there is "replacement dpf option" on VCDS? + picture
yaron1245
New Member
Israel
i have garage, and i work with VAG cars.
usually the DPF ( disel particular filter ) was clogged. so i clean it, and later use with software to "reset DPF" ( without regeneration ) .
its not "REGENERATION"
its reset dpf ( after manual reneneration, with Special machine)
my qustion is: if you have this option on VCDS?
thanks.
("replacement of dpf" ) is as the picture.
VCDS gives you access to the actual functions needed to do that, but exactly how it's done varies by engine type (and by the protocols the ECU uses).
yaron1245
New Member
Israel
Hello
I asked about renewal, because last week I got a car of the type:
Vw Touareg, 3.0 Diesel BKS engine, year: 2006- 2007.(the first year with DPF ).
I've cleaned the particle filter. I did not have any options to replace the filter particles.
(I work with 3 different types of diagnostics).
I had to go to the company to reset the problem, and set up a replacement.
Is it possible to define a particle filter replacement in this model? Thank you
Dana
Western PA, USA
Yes, it should be possible in that BKS with VCDS. Please check the Scans folder on that PC (C:\Ross-Tech\VCDS\Scans) and post the Auto-Scan if you have one saved so we can see which controller was installed.
If you don't have a scan from this vehicle make sure to run/save one from the next vehicle you have a procedural question about so it can be posted with the inquiry.
Since this is posted in Pre-Sales Support, I'm supposing the OP doesn't have VCDS yet...
