2007 Passat with 2.5L 5-Cyl. Engine - ABS Coding?
Geoffzie
C?ID=309752
I don't know if this is the right place to post this ... but ...
I've got a 2007 VW Passat Wagon 2.0t that was purchased in boxes with a blown engine (HPFP issue which led to engine failure). Instead of repairing the 2.0t engine (expensive!), I installed a 2010 Jetta 2.5L 5-cyl. engine with a 2008 Jetta ECU ... that was the easy part!
Long story short, I've got the car running, and I've put about 350 miles on it. But I'm getting several VCDS errors including: ABS Module incorrectly coded, Parking Brake Fault (parking brake works fine), and most recently, incorrect coding for Steering Angle Sensor (G85) ... which apparently, is affected by the ABS Module.
The problem seems to be that there's no coding examples that I can find for a Passat with a 2.5L engine. (I've tried a ton of codes, all to no avail).
Any ideas or solutions? I thought about replacing the ABS pump with one from a Jetta ... but then I might have compatibility issues with other components. I've only had VAG-COM for about a week ... so I'm not yet familiar with all it's in's and out's.
- The ECU is from a 2008 Jetta: 07K-906-032-BJ (the immobilizer was deleted by a company in Massachusetts)
- The ABS Module is the existing 2007 Passat: ESP 440 C2 H015 0004 (3CD-614-095-S)
- The 2007 Passat VIN Number: WVWLK73C97E009332 (The VIN number shown in VCDS is the Jetta ECU VIN number - I'd like to change it)
Here's the latest VCDS scan: (I was going to attach a link to a photo of the PR-Code label ... but apparently, I can't)
Tuesday,06,June,2017,21:06:45:23114
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: WVWBA71K78W315062   License Plate:
Chassis Type: 1K (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 6D
          72
VIN: WVWBA71K78W315062   Mileage: 219120km-136154miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BJ    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1567
   Revision: 1NH01---    Serial number: VWX7Z0H33N97Z2
   Coding: 0000003
   Shop #: WSC 01279 785 00200
   VCID: 72BED2CB78AA85372BD-8026
050197 - Implausible Data Received from ABS Control Module
               U0415 - 008 -
                    Fault Frequency: 25
                    Mileage: 219110 km
                    Date: 2016.01.20
                    Time: 12:25:06
                    RPM: 776 /min
                    Load: 23.9 %
                    Temperature: 31.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 14.605 V
005171 - Secondary Air Pump Relay (J299)
               P1433 - 004 - Open Circuit - Intermittent
                    Fault Frequency: 9
                    Mileage: 219110 km
                    Date: 2016.01.20
                    Time: 12:50:03
                    RPM: 294 /min
                    Load: 76.8 %
                    Temperature: 34.0°C
                    Temperature: 34.0°C
                    Voltage: 11.176 V
001393 - Brake Switch (F)
               P0571 - 008 - Implausible Signal
                    Mileage: 219112 km
                    Date: 2016.01.20
                    Time: 13:14:41
                    RPM: 1176 /min
                    Load: 18.4 %
                    Speed: 46.0 km/h
                    Temperature: 80.0°C
                    Temperature: 43.0°C
                    Voltage: 14.351 V
Readiness: 0000 1100
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 CJ
   Component: AQ 250 6F           1068
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 08114 444 84076
   VCID: 005A88034606A7A72D9-8054
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0100005710
   Coding: 0000000
   Shop #: WSC 05311 000 00000
   VCID: 323E12CBB82AC537EBD-8066
                    Reset counter: 47
                    Mileage: 219120 km
                    Date: 2016.01.20
                    Time: 20:52:13
00599 - Plausibility of Pressure/Brake Light Switch
                    Reset counter: 48
                    Mileage: 219120 km
                    Date: 2016.01.20
                    Time: 21:00:36
                    Reset counter: 48
                    Mileage: 219120 km
                    Date: 2016.01.20
                    Time: 21:00:36
   Part No: 1K0 820 047 EB
   Component: Climatic PQ35   090 0505
   VCID: 688AB0A34E767FE7859-803C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Revision: 00H46000    Serial number: 00000005468122
   Coding: 008C0F0340041A00470A00000F00000000285D435C0000
   Shop #: WSC 05311 123 12345
   VCID: 372823DF5348201FDC3-8062
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 05311
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P2W7PWA
   Coding: 0012366
   Shop #: WSC 05311 000 08193
   VCID: 2E0606BBAC12E1D78F5-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000032EPS
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0E716159Eÿ†63
   Subsystem 5 - Serial number: 16159Eÿ†6342MSME105B60746ÿ†63
   Subsystem 6 - Serial number: B60746ÿ†6351HTS64IKQTM627ÿ†63
   Subsystem 7 - Serial number: QTM627ÿ†6361HTS6TLLE15C3Uÿ†63
   Subsystem 8 - Serial number: E15C3Uÿ†63727TS63IK2T6C39ÿ†63
   Subsystem 9 - Serial number: 2T6C39ÿ†63827TS63IKEPNQ25ÿ
   Subsystem 10 - Serial number: EPNQ25ÿ
   Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
   Revision: 00005000    Serial number: 3C9953507R
   Coding: 0002014
   VCID: 313C1DC7BD2CFE2F927-8064
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Revision: V0033000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 01119 067 57207
   VCID: 333017CF4730CC3FE0B-8066
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C0631304F6
   Coding: 3FFD0C0CD22002
   VCID: 211CED87EDCC4EAF027-8074
                    Reset counter: 47
                    Mileage: 219086 km
                    Date: 2016.01.19
                    Time: 09:52:59
   Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1339817TQ3XP02
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 64713 001 1048576
   VCID: 2A0E0AAB90FA8DF753D-807E
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2801
   Coding: 0001205
   VCID: 36362EDB5442D917C75-8062
   Part No: 1K1 909 144 K
02546 - Steering Limit Stop
                    Mileage: 9080 km
                    Temperature: 27.0°C
                    Voltage: 14.60 V
                    Voltage: 14.30 V
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13900E88D1032E521804141FF00A0F0E081800
   Part No: 1K0 959 702 K
   Coding: 0001204
   Revision:   013
   Coding: 0000013
00650 - Clutch Pedal Switch (F36)
                    Fault Status: 00101010
                    Reset counter: 89
                    Mileage: 219120 km
                    Date: 2016.01.20
                    Time: 20:00:48
                    Voltage: 13.25 V
                    Count: 71
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 A    HW: 1K0 035 161 A
   Component: Radio DE2       012 0015
   Revision: 00012000    Serial number: VWZ4Z7F6117447
   Coding: 0040400
   VCID: 1D64D177D1B46A4F26F-8048
   Part No: 3C9 959 703 A
   Component: Tuer-SG         021 2507
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100101
                    Fault Status: 01110100
                    Reset counter: 47
                    Mileage: 219097 km
                    Date: 2016.01.19
                    Time: 11:43:11
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
   Component: J605  HECKDECKEL    0405
   Revision: 00H20001
   Shop #: WSC 23250 384 715754
   VCID: 303A18C3B626F7279D9-8064
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0405
   Subsystem 2 - Serial number: 0600H20001001C0055ÿ
00317 - Rear Lid Control Module (J605)
                    Reset counter: 88
                    Mileage: 218433 km
                    Date: 2015.06.28
                    Time: 00:01:23
                    Fault Frequency: 10
                    Reset counter: 65
                    Reset counter: 88
                    Mileage: 218433 km
                    Date: 2015.11.13
                    Time: 00:00:02
   Part No: 3C9 959 704 A
   Coding: 0000144
End----------(Elapsed Time: 01:15, VBatt start/end: 14.1V/14.2V)-----------
kamold
Australia
C?ID=241363
This is a very non-scientific approach but given enough time it will work...
Try coding your ABS to 0000001. Then 0000002.....etc.
At some point you will start to get request out of range errors. At this point start adding 3 to your values, then when you start getting request out of range errors start adding 5 etc.
Eventually you will find a coding string that is accepted and gives you no more fault codes regarding incorrectly coded.
Then you do G85 steering angle sensor basic settings (also may need to calibrate G200 and G201), clear faults from all modules and you should be good to go.
I have done this before. Slow but eventually effective. In my case I ended up with a coding string of 001434.
NZDubNurd
New Zealand
C?ID=230482
Could you please confirm your Vin Number as I have never seen before Passat with 1K or is it Jetta 2008 model.....?
That will be the VIN from the Jetta ECU he fitted to the Passat.
Ashraf6119
C?ID=174194
OK I got it now Thanks....Fitted with Immobiliser been deleted that's why the Vin Number did not change
Geoffzie
C?ID=309752
Yes Ashraf6119, that's another side issue (less important) that I'd like to change ... the VIN number ... so that the correct 2007 Passat VIN number is in the Jetta ECU. I assume that's possible with VCDS? CAN the VIN be changed?
Kamold, that's an interesting solution. But explain why you would add 3 or 5 to your numbers (although I have already gotten out-of-range errors with many of the numbers I've tried) ... aren't you skipping potential coding that could work?
As I understand it, the coding for any module is simply a summation of all the components it's connected to and must communicate with. Therefore, there MUST be a coding that will work somewhere out there in the universe ... but finding it is the issue! ... Is that assumption correct?
I probably won't get back to this until tomorrow, I'll give it a try.
Ashraf6119
C?ID=174194
Can you try this code and let us know......
Coding: 0013629 or Coding: 0013569
kamold
Australia
C?ID=241363
1. Because it's a short coding string which is a hexadecimal long code converted to decimal. It's not a summary of all modules but rather a configuration parameter which tells the module how to behave. Only certain values are valid based on a config map from VW. Unfortunately for these abs units these maps do not appear to be widely available hence the guesswork
2. I got the technique from Golfi_vend
3. It works ;)
Geoffzie
C?ID=309752
Thanks Ashraf6119, those are two of the codes on my list I haven't tried yet. I'll let you know tomorrow.
And thanks kamold, I knew there had to be a "method to your madness" ... I'll give it a go tomorrow as well.
So, my question is, (I'm probably not understanding all this yet fully) ... if VW never pared the 2.5L engine with this particular ABS module, would there still be coding available for it? (theoretically)
kamold
Australia
C?ID=241363
Only 1 way to find out..
Geoffzie
C?ID=309752
Well, it seems I've got a major problem now.
I was coding the ABS module ... I started at 0000000 and progressed (eventually in increments of 3) to 0000157. Here was my process. (by the way Ashraf6119, I tried 0013629 and 0013569, they're accepted, but the ABS and ESP lights return).
1. Battery charger hooked up on trickle charge (I'm going to be starting the car a lot)
2. VCDS cable hooked up
3. Ign. on
4. recoded ABS module
5. If the code was accepted, I cleared any previous ABS codes and started the car
6. If the ABS and ESP lights returned, I'd turn the car off
7. Turn ign. back on and try the next code
But when I got to around 0000131 ... the car began "chugging" at idle, although it would rev up OK. No engine codes yet ... I checked. I then decided to just start at 0001000 since none of the ABS codes I've seen were under that (to save some time).
I got to 0001031, coded the ABS module, and VCDS froze up! I shut the engine off, and turned it back on ... same thing. I rebooted my computer and tried again ... same thing VCDS freezing ... and eventually giving me an error message saying "Too many communication errors to continue" (or something to that effect). I tried to do an Autoscan ... NOTHING! ... said it's "unable to communicate"! I checked that the cable was connected to both the computer and the car (just got the VCDS a week ago - it's new).
I took the car for a drive and when I pulled back into the garage, it wouldn't idle at all, and the check-engine light was flashing. Checked the codes with an OBDII scanner since VCDS wouldn't work ... I got P0300, P0301, P0302, P0303, P0305, P2279.
I disconnected the car battery for about 10 minutes, reconnected, and tried again ... VCDS cannot communicate ... and the engine still idles rough.
At this point, I don't know where to go. Keep in mind, the engine only had about 70,000 miles on it when I got it ... and it ran perfectly for about 350 miles ... although, in one of my VCDS scans, I DID get a P2279, but it went away in later scans. The codes point to a major vacuum leak somewhere, but why would that keep VCDS from communicating?
Tomorrow, I'm going to look for vacuum leaks ... I already disassembled the PCV valve (a few days ago) on the cam cover (that's a common problem with the 2.5 engines), it looked fine and held vacuum.
Any ideas as to why VCDS cannot communicate? I realize that my programming the ABS module may not be directly related to the engine codes / problems ... but COULD it be?
Test VCDS on a different car to make sure that your interface hasn't lost its mind.
In principle, coding the ABS should not have that kind of effect on the ECU.
http://wiki.ross-tech.com/wiki/index.php/18711/P2279/008825
The P030x codes are misfires, which might well be a side-effect of an air leak.
Ashraf6119
C?ID=174194
Once the code is accepted than Do Not Recycle the Ignition carry on the Basic Settings for the Steering Angle Sensor and for any other Sensors you have faults for.........
1) Enter the Coding>>>>>
2) Basic Settings for Sensor for Steering Angle (G85)
3) Basic Settings for Lateral Acceleration Sensor (G200)
4) Basic Settings for Brake Pressure Sensor 1 (G201)
Check fault codes if you have and other faults carry out the Basic Settings and than you can recycle the ignition but if you recycle before doing the basic settings the ABS Coding will not be saved
Edited: Can you please confirm: When you connect your VCDS interface does the Orange light on the interface change to Green..............?
Also does the vehicle still have its original radio or, its a after market radio fitted
He's got a HEX-V2. There is no orange on that one. Plugged into car only, it should be yellow. Plugged into computer only, it should be blue. Plugged in on both ends, green. It should switch reg/green when actively communicating.
Ashraf6119
C?ID=174194
Thanks Uwe I thought it was an old type of interface :) like my is over 15 years old interface :) which switches from orange to green :)
Hyperbole, Ash. Your HEX+CAN is only about 5 years old. :p
Ashraf6119
C?ID=174194
The one registered here yes........Got another which is that old which is under our workshop name
Geoffzie
C?ID=309752
Ashraf6119, no aftermarket radio ... actually, there's nothing aftermarket on the car ... everything is just as it came from the factory ... except the engine and ECU of course.
First off, I'll have to verify that the cable is OK with another car. I don't have another VW, but I could probably take it over to the guy I bought the engine from.
Concerning the coding, you mean I have to go through all the basic settings, for EVERY code that is accepted? If so, this is going to take FOREVER! I do know that when I went back to try another code (even after turning the ignition off), the previous (accepted) code was still there ... the field only remained unchanged if the previous code I tried was NOT accepted.
Geoffzie
C?ID=309752
Ashraf6119, are you saying that without going through the basic settings, the ABS and ESP lights could still remain on ... even though the ABS coding were correct?
kamold
Australia
C?ID=241363
Once the ABS accepts a valid coding string, THEN you need to perform basic settings on G85, G200, G201.
