I have retrofitted a genuine factory towbar and dedicated wiring kit to my A6.
The parts were bought from my local Audi Main Dealer and I was reasonably confident because this is something that I have done to both my B6 Passat and my dads VW Golf.
However, the A6 has a lever in the boot to operate the swivel towbar mechanism and an indicator light on the bracket that shows whether the ball is locked into place.
The problem is I cant get the indicator light on the bracket to work at all.
I have tested all the lights with a trailer board and the trailer board is functioning properly and I have also tested the parking sensors and they are correctly disabled when I attach the trailer light board and I even get a picture of a trailer on the MMI display. So on the whole everything is working as it should.
I just cant get the status light on the handle in the boot to work though. I am sure there was an option in the coding somewhere to tell the car it had a lever mechanical swivel towbar when I looked in the past, but I cant for the life of me find it now?....
Any thoughts?
Auto scan posted below for reference.
Any thoughts?
Sunday,16,April,2017,09:52:41:40467
VCDS Version: 17.1.3.0 (x64)
VIN: WAUZZZ4G4HN002211 License Plate:
Chassis Type: 4G (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 47 52 53
55 5F 62 69 6D 72 AC
VIN: WAUZZZ4G4HN002211 Mileage: 11686km-7261miles
Address 01: Engine (J623-CNHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 BP HW: 04L 907 309
Component: R4 2,0L EDC H23 1661
Revision: 85H23---
Coding: 12254012243601080000
Shop #: WSC 01236 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021BP 002006
ROD: EV_ECM20TDI01104L906021BP.rod
VCID: 74E19366DF253CE1FD-8020
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G0 927 166 N HW: 0B5 927 156 K
Component: 0B5 20 TDIRdW H03 0003
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021_VW51.rod
VCID: 3879675683CD988111-806C
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A69E41606579829B00
ROD: EV_ESP9BOSCHAU57X_VW51.rod
VCID: 418F0AB2D017D949A6-8014
Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
Component: BCM2 2.0 H61 0824
Coding: 01B9704E000000000000
VCID: 7CF1BB46FF7574A1B5-8028
Serial number: 3216000098481006
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 12051600040490
Coding: 34220978210000
VCID: 63C3E03A6ACBAB5994-8036
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 15020001 Serial number: 00001358348101
Coding: 0105001440349FE041014083800018000F9DC7082F08020100000894E100150200400024030000
VCID: 74E19366D7253CE1FD-8020
Component: WWS57X 160329 H38 0080
Serial number: 160404103927
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 61803318
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 14 05 2016 00001080
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0005
Serial number: 0BD8872800PAG0MUFU01
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1009VMY$
Coding: 30333130313630323639554A305234473053
VCID: 3B73785AB2FBB399FC-806E
Serial number: 3575HRB405H436HU60FA
Serial number: 3585HRB4055436HU88NH
Serial number: 3515JRB40593V4GO99U0
Serial number: 3525JRB405N3VEM880N+
Serial number: 3554VRB400E570C0PH1%
Serial number: 3564VRB400E571N8E0NE
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862PEC000HL
Coding: 000035
VCID: 3B73785ABAFBB399FC-806E
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 06 05 2016 D0014290
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 951 E HW: 4G8 920 951 E
Component: MDieGb H43 0604
Revision: 30450307 Serial number: 658120516592018
Coding: 33A715000B412600010000
ASAM Dataset: EV_RBC7KMID 004050
ROD: EV_RBC7KMID.rod
VCID: 326D557E65B172D12F-8066
Part No SW: 4G5 907 468 H HW: 4G0 907 468 AC
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002249889
Coding: C0CD074418
ROD: EV_GatewPkoUDS_002.rod
VCID: 3A7D7D5EBDC18A91E7-806E
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 3471590204
Voltage stabilizer:
6151 - Instrument Cluster Control Module on Optical Bus
U10C0 00 [009] - No Communication
Reset counter: 44
Mileage: 11686 km
Date: 2017.04.16
Time: 09:48:25
Voltage terminal 30: 11.4 V
Voltage terminal 15: 11.3 V
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 67DBF42A96F3C77948-8032
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 19051600040548
Coding: 22
VCID: 3D777642ACEFBDA9C2-8068
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000198819899
VCID: 77FBA46AC65357F9D8-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720R84XW
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_VW51.rod
VCID: 3363507A9AAB7BD924-8066
Component: TSG FA H03 0511
Coding: 011C16015E01620002080002
VCID: 479B14AAF633E77968-8012
Address 44: Steering Assist (J500) Labels: 4G0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000002 Serial number: 0000811314
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0404591033
Coding: 013F0622A0B93080C320098420010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Serial number: 0000000AP00020475043
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000192195
Coding: 030000
VCID: 1D3796C2042FDDA9E2-8048
Component: TSG BF H03 0511
VCID: 468519AEF139FE7193-8012
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001845044
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_AU57.rod
VCID: 316F5A7260B749C956-8064
Address 55: Headlight Range (J745) Labels: 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FE02102A600200
VCID: 346153669FA57CE13D-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Part No SW: 4G1 035 192 F HW: 4G1 035 192 A
Component: RMC Nav Plus H62 0186
Coding: 010101010141DB47082B060301020100000000
VCID: 2645B92E51791E71B3-8072
Subsystem 1 - Part No: 8X0 919 884 J
Component: P32-50-15.03 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464D80G2759928
Subsystem 3 - Part No SW: 4G2 919 610 E HW: 4G2 919 610 E
Serial number: 90349PEH0000V
Component: TSG HL H03 0511
VCID: 499F1292E02711097E-801C
Address 69: Trailer (J345) Labels: 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H20 0160
Revision: 7B001003 Serial number: 0403032178
Coding: 0100000202000000
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 117601500
Coding: 093205C010
ROD: EV_HDSGAu571.rod
VCID: 3665696E89D96EF103-8062
Component: TSG HR H03 0511
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 161060507
ROD: EV_RDCMA00100_008.rod
VCID: 2F6B5C0A76835F3940-807A
End-------------------------(Elapsed Time: 04:54)--------------------------
