DAMPING SUSPENSION BASIC SETTING
jawad
UAE
C?ID=261487
HI , I HAVE GOLF R 2016 WITH DAMPING SHOCKS AND I NEED TO DO BASIC SETTING BUT I DO NOT KNOW THE SECURITY ACCESS NUMBER , WOULD YOU PLEASE HELP ME WITH IT. THANKS.
Monday,19,June,2017,04:56:39:47987
VIN: WVWGR2AU1GW001019   License Plate: GOLF R DAMPING SUSPENSION
Mileage: 28701km-17833mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN: WVWGR2AU1GW001019   Mileage: 28701km-17833miles
Address 01: Engine (J623-CJXB)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0006
   Revision: --H13---
   Coding: 091D00322426050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259E 001006
   ROD: EV_ECM20TFS0205G0906259E.rod
   VCID: 306F4F116B9820C159-8064
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4522
   Revision: 03253104    Serial number: TFK01501272818
   ROD: EV_TCMDQ250021.rod
   VCID: 1F4DBCAD0606AFB9F0-804A
7 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21154 - Gear 2
          P072D 00 [002] - Not Selectable
21155 - Gear 3
          P072E 00 [002] - Not Selectable
21156 - Gear 4
          P072F 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 61015000005072
   Coding: 01FA6BA15420296D0777070141CC6980D62A94E0E08296F7004200B8C208
   VCID: 489F07F1F308880161-801C
   Revision: 00021000    Serial number: 0365108064
   Coding: 030C0C
   VCID: 3A7B6D39BDE4EA91E7-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020014200100001005000012101400
   VCID: 6ADB9D798DC49A1157-803E
459015 - Databus
                    Reset counter: 65
                    Mileage: 28694 km
                    Date: 2017.06.15
                    Time: 13:27:38
459526 - Databus
                    Reset counter: 105
                    Mileage: 28694 km
                    Date: 2017.06.15
                    Time: 13:27:44
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011511001758
   Coding: 00111A46C24122F30BA44080B10C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 000FDFD19BB87041E9-8054
   Component: WWS    150409  043 0551
   Serial number:         150414194522
   Serial number: 000000000ZY150750Y9Y
   Serial number: 00000000000062170692
   Sun Roof:
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST0008T7IQ00000
   Coding: 181801
939524 - No Communications with Humidity Sensor
          U10F5 00 [009] - -
                    Reset counter: 65
                    Mileage: 28694 km
                    Date: 2017.06.15
                    Time: 13:27:39
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391510504126
   Coding: 0031151011
   VCID: 3D716625ACCADDA9C2-8068
   Serial number: 14031741350125
   ROD: EV_DRCONTITEMIC.rod
   VCID: 387F773183E8F88111-806C
278272 - Basic Setting of Deflected Position not Performed
          C10C5 00 [137] -  -
                    Reset counter: 65
                    Mileage: 28694 km
                    Date: 2017.06.15
                    Time: 13:27:38
   Component: AirbagVW20    014 0385
   Serial number: 003F6R0J7J7H
   VCID: 41891AD5D032B949A6-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 204 15
   Serial number: 357670000003A659041N
   Subsystem 2 - Part No SW: -----------    HW: 480 001 004 15
   Serial number: 35867000000BD891D312
   Subsystem 3 - Part No SW: -----------    HW: 480 401 304 15
   Serial number: 3516502C91A8785072BG
   Subsystem 4 - Part No SW: -----------    HW: 480 401 304 15
   Serial number: 3526502C11A87852A3BF
   Subsystem 5 - Part No SW: -----------    HW: 480 401 004 15
   Serial number: 3556502C91941316625%
   Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 14041504401868
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 79F9B235F8622189AE-802C
   Part No SW: 5G1 920 758     HW: 5G1 920 758
   Component: KOMBI         304 4310
   Coding: 47AD08183B80000801086A001400000000000000
   VCID: 6CD79B618730842125-8038
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003342461
   Coding: 030100042F085900EF00026A9C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72EB8519A51452D1EF-8026
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150000740010025155
   Coding: 29FFFF
   Serial number: 7660836403
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00010.03.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_SK12.rod
   VCID: 468309C9F91C9E7193-8012
   Revision: 00000000    Serial number: 15000092790001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 346743019F801CE13D-8060
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 300315BCU00545
   Coding: 003E1220D000040000001000
   VCID: 428B15D9D534A251BF-8016
   Serial number: 00000000000005964517
   Coding: 110000
   Coding: 8103
   ROD: EV_SteerAssisMQB_VW31.rod
   VCID: 377D740D8EF6F7F918-8062
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 010415BCV16064
   Coding: 003E1020DC00040000801000
   Serial number: 00000000000005928692
   Coding: 090000
   Coding: 02A202000B010200
   VCID: 408F1FD1DB38B041A9-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 5G0 035 045 D    HW: 5G0 035 045 C
   Component: MU-H-N-RW     H44 0377
   Serial number: A311D0F7513377
   Coding: 0273000CFF00000011110001001800001F0207D40100010057
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 2149BA5530729949C6-8074
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU301FNB
   Subsystem 2 - Part No SW: V03 959 801 QH    HW: -----------
   Component: ROW 2015  --- 0039
   Component: Gracenote  --- 4006
   Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 150228200310
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   VCID: 2D5156657CAA4D2972-8078
End-------------------------(Elapsed Time: 04:51)--------------------------
PetrolDave
Westbury, UK
C?ID=1423
OP - please don't type in all upper case, it's regarded as SHOUTING...
dreke
Spain
C?ID=170515
Try 31564 to enable basic settings
grtz, dre
jawad
UAE
C?ID=261487
Hi , I tried 31564 with no luck. Also I noticed that vcds cannot see the coding of the suspension control module!
jawad
UAE
C?ID=261487
What makes you think it has coding? Some modules simply do not.
Oh , i did not know that , i am still stuck with this car .
jawad
UAE
C?ID=261487
TBAx
C?ID=287144
How does the crash/the method of purchase affect the warranty status?
DV52
C?ID=194404
jaward: Hi.
I've recorded 20103 as a SA for the module @ address hex14 (originally provided by NEtech according to my records). Worth a try IMO given the pedigree of the advice!
jawad
UAE
C?ID=261487
Hi , I will try and report back. I hope it will work. Thanks.
jawad
UAE
C?ID=261487
Because the insurance company refused to pay for the high repairing cost put by the dealer. So the dealer will cancel the car if it is not repaired by him. The insurance company will compensate the owner for the value of his car in the market and then sell the car in an auction.
Yes, in North America, a Salvage Title also means the original manufacturer's warranty is void.
jawad
UAE
C?ID=261487
Hi , i have good news and bad news , good news access is accepted , bad news sequence error , is there a special procedure for doing the adaptation. what does it mean to do adaptation with deflected tyres. should i remove air from the tyres or disconnect the sensors. there are 3 level sensors installed , 2 front and 1 left rear.
NEtech
C?ID=56995
What Secure access ?
Normally the basic setting on these new systems are done on a lift, wheels hanging free.
Why are you doing Adaptation, I thought it was about Basic setting ?
While trying basic setting, choose different measurement values, for example search for "status" etc.
Look at the messages.
jawad
UAE
C?ID=261487
Hi , this is the first time for me to tackle such a car , i saw that the fault code is about basic settings so i thought that i should do basic setting , how to do it on the jack after lifting?
jawad
UAE
C?ID=261487
Sorry i meant basic setting not adaptation
jawad
UAE
C?ID=261487
Hi , i looked at the measured values and i can see that level sensors not adapted . i went to security access and entered 20103 but still the adaptation asked for security access login . maybe adaptation access is different from basic settings.
NEtech
C?ID=56995
Please write exact commands/messages or post screenshots, so it is possible to find out what you are doing. 1)
What do you want do do now in [Adaptation-10] ?
Put the car on a lift, so that all 4 wheels are free.
Copy this file to:
\Ross-Tech\VCDS\Labels\User
Try [Security Access-16], first enter:
S12345
If not accepted, then use the 20103 that you told, was accepted.
Then try again [Security Access-16], enter:
S23456
Before you start an possible [Basic Setting-04], find and choose the right measurement values, search for "status" and "basic"
You can save the setting, before doing [Basic Setting-04].
Remember 1)
Use the VCDS 17.1.3 for this.
jawad
UAE
C?ID=261487
Hi , finally it is done , many thanks to NEtech for his help . but strange things has happened during the procedure. i have put the file in the destination folder , lift the car , went to security access login put S12345 agin seed key error , tried the other one same result seed key error , out of hope i went to basic setting and pressed basic setting with deflected tyres and voila . it took it and everything is good now.
