2009 Audi Q7 TDI TPMS Either fix or disable
tuningbyamg
Canada
C?ID=230173
Hey guys
Breaking my head with a 2009 Q7 and its TPMS System, can't get it to disable or work, either would be nice
So far i have done the following:
-Checked tire pressures in all
-Tried to disable by removing fuse to TPMS module, CAN Gateway remove module adr 65, and In instrument cluster Long Coding, untick TPMS installed = Doesn't work
-Replaced R96 Antenna under right underbody panel, code for it use to not go away when cleared, now it does. Code for it was 01833 Antenna for Tire Pressure Monitoring/Rear (R96) - No Signal/Communication - MIL ON
-Checked measuring blocks, no pickup of values from any wheel, all 4 have sensors on the valve/inside mag.
-Tried to play with TPMS coding change country to USA/ ROW and add +2 for extra load = no change in situation
Only code that remains in the TPMS module 4F0910273B and immediately re-appears
0521- Sensor for Tire pressure
004 - No signal/communication - MIL ON
S'il vous plait HELP :confused:
I just wont ask for auto-scan but I find a request to disable TPMS hilarious
Oh lighten up, Jack. He asked for help to fix (or disable), and you know better than to worry that we're going to help him disable. I think it sucks that such complexity is mandatory, but I sure don't want the liability associated with disabling either.
tuningbyamg
Canada
C?ID=230173
Thanks Uwe, i said either or :)
now i saw a field in measuring blocks about battery age, are the wheel sensors integrating a battery? Un-replaceable i presume?
Scan will be posted tomorrow
Uwe you know I'm just busting balls....... :p
OP: Lets fix this thing! :rolleyes:
What TPMS controller are we playing with by means of scan or VIN?
I have an ass load of overstock on TPMS controllers if needed but the batteries in the sensors are probably kaput.
There are ways to take apart and replace them in YouTube how to videos....... I have had success myself and saved a customer over $1000 USD!
I am not unsympathetic to the system being a POS!
The force says there is good FOD and BAD FOD .......we know where I stand on the BAD DARK FOD!
Sharing videos .......... 123 HOT knife.........
tuningbyamg
Canada
C?ID=230173
Ok here goes the full scan
I must have at least 8 other sensors around on other wheels the OEM HUF 433mhz
Tried leaving a wheel with sensor close to the frong right, picks up nothing.
Why do i have the feeling the module doesnt see what the antenna picks up?
Wednesday,14,February,2018,14:12:16:44955
VCDS Version: 17.8.0.1
VIN: WA1AM64L89D034266   License Plate:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 55
          56 62 65 67 69 6C 6D 6F 72 76 77
VIN: WA1AM64L89D034266   Mileage: 248530km-154429miles
Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 4L0 910 401 Q    HW: 4L0 907 401 B
   Component: 3.0TDI EDC17G004AG  0100
   Revision: 31H01---    Serial number:
   Coding: 0121002A190F0968
   Shop #: WSC 48286 000 1048576
   VCID: 306F3F00A38CC8C63A-8064
   Part No SW: 09D 927 750 FD    HW: 09D 927 750 FD
   Component: AL 750 6A           1474
   Revision: 00H78000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 75E1CE141C6EADEEA9-8020
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0099473
   VCID: 2959D2648056B90EFD-807C
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601251216
   Coding: 0000131
   VCID: 2541DE54EC4E9D6ED9-8070
   Subsystem 1 - Part No: 4F0 910 132 J
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 732 R    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 354AS097546552
   Coding: 0002003
   VCID: 387F07204BFC108672-806C
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000001239468
   Subsystem 3 - Serial number: 0102.12.080000000100010955ÿ
   Subsystem 4 - Serial number: 010955ÿ
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 N
   Component: KLIMABETAETIGUNGH07 0040
   Revision: 00---014    Serial number: 00000000196204
   Coding: 0000054
   VCID: 2345C04CE27A635EB7-8076
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H22 0320
   Coding: 0012114
   VCID: 346733105794F4E65E-8060
   Component: Wischer AU716   H16 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 110 B    HW: 4L0 035 110
   Component: MP3-Changer     H46 0390
   Revision: 00046004    Serial number: AUZ5ZBI8734625
   VCID: 1E33F1B8C9184EB698-804A
   Component: 75 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD097E93
   Coding: 0014133
   VCID: 2B55286C8AAAAB1E0F-807E
   Subsystem 1 - Serial number: 6332QSME4D1643006
   Subsystem 2 - Serial number: 6342QSME0A173C2CN
   Subsystem 3 - Serial number: 6352QSME4A2038048
   Subsystem 4 - Serial number: 6362QSME0A171D24G
   Subsystem 5 - Serial number: 63734SME1C0C0A04/
   Subsystem 6 - Serial number: 63834SME3F0E411C9
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0530
   Revision: 00H06000    Serial number: 90055083400094
   Coding: 0002242
   VCID: 275DD45C96428F7EEB-8072
   Part No SW: 4L0 920 931 E    HW: 4L0 920 931 E
   Component: KOMBIINSTR.   H06 0135
   Revision: 00100000    Serial number: AF701RV19
   Coding: 8B96640401000008020300
   VCID: 2D51267474BEA52E11-8078
   Part No SW: 4F0 907 468 K    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0025
   Revision: 4LA80024    Serial number: 2400L0911080A1
   Coding: 000303
   VCID: 377D041C86E21FFE7B-8062
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140398033
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001001206643
   Coding: 00581300000011110000
   VCID: 31693A046886C1CE35-8064
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H52 1100
   Revision: 00000000    Serial number: 313KZ087545178
   Shop #: WSC 95863 999 84060
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000100631194
   Coding: 010D07205E40440004
   VCID: 468379D8F1087676F0-8012
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H08 0060
   Revision: 0060 ---    Serial number: 01159467890000
   Coding: 3438621
   VCID: 3365300C529AF3DE47-8066
   Part No SW: 4L0 910 223 K    HW: 4L0 035 223 C
   Component: DSP-AU716-RD  H07 0270
   Revision: S1100000
   Coding: 020100
   VCID: 2C572B704FA4AC2606-8078
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000050873
   Coding: 0012001
   VCID: 5EB3B1B889980EB6D8-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000100650265
   VCID: 45817ED4CC0E7D6EF9-8010
   Part No: 8P0 907 357 H
   Coding: 0000007
   VCID: 3F8D6C3C6ED227BEB3-806A
   Part No SW: 4E0 910 541 T    HW: 4E0 035 542
   Revision: 00000000    Serial number: 304AL097631906
   VCID: 31693A04A886C1CE35-8064
   Revision:             Serial number: 0000100637725
   Coding: 010C07204040230004
   VCID: 438560CCC23A435ED7-8016
   Revision: 00050100    Serial number: 00000900082302
   Coding: 0062424
   Shop #: WSC 45056 347 116111
   VCID: 224BC548FD606A56BC-8076
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000901160151
   Shop #: WSC 12336 024 394758
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 H    HW: 4E0 907 383 G
   Component: Anhaenger     H08 0080
   Revision: 2A002002    Serial number: 00000115335551
   Coding: 0200000000000000
   VCID: 2F6D3C7C7EB2D73E23-807A
   Revision: --H03---    Serial number: 525PA8-J8Y40L5
   Coding: 1020101
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H28 0290
   Revision: --H28001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7EB704F246C2646-8038
   Subsystem 3 - Serial number: RD23.01.09--H28001001C0464ÿ
   Subsystem 4 - Serial number: 1C0464ÿ
   Revision: AAH05061    Serial number: 003861365-----
   Coding: 0003595
   VCID: 2643D95891489676D0-8072
   Component: J_245_EE16_SKB09H10 0200
   Component: J_394_EE16_SKB09H10 0200
   Component: J_392_EE16_SKB09H10 0200
   Revision:             Serial number: 0000100637382
   Part No SW: 4L0 910 283 A    HW: 4L0 919 283 A
   Component: Parkhilfe 8-Kan H02 0400
   Revision: 00H02000    Serial number: 13630833003313
   Coding: 0231246
   VCID: 285FD7609B5C8006E2-807C
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005077987
   Coding: 0010900
End---------------------(Elapsed Time: 03:43, udsna)-----------------------
How old are the sensors?
This is a known good, working sensor? What did you do to wake it up?
tuningbyamg
Canada
C?ID=230173
The sensors on the Audi wheels are probably old.
But the one i took off for testing today from an aftermarket wheel is not even dirty, maybe 2-3 years old tops, and valve stem looks pretty decent too.
To wake it up, well tried the MMI set tire pressure and change wheels, what else can i try?
I've heard that deflating by some substantial amount followed by re-inflation will do the trick. Since it's loose and not supporting a car, I'd drop the pressure by 50%, then re-inflate. But, I think it might also take some rolling time for the system to learn that a particular sensor belongs to it, 'cause otherwise it might decide it owns the sensor(s) in the car(s) parked next to it...
tuningbyamg
Canada
C?ID=230173
Ok i'll try deflating all 4 tires totally and bring them back to correct pressure, see if that changes anything
Is the R96 No basic setting code relevant at all here? What basic settings are there for that antenna?
Just another FYI I found ..............
If you can access the sensors and read them with an external antenna, this is always a good idea to check ID and broadcast.
In addition for sensors with weak batteries:
I have seen you get a few extra years out by taping a piece of copper wire on sensor and rim doing one loop around rim so it broadens range of the broadcast.
Basically a large antenna just like when a remote is with weak battery and guys put under chin to make their skull into a linear of sorts & to make the clicker work again for a further range.
tuningbyamg
Canada
C?ID=230173
Tried deflating one tire and putting back to 44psi as per B pillar label, nothing.
Mounted a wheel with a tire with another 433mhz sensor, set change wheels in MMI and still can't pick up a signal from any wheel.
Might try to tackle this from another angle, my buddy has access to a scanner that can wake up and/or see if an individual wheel sensor transmits something.
I think this will point the direction of the investigation.
tuningbyamg
Canada
C?ID=230173
Ok so here's the latest
The sensors all check out and transmit data when summoned by the reader.
Once awake, i tried going into the MMI and pressed change wheels in order to start the learning by the module.
If code is cleared this time it does not come back immediately like before but until next ignition key cycle
When igintion is cycled only code that comes back is:
What basic setting does it want for that antenna i'm not understanding, my buddy's more advanced reader was asking for a security log in to the TPMS module but i think that requires the SKC of the car which is probably impossible to get, other than to bend over in an Audi dealership...
Oh and with nothing i did so far did the measuring block values fill up for any of the 4 sensors, everything including the ID is 0's or no value.
So if antenna was replaced, and WD for module to antenna shows 3 direct wires, that's it, what else is left??
Me either, because we don't have anything like that documented.
If such a think is needed, it's not the "SKC" for the immobilizer (which varies from car to car). It would be a fixed security code for all the TPMS modules like that, but again, I'm not seeing it anywhere.
If anyone has better info, please chime in.
The autel maxi reads and writes the eeprom of the TPMS directly or by ram overwrite swap from reading and resetting the sensors manually at each respective TPMS sensor.
Then after completed the control module has a faulty antenna so it stops the ADP from being saved during next key cycle and displays the error because either there is a bad TPMS module, wiring or antenna to compare the reading from saved table upon boot from last value.
or
The sensor batteries are so weak they can be seen by the tool so close locally but can't reach the actual antenna for the TPMS module.
https://www.auteltech.com/TPMS Diagnostic & Service Tool/403.jhtml
Keep in mind Autel makes a few different MAxi TPMS tools and the one pictured doesn't have the OBD function as aforementioned but can reset the transponder at each of the respective sensors.
This one however can ..........
https://www.auteltech.com/TPMS Diagnostic & Service Tool/404.jhtml
I think it is time for RT to add to VCDS interface & to make a external key coil and TPMS exciter generator to do similar tasks and backups of transponders.
tuningbyamg
Canada
C?ID=230173
Jack, following your logic here, how does the battery reporting happen then via the signal transmission.
Why can we observe Battery status: OK on the reader?
tuningbyamg
Canada
C?ID=230173
I'm not so sure, it didn't even pick up the newer sensor i offered next to the antenna with another wheel.
That no basic setting code for the R96 is bugging me. I'll try to swap out the TPMS module with one from a Treg i got handy, to see what happens.
