Heres a strange one
Hassan
C?ID=137303
I was driving going home couple of nights ago and this happens; Gearbox malfunction - Safe to drive message came on along with Parking Brake Failure, Steering Assist malfunction and also ABS failure.
My speedometer RPM has stopped working too and pretty sure its linked with the above.
I came home and plugged it into VCFS to see pretty much every single module is seeing red. When I try to access the following modules via VCDS, it throws up a message saying no communication:
Engine
Transmission
Airbag
Parking Brake
Every other module I access seems to say no communication with those 4 modules.
The weird thing I have noticed is that whilst ignition is switched on, but engine off I can move the steering wheel as if the car is running.
Last thing to mention my car is running normal, starts fine and drives fine apart from the above which is strange considering I cannot communicate with the those 4 modules above.
I am thinking along the lines of CAN network issue however have no idea where to start and hoping someone can share some light
Find Scan attached:
Saturday,13,January,2018,12:16:24:05540
VCDS Version: 17.8.1.0 (x64)
VIN:    License Plate: AUDI A7
Mileage: 165566km-102877mi   Repair Order:
Chassis Type: 4G0
Scan: 01 02 03 05 08 09 10 15 16 17 19 30 36 3B 42 44 46 47 52 53
          55 56 5F 62 6D 72 82 8F 90
   Mileage: 165566km-102877miles
01-Engine -- Status: Malfunction 0110
02-Auto Trans -- Status: Malfunction 0110
03-ABS Brakes -- Status: Malfunction 0110
04-Steering Angle -- Status: Malfunction 0110
15-Airbags -- Status: Malfunction 0110
53-Parking Brake -- Status: Malfunction 0110
82-Heads Up Display -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine
Address 02: Auto Trans
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 27A68703E465E1C0DB00
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 3462BB999F2ECBE645-8060
13 Faults Found:
0044 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:01:49
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 22
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: AA
                    Uz: B4
0051 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Time: 00:00:00
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: B3
                    Uz: 98
0058 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:13:44
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: BB
                    Uz: 7E
0060 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:16:43
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: BE
                    Uz: 96
0067 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:13:44
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: D8
                    Uz: 8B
0069 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:16:43
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E0
                    Uz: 96
0073 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:16:43
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F2
                    Uz: 96
0077 - Function Restricted due to Missing Message(s)
          U1111 00 [129] - -
0713 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:13:44
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C2
                    Uz: 82
0715 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:13:44
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C5
                    Uz: 82
0722 - Function Restriction due to Implausible Message(s)
          U1112 00 [137] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:13:44
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 22
                    Uz: 82
0821 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:13:44
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F9
                    Uz: 82
0725 - Function Restriction due to Implausible Message(s)
          U1112 00 [137] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:13:44
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 24
                    Uz: 82
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0330
   Coding: 01BA3000000000000000
   Shop #: WSC 02311 785 00200
   VCID: 76E64191C1D299F6BB-8022
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000115359003
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 45
                    Reset counter: 54
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:35:30
   Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
   Component: KLIMA 2 ZONEN H10 0056
   Serial number: 15061100040722
   Coding: 3623000830
   ASAM Dataset: EV_AirCondiBasisUDS 002033
   VCID: 24424BD92FCE5B66D5-8070
0260 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 12
                    Reset counter: 54
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:49:36
                    Voltage terminal 30: 14.77 V
                    Outside air temperature: 11.0 °C
0275 - Development code 1
          B2F01 00 [008] -  -
                    Reset counter: 94
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:44:40
                    Voltage terminal 30: 14.68 V
                    Outside air temperature: 7.5 °C
                    Energy management heat output control status: Default
                    Electric auxiliary air heater: stage: 2
0276 - Engine Off Timer Performance
          P150A 00 [008] - -
                    Reset counter: 94
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:00:35
                    Voltage terminal 30: 11.59 V
0331 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 35
                    Reset counter: 54
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:35:30
                    Voltage terminal 30: 14.53 V
                    Outside air temperature: 10.5 °C
0392 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 54
                    Mileage: 163253 km
                    Date: 2017.07.14
                    Time: 08:23:34
                    Voltage terminal 30: 13.15 V
                    Outside air temperature: 17.5 °C
                    Interior temperature: 19.99 °C
   Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0100
   Revision: 20012002    Serial number: 00000000940391
   Coding: 2600201040349FE08181008380001D0CCF9DC30A27090101000004602100
   VCID: 6DD46EFDB4845A2E4A-8038
   Component: WWS57X 110518  H35 0051
   Serial number:         110523150047
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11486366
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 G    HW: 4G0 941 531 G
   Component: E1 - LDS  H07 0044
   Serial number: 31 05 2011  00000423
   Component: Humidity_Sens  H02 0002
   Serial number: B5588AA5000000000001
6 Faults Found:
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:43:00
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:43:00
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:43:00
01771 - Control Module for Headlight Range (J431)
                    Reset counter: 94
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:07:00
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:43:00
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:43:00
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4H0 919 475 M    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56231116108267
   Coding: 981304
   ASAM Dataset: EV_EPHVA2CAU57X0000 002008
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 3C7293B9B77E03A68D-8068
6 Faults Found:
12648720 - Databus
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:16:45
12658704 - Databus
                    Reset counter: 54
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:49:23
12648448 - Databus
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:16:46
12648464 - Databus
                    Fault Frequency: 42
                    Reset counter: 54
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:35:29
13637413 - Databus
                    Fault Frequency: 7
                    Reset counter: 54
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:34:47
13679386 - Databus
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:45:15
Address 15: Airbags
   Revision: 00000000    Serial number: 20110610000026
   Coding: 000034
   VCID: 306AB7896336F7C621-8064
   Component: E221 - MFL  H07 0009
01312 - Powertrain Data Bus
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:04:03
                    Fault Status: 01100101
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:04:03
                    Voltage: 11.80 V
                    Hex Value: 0x0000
                    Steering Angle: -1.97°
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:04:03
02085 - Incorrect Control Module Installed
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:04:03
                    Voltage: 11.80 V
                    Hex Value: 0x0000
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:04:03
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 981 S    HW: 4G8 920 981 S
   Component: TDieGb        H71 0375
   Revision: 26181114    Serial number: 658170611593007
   Coding: 33A600020B032600010100
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
   VCID: 4380E845CA807C5ECC-8016
16776962 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:03:20
16776967 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:03:20
16776970 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 94
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:07:48
16776971 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:03:20
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000169292
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 326EBD81653AC5D657-8066
   Component: J367-BDM  H07 0141
   Serial number: 40262M36331051046269
   Voltage stabilizer:
5013 - Headlight Range Control Module
          U101E 00 [008] - No Communication
                    Reset counter: 94
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:07:49
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 11.7 V
                    Control Module temperature: 17 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0257 - Powertrain Databus
          U0002 00 [009] - No Communications
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:46:48
                    Voltage terminal 30: 11.8 V
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 14 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0264 - Powertrain Databus (VAG Wingle-Wire Mode) (SAE  L Shorted H)
          U0009 00 [009] - -
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:46:47
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000016389
   Coding: 01010101000000000001000202
   VCID: 64C20BD9674E1B6615-8030
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006174939
   VCID: 77F84C95C6D8E0FEA0-8022
                    Fault Frequency: 29
                    Reset counter: 54
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:35:30
                    Fault Frequency: 33
                    Reset counter: 54
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:49:23
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA42013VLD0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D54AEFD7C049A2E0A-8078
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011F46225E21628002080402
   Shop #: WSC 02312 785 00200
   VCID: 428EED41DD9A7556C7-8016
                    Fault Frequency: 18
                    Reset counter: 54
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:49:35
                    Fault Frequency: 10
                    Reset counter: 54
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:49:52
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0009399269
   Coding: 000000000000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 3360B8859A20CCDE5C-8066
6 Faults Found:
3158274 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 49
                    Reset counter: 54
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:35:30
                    valid
3158276 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 43
                    Reset counter: 54
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:49:26
                    valid
4205828 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 94
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:00:48
                    valid
4208000 - Steering Angle Sensor
          B1168 F1 [137] - Synchronization Failed
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:45:14
                    valid
                    Fault Frequency: 15
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 02:45:31
                    valid
3150596 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Fault Frequency: 200
                    Reset counter: 94
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:41:48
                    valid
   Revision: 00002001    Serial number: 0151854802
   Coding: 013B062220B9BC8083200A04080100000000000000000000000000000000
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H09 0027
   Serial number: WA102622000000315231
6 Faults Found:
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:48:45
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:48:45
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:48:45
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:48:45
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:48:45
00218 - Humidity Sensor (G355)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:48:49
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000004200
   VCID: 1C3273391FBE63A66D-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 418CE24DD89C6E4EDE-8014
                    Fault Frequency: 18
                    Reset counter: 54
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:49:35
                    Fault Frequency: 10
                    Reset counter: 54
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:49:52
Address 53: Parking Brake
   Serial number: 110612-0004-013
   Coding: 1123A6101000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C52A3F9471E93261D-8078
0095 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Fault Frequency: 63
                    Reset counter: 54
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:35:30
336388 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Fault Frequency: 42
                    Reset counter: 54
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:35:30
   Part No SW: 4G0 035 061 G    HW: 4G0 035 061
   Component: Radio U DAB   H52 0097
   Revision: AB001007    Serial number: 109F 0B7524287
   Coding: 010103010000000001
   VCID: 214C42CD38DC4E4EBE-8074
03278 - Functionality Limited due to Missing Messages
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:39:45
                    Bin. Bits: 00000000 00001000
   Part No SW: 4G0 035 670 C    HW: 4G0 035 670
   Component: H-BNT-EU      H47 0406
   Revision: --------    Serial number: 428FZ0B7516802
   Coding: 090101040003E5ED45108B3E00000003000001000000000000
   VCID: 234048C522C05C5EAC-8076
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Serial number: AUZ8ZDB1300VEAT
   Subsystem 3 - Part No SW: 4G2 919 610 A    HW: 4G2 919 610 A
   Component: E380 BDT C7  H08 0203
   Serial number: 90349KEU000AJ
   Component: CD-Database  3371
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:39:51
                    Bin. Bits: 00010000 00000000
                    Bin. Bits: 00000000 00010000
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F04224021628002080002
   VCID: 4482EB59C78E7B66F5-8010
   Part No SW: 4G8 959 107 L    HW: 4G8 959 107 F
   Component: HDSG-Modul    H13 0039
   Revision: 11013001    Serial number: 137100061
   Coding: 0A3305C002
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 3E7699B1A16211B6A3-806A
   Component: TSG HR        H04 0212
   Part No SW: 4G8 919 604 E    HW: 4G8 919 604 E
   Component: HeadUpDisplay 006 0103
   Coding: AA0000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7_VW51.rod
   VCID: 3564869D9454D2EE72-8060
          U1111 00 [009] - -
                    Fault Frequency: 45
                    Reset counter: 54
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:34:54
16777212 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Fault Frequency: 22
                    Reset counter: 94
                    Mileage: 165567 km
                    Date: 2018.01.12
                    Time: 14:45:00
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FE874F5B688A83E78-803A
8 Faults Found:
12583681 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:00:47
12583691 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:39:40
12583692 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:39:40
12583940 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Reset counter: 94
                    Mileage: 165562 km
                    Date: 2018.01.05
                    Time: 16:45:10
12583961 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Fault Frequency: 124
                    Reset counter: 94
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:38:14
12583964 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Fault Frequency: 18
                    Reset counter: 94
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:44:39
12583967 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 93
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:44:46
12588800 - Internal Control Module Memory Check Sum Error
          B2000 98 [137] - Component or system over temperature
                    Mileage: 148959 km
                    Date: 2016.09.14
                    Time: 15:12:38
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70EA7789ABB6B7C661-8024
8 Faults Found:
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:00:47
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165567 km
                    Date: 2018.01.13
                    Time: 11:39:40
          U1111 00 [009] - -
                    Reset counter: 54
                    Mileage: 165566 km
                    Date: 2018.01.13
                    Time: 00:00:47
          U1112 00 [008] - -
                    Reset counter: 94
                    Mileage: 165562 km
                    Date: 2018.01.05
                    Time: 16:45:10
          U1112 00 [008] - -
                    Fault Frequency: 109
                    Reset counter: 94
                    Mileage: 165555 km
                    Date: 2018.01.05
                    Time: 14:38:14
          U1112 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 94
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:42:44
          U1112 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 93
                    Mileage: 165556 km
                    Date: 2018.01.05
                    Time: 14:44:46
                    Mileage: 148959 km
                    Date: 2016.09.14
                    Time: 15:11:39
End-------------------------(Elapsed Time: 05:24)--------------------------
myounus
Northwest UK
C?ID=321059
Hi Hassan, it sounds like you've either got a flat battery, insufficient voltage, loose terminal, etc. This is the most likely issue, being power related.
Failing in that it could be an issue with the BCM. I'd check power related issues firstly before thinking along those lines.
Hassan
C?ID=137303
Battery seems to be fine although I have not checked it. It starts instantly and always has, so not sure if this is the case.
I did open the terminal on the battery hoping everything would reset, but unfortunately this did not work.
Hassan
C?ID=137303
I think I am in the right track as I've just looked at how all the modules are linked up on the Self Study Program for the A7.
The diagram confirms my suspicion of it being CAN issue as all the modules I have that are not communicating share the Powertrain CAN bus line
myounus
Northwest UK
C?ID=321059
I would get the battery tested and check the cables properly, then try clearing all DTC's.
iichel
Netherlands, eastern part
C?ID=284912
Here is the cause:
Reset counter: 54
Mileage: 165567 km
Date: 2018.01.13
Time: 11:46:48
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
U0009 00 [009] - -
Reset counter: 54
Mileage: 165567 km
Date: 2018.01.13
Time: 11:46:47
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
So somewhere there is likely a short or break in the powertrain can wires. Bring out the multimeter, time to check wiring. Maybe Google for the usual suspects, i.e. corrosion on a module or a sharp edge near a wiring loom.
Here is the cause:
I concur.
Zenerdiode
Newcastle, England
C?ID=24330
Here is the cause:
Wingle-Wire :confused: Eric?
I think that should be Single-Wire. Or maybe Wiggle-Wire. Yep, you've entered VAG Wiggle-Wire Mode and need to wiggle the wire to test it. :D
Wingle-Wire :confused: Eric Uwe?
Fixed that for you -- that's almost certainly a typo that I made. I've already corrected it in the "Source" data, which will make its way into an updated CODES.DAT file at some point. :)
Adz0121
England
C?ID=367928
What was the outcome
