- Joined
- Aug 1, 2014
- Messages
- 4
- Reaction score
- 0
- VCDS Serial number
- C?ID=210970
I have the following problem with coding an Audi A6 4G model, especially if the car is equip with a ACC cruise control en lane assist. I tried to code the car and all I can do is check the box in the can gateway 19 installation list module 69.
But I cannot change codes, module 03 (ESP) - module 13 (ACC Cruise control) and module 10 (PDC) .
So every time I start the car I get fail notice (ACC and BRAKE GUARD ASSISTANCE inactivated) also the PDC is still active when trailer is mounted.
When I read the manual from the trailer hitch module (cable) it refers to AVM code but that's all they refer to.
Can someone help me with this problem ? is there any knowledge about this car model concerning coding a trailer module ?
here the log autoscan Audi A6 g
Monday,28,July,2014,12:09:28:14997
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUZZZ4G1DN137687 License Plate: 1-EYH-853
Mileage: Repair Order: 28072014
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 3B 3C 42 44 46 52 53
55 56 5F 62 6D 72 85 8B 8E 8F 90
Address 01: Engine (J623-CGLE) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 QG HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 3842
Revision: 45H25---
Coding: 12034012244401080000
ASAM Dataset: EV_ECM20TDI01103L906018QG 003004
ROD: EV_ECM20TDI01103L906018QG.rod
VCID: 7F0B6D0FE6C7E9E6E2D-802A
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 4G2 927 155 C HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H05 0001
Revision: --H05--- Serial number: 0000001062
Coding: 000001
ASAM Dataset: EV_TCMVL381 A02432
ROD: EV_TCMVL381.rod
VCID: 2D5767477C2BAB76001-8078
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Coding: 06A187016085E180DB00
ROD: EV_ESPPremiAU57X.rod
VCID: 3879461383691EDE637-806D
Part No SW: 4H0 907 064 CN HW: 4H0 907 064 CN
Component: BCM2 2.0 H33 0433
Coding: 01A93046000000000000
VCID: 77FB852FC6F7D1A6AAD-8022
Part No SW: 4G0 820 043 AC HW: 4G0 820 043 AC
Component: KLIMA 2 ZONEN H11 0086
Serial number: 28031300110052
Coding: 3402000885
ASAM Dataset: EV_AirCondiBasisUDS 002044
ROD: EV_AirCondiBasisUDS.rod
VCID: 60C9CE737B79361EFB7-8035
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001537574
Coding: 2600201040749FE28181008320001D0CCF9CC7082E090201000004606101
VCID: 6ED5A04BB9AD906E79B-803B
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119
Component: WWS57X 130316 H36 0080
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Address 10: Park/Steer Assist (J791) Labels: None
Part No SW: 4H0 919 475 AB HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0060
Revision: -------- Serial number: 56231308000412
Coding: 982B07
ASAM Dataset: EV_EPHVA2CAU57X0000 002012
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 72EDB43BA595B48E9D3-8027
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X.rod
VCID: 2859965353C98E5EF37-807D
Address 15: Airbags (J234) Labels: None
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00CGMCE
Coding: 3032343631324E303131554A304C34473053
VCID: 3665482B897DE8AE71B-8063
Serial number: 3575HRB401050CQ09PUF
Serial number: 3585HRB401050FIQBOJR
Serial number: 3515JRB400O50GBONOPC
Serial number: 3525JRB400Q50GBOGQ6Y
Serial number: 3554VRB40631TJJMBOGP
Crash sensor for front airbag; passenger side:
Serial number: 3564VRB405R1RGAMNHG/
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MCR0019C
Coding: 0000DD
VCID: 377B452F867711A66AD-8062
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 932 M HW: 4G8 920 932 M
Component: TDieRdwAcc H79 0515
Revision: 28460208 Serial number: 658230313592031
Coding: 138610000F5500080D0000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 397F4317B86307D69C9-806C
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000881957
Coding: 00CD074400
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS.rod
VCID: 71EFBB37A0938F96649-8024
Serial number: 4000420203
Voltage stabilizer:
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Reset counter: 61
Mileage: 38396 km
Date: 2014.07.19
Time: 15:21:26
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02018264747464545425363E00
VCID: 7CF19A03FFD1F2FEC7F-8029
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA82033S83
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0000102
VCID: 30697E33A319C69E2B7-8065
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0050
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F28.03.1300H03000AMS14392ÿ
Subsystem 4 - Serial number: S14392ÿ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F16005C00628002080013
VCID: 45873FE7CC9B7336E81-8010
Address 44: Steering Assist (J500) Labels: None
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0017888533
Coding: 101101010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 326D743B6515F48E5D3-8067
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0303311032
Coding: 013A062020B93080832009840C010F0F0000000000000000000000000000
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: TSG BF H03 0507
Coding: 011F16005E00628002080002
VCID: 468538EBF19D782EE1B-8013
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000637131
ROD: EV_ParkiBrake_AU48.rod
VCID: 2B53695F423FA5461E5-807E
Address 55: Xenon Range (J431) Labels: None
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 130328-0002-154
Coding: 112296101002A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 056 G HW: 4G0 035 056
Component: Radio U STD H60 0121
Revision: AB001007 Serial number: 230CL0D2733603
Coding: 010003020100000001
VCID: 25479F672CDB9336C81-8070
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 666 F HW: 4G0 035 666 H
Component: H-BN-EU H50 0637
Revision: -------- Serial number: 189C+0D7537612
Coding: 050100010003E9ED3DB0CB3E00000003E80001020000000000
VCID: 2B53695F4A3FA5461E5-807E
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Component: CD-Database 4949
Component: TSG HL H03 0507
Coding: 010F14004000628002080002
VCID: 499F33D7E08397560C9-801C
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 084300725
Coding: 097205C010
ROD: EV_HDSGAu571_AU57.rod
VCID: 35674F27947BE3B6781-8060
Component: TSG HR H03 0507
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2645986B59DD982EC1B-8073
Address 8B: Adaptive Cruise 2 (J428) Labels: None
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851) Labels: 4G0-907-107.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H31 0041
Serial number: 005000120304137
Coding: 04C0B9181111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 316F7B376013CF96249-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End ---------------------------------------------------------------------
Monday,28,July,2014,12:24:44:14997
55 56 5F 62 69 6D 72 85 8B 8E 8F 90
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Revision: 45H25---
Coding: 12034012245401080000
4865 - No Communication with Towing System Control Module (J345)
U1003 00 [038] - -
Mileage: 38743 km
Date: 2014.07.28
Time: 12:14:57
Coding: 000001
Coding: 3402000885
Coding: 0045F7
Coding: 02006D
Coding: 982B07
Coding: 7E04010202
87552 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 36
Mileage: 38743 km
Date: 2014.07.28
Time: 12:17:18
Coding: 0000DD
ROD: EV_RBD4K.rod
Coding: 00CD074400
Voltage stabilizer:
5729 - No Communication with Towing System Control Module (J345)
U1003 00 [008] - -
Reset counter: 76
Mileage: 38743 km
Date: 2014.07.28
Time: 12:10:42
Revision: AA001002
Coding: 0000102
ROD: EV_RCEPS.rod
Address 69: Trailer (J345) Labels: None
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: ConWys Trailer H07 0072
Revision: 5G001002 Serial number: 00000133243642
Coding: 0100000000000000
VCID: F1EF3B3728930F96E49-80A4
Coding: 097205C010
Coding: 6A060000
Coding: 7E04010202
U1014 00 [009] - -
Reset counter: 36
Mileage: 38743 km
Date: 2014.07.28
Time: 12:17:18
ROD: EV_BC7.rod
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
