- Joined
- Feb 23, 2016
- Messages
- 42
- Reaction score
- 2
- Location
- Cornish ME, USA
- VCDS Serial number
- C?ID=271523
Thursday,22,February,2018,21:27:14:18282
VCDS Version: 18.2.0.3
VIN: WAUAF78E37A031868 License Plate: TOMS A4
Mileage: 170720km-106080mi Repair Order: at home
67 69 75 76 77
VIN: WAUAF78E37A031868 Mileage: 170720km-106080miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E0 910 115 P HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0020
Revision: 5EH13--- Serial number:
Coding: 0104010A02070120
Shop #: WSC 05140 444 85840
VCID: 2E536645B9502F34BA-807A
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
000665 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached
Fault Status: 01100010
Mileage: 170722 km
RPM: 3057 /min
Load: 69.0 %
Speed: 82.0 km/h
Temperature: 93.0°C
Temperature: 12.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 M HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI USA 0020
Revision: 00000012 Serial number: 00000002098261
Shop #: WSC 06335 000 00000
VCID: 326B7235AD680BD4DE-8066
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Coding: 0004525
VCID: 2C576C4D8F4C5D2494-8078
Reset counter: 14
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x01A7
Hex Value: 0x0000
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2833
Coding: 00000
VCID: 6CD7AC4D1CCC9D24D4-5106
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 00003
Shop #: WSC 06335
VCID: 3D7151093736C4AC33-4B00
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G00SUK
Coding: 0032607
VCID: 3C775C0D7F2CCDA404-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3BHZX
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB403824CA0Mÿ†63
Subsystem 5 - Serial number: 24CA0Mÿ†6342DRB4035D10A0Gÿ†63
Subsystem 6 - Serial number: D10A0Gÿ†6352ARB4015091ABJÿ†63
Subsystem 7 - Serial number: 091ABJÿ†6362ARB4015BFADFAÿ†63
Subsystem 8 - Serial number: BFADFAÿ†63729RB401658BEA ÿ†63
Subsystem 9 - Serial number: 58BEA ÿ†63829RB401658BC2Tÿ
Subsystem 10 - Serial number: 58BC2Tÿ
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02021
Shop #: WSC 06335
VCID: 41892DF94BCEA04C57-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 G HW: 8E0 920 951 G
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0022201
VCID: 2E536645BA502F34BA-5140
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0022201
VCID: 2E536645BA502F34BA-5124
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11820
Shop #: WSC 06335
VCID: 78FF801D5894218420-4B00
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Component: Tõrsteuer.HL BRM 0606
Component: Tõrsteuer.HR BRM 0606
6 Faults Found:
35-00 - -
35-00 - -
00914 - Window Regulator Switch; Rear Left; Driver (E53)
00912 - Window Regulator Switch; Front Left (E40)
01559 - Drivers Door
57-10 - Electric Circuit Failure - Intermittent
62-10 - No or Incorrect Adjustment - Intermittent
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8E0 035 195 AC HW: 8E0 035 195 AC
Component: R Symphony2+ H07 0250
Revision: 00H07000 Serial number: AUZ1Z4G5809358
Coding: 0000000
VCID: 68DFD05D5834B104B0-5140
Time Indication: 15
End-------------------------(Elapsed Time: 06:32)--------------------------
