VCDS 17.1.3.0 label file for Seat MIB navigation 5F0 035 846 missing
downtime
C?ID=280813
VCDS seems to be missing long coding helper label file for Seat MIB navigation 5F0 035 846. Is there by any chance any possibility to get one?
Here's my complete autoscan from the car.
Monday,15,May,2017,16:25:16:18632
VCDS Version: 17.1.3.0
Dealer/Shop Name: Chop shop
VIN: VSSZZZ5FZDR039344   License Plate: OTV-740
Mileage: 105408km-65497mi   Repair Order:
Chassis Type: 5F (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A5
VIN: VSSZZZ5FZDR039344   Mileage: 105408km-65497miles
Address 01: Engine (J623-CJZA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 A    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 5541
   Revision: WAH08---
   Coding: 01250032232401080000
   Shop #: WSC 00049 770 00125
   ASAM Dataset: EV_ECM12TFS01104E906016A 001006
   ROD: EV_ECM12TFS01104E906016A_AU37.rod
   VCID: 20766ECA3B8B2B41C9-8074
7 Faults Found:
5604 - Park/Neutral Switch Input Circuit
          P0850 00 [032] - Open or Short to Plus
17158 - Databus
2838 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 105363 km
                    Date: 2017.04.25
                    Time: 17:58:31
                    Engine speed: 1410.50 /min
                    Normed load value: 21.6 %
                    Vehicle speed: 16 km/h
                    Coolant temperature: 9 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 14.983 V
                    Unlearning counter according OBD: 36
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Oxygen sensor 2 bank 1 internal resistance limit value: 116072 Ohm
                    Long-term fuel trim bank 1 at idle: 0.00 %
10591 - Cylinder 1
          P0301 00 [096] - Misfire Detected
10593 - Cylinder 3
          P0303 00 [096] - Misfire Detected
                    Mileage: 105363 km
                    Date: 2017.04.25
                    Time: 17:58:31
                    Misfire recognition reference moment: 10.843 %
                    Misfire sum counter: 82
                    Counter: implaus. short-term adapt. values: misfire detection: 0
10592 - Cylinder 2
          P0302 00 [096] - Misfire Detected
                    Mileage: 105363 km
                    Date: 2017.04.25
                    Time: 17:58:31
                    Misfire recognition reference moment: 11.043 %
                    Misfire sum counter: 81
   Part No SW: 0CW 300 044 T    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4512
   Revision: 00043014    Serial number: CU501303286885
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021.rod
   VCID: 49A0D36EE8F1CA097E-801C
   Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
   Component: ESC           H75 0333
   Coding: 20EE6A9220231275007A060401C7240456044800608024F200290020C0
   Shop #: WSC 00049 770 00104
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
   ROD: EV_Brake1UDSContiMK100ESP_008.rod
   VCID: 3A42BCA2BD175191E7-806E
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 14
                    Mileage: 105371 km
                    Date: 2017.05.03
                    Time: 15:52:21
   Part No SW: 5F0 907 044 A    HW: 5F0 907 044 A
   Component: Climatronic   H02 0503
   Revision: 00001K05
   Coding: 00000004200100011105000000101000
   ROD: EV_ACClimaBHBVW37X_002.rod
   VCID: 247E62DA2F933761AD-8070
328196 - Motor for Right Temperature Flap
          B108D 71 [008] - Actuator stuck
                    Reset counter: 12
                    Mileage: 105362 km
                    Date: 2017.02.01
                    Time: 16:16:02
                    Voltage terminal 30: 14.0 V
                    Outside air temperature: -7.0 °C
                    Interior temperature: -2.6 °C
                    Right temperature flap: actual value: 25
                    Right temperature flap: actual value: 0.0 %
                    Right temperature flap: specified value: 238
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011308700426
   Coding: 08001946C2C102FB4BE44000401C07081008000000000000000000000000
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46BAD852F9EF257193-8012
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130318  041 0574
   Serial number:         130326035958
   Coding: 0BC5FD
   Component: RLFS  024 0042
   Serial number: Y13M04D06H03M24S39S2
   Coding: 00885D
11274 - Bulb for Center Brake Light
          B12C6 15 [009] - Open or Short to Plus
                    Reset counter: 227
                    Mileage: 105361 km
                    Date: 2017.02.01
                    Time: 16:13:02
203016 - Unlock Switch in Rear Lid Handle
          B140B 29 [008] - Signal Implausible
                    Reset counter: 12
                    Mileage: 105362 km
                    Date: 2017.02.01
                    Time: 16:17:17
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 227
                    Mileage: 105356 km
                    Date: 2017.01.30
                    Time: 14:46:36
539925 - Databus
                    Reset counter: 15
                    Mileage: 105400 km
                    Date: 2017.05.04
                    Time: 14:57:42
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231308202247
   Coding: 0031051011
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   Part No SW: 3Q0 959 655 R    HW: 3Q0 959 655 R
   Component: Airbag VW20   011 0186
   Revision: --------    Serial number: 003NPP5V7JX%
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 4DA8E77E1C99D62952-8018
   Subsystem 1 - Part No SW: -----------    HW: 454 001 603 13
   Serial number: 3576U0000009B1343C08
   Subsystem 2 - Part No SW: -----------    HW: 454 002 403 13
   Serial number: 3586U000000A76243C0A
   Subsystem 3 - Part No SW: -----------    HW: 454 801 403 13
   Serial number: 3516R2A107300000000M
   Subsystem 4 - Part No SW: -----------    HW: 454 801 403 13
   Serial number: 3526R84A42100000000T
   Subsystem 5 - Part No SW: -----------    HW: 454 801 302 13
   Serial number: 3556V76EAD400000000I
   Part No SW: 5Q0 953 507 AN    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 04041304220068
   Coding: AC00
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 023204429547D951FF-8056
   Part No SW: 5F0 920 870 F    HW: 5F0 920 870 F
   Component: KOMBI         336 0556
   Coding: 07A402086980000800086A02000000
   ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
   VCID: 2B6C89E6424DF8196C-807E
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000508532
   Coding: 030100F42B086400EF0006481C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 345E929A9F73A7E13D-8060
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H03 0100
   Serial number: 000000000A0645050313
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004050365332
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000057243659
   Coding: 00100320DC00020000001000
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000151396
   Coding: 310000
   Coding: 11
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D48B7BEAC3966A9C2-8068
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000056244561
   VCID: 01300B4E9041C249E6-8054
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000131183
   Coding: 290000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Component: LWR-ECU       005 0070
   Coding: 048A000009000000
   ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
   VCID: 75D86F9ED489FEE9CA-8020
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5F0 035 846     HW: 5F0 035 846
   Component: MU-S-N-ER     039 0171
   Serial number: E1F03103130409
   Coding: 04730001D70A000021110001000800002F0106040100010046
   ASAM Dataset: EV_MUStd6C1PASE 002030
   ROD: EV_MUStd6C1PASE_VW37.rod
   VCID: 65F83FDE64290E697A-8030
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H45 0020
   Serial number: SEZ8Z9N5600CUK
   Subsystem 2 - Part No SW: 5F0 919 866 C    HW: -----------
   Component:  ECE 2013  --- 0021
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0050
   Serial number: 00000039868
   Coding: 0100010001000004000500000000000100
   ROD: EV_MFKBoschAU370.rod
End-------------------------(Elapsed Time: 03:07)--------------------------
Looks like we're aware of the part number, but there's no label file yet, not in English, nor in German...
downtime
C?ID=280813
Ok, thank you for a quick reply. No other possibility then than to wait.
downtime
C?ID=280813
By the way, is there any way I could help? Do you need adaptation map and coding from the unit?
In this case, no I don't think so. Feel free to post an Adaptation map for general reference purposes, but unfortunately, that doesn't help with coding info.
