3D cluster tacho - how to change phone language?
Christiank
C?ID=253485
So.. I've got a 3D cluster installed to my MK5 and menu is set to "Danish" since I'm from Denmark.
However the phone language is in german? Anyone had any luck or "know-how" how to change this to English or even Danish?
I've tried to change the IDE11122-Country identification: Country of sale HMI from the stored value to "EN" for English. It did work for 5 mins and then change back to german...
Anyone? :)
m87a
Bosnia and Herzegovina
C?ID=156900
go to bluetooth module adaptation 77 Telephone
Christiank
C?ID=253485
I don't have a RNS-510 installed so I'm not having a seperate BT module installed that can operate with the 77 Telephone in VCDS.
I've got the MIB 2 navi installed in mine that has build in BT like the RNS-315
Spacewalker
Poland
C?ID=159607
simple post autoscan at first .
what is a point asking for help w/o any info what you have ?
Christiank
C?ID=253485
@spacewalker
Here is a full auto-scan from my car.
Hope it can help leading you guys to a possible solution for my problem, since I really have no clue what to do anymore hehe.
Saturday,10,February,2018,12:06:19:31035
VCDS Version: 18.1.0.2 (x64)
VIN: WVWZZZ1KZ5W036030   License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 55 5F 62 72 7D
VIN: WVWZZZ1KZ5W036030   Mileage: 355100km-220648miles
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 KC    HW: 028 101 190 3
   Component: R4 2,0L EDC G000SG  8457
   Revision: 12345678    Serial number: VWZ7Z0D0121566
   Coding: 0000072
   Shop #: WSC 00774 204 87198
   VCID: 6ED39C4A79EE3E3557-803A
Readiness: 0 0 1 1 1
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 113B400D09250000880B02E790190062310800
   Shop #: WSC 12345 678 12345
   VCID: 76E3B42AC1BE06F59F-8022
   Part No SW: 3AD 907 044 AE    HW: 3AD 907 044 AE
   Component: Climatronic   H03 0808
   Revision: 00001K02
   Coding: 0000000002
   Shop #: WSC 01234 567 56789
   ROD: EV_ACClimaBHBVW411_VW36.rod
   VCID: 76E3B42AC9BE06F59F-8022
9472881 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [009] - Actuator stuck
                    Reset counter: 26
                    Mileage: 354999 km
                    Date: 2018.02.05
                    Time: 18:04:27
9472882 - Motor for Fresh Air / Recirculated Air Flap
          B108B 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 22
                    Mileage: 354999 km
                    Date: 2018.02.05
                    Time: 18:04:27
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 20
                    Reset counter: 27
                    Mileage: 354999 km
                    Date: 2018.02.05
                    Time: 18:04:26
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [009] - Open or Short to Plus
                    Reset counter: 22
                    Mileage: 354999 km
                    Date: 2018.02.05
                    Time: 18:04:31
   Revision: 00H54000    Serial number: 00000003324221
   Coding: EFEB0F0601041800001400001400000000017F035C00002C17C000000000
   VCID: 33654D3E524C53DD78-8066
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 01234
   Component: RLS     140712 054  0403
   Coding: 00479405
   Shop #: WSC 01234
                    Reset counter: 27
                    Mileage: 355106 km
                    Voltage: 11.60 V
00984 - Left Tail Light (M4)
                    Reset counter: 27
                    Mileage: 355106 km
                    Voltage: 11.60 V
00985 - Right Tail Light (M2)
                    Reset counter: 27
                    Mileage: 355106 km
                    Voltage: 11.60 V
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12561208004496
   Coding: 100001
   Shop #: WSC 31136 677 00001
   VCID: 387F7A128B2AB0854D-806C
   Part No SW: 1K0 909 605 D    HW: 1K0 909 605 D
   Component: 01 AIRBAG VW8   022 0600
   Revision: 05022000    Serial number: 0033JD0F8V28
   Coding: 0012337
   Shop #: WSC 01371 785 00200
   VCID: 2D515B46B468052D2E-8078
   Subsystem 1 - Serial number: 6332MSME4C4A5203
   Subsystem 2 - Serial number: 6342MSME74384E02
   Subsystem 3 - Serial number: 6351HSME32087E02
   Subsystem 4 - Serial number: 6361HSME4D0B5C02
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           056 0111
   Coding: 0000532
   VCID: 7AFBA01A35A66295FB-802E
   Subsystem 1 - Part No: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H31 0037
   Coding: 00000130
   Part No SW: 1K8 920 885 G    HW: 1K8 920 885 G
   Component: KOMBI         H03 1008
   Coding: 170F080000
   VCID: 3B75651EB21C9B9DA0-806E
   Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1653
   Revision:   H56       Serial number: 050515F1001937
   Coding: 350002
   VCID: 0109D7F69870314DBA-8054
   Component: IMMO          H03 1008
   Shop #: WSC 00020 999 00000
   VCID: 6ADB905A8D06D2150B-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2455
   Coding: 0000252
   VCID: 377D792E4634BFFD44-8062
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.8       1401
   VCID: 2F6D414EBE64773D1C-807A
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 989008085103087F00028505E00A0F0660E400
   VCID: 000FD2F2537A3845B5-8054
                    Reset counter: 62
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Component: Tuer-SG         024 2461
   Coding: 0000252
   VCID: 387F7A124B2AB0854D-806C
00121 - Outside Warning Light/Door exit Light Passenger Side
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000003
   Shop #: WSC 01392 785 00200
   VCID: 74E78E2217C214E5A1-8020
   Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
   Component: MU-S-ND-ER    H20 0241
   Serial number: VWZAZ2R8769189
   Coding: 02731201FF0000000111120100880A001F0106C400200100CF
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2149B77630B0D14D9A-8074
   Subsystem 1 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
6714 - Databus
                    Reset counter: 22
                    Mileage: 354999 km
                    Date: 2018.02.06
                    Time: 15:35:50
                    Voltage terminal 30: 13.7 V
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 22
                    Mileage: 354999 km
                    Date: 2018.02.06
                    Time: 15:35:47
                    Voltage terminal 30: 14.1 V
                    BAP-BAP_Function_ID: 02
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Reset counter: 22
                    Mileage: 354999 km
                    Date: 2018.02.06
                    Time: 15:35:45
                    Voltage terminal 30: 13.6 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Electrical OK
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0202
   Coding: 0000016
   VCID: 306F4232A35A68C505-8064
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
   VCID: 31694736A85061CD0A-8064
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Revision: 00700000    Serial number:
   VCID: 2C5756428F720C2539-8078
End-------------------------(Elapsed Time: 02:13)--------------------------
Christiank
C?ID=253485
IDE11122-Country identification: country of sale HMI
Here the old value was something other than "EN" ... Changed it to "EN" and nothing happened.
PetrolDave
Westbury, UK
C?ID=1423
Have you tried rebooting 5F? Some settings don't change until it is rebooted - press and hold the power button.
Christiank
C?ID=253485
Hi Dave, not sure how this will be related? I will give it a try later but not sure if this will cure the problem
I have changed the language in the cluster and not the MIB2. I know the bluetooth is set to "Danish" at the MIB2 unit since the phone menu on it shows the right language.
It the language in the phone menu at the cluster that keeps the german language no matter what I do.
golfi_vend
Tartu, Estonia
C?ID=195131
Well, Your DM firmware is old too "0241". Lateat would be 0252.
Christiank
C?ID=253485
Not sure how I can upgrade this when the MIB2 isn't suppose to be installed in the mk5 platform ? :)
Christiank
C?ID=253485
Still need some help with the problem if anyone got any suggestions? :)
kamold
Australia
C?ID=241363
Maybe post your complete admap from your Discover.
Can then compare with other maps to see if there is something amiss
Christiank
C?ID=253485
Hey, this is the info for my Discover 2 unit.
HMI Software: H25.14.25._STD2NavPQ_EU
Model: Guidemodel_25.14.25
Software Base: H25.14.25-201503171531
CGRun Number: H25.14.25-201503171535_STD2NavPQ_EU20...
Skin Editor: LSEV
Skin Model: MSH25.14.25
Skin Build: BH25.14.25-201503171531
Skin Short: STD_VW_PQ_Skin_A-3HELLYL
Skin SPF Filename: MIB_HMI_VW_STD_PQ_SKIN_A_H25.14.25_with_
Speller: (Guidemodel_11.10.4)
Text Translation Number: VWTexte_70.18.2_H25.14.11
Installed SW-train-version: MST2_EU_VW_PQ_P0241T
Installed SW-MU-version: 0241
Software version: H25.14.25_STD2NavPQ_EU
Will try update to newest software version thanks to Golfi :)
kamold
Australia
C?ID=241363
There are lots of settings which are controlled from adaptation channels.
You need to make an adaptation channel map of your 5F infotainment unit:
Christiank
C?ID=253485
I'll do this tomorrow night when I have some time to do this :) Just updated the firmware and that didn't help
Christiank
C?ID=253485
;SW:5C0-035-680-C   HW:5C0-035-680-C ---  Information Electr.
;Component:MU-S-ND-ER    H20 0252, Coding:02731201AA0000001111120100880A001F0106D400200100CF
;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW21.rod
;Sunday,04,March,2018,10:15:57:31035
;VCDS Version: Release 18.1.0 (x64)  Data version: 20180122 DS285.1
;VCID: 2149B77630B0D14D9A-8074
IDE00346-Summertime-automatic,none ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00845-Wheel circ.,0 mm,2
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 ,49
IDE02502-Confirmation of installation change,C1 11 ,2
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE05111-Fee-based traffic information (TMC),32768 ,2
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,9 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),4 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),7 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),4 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,7 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,10 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE10604-Menu entries for mobile online services,activated ,1
IDE11122-Country identification: country of sale HMI,EN ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
MAS00950-Audio Parameter,0 ,1
MAS00951-Bluetooth,On ,1
MAS03782-WLAN,On ,1
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,not activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not activated ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,not activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,not activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,not activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,not activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,not activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not activated ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not activated ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Not available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not available ,8
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50 ,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,3 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,15 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,60 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,0 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,0 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,10 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,15 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,90 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,0 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,0 %,12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 2D 1E 37 28 37 28 2D 1E 07 64 1E 04 10 03 0A 00 00 00 01 03 ,40
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF ,30
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF ,30
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On ,30
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF ,30
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF ,30
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked ,30
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 ,30
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On ,30
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF ,30
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On ,30
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF ,30
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF ,30
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF ,30
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF ,30
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated ,30
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present ,30
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present ,30
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF ,30
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated ,30
ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF ,30
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF ,30
ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF ,30
ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 ,30
ENG109862-ENG152537-Vehicle_configuration-media_control,not activated ,30
ENG109862-ENG138662-Vehicle_configuration-Mirror_link,OFF ,30
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU ,30
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 ,30
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF ,30
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF ,30
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF ,30
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF ,30
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF ,30
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF ,30
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF ,30
ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated ,30
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF ,30
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,On ,30
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 ,30
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 ,30
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 ,30
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active ,30
ENG109862-ENG117844-Vehicle_configuration-picture_navi,On ,30
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated ,30
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated ,30
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 ,30
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF ,30
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF ,30
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 ,30
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF ,30
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated ,30
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS ,30
ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated ,30
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction ,30
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region ,30
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated ,30
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present ,30
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF ,30
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated ,30
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1 ,30
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF ,30
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF ,30
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On ,30
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF ,30
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF ,30
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked ,30
ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF ,30
ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF ,30
ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF ,30
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated ,30
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated ,30
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated ,30
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF ,30
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF ,30
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF ,30
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On ,30
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated ,30
Elapsed Time: 00:43
Here's the list I made with help from the ross tech video in the post above. :)
Christiank
C?ID=253485
Any suggestions to what else can be done to help me get my phone menu in the cluster to be English or even Danish if that is some that can be done hehe :)
kamold
Australia
C?ID=241363
I've had a look through the adaptation channel map and compared to mine and I can't find a setting which would affect just the phone menu...it's certainly strange.
What if you set your cluster language to Danish, and the infotainment to Danish, and then set both of to English after rebooting 5F?
