Trailer Module - Spot The Difference
VAG_MAN
C?ID=180336
Hi guys,
Just over a month ago I installed a Genuine factory trailer module to my car. Its all been working perfectly in terms of trailer lights and I have towed several times successfully with it now.
However, I couldnt get the status LED to light up on the handle that you pull in the boot and I think I may have found why now....
I have a suspicion that my trailer module still needs activating but wanted your opinnion and if it can be done via VCDS?
I have pasted below the advancecd ID output from my module and then from another module the same but in a working car. The difference in the output below seems to be in the Programming Attempts(data) fields.
Does this mean anything to anyone or can anyone offer some advice please?
Thanks in advance!
Brand new in my car but not working:
Thursday,08,June,2017,20:51:00:40467
VCDS Version: Release 17.1.3 (x64)
Address 69: Trailer
Control Module Part Number: 4G8 907 383 B
Component and/or Version: Anhaenger H20 0160
Software Coding: 0100000202000000
Work Shop Code: WSC 01236
VCID: 3363507A9AAB7BD924-8066
Advanced Identification/FAZIT
Serial number: 0403032178
Identification: HLH-W42
Revision: 7B001003
Date: 30.04.16
Manufacturer number: P007
Test stand number: 1226
Flash Status
Programming Attempts(application): 1/0
Programming Attempts(data): 0/0/0
Successful Attempts(data): 0/0/0
Flash Date: 00.01.01
Flash Tool Code(data): 00000 000 00000
Misc.
Hardware number: 4G8 907 383 B
Workshop System Name: J345
Equipment/PR Code: 3030303030303030
Dataset Number: -----------
Dataset Version: ----
ASAM Dataset: EV_TrailFunctGener2Hella
ASAM Dataset Revision: 001005
VCDS Info:
Labels: 4H0-907-383-V2.clb
Someone elses working version in another vehicle-
Coding - 0100000202000000
Serial number: 0376447911
Revision: 7B001002
Date: 08.08.15
Test stand number: 0037
Flash Status
Programming Attempts(data): 1/0/0
Successful Attempts(data): 1/0/0
Flash Tool Code(data): 00200 785 02391
Misc.
Equipment/PR Code: 0000000000000000
Dataset Number: 4G0909527B
Dataset Version: 0009
VCDS Info:
VCID: 3362C48E9AAE28D924-8066
:confused:
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The Advanced ID information doesn't include all the Standard/Basic ID information, do you happen to have a full Auto-Scan from both cars? Also, what was the source for the new module? Did a dealer supply that brand spanking new or did you get one used?
VAG_MAN
C?ID=180336
Hi Sebastian,
Thanks for your reply.
I have just run a fresh autoscan on my car and attached below but I dont have access to the working car I am afraid so cant post a full scan for that.
Thursday,08,June,2017,21:15:02:40467
VCDS Version: 17.1.3.0 (x64)
VIN: WAUZZZ4G4HN002211   License Plate:
Chassis Type: 4G (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 47 52 53
          55 5F 62 69 6D 72 AC
VIN: WAUZZZ4G4HN002211   Mileage: 14939km-9282miles
Address 01: Engine (J623-CNHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BP    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1661
   Revision: 85H23---
   Coding: 12254012242601080000
   Shop #: WSC 01236 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021BP 002006
   ROD: EV_ECM20TDI01104L906021BP.rod
   VCID: 74E19366DF253CE1FD-8020
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G0 927 166 N    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H03 0003
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021_VW51.rod
   VCID: 3879675683CD988111-806C
   Coding: 06A69E4160657982BB00
   ROD: EV_ESP9BOSCHAU57X_VW51.rod
   VCID: 418F0AB2D017D949A6-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0824
   Coding: 01B9704E000000000000
   VCID: 7CF1BB46FF7574A1B5-8028
   Serial number: 3216000098481006
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 12051600040490
   Coding: 34220978210000
   VCID: 63C3E03A6ACBAB5994-8036
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 15020001    Serial number: 00001358348101
   Coding: 0105001440349FE041014083800018000F9DE7082F08020100000894E100150200400024030000
   VCID: 74E19366D7253CE1FD-8020
   Component: WWS57X 160329  H38 0080
   Serial number:         160404103927
   Coding: 0045F7
   Serial number: 61803318
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 14 05 2016  00001080
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: 0BD8872800PAG0MUFU01
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1009VMY$
   Coding: 30333130313630323639554A305234473053
   VCID: 3B73785AB2FBB399FC-806E
   Serial number: 3575HRB405H436HU60FA
   Serial number: 3585HRB4055436HU88NH
   Serial number: 3515JRB40593V4GO99U0
   Serial number: 3525JRB405N3VEM880N+
   Serial number: 3554VRB400E570C0PH1%
   Serial number: 3564VRB400E571N8E0NE
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: C0068538    Serial number: 90862PEC000HL
   Coding: 000035
   VCID: 3B73785ABAFBB399FC-806E
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 06 05 2016  D0014290
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
   Component: MDieGb        H43 0604
   Revision: 30450307    Serial number: 658120516592018
   Coding: 33A715000B412600010000
   ASAM Dataset: EV_RBC7KMID 004050
   ROD: EV_RBC7KMID.rod
   VCID: 326D557E65B172D12F-8066
   Part No SW: 4G5 907 468 H    HW: 4G0 907 468 AC
   Component: J533--Gateway H15 0096
   Revision: --------    Serial number: 00000002249889
   Coding: C0CD074418
   ROD: EV_GatewPkoUDS_002.rod
   VCID: 3A7D7D5EBDC18A91E7-806E
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 3471590204
   Voltage stabilizer:
6151 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [009] - No Communication
                    Reset counter: 113
                    Mileage: 14939 km
                    Date: 2017.06.08
                    Time: 21:10:34
                    Voltage terminal 30: 11.4 V
                    Voltage terminal 15: 11.4 V
                    Control Module temperature: 35 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 67DBF42A96F3C77948-8032
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 19051600040548
   Coding: 22
   VCID: 3D777642ACEFBDA9C2-8068
   Revision: AA000000    Serial number: 00000198819899
   VCID: 77FBA46AC65357F9D8-8022
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720R84XW
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_VW51.rod
   Coding: 011C16015E01620002080002
   VCID: 479B14AAF633E77968-8012
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000811314
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0404591033
   Coding: 013F0622A0B93080C320098420010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00020475043
   Revision: CJ007001    Serial number: 00000000192195
   Coding: 030000
   VCID: 1D3796C2042FDDA9E2-8048
   VCID: 468519AEF139FE7193-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001845044
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 316F5A7260B749C956-8064
Address 55: Headlight Range (J745)       Labels: 4H4-907-357-V2.clb
   Coding: 04FE02102A600200
   VCID: 346153669FA57CE13D-8060
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 192 F    HW: 4G1 035 192 A
   Component: RMC Nav Plus  H62 0186
   Coding: 010101010141DB47083B060301020100000000
   VCID: 2645B92E51791E71B3-8072
   Subsystem 1 - Part No: 8X0 919 884 J
   Component: P32-50-15.03  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464D80G2759928
   Subsystem 3 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
   Serial number: 90349PEH0000V
   VCID: 499F1292E02711097E-801C
Address 69: Trailer (J345)       Labels: 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H20 0160
   Revision: 7B001003    Serial number: 0403032178
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 117601500
   Coding: 093205C011
   ROD: EV_HDSGAu571.rod
   VCID: 3665696E89D96EF103-8062
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 161060507
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F6B5C0A76835F3940-807A
End-------------------------(Elapsed Time: 04:59)--------------------------
VAG_MAN
C?ID=180336
Sorry Sebastian, I have just realised I didnt reply to the second part of your question.....
A Main Audi Dealer supplied my module brand spanking new from their parts department so I have a feeling it needs to be activated and maybe thats why my new one doesnt have anything against the program attempts data field?
Does that help?
