New Gateway Installation
Bamba1955
C?ID=79996
Hello Gents,
Replacing a gateway on Audi A3 2009, new gateway won't accept long coding, could anyone help with the right coding and installation list from the info below? Tried Hexi Deci converter but nor sure of results.
 Wednesday,25,October,2017,11:43:49:34373
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 17.8.0.1
VIN: WAUZZZ8P69A132199   License Plate: ML09YUK
Mileage: 182470km-113381mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 77
VIN: WAUZZZ8P69A132199   Mileage: 182470km-113381miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 056 S    HW: 03G 906 021 AB
   Component: R4 1,9L EDC  000SG  2917
   Revision: --H09---    Serial number: AUX7Z0I2FNB0CN
   Coding: 0000071
   Shop #: WSC 80093 222 69422
   VCID: 3776C06E46CBC1FE7B-8062
8 Faults Found:
005712 - Powertrain Data Bus
               P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Fault Frequency: 29
                    Mileage: 182362 km
                    Date: 2017.10.23
                    Time: 07:09:26
                    RPM: 1659 /min
                    Speed: 11.0 km/h
                    Load: 37.6 %
                    Voltage: 14.52 V
                    Bin. Bits: 00000000
                    Torque: 187.9 Nm
                    Torque: 83.0 Nm
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -  - Intermittent
                    Fault Frequency: 28
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
                    RPM: 1323 /min
                    Speed: 54.0 km/h
                    Load: 27.5 %
                    Voltage: 14.59 V
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    (no units): 33.0
006272 - Powertrain Data Bus
               P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
                    Fault Frequency: 27
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
                    RPM: 1323 /min
                    Speed: 54.0 km/h
                    Load: 26.7 %
                    Voltage: 14.52 V
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    (no units): 33.0
005785 - Powertrain Data Bus
               P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
                    Fault Frequency: 26
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
                    RPM: 1302 /min
                    Speed: 54.0 km/h
                    Load: 24.7 %
                    Voltage: 14.59 V
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    (no units): 33.0
005685 - Powertrain Data Bus
               P1635 - 000 - Missing Message from A/C Controller - Intermittent
                    Fault Frequency: 26
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
                    RPM: 1302 /min
                    Speed: 54.0 km/h
                    Load: 16.9 %
                    Voltage: 14.59 V
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    (no units): 0.0
053273 - Control Module for Instrument Cluster
               U1019 - 000 - Missing Signal for Oil Level/Temperature - Intermittent
                    Fault Frequency: 14
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
                    RPM: 924 /min
                    Speed: 38.0 km/h
                    Voltage: 14.52 V
                    Bin. Bits: 00000111
                    Bin. Bits: 00000000
                    (no units): 33.0
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
                    RPM: 1008 /min
                    Voltage: 11.86 V
                    Bin. Bits: 00000100
                    Bin. Bits: 11000000
                    (no units): 33.0
005672 - Powertrain Data Bus
               P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
                    RPM: 756 /min
                    Load: 19.2 %
                    Voltage: 11.86 V
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    (no units): 33.0
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 13422012092500FCC80C04ED902200813800
   Shop #: WSC 06314 000 00000
   VCID: 74EC3762D73D6AE69E-8020
                    Reset counter: 219
                    Count: 2
                    Count: 12
                    Count: 12288
                    Count: 8211
                    Count: 43264
                    Count: 257
                    Reset counter: 219
                    Count: 12
                    Count: 4608
                    Count: 8213
                    Count: 42752
                    Count: 513
                    Reset counter: 0
                    Count: 2
                    Count: 12
                    Count: 4608
                    Count: 166
                    Count: 43264
                    Count: 513
                    Reset counter: 0
                    Mileage: 182362 km
                    Date: 2017.10.23
                    Time: 07:09:26
                    Count: 4608
                    Count: 8208
                    Count: 51983
                    Count: 6948
                    Count: 256
                    Reset counter: 0
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
                    Count: 4608
                    Count: 8233
                    Count: 52278
                    Count: 2
   Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
   Component: KlimavollautomatH09 0100
   Revision: 000672      Serial number: 8P0820043BG
   VCID: 72E0317A6D2964D68C-8026
                    Reset counter: 0
                    Mileage: 182476 km
                    Reset counter: 219
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
                    Reset counter: 219
                    Mileage: 182418 km
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000009483517
   Coding: 11A82F81B0141380EF00001C0000000000084E0564010403002800000000
   Shop #: WSC 06314 000 08192
   VCID: 4894B3923B35BE0602-801C
   Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 06314
                    Fault Frequency: 7
                    Reset counter: 219
                    Voltage: 14.15 V
                    Fault Frequency: 9
                    Reset counter: 219
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:00
                    Voltage: 14.30 V
                    Fault Frequency: 9
                    Reset counter: 219
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:00
                    Voltage: 14.30 V
                    Fault Frequency: 10
                    Reset counter: 219
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:00
                    Voltage: 14.30 V
                    Reset counter: 219
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:00
                    Voltage: 14.25 V
Address 15: Airbags (J234)       Labels:| 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003CA005RLUM
   Coding: 303142383038303030374A55305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4992B696E83F470E1D-801C
   Serial number: 3572DRB400008448521I
   Serial number: 3582DRB40000842CCA5/
   Serial number: 35128RB400004C8E81E-
   Serial number: 35228RB400004C9172AL
   Serial number: 35547RB400004B8787E$
   Serial number: 35647RB400004B8786E$
             U0155 00 [008] - -
                    Reset counter: 219
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0002012
   VCID: 4182AEB6180F8F4EC5-8014
01304 - Radio
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 982 C    HW: 8P0 920 982 C
   Component: KOMBIINSTR. VDO H19 0860
   Revision: D0H19007    Serial number: 2242I007017502
   Coding: 0004428
   Shop #: WSC 54064 210 66681
   VCID: 3972C65670DFD78E8D-806C
                    Fault Frequency: 7
                    Reset counter: 219
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K093190363
   Coding: E9807F06500602002103
                    Reset counter: 179
                    Mileage: 76254 km
                    Date: 2014.01.30
                    Time: 15:19:56
   Revision: D0H19007    Serial number: AUX7Z0I2FNB0CN
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 193 G    HW: 8P0 035 193 G
   Component: RNS-E PU EU     H05 0200
   Revision: 0000011S    Serial number: AUZBZ7KD204373
   Coding: 0205755
   Shop #: WSC 46671 133 53260
   VCID: 346CF76257BD2AE65E-8060
7 Faults Found:
                    Reset counter: 219
                    Mileage: 130331 km
                    Date: 2015.10.11
                    Time: 18:37:28
                    Voltage: 10.60 V
                    Mileage: 182470 km
                    Count: 2510
                    Clock: 10:30
02261 - Data Medium
                    Fault Status: 00101110
                    Reset counter: 181
                    Mileage: 178129 km
                    Date: 2017.07.29
                    Time: 13:32:56
                    Mileage: 181340 km
                    Count: 2709
                    Clock: 17:19
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 70
                    Mileage: 76254 km
                    Date: 2014.01.30
                    Time: 14:22:51
                    Mileage: 76250 km
                    Count: 3001
                    Clock: 14:22
                    Reset counter: 219
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
                    Reset counter: 179
                    Mileage: 182476 km
                    Date: 2017.10.25
                    Time: 10:34:57
                    Reset counter: 219
                    Mileage: 182476 km
                    Date: 2017.10.25
                    Time: 10:32:25
                    Reset counter: 219
                    Mileage: 182476 km
                    Date: 2017.10.25
                    Time: 10:32:25
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000692
   VCID: 438EA4BE02139D5ED7-8016
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 232    2501
   Revision: 00H15000
   VCID: 2C5CEF028F8D722606-8078
                    Fault Frequency: 12
                    Reset counter: 229
                    Mileage: 182476 km
                    Date: 2017.10.25
                    Time: 10:35:01
                    Voltage: 14.25 V
                        DU
                    Temperature: 17.0°C
                    RPM: 979 /min
   Part No: 8P0 959 433 J
   Component:    KSG          H11 0080
   Coding: 1980200002186D0985054C9FC637
   Component: Neigungssensor  005 0003
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158948847322
   VCID: 3668CD6A41C138F660-8062
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000692
   VCID: 448CA7A2071D9A66EE-8010
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0205755
7 Faults Found:
                    Reset counter: 219
                    Mileage: 130331 km
                    Date: 2015.10.11
                    Time: 18:37:28
                    Voltage: 10.60 V
                    Mileage: 182470 km
                    Count: 2510
                    Clock: 10:30
02261 - Data Medium
                    Reset counter: 181
                    Mileage: 178129 km
                    Date: 2017.07.29
                    Time: 13:32:56
                    Mileage: 181340 km
                    Count: 2709
                    Clock: 17:19
                    Reset counter: 70
                    Mileage: 76254 km
                    Date: 2014.01.30
                    Time: 14:22:51
                    Mileage: 76250 km
                    Count: 3001
                    Clock: 14:22
                    Reset counter: 219
                    Mileage: 182418 km
                    Date: 2017.10.24
                    Time: 06:54:48
                    Reset counter: 179
                    Mileage: 182476 km
                    Date: 2017.10.25
                    Time: 10:34:57
                    Reset counter: 219
                    Mileage: 182476 km
                    Date: 2017.10.25
                    Time: 10:32:25
                    Reset counter: 219
                    Mileage: 182476 km
                    Date: 2017.10.25
                    Time: 10:32:25
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
No Faults Found
Address 72: Door, Rear Right
Address 77: Telephone        Labels: RETROFIT77.lbl
   Part No SW: KTC 364 31P     HW: KTC 364 31P
   Component: SWP:3.23.5      H24 0210
   Shop #: WSC 21977 142 74100
   VCID: 336EF47E52B32DDE47-8066
End-------------------------(Elapsed Time: 02:37)--------------------------
What do you mean it "won't accept long coding"? What is the error?
Do you have any data from the original gateway?
Bamba1955
C?ID=79996
Gateway original part No was 1K0 907 530 S, new genuine gateway part No is 7N0907530AK (been told this is the superseded part). Original coding numbers are 20 characters in length E9807F06500602002103, new unit won't accept all of that code (from memory only 6 characters) Use hexadecimal converter to come up with six numbers which it accepted, but get ABS lamp intermittently coming on and reporting numerous Bus data as above.
Update: Instrument cluster has now gone dead so looks like I miss-diagnosed gateway problem.
Bamba1955
C?ID=79996
Update: Instrument cluster checked out OK, now looking for something dragging the CAN down, spied out the ABS wiring looks exposed (can see the individual wires entering the multiplug connector) I assume that being in a splash area water might have got in to the ABS ECU.
Three bytes of new Gateway's coding define characteristics of car and should be documented in Long Coding Helper, while Installation List needs to be done separately using the dedicated function for that.
Bamba1955
C?ID=79996
Sorry for the slow reply been on holiday, thanks for the reply. Situation become worse; no comms possible with any module, disconnected ABS connector but no recovery, suspect the network is down, going to get wiring diagram from ELSAWIN to check system over will report my findings.
downtime
C?ID=280813
Hey, before you do anything of that sort. Did you do what Uwe proposed? When changing gateway to a superseding part, you need to transfer the coding manually and tick the boxes from the installation list manually as well. You can't just copy the old code, it won't work as the new gateway has different byte length than the old one.
So put in your old gateway, record the bytes with long coding helper by taking screenshots. Also do the same to the installation list. Now put in the new gateway and manually change the long coding bytes and manually check the right boxes in installation list.
If the network is completely down, your problem is the gateway not the ABS.
Bamba1955
C?ID=79996
Thanks for the reply downtime, I used the long coding helper and ticked the boxes in the installation list that I recorded from the old gateway and it worked fine for a day. But the next morning the instrument cluster was dead (no lights no gauges) and the engine momentarily starts and then cuts out (immobilizer activated), scoped the CAN high and low at the gateway and the only can signals missing are to the instrument cluster and the diagnostic socket; so no comms with VAG-COM. I still believe it's the instrument cluster at fault but don't know which pins are 12v feed and ground so will have to visit ELSAWIN to get the appropriate diagram. Does anyone know if a dead cluster will give these symptoms? And what is the procedure for replacing the cluster? I guess I will need the pin code, is there anyway to obtain that??
downtime
C?ID=280813
Ground connection T32/3, T32/4 and T32/19.
+12v T32/1, T32/2 and T32/18.
+12v is fed from SB6 which is fuse nbr 6 (5A) on fuse holder B. Fuse holder B is located on the engine compartment.
Check the fuse first :)
Bamba1955
C?ID=79996
Thanks for that Downtime, will check fuses (once again) just to be sure and report my findings.
Bamba1955
C?ID=79996
Hmm, feeds and grounds checked out OK, double checked can signals at instrument cluster pins 29 & 30 both flat line (no signal) this was with plug disconnected from the instruments. I thought that if the cluster was faulty I should see signals restored form gateway with plug disconnected. However I noticed that the radio can signals were only there when radio was switched on. So my suspicion is a faulty instrument cluster, I can't think of anymore tests I can do now so I guess I'm going to have to throw some money at it. Not sure if I'm able to replace the cluster though.:(
downtime
C?ID=280813
Seems that this problem is not unheard of :
http://forums.vwvortex.com/showthread.php?6888948-Instrument-cluster-dead-interior-backlighting-inop
If you google you'll see that Audis for some reason seem to be a bit prone to kill their dashboards.
Have you tried putting back the original gateway?
If you need to swap the cluster, you cannot do it yoursef. It is dealer job entirely if you take that road. And bad thing is that if you buy an used cluster, you cannot change the mileage on it if it has over 100 kms on the odometer.
Your car is still not MQB platform so there are some options. I would suggest you to contact Spacewalker. He might be able to help you get the cluster swapped. There's an option to clone the old cluster EEPROM contents to a new one.
Bamba1955
C?ID=79996
Had the cluster checked again by an electronics specialist, he plugged it into his rig and it works perfectly!! It has to be a problem with the gateway, I've tried the old gateway and have exactly the same results. Gateway communicates via can to everything bar the diagnostic socket on pins 14 and 6 (can high and low) and instrument cluster pins 29 and 30, checked signal with Picoscope and there's nothing on these pins at the component or gateway, checked for continuity and that's OK. Checked relay J681 terminal 15, and j689 terminal 30. I'm thinking is it possible that a feed is missing on the gateway; but having a hard time working out what pin does what from the ELSAWIN diagrams, does anybody have a spiders-web type diagram for the gateway?
Bamba1955
C?ID=79996
Happy days! Run through the training videos on reading VAG wiring diagrams, finally found pin 1 on gateway J533 is 12v feed and it was missing, this is supplied by fuse SB12 in engine bay (which is OK) there must be a break in the wire somewhere, so run new wire into the gateway, dashboard came alive and engine now runs, hope this will help somone, thanks to everyone for their input.
