VW touran MFD menu
Fredrick Awuor
Kenya
C?ID=309834
Hello,does anyone have a tip or trick of enabling MFD menu on this touran somewhere in the convenience or instruments ,settings like time,winter;language,units auto door lock etc do not appear however much i press the ok,up,bottom buttons on wiper stalk! even though the MFD is high line,red in colour, any insight will be greatly appreciated
Friday,02,March,2018,17:03:28:48669
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WVGZZZ1TZ9W066359   License Plate
Chassis Type: 1T (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
Address 01: Engine        Labels: 03C-906-032-BLG.lbl
   Part No SW: 03C 906 032 H    HW: 03C 906 032 C
   Component: MED17.5.1       G   2983
   Revision: 96H07---    Serial number: VWX7Z0H93NA0US
   Coding: 0000075
   Shop #: WSC 01324 785 00200
   VCID: 221EE36518C410C744C-8076
008198 - Intake Manifold Flap; Bank 1
               P2006 - 000 - Stuck Closed
                    Mileage: 81443 km
                    Time: 16:36:48
                    RPM: 871 /min
                    Load: 19.6 %
                    Temperature: 74.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 820.0 mbar
                    Voltage: 13.716 V
008803 - Turbo/Super Charger Boost System
               P2263 - 000 - Performance
                    Fault Status: 01110000
                    Mileage: 81624 km
                    Time: 17:01:02
                    RPM: 3501 /min
                    Load: 62.7 %
                    Speed: 121.0 km/h
                    Temperature: 84.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 900.0 mbar
                    Voltage: 13.843 V
000808 - Knock Sensor 1 (G61)
               P0328 - 000 - Signal too High - Intermittent
                    Fault Status: 00110000
                    Mileage: 81901 km
                    Time: 17:37:57
                    RPM: 3107 /min
                    Load: 49.0 %
                    Speed: 108.0 km/h
                    Temperature: 90.0°C
                    Temperature: 41.0°C
                    Absolute Pres.: 850.0 mbar
                    Voltage: 13.716 V
   Part No SW: 02E 300 051 N    HW: 02E 927 770 AM
   Component: GSG DSG AG6     521 1953
   Revision: 05652104    Serial number: 00001307171240
   Shop #: WSC 04940 001 00001
   VCID: 1E66D7952CBC3427604-804A
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0004806
   VCID: 688AB14DBE783A97DA8-803C
   Part No SW: 1K0 907 044 CT    HW: 1K0 907 044 CT
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 7BA0FE01DFEE810F27A-802E
   Revision: 00H54000    Serial number: 00000009029759
   Coding: 038F0F2100040F0047120C0000000000000B7F075C000120000000000000
   VCID: 33301621B73E894FBFA-8066
   Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 230908 021  0501
   Coding: 00038805
   Shop #: WSC 01324
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 D    HW: 1T0 909 605 D
   Component: 04 AIRBAG VW8   021 0100
   Revision: 02021000    Serial number: 003B9D0AY8JL
   Coding: 0012340
   Shop #: WSC 01324 020 00200
   VCID: 36362F35A44C9C67984-8062
   Subsystem 1 - Serial number: 6332QSME66093F1ET
   Subsystem 2 - Serial number: 6342QSME3E0F020EO
   Subsystem 3 - Serial number: 6352QSME4B0E5438Q
   Subsystem 4 - Serial number: 6362QSME470E1D32M
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           752 0101
   Coding: 0012142
   VCID: 78AAE10DEED8AA174A8-802C
Address 17: Instruments
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 101008F2001566
   Coding: ED817F060002028003
   VCID: 35342839B94A977F91E-8060
                    Reset counter: 144
                    Mileage: 81443 km
                    Time: 16:26:50
   Part No SW: 1T0 920 874 C    HW: 1T0 920 874 C
   Component: IMMO            VDD 2416
   Revision: V0002000    Serial number: VWX7Z0H93NA0US
   Part No SW: 1T0 959 701 N    HW: 1T0 959 701 N
   Component: Tuer-SG         008 2008
   Coding: 0004789
   VCID: 42DE43E5F88430C724C-8016
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A0E0B4560F4C8870CC-807E
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 9990020851030C7F2D06840560085F03E0FC00
   VCID: 71BCDC298DA2FB5F8D6-8024
   Part No SW: 1T0 959 702 N    HW: 1T0 959 702 N
   Coding: 0004789
   VCID: 43D046E1E79E39CF2FA-8016
   Part No SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Component: AFS-Steuergeraet    0001
   Revision:   H02       Serial number:
   Coding: 3293444
   VCID: 323E132548248047B4C-8066
   Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0003
   Coding: 00000050
   Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0003
   Coding: 00000050
Address 56: Radio
   Part No SW: 1K0 959 703 AK    HW: 1K0 959 703 AK
   Component: Tuer-SG         007 2002
   Coding: 0000144
   Shop #: WSC 01324 785 1012552
   VCID: 79ACE409D5D2B31F356-802C
   Part No SW: 1K0 959 704 AK    HW: 1K0 959 704 AK
   Coding: 0000144
   VCID: 7AAEFB05D0D4B8073CC-802E
End----------(Elapsed Time: 01:15, VBatt start/end: 13.1V/13.7V)-----------
siLc
Tallinn, Estonia
C?ID=330192
Have you tried long pressing the OK/RESET button on the right stalk?
By your autoscan, your car appears to have MFSW so the MENU button (3 bars) on the steering wheel right button group should work. If so, then from the factory there shouldn't be no MFD menu buttons on the right stalk. If you have retrofitted the MFSW, there could be a coding issue. When I retrofitted a MFSW on my old Golf 5, I also changed the right stalk to no longer have the said buttons.
Fredrick Awuor
Kenya
C?ID=309834
Thanks I will try on Tuesday and post results
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
This could be a problem,
Can you go direct in 17-Instruments and have access?
Fredrick Awuor
Kenya
C?ID=309834
Yes i got access yesterday,i will try more on tuesday and post
Fredrick Awuor
Kenya
C?ID=309834
Hello,owner brought car yesterday and behind steering wheel there are two + and - buttons one on either side of spoke,owner says car came from Japan this way,so I think maybe they made those changes there
