Results 1 to 10 of 16
Thread: VCDS Beta 17.4.0 - A Speed Leap
    Jan 2017
    Im impressed with the speed of recording (Advanced Measuring Values) using new Group UDS request feature in your VCDS Beta 17.4.0 . To make most of it, would like to hear a few words about implementation or restrictions because not all selectable settings doesnt seem to work stable . Anyways, the setting 8 seems to work for me perfectly. Setting 11 was somehow unstable. I did a couple of long runs, more than 5 hours without any glitches. Thank you very much!!
    But now I have a wish. Can we now use the speed to add the number of recorded parameters?
    As I am working on my new engine loaded with tens of sensors and actuators, current limitation of 12 recorded measuring values doesnt allow me to record all interesting stuff at once. The 12 values have been very nice, giving sample rate of about one set (12 values)/second and, I have been very pleased with that.
    Now with your new tool I received the same 12 sample set more than five times in a second.
    I would be happy to get a big bunch of samples "only" once a second, so could we now do 60 measuring values/second? Or perhaps only 50? 40?
    I understand that bigger number of parameters would hit limitations of VCScope but benefits of having capability to record more different values would definitely overcome that downside.
    Anyways, I have been very satisfied with your product but because you revealed that there might be potential for even more I look forward to new upgrades.
  2. Likes jyoung8607, Uwe liked this post
  3. #2
    Jan 2017
    Just an update. Group UDS requests settings split, 9, 10 and 11 do not work for me. Setting 7 and 8 - perfect. Tested with engine CXFA.
    And, thanks for including engine CXEB.
  4. Likes Andy, Boki Ar, Uwe liked this post
  5. #3
    Jan 2017
    I recently tested the new setting - but I did not understand it - what does "split" mean?
    The only option, which was working is split by 8. This way it was possible to turbo-log more than 8 values.
    And I have to say, that the time stamp in/before every column is ab bit annoying, because when the values are grouped - the time stamp is always the same.
    This just eats space and reduce the overview - could you please remove them?
  6. #4
    Quote Originally Posted by Blackfrosch View Post
    Instead of grouping the values into one group, you can split them into two groups. This is still somewhat slower than a single group, but certainly faster than reading them one at a time.
    Most modules only allow 8 items in a group, but a few allow more, so automatically splitting at 8 is not an optimal solution for all modules.
    If you're logging enough values where splitting makes sense, the time stamps on a row should not all be the same; they should give an indication when each group was received. I suppose we could have just two time stamps, one for each group, but having a time-stamp column appear in a somewhat arbitrary location (depending on where the split is) would make it a pain to parse the file.
  7. Likes Blackfrosch, VWT6 liked this post
  8. #5
    Jan 2017
    I think that the data format is just perfect as it is now. And yes, parsing the data is now extremely simple because each data value comes with time stamp of its own- no need to use any brainpower when you move/import/export data of recordings - just grab pair of "columns".
    Especially useful these individual time stamps will be as soon as VCDS will allow us record some 60+ measuring values - please! .
    So, let's stick with the current format - it's only about 3MB/hour = really nothing on today's computers.
  9. Likes Uwe liked this post
  10. #6
    Jun 2014
    Poland
    also happy , working muuuuuch faster
    HOT HOT HOT VW Touran 2005 CCS via MFSW HOT HOT HOT
  11. Likes Uwe liked this post
  12. #7
    Oct 2016
    Any news on when this software update will be in general release?
  13. #8
    Jun 2016
    I have notice after upgrading from 15.7 version to the never version vcds the valeu dont show kg/100 km even not the beta.
    IDE08140-Driving profiled for range remaining CNG,8.0 ( ????? )
    On the 15.7 was this valeu Driving profiled for range remaining CNG,8.0 kg/100 km.
  14. #9
    Quote Originally Posted by barstanders View Post
    With a UDS module like that, we would need to see a scan from the version that had it and a scan from a version that doesn't in order to investigate why the data is not in there anymore.
  15. #10
    Jun 2016
    Hello Uwe,
    this is the 15.7.4 version.
    SW:5G0-920-871   HW:5G0-920-871 ---  Instruments
    Component:KOMBI         353 2200
    Coding:07A50A002390000800086E00040000
    EV_DashBoardVDDMQBAB,008031
    EV_DashBoardVDDMQBAB_AU37.rod
    Friday,10,June,2016,09:22:56:42750
    VCDS Version: Release 15.7.4  Data version: 20160216
    VCID: 67F2E1F49ECB2A06DF-8032
    Activating and deactivating all development messages,not active
    Cylinder shut-off,Display
    Day,10 d
    Day counter,1318 d
    Deactivate seat belt warning,No
    Digital speedometer,Display
    Display correction of consumption and operating range	 gas,100 %
    Display correction of consumptions and operating range,100 %
    Display depiction,Version 1
    Distance,46484 km
    Driving profile for range remaining LPG,8.0 l/100km
    Driving profiled for range remaining,7.5 l/100km
    ESI: distance driven from inspection,8612 km
    ESI: maximum value km-driving distance/inspection,30000 km
    ESI: maximum value of time between inspections,730 d
    ESI: minimum value km-driving distance/inspection,15000 km
    ESI: minimum value of time between inspections,365 d
    ESI: oil quality,good oil quality
    ESI: Resetting ESI,no warning
    ESI: soot entry,0 km
    ESI: thermal load,12700 km
    ESI: time from inspection,225 d
    FIX: Distance covered since last mileage-dependent inspection,8500 km
    FIX: Max. distance until next mileage-related inspection,30000 km
    FIX: Maximum time until next time-dependent inspection,365 d
    FIX: Reset value for next mileage-dependent inspection,32200 km
    FIX: Reset value for next mileage-dependent inspections,365 d
    FIX: Time since last time-dependent inspection,225 d
    Hour,9 H
    Ignition active message	 actuator,Driver door
    Language version,Dutch
    (1)-MFA3-Reset-MFI button RESET / OK,Manual reset	 not possible
    (2)-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
    (3)-MFA3-Reset-Refuel detection gas,MFA3-Reset
    (4)-MFA3-Reset-Nachtankerkennung Elektro,No automatic reset
    Minute,22 min
    Month,6 mon
    No-voltage display,No display
    (1)-Offset for tank calibration values-Offset sensor 1,-12.8 l
    (2)-Offset for tank calibration values-Offset sensor 2,12.7 l
    (3)-Offset for tank calibration values-Offset sensor 3,12.7 l
    (4)-Offset for tank calibration values-Offset sensor 4,12.7 l
    (5)-Offset for tank calibration values-Complete tank calibration,-12.8 l
    Oil temperature display,On
    Roller test bench mode	 functional,not activated
    Service notification in days,20 d
    (1)-Service-key settings-p_write_delay_time,40 s
    (2)-Service-key settings-p_write_delay_speed,20 km/h
    (3)-Service-key settings-p_write_distance,20 km
    (4)-Service-key settings-p_forcewrite_qual_time,10 s
    (5)-Service-key settings-p_main_switch_keyless,On
    (6)-Service-key settings-p_main_switch_Basic,On
    (7)-Service-key settings-p_deactivate_SK_Function,On
    SIA: maximum value of distance to service,15000 km
    SIA: maximum value of time to service,365 d
    Source for synchronization of time,internal clock
    (1)-Speed warning-,active
    (2)-Speed warning-Unit,Kilometers per hour
    (3)-Speed warning-Speed,200
    Trip recorder,not installed
    (1)-Units adjusted-Temperature,Degrees Celsius
    (2)-Units adjusted-Distance,Kilometers
    (3)-Units adjusted-Speed,Kilometers per hour
    (4)-Units adjusted-Pressure,bar
    (5)-Units adjusted-Volume,Liter
    (6)-Units adjusted-Time,24h
    (7)-Units adjusted-Date,dd_mm_yy
    (8)-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
    (9)-Units adjusted-Operating range consumption	 CNG (compressed natural gas),kg per 100 km
    (10)-Units adjusted-Average consumption	 electric drive,kWh per 100 km
    Vehicle Positioning System Interface Control Module,not installed
    Year,2016 yr
    (1)-Total operating range gas-State,active
    (2)-Total operating range gas-selection_consumption_factor,consumption_factor_CAN
    (3)-Total operating range gas-consumption_profile,consumption_profile_calculation
    (4)-Total operating range gas-consumption_factor,0.000
    BAP_Debug_Mode_Release,not_released
    (1)-Configuration of Development CAN-Messages-Block 1,OFF
    (2)-Configuration of Development CAN-Messages-Block 2,OFF
    (3)-Configuration of Development CAN-Messages-Block 3,OFF
    (4)-Configuration of Development CAN-Messages-Block 4,OFF
    (5)-Configuration of Development CAN-Messages-Block 5,OFF
    (6)-Configuration of Development CAN-Messages-Block 6,OFF
    (7)-Configuration of Development CAN-Messages-Block 7,OFF
    (8)-Configuration of Development CAN-Messages-Block 8,OFF
    (9)-Configuration of Development CAN-Messages-Block 9,OFF
    (10)-Configuration of Development CAN-Messages-Block 10,OFF
    (11)-Configuration of Development CAN-Messages-Block 11,OFF
    (12)-Configuration of Development CAN-Messages-Block 12,OFF
    (13)-Configuration of Development CAN-Messages-Block 13,OFF
    (14)-Configuration of Development CAN-Messages-Block 14,OFF
    (15)-Configuration of Development CAN-Messages-Block 15,OFF
    (16)-Configuration of Development CAN-Messages-Block 16,OFF
    (17)-Configuration of Development CAN-Messages-Block 17,OFF
    (18)-Configuration of Development CAN-Messages-Block 18,OFF
    (19)-Configuration of Development CAN-Messages-Block 19,OFF
    (20)-Configuration of Development CAN-Messages-Block 20,OFF
    (21)-Configuration of Development CAN-Messages-Block 21,OFF
    (22)-Configuration of Development CAN-Messages-Block 22,OFF
    (23)-Configuration of Development CAN-Messages-Block 23,OFF
    (24)-Configuration of Development CAN-Messages-Block 24,OFF
    (25)-Configuration of Development CAN-Messages-Block 25,OFF
    (26)-Configuration of Development CAN-Messages-Block 26,OFF
    (27)-Configuration of Development CAN-Messages-Block 27,OFF
    (28)-Configuration of Development CAN-Messages-Block 28,OFF
    (29)-Configuration of Development CAN-Messages-Block 29,OFF
    (30)-Configuration of Development CAN-Messages-Block 30,OFF
    (31)-Configuration of Development CAN-Messages-Block 31,OFF
    (32)-Configuration of Development CAN-Messages-Block 32,OFF
    (33)-Configuration of Development CAN-Messages-Block 33,OFF
    (34)-Configuration of Development CAN-Messages-Block 34,OFF
    (35)-Configuration of Development CAN-Messages-Block 35,OFF
    (36)-Configuration of Development CAN-Messages-Block 36,OFF
    (37)-Configuration of Development CAN-Messages-Block 37,OFF
    (38)-Configuration of Development CAN-Messages-Block 38,OFF
    (39)-Configuration of Development CAN-Messages-Block 39,OFF
    defuel_threshold,45 l
    (1)-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
    (2)-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
    (3)-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32
    (4)-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
    (5)-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66
    (6)-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
    (7)-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
    (8)-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05
    (9)-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
    (10)-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14
    (11)-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
    (12)-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
    (1)-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
    (2)-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02
    (3)-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
    (4)-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02
    (5)-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32
    (6)-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,17
    (7)-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64
    (8)-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,32
    (9)-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96
    (10)-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,46
    (11)-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
    (12)-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
    (1)-dimming_characteristic_curve_adjustment_gauge-X1,00
    (2)-dimming_characteristic_curve_adjustment_gauge-Y1,03
    (3)-dimming_characteristic_curve_adjustment_gauge-X2,0A
    (4)-dimming_characteristic_curve_adjustment_gauge-Y2,03
    (5)-dimming_characteristic_curve_adjustment_gauge-X3,32
    (6)-dimming_characteristic_curve_adjustment_gauge-Y3,08
    (7)-dimming_characteristic_curve_adjustment_gauge-X4,64
    (8)-dimming_characteristic_curve_adjustment_gauge-Y4,20
    (9)-dimming_characteristic_curve_adjustment_gauge-X5,DC
    (10)-dimming_characteristic_curve_adjustment_gauge-Y5,55
    (11)-dimming_characteristic_curve_adjustment_gauge-X6,FD
    (12)-dimming_characteristic_curve_adjustment_gauge-Y6,64
    (1)-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
    (2)-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05
    (3)-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
    (4)-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05
    (5)-dimming_characteristic_curve_adjustment_indicator_lights-X3,32
    (6)-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C
    (7)-dimming_characteristic_curve_adjustment_indicator_lights-X4,64
    (8)-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17
    (9)-dimming_characteristic_curve_adjustment_indicator_lights-X5,96
    (10)-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32
    (11)-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
    (12)-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
    (1)-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
    (2)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
    (3)-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
    (4)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E
    (5)-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
    (6)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41
    (7)-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
    (8)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
    (9)-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
    (10)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
    (1)-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
    (2)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01
    (3)-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
    (4)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01
    (5)-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32
    (6)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07
    (7)-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64
    (8)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12
    (9)-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96
    (10)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E
    (11)-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
    (12)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
    Gas_functionality,not active
    (1)-Illumination_algorithm-Scale_switching_algorithm,parking_light
    (2)-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight
    init_fuel_algorithm,No
    (1)-outside_temperature-p_time_constant_pt1,40 s
    (2)-outside_temperature-p_time_constant_slow_damping,2.0
    (3)-outside_temperature-P_speed_threshold,20 km/h
    (4)-outside_temperature-p_tendency_threshold,1.0 C
    (5)-outside_temperature-p_kmt_at_delta,25 C
    (6)-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
    (7)-outside_temperature-p_storage_time_engine_off,180 min
    (8)-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
    (9)-outside_temperature-p_ice_warning_exit_temperature,6 C
    (10)-outside_temperature-p_ice_warning_entry_temperature,4 C
    (11)-outside_temperature-p_tendency_damping,15 s
    Picture_Upload_Download,not active
    Service_Key_Clear_All_Counter,Yes
    (1)-time_parameter_display-tDDWUP,0.0
    (2)-time_parameter_display-tDD15_on,0.0
    (3)-time_parameter_display-tDD15_off,0.6
    (4)-time_parameter_display-hmi_t_Dreiter_ms,2.0
    (5)-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
    (6)-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
    (7)-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
    (8)-time_parameter_display-hmi_t_TWSAnz_ms,3 s
    (9)-time_parameter_display-hmi_t_NextWarning_ms,6 s
    (10)-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
    (11)-time_parameter_display-hmi_t_P1Pause_ms,20 s
    (12)-time_parameter_display-hmi_t_P2Pause_ms,900 s
    (13)-time_parameter_display-hmi_t_Quit_ms,10 s
    (14)-time_parameter_display-hmi_t_FondGurt,30 s
    (15)-time_parameter_display-hmi_t_USZ,0.20 s
    (16)-time_parameter_display-hmi_t_FTuerAUF,300 ms
    (17)-time_parameter_display-rollierblockgroesse,3
  16. Likes Uwe liked this post
