,not active
    IDE00827-ESI: minimum value of time between inspections,365 d
    IDE01153-SIA: maximum value of distance to service,15000 km
    IDE01154-SIA: maximum value of time to service,365 d
    IDE02489-Display depiction,Version 1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l
    IDE03329-Driving profiled for range remaining,7.9 l/100km
    IDE03346-IDE00301-Units adjusted-Distance,Kilometers
    IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
    IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour
    IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius
    IDE03346-MAS02957-Units adjusted-Time,24h
    IDE03346-MAS03032-Units adjusted-Volume,Liter
    IDE03346-MAS03034-Units adjusted-Pressure,bar
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km
    IDE03348-MAS01456-Speed warning-Speed,150
    IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour
    IDE03348-IDE03348-Speed warning-,not active
    IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,6300 km
    IDE03352-FIX: Time since last time-dependent inspection,273 d
    IDE03372-Source for synchronization of time,internal clock
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
    IDE03867-Deactivate seat belt warning,No
    IDE04169-Display correction of consumption and operating range: gas,100 %
    IDE05930-Service notification in days,20 d
    IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km
    IDE05932-FIX: Reset value for next time-dependent inspections,365 d
    IDE05971-Vehicle Positioning System Interface Control Module,not installed
    IDE06425-Roller test bench mode: functional,not activated
    IDE06588-Ignition active message: actuator,Driver door
    IDE06922-No-voltage display,Display
    IDE07221-Cylinder shut-off,Display
    IDE08140-Driving profiled for range remaining CNG,8.0
    IDE08247-Driving profile for range remaining LPG,8.0 l/100km
    MAS03555-Lap counter,Display
    MAS03685-Digital speedometer,Display
    ENG117917-BAP_Debug_Mode_Release,not_released
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF
    ENG119875-defuel_threshold,45 l
    ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
    ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14
    ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
    ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
    ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32
    ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96
    ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,17
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,32
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,46
    ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
    ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,08
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,20
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55
    ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64
    ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
    ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96
    ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32
    ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
    ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
    ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
    ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
    ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
    ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
    ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
    ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
    ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96
    ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E
    ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
    ENG119874-Gas_functionality,not active
    ENG125906-Illumination_algorithm,terminal_58xd_log_bus_parkinglight
    ENG119882-init_fuel_algorithm,No
    ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 C
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 C
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 C
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
    ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h
    ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min
    ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 C
    ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0
    ENG119825-Picture_Upload_Download,not active
    ENG119876-Service_Key_Clear_All_Counter,Yes
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s
    ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.60
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00
    ENG112418-ENG112412-total_range_gas-consumption_factor,0.000
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN
    ENG112418-ENG99298-total_range_gas-State,active
  2. Likes Uwe liked this post
  3. #12
    Jun 2016
    And this 17.4.1 BETA.
    Coding:07BD0A002390000800087A00140000
    EV_DashBoardVDDMQBAB,008031,
    Wednesday,03,May,2017,06:06:47:42750
    VCDS Version: Beta 17.4.1 (x64)  Data version: 20170413 DS270.4
    VCID: 67F2E1F49ECB2A7FA1-8032
    IDE00295-Oil temperature display,On ,1
    IDE00301-Distance,54140 km,3
    IDE00342-ESI: Resetting ESI,no warning ,1
    IDE00343-Language version,Dutch ,1
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
    IDE00345-ENG17917-MFA3-Reset-MFA3-Reset_automatic_electric,MFA3-Reset ,3
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,6 H,1
    IDE00501-Minute,7 min,1
    IDE00502-Year,2017 yr,2
    IDE00503-Month,5 mon,1
    IDE00504-Day,3 d,1
    IDE00510-ESI: distance driven from inspection,6785 km,3
    IDE00511-ESI: time from inspection,299 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
    IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
    IDE00514-ESI: maximum value of time between inspections,730 d,2
    IDE00515-ESI: oil quality,good oil quality ,1
    IDE00517-ESI: soot entry,0 km,2
    IDE00518-ESI: thermal load,11400 km,2
    IDE00711-Tachograph,not installed ,1
    IDE00819-Day counter,1642 d,2
    IDE00827-ESI: minimum value of time between inspections,365 d,2
    IDE01153-SIA: maximum value of distance to service,15000 km,2
    IDE01154-SIA: maximum value of time to service,365 d,2
    IDE02489-Display depiction,Version 1 ,1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
    IDE03329-Driving profiled for range remaining,6.3 l/100km,2
    IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
    IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
    IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
    IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
    IDE03346-MAS02957-Units adjusted-Time,24h ,3
    IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
    IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
    IDE03348-MAS01456-Speed warning-Speed,200 ,2
    IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
    IDE03348-IDE03348-Speed warning-,not active ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,6700 km,2
    IDE03352-FIX: Time since last time-dependent inspection,299 d,2
    IDE03372-Source for synchronization of time,internal clock ,1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
    IDE03867-Deactivate seat belt warning,No ,1
    IDE04169-Display correction of consumption and operating range: gas,100 %,1
    IDE05930-Service notification in days,20 d,1
    IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
    IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
    IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
    IDE06588-Ignition active message: actuator,Driver door ,1
    IDE06922-No-voltage display,Display ,1
    IDE07221-Cylinder shut-off,Display ,1
    IDE08140-Driving profiled for range remaining CNG,8.0 ,2
    IDE08247-Driving profile for range remaining LPG,8.0 l/100km,2
    MAS03555-Lap counter,Display ,1
    MAS03685-Digital speedometer,Display ,1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
    ENG119875-defuel_threshold,45 l,1
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,17 ,12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,32 ,12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,46 ,12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,08 ,12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,20 ,12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12 ,12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
    ENG119874-Gas_functionality,not active ,1
    ENG125906-Illumination_algorithm,terminal_58xd_log_bus_parkinglight ,1
    ENG119882-init_fuel_algorithm,No ,1
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 C,16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 C,16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 C,16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 C,16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
    ENG119876-Service_Key_Clear_All_Counter,Yes ,1
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 ,18
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.60 ,18
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
    ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
    ENG112418-ENG99298-total_range_gas-State,active ,4
  4. Likes Uwe liked this post
  5. #13
    I think the difference is the more version-specific data we are using since about 16.8.1.
    Is this really a CNG vehicle? And is the cluster the correct one for it?
    Ceterum censeo, delenda est Daesh.
  6. #14
    Jun 2016
    Hello Uwe,
    My car is not a CNG car, maybe the cluster wont be the right one because the fault on the instrument cluster.
    When it was a CNG car the valeu always change when driving.
    But is it not possible that Ross Tech is forgetten to add this o the never version data!!
    Because i time ago i have olso see the missing valeu.
    Interesting.
    "ENG125906-Illumination_algorithm" in your video shows the options that the data I have should be for "ENG125906-ENG125912 Illumination_algorithm - Pointer_illumination_algorithim".
    "Illumination_algorithm - Scale_switching_algorithm" does seem to have existed in some older data versions, specifically the ones that did not take the ASAM Dataset Revision into account, but I can't find it in the current one that does. The implication is that it is not defined in the factory data for your revision.
    Olso this valeu was on the 15.7.4 and after update vcds to newer version its gone again.
  7. #15
    If your car is not a CNG car, what do you want with a CNG consumption profile?
    I'm going to suggest what you're looking for is:
    ... which is present in the newer data sets.
  8. #16
    Jun 2016
    Hello UWE,
    I think you have not understand it good.
    I dont need the Profile.
    I Only suggest that the kg/100 km are missing on the tekst IDE08140-Driving profiled for range remaining CNG.
    15.7.4 are this present and after this no more.
