- Joined
- Jun 27, 2016
- Messages
- 22
- Reaction score
- 15
- Location
- N Wales, UK
- VCDS Serial number
- C?ID=249332
Thursday,18,May,2017,21:41:59:37770
VCDS Version: 17.1.3.0
Data version: 20170505 DS267.9
VIN: WVGZZZ7PZED055678 License Plate:
Mileage: 52116km-32383mi Repair Order:
Chassis Type: 7P (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
6D 72
VIN: WVGZZZ7PZED055678 Mileage: 52116km-32383miles
Address 01: Engine (J623-CRCA) Labels: 059-907-401-V2.clb
Part No SW: 7P0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H41 0007
Revision: 53H41---
Coding: 292A4012232601020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
ROD: EV_ECM30TDI0117P0907311C.rod
VCID: 326B55B365BCEBD12F-8066
5568 - Sensor for Ambient Air Temperature (G17)
P0073 00 [040] - Signal too High
Mileage: 50904 km
Date: 2017.04.24
Time: 10:48:33
Coolant temperature: 10 °C
Intake air temperature: 10 °C
Voltage terminal 30: 11.120 V
Unlearning counter according OBD: 19
Mean injection quantity: 0.00 mg/stroke
Control Module temperature: 20.9 °C
EGR_governor_deviation: 1036.8 mg/stroke
Inj Ctl q Curr: 0.00 mg/stroke
Standardised airflow ratio: 3.9999
Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 0.0 kg/h
Actual charge pressure: 1011 hPa
Readiness: 0 1 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 BQ HW: 0C8 927 750 BQ
Component: AL1000 AISIN 002 2530
Coding: 003568
Shop #: WSC 49881 002 1048576
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002.rod
VCID: 7CF7BB8BF778EDA1B5-8028
Address 03: ABS Brakes (J104) Labels: 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 412340010EC818
Coding: 5B6B13C309292558DAFAC89A90DAA450F700
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 4A9B2D53ED2C831177-801E
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.CLB
Part No SW: 4H0 907 064 FH HW: 4H0 907 064 EH
Component: BCM2 2.0 H36 0551
Coding: 05B60016000000000000
VCID: 74E793ABD728A5E1FD-8020
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 0214000121732004
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 246
Mileage: 50865 km
Date: 2017.04.13
Time: 11:37:25
Reset counter: 246
Mileage: 50865 km
Date: 2017.04.13
Time: 11:37:25
Address 08: Auto HVAC (J255) Labels: 7P6-907-040.clb
Part No SW: 7P6 907 040 BR HW: 7P6 907 040 BR
Component: Klima 2 Zonen H21 1306
Coding: B6A6000890
VCID: 0501DE6F84B2AC69DA-8050
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 18
Mileage: 50904 km
Date: 2017.04.24
Time: 10:48:37
Voltage terminal 30-Data: 12.0 V
Outside air temperature-Data: 77.50 °C
Engine speed-Data: 902 /min
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.CLB
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001773614
Coding: 26001010D1345D010021000300005D0C431D470807010241000000020000
VCID: 6CD78BCB8F187D2125-8038
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 140612 033 0021
Serial number: 90243401140617111403
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20352111
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 D HW: 7P6 941 431 D
Component: E1 - LDS H04 0031
Serial number: 00000000000307140169
Fault Status: 00101100
Fault Frequency: 27
Reset counter: 18
Mileage: 50904 km
Date: 2017.04.23
Time: 16:42:00
Address 10: Park/Steer Assist (J446) Labels: 7P6-919-475.clb
Part No SW: 7P6 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H05 0026
Revision: -------- Serial number: 28231417903292
Coding: 108501
ASAM Dataset: EV_VW526ParkiAssis2 001012
ROD: EV_VW526ParkiAssis2.rod
VCID: 43850077CA065259B4-8016
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Reset counter: 18
Mileage: 50904 km
Date: 2017.04.24
Time: 10:48:37
Address 15: Airbags (J234) Labels: 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag00K H10 0043
Revision: -------- Serial number: 003NK000BU45
Coding: 00000000000000000000000000000000304B
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002.rod
Serial number: 3575LRB404T2LFGMDPO$
Serial number: 3585LRB404P2L7IMC13R
Serial number: 3517ARB40592NFSGCGM1
Serial number: 3527ARB40592NFSGHP60
Serial number: 3557BRB405J2N220IP30
Serial number: 3567BRB405L2N220EQ1+
Address 16: Steering wheel (J527) Labels: 4H0-953-568.CLB
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 01335NFT000X5
Coding: 000C35
VCID: 387F679B8BC0018111-806C
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0054621 TRW 20140610
Address 17: Instruments (J285) Labels: 7P6-920-xxx-17.clb
Part No SW: 7P6 920 982 S HW: 7P6 920 982 S
Component: Kombi H13 0419
Revision: 13240270 Serial number: 658010714592058
Coding: 332731002B00260001000C
ASAM Dataset: EV_KombiUDSRBVW526 001020
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 4E9321431144AF312B-801A
16776976 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 18
Mileage: 50904 km
Date: 2017.04.24
Time: 10:48:37
Part No SW: 7P6 907 530 J HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H13 6032
Revision: -------- Serial number: 00000001456757
Coding: 000D07AD00
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 3F8D0C87A6EE36B9D0-806A
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 41178017095701471335
Voltage stabilizer:
16384 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] - -
Fault Frequency: 31
Reset counter: 35
Mileage: 50940 km
Date: 2017.05.05
Time: 18:22:41
Voltage terminal 30: 14.5 V
Voltage terminal 15: 14.5 V
Control Module temperature: 38 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Address 42: Door Elect, Driver (J386) Labels: NONE
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000108481241
Coding: 011D1620D001451005080002
VCID: 7AFBBD93F54CD391A7-802E
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.CLB
Revision: 00002001 Serial number: 0339372823
Coding: 011B1E2228B9109583200624010000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO30258451
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO30373842
Coding: 191100
02741 - Bulb for Tail Light 2; Right
Reset counter: 17
Mileage: 50904 km
Date: 2017.04.23
Time: 16:00:37
Reset counter: 17
Mileage: 50904 km
Date: 2017.04.23
Time: 16:00:37
Fault Status: 00101101
Fault Frequency: 41
Reset counter: 17
Mileage: 50904 km
Date: 2017.04.23
Time: 16:42:38
Address 52: Door Elect, Pass. (J387) Labels: NONE
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000108521191
Coding: 011D1620D001451005080000
VCID: 489F175BFB20710161-801C
Address 53: Parking Brake (J540-) Labels: 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1462700653
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 366369A389D4F7F103-8062
Slave 3:
12656790 - Databus
Reset counter: 233
Mileage: 50904 km
Date: 2017.04.24
Time: 10:48:41
Voltage: 13.2 V
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 018E00000F000200
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 U008
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
Address 56: Radio (R) Labels: REDIR FAIL!
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109AK0H2700025
Coding: 010105020100000003
Shop #: WSC 01414 002 1048576
VCID: 285FB7DB5B60910181-807C
Address 5F: Information Electr. (J794) Labels: 4E0-035-6XX-5F.CLB
Part No SW: 7P6 035 670 G HW: 7P6 035 670 A
Component: H-BNT-EU H40 0822
Revision: -------- Serial number: 444F+0F7514357
Coding: 010101050040E1ED01000B0E00000003F00401030000000000
VCID: 3979629FB0CA1889EE-806C
Subsystem 1 - Part No: 8R0 060 884 BT
Component: EUR 2014 1903
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H28 0045
Serial number: VWZ8Z9PA201B7Y
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels: NONE
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000109333725
Coding: 011814200001251005080000
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 K HW: 7P6 907 273 K
Component: RDKBERU25 H09 0009
Serial number: 10000000144383
ROD: EV_RDKBERU25_VW52.rod
VCID: 4487036BCF0855618D-8010
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 171401259
Coding: 0533314002
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
0079 - Pinch Protection Strip 2
B11DC 02 [008] - Signal Failure
Reset counter: 18
Mileage: 50904 km
Date: 2017.04.25
Time: 12:27:23
12.38 V
Address 72: Door, Rear Right (J389) Labels: NONE
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000109345908
End---------------------(Elapsed Time: 12:52, Deb=2)-----------------------
Regards,
Mel
