2018 Tiguan, 2.0T DGUA maps
Jef
HQ
All glory to the Hypno-Scan
Monday,13,November,2017,16:29:08:47536
VCDS Version: 17.10.0.2 (x64)  HEX-NET CB: 0.4408.4
Data version: 20171026 DS283.3
VIN: 3VV1B7AX6JM018053   License Plate: 02
Mileage: 96km-59mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: 3VV1B7AX6JM018053   Mileage: 96km-59miles
Address 01: Engine (J623-DGUA)       Labels: None
   Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H30 0004
   Revision: 1DH30000
   Coding: 012A00122424010F24000000000000000000000000000000
   Shop #: WSC 00066 790 00453
   ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
   ROD: EV_ECM20TFS0115NA907115A.rod
   VCID: BC3B37BD37D297CA201-80E8
Readiness: 0000 0101
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 B    HW: 09G 927 158
   Component: AISIN AQ8     206 3380
   Coding: 0002000100000000000000000000000000000000
   ROD: EV_TCMAQ450031.rod
   VCID: B2271985E59651BAFAD-80E6
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 51557000000942
   Coding: 0BFA6BA454211B74C5770205A2C649D0D62AD8A34045927000415058C2024200002764121A1C230A35351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: F8B3EBAD436A7BEA049-80AC
   Part No SW: 5NN 907 426     HW: 5NN 907 426
   Component: AC Manuell el H34 4301
   Revision: 20K05000    Serial number: 00000D00019381
   Coding: 00020004200110001000000000000006
   ASAM Dataset: EV_ACManuePrehVW37X 002021
   ROD: EV_ACManuePrehVW37X_002_VW37.rod
   VCID: 8D5DAA795CE86E4247F-80D8
   Yes:
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0243
   Revision: --------    Serial number: C86407061700CD
   Shop #: WSC 00066 790 00445
   ROD: EV_BCMBOSCH_018.rod
   VCID: 8B59A46122FC607259B-80DE
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170623  034 0373
   Serial number: 17061721028510
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM05NEWN
   Coding: 8CCCFC00000000005000001AC20800000065
   VCID: 854D9259049816020FF-80D0
   Occupant Detection:
   Serial number: IBH000000000007GGS2T
   Coding: 303345
   Subsystem 2 - Part No SW: -----------    HW: 480 002 005 17
   Serial number: 35700000000E5940142B
   Subsystem 3 - Part No SW: -----------    HW: 480 002 005 17
   Serial number: 358000000002A7D8942S
   Subsystem 4 - Part No SW: -----------    HW: 480 402 205 17
   Serial number: 3510001B524A431614CU
   Subsystem 5 - Part No SW: -----------    HW: 480 402 205 17
   Serial number: 3520001C124A431593BX
   Subsystem 6 - Part No SW: -----------    HW: 480 401 706 17
   Serial number: 3550001B726441E194E5
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 706 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001B526441E561C0
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 23051704220360
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 8247894515B6213A2AD-80D6
   Part No SW: 5NA 920 850 B    HW: 5NA 920 850 B
   Component: KOMBI         370 0310
   Coding: 0BA4090A2380CF0502082A001400000020000000
   VCID: BE3F3DB521CE85DA0E5-80EA
   Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5304
   Serial number: 08071700840504
   Coding: 030100347F085900FA0000481C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   Subsystem 2 - Part No SW: 5NN 959 442     HW: 5NN 959 442
   Serial number: 1671701541100249BH2B
   Coding: 280000
   Serial number: 5951073804
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        010 0032
   Serial number: 7028719600941
   Coding: 003003200000028000000000
   VCID: C5CD52594418D6024FF-8090
   Serial number: 00000000000006803153
   Coding: 011000
   Revision: 00000000    Serial number: 0001782725
   Coding: 01000010004000
   ROD: EV_SteerAssisVWBSMQBA_009.rod
   VCID: C0C3434D5B3AF32A7C9-8094
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       010 0032
   Serial number: 8028719401241
   VCID: C4CB4F5D4F22EF0A581-8090
   Serial number: 00000000000006862477
   Coding: 091000
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      671 8395
   Serial number: 29041700020074
   Coding: 02230600BE00000041220001001000009F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW37.rod
   VCID: F0A3D38D2B1A23AACC9-80A4
   Subsystem 2 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
End----------(Elapsed Time: 01:03, VBatt start/end: 14.8V/14.9V)-----------
Engine map, cold start
;SW:5NA-907-115-A   HW:06L-907-309-B ---  Engine
;Component:R4 2.0l TFSI  H30 0004, Coding:012A00122424010F24000000000000000000000000000000
;EV_ECM20TFS0115NA907115A,001005,EV_ECM20TFS0115NA907115A.rod
;Monday,13,November,2017,16:26:27:47536
;VCDS Version: Beta 17.10.0 (x64)  Data version: 20171026 DS283.3
;VCID: BC3B37BD37D297CA201-80E8
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VV1B7AX6JM018053,
IDE00019,Voltage terminal 30,14.460, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,1191, /min
IDE00025,Coolant temperature,13, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,7, s
IDE00083,Throttle valve position (absolute),15.3, %
IDE00084,Absolute load value,45, %
IDE00085,Normed load value,3.9, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,42.5, Nm
IDE00102,Control Module temperature,14.1, °C
IDE00148,Median injection timing,2.4732, ms
IDE00150,Pressure in brake booster,86.99, hPa
IDE00151,Oil fill level,84.800, mm
IDE00152,Oil warning threshold,58.000, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,41.1, °C
IDE00172,A/C compressor torque,30.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-25.22, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-24.20, °
IDE00178,Camshaft adjustment intake bank 1: specified value,0.00, °
IDE00179,Camshaft adjustment intake bank 1: actual value,-0.13, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,0.00, °
IDE00186,Fuel low pressure: actual value,0.0, kPa
IDE00187,Coolant temperature at engine start,12.9, °C
IDE00188,Fuel high pressure: actual value,9.5980, MPa
IDE00190,Charge air pressure specified value,647.58, hPa
IDE00191,Charge air pressure: actual value,1062.58, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,12.6, °C
IDE00194,Coolant temperature at radiator output: specified value,98.9, °C
IDE00196,Engine oil temperature,9.9, °C
IDE00201,High fuel pressure: specified value,9.5080, MPa
IDE00202,Low fuel pressure: specified value,438.4, kPa
IDE00304,Fuel level,32.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,10.55, g/s
IDE00348,Intake air temperature,12, °C
IDE00349,Throttle valve position: normed,5, %
IDE00350,Air mass: specified value,37.6, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,0,
IDE00357,Fuel temperature,12.8, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,995.90, hPa
IDE00371,Fuel consumption,4.56, l/h
IDE00375,Generator: load signal,35.43, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,739.8, mV
IDE00393,Accelerator pedal: sensor voltage 2,368.6, mV
IDE00394,Camshaft position: start of phase window,118.19, °
IDE00405,Crankshaft speed (RPM),1181.0, /min
IDE00406,Camshaft speed (RPM),592.8, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown,
IDE00474,Ambient air pressure,99, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,12.6, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,0,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,143,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,9, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.003 Lambda / -0.004 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,1.275, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,0.915, Lambda
IDE00583,Throttle valve specified value,6, %
IDE00584,Distance driven since erasing DTC memory,78, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,55.7, %
IDE00589,Fuel pressure,6940, kPa rel
IDE00592,Oxygen sensor control status,Open loop, conditions for  / closed loop not yet satisfied ,
IDE00593,Ignition timing adjustment cylinder 1,-11.5, Degrees
IDE00594,Absolute intake pressure,52, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,-3.9, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,5,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00699,ESI: minimum oil level in service interval,32.000, mm
IDE00700,ESI: maximum oil level in service interval,-32.000, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,-0.00159,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,9.5, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator power,1696.46, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,3,
IDE01267,Height correction,0.98273,
IDE01378,High fuel pressure: control deviation,0.0180, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Status of starter activation-Bits 0-7,2,
IDE01590,Status of brakes,Not operated,
IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,167,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test off,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,1.526, V
IDE01650,Throttle valve position 2,15, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test off,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,14540, mV
IDE01869,Long-term fuel trim bank 1 at idle,-0.19, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,8.0000,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,5.6, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,32.047, %
IDE01885,Shut off of oxygen sensor control,l-Reg.OFF,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
IDE01887,Adaptation of Fuel Pump (FP),0.0, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.016,
IDE01891,Cold start enrichment: adaptation area 4,1.039,
IDE01892,Cold start enrichment: adaptation area 5,1.109,
IDE01893,Fuel pump: specified value,55.614, %
IDE01896,Charge pressure control: damping grtr max. threshold adaptation,0.000, %
IDE01897,Charge pressure control: damping lsr min. threshold adaptation,0.000, %
IDE01899,Load value: corrected specified value,111.98, %
IDE01900,Charge press. ctrl.: spec. value,99.6, %
IDE01901,Lost torque adaptation: idle,5.6, Nm
IDE01902,Lost torque adaptation A/C compressor,5.8, Nm
IDE01903,Lost torque adaptation driving mode,0.2, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,8.1, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.96515,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.02863,
IDE01911,Leakage air,3.0, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,0,
IDE01916,Leakage recognition from oxygen sensor control,0.9814,
IDE01917,Leakage after throttle valve,0.000,
IDE01918,Leakage before throttle valve,-1.000,
IDE01919-ENG57549,Leakage recognition: status-Bits 0-7,208,
IDE01922,Vehicle distance driven,96, km
IDE01923,Control module distance driven,95639, m
IDE01924,Load shift flaps: actual value,0.000, %
IDE01925,Load shift flaps: specified value,0.000, %
IDE01926,Adaptation of load shift flaps,3.765, V
IDE01927,Result of load shift flap adaptation,ADP is OK,
IDE01927-ENG129325,Result of load shift flap adaptation-Test_Program_Channel 514,2,
IDE01928,Close cam shaft angle at quantity control valve,37.4, °
IDE01929,Open cam shaft angle at quantity control valve,-3.0, °
IDE01930,High pressure regulation: adaptation value,-0.128, MPa
IDE01932,High pressure pump injection volume,-29.30, mm³
IDE01975,Numb.of misfir.: cylinder 1,48,
IDE01976,Numb.of misfir.: cylinder 2,59,
IDE01977,Numb.of misfir.: cylinder 3,94,
IDE01978,Numb.of misfir.: cylinder 4,59,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,178,
IDE02117,Relative load value,31.48, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.03, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,107,
IDE02757,Number of automatic engine starts,11,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,9,
IDE03010-MAS01627,Number of prevented stop processes-Steering,36,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,49,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,1,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,48,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,24,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,1,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,1,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,27,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,3, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,1,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,12,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,30, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,11,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,9,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,2017,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.488, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.508, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG57549,Adaptation status for transmission neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3857.0, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver door status-Dsplb Drv Door Act Opn,1,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,-0.033, m/s²
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,231,
IDE03700,Status adaptation dew point end,ADP is running,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
IDE03709,Angle difference actual-specified camshaft adjuster,-0.02, °
IDE03711,Mass flow through throttle valve,29.1, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,17.572, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,0,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,0,
IDE03813,Test of secondary air system: result,Syst. OK,
IDE03813-ENG129327,Test of secondary air system: result-Test_Program_Channel 239,228,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,131070.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.0, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,1.566, %
IDE03830,Status of adaptation of on-demand fuel pump,Test off,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03932,Charge pressure actuator: specified position,150.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3497.0, mV
IDE03935,Charge pressure actuator: adaptation for upper stop,687.0, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03952-ENG114938,Intake manifold pressure plausibility check recovery conditions-Bhepl psr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.96448,
IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,0,
IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,0,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04002,Charge press. ctrl.,BP_A act:100, kPa
IDE04083,Coolant temperatures,ECT 1:27 °C / ECT 2:12 °C,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,3269.8, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,100.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,99.12, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,-1.17, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,1.17, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-14.25, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3472.4, mV
IDE04409,Intake manifold pressure: corrected,484.22, hPa
IDE04410,Intake manifold pressure: target value,489.45, hPa
IDE04414,Cat conv temp: modeled,105, °C
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04630,AVS valve stroke position: current,false,
IDE04630-ENG06942,AVS valve stroke position: current-Test_Program_Xaied Fa Ehan Adc jnotd jb n 0 A1T UBYTE,0,
IDE04637,Engine temperature management actuator,0.00, %
IDE04638,Transmission coolant valve,False result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04685,Setpoint generation interior torque,42.1, Nm
IDE04689,Starter control: Start interruption status,Correct result,
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-3276.8, Nm
IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04814,Transmission oil cooler valve,False result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,976.45, hPa
IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
IDE04887,Powertrain target torque,6.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,9.3, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,0,
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE05128,Intake air temperature in intake manifold bank 1,12.0, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,528978, s
IDE05140,Intake manifold pressure raw value,483.83, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05215,Tank vent valve diagnosis result correlation factor,0.00,
IDE05221,E-machine torque actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05260-ENG57549,Gear position sensor: current value-Bits 0-7,0,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05262,Gear position sensor: gear position valid,False result,
IDE05262-ENG127289,Gear position sensor: gear position valid-Test_Program_B TRUE UBYTE,0,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,9.0, °C
IDE05438,Rear cat conv temp main cat conv model value,122.4, °C
IDE05442,Roadway slope angle acceleration interface: calculated,-0.0031, rad
IDE05444,Air filling: specified value,32.27, %
IDE05445,Pressure before throttle valve of pressure sensor,997.27, hPa
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,700, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00507,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05474,Main cat converter OSC age correction factor,1.44531,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05479,Misfire recognition reference moment,8.571, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05488,Coolant temperature modeled value,12.9, °C
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05593,Secondary air injection sensor 1,993.87, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,6.023, %
IDE05809,Counter: implaus. short-term adapt. values: misfire detection,0,
IDE05928,Fuel consumption since DTC memory last erased,15.901, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05943,Release for supply to fuel pump,On,
IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,135,
IDE05950,Charge pressure control adaptation value 1,-8.4375, hPa
IDE05951,Charge pressure control adaptation value 2,0, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,0, hPa
IDE06015,Time since term 15 OFF StartStop,65535, s
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,12.3, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,65,
IDE06039,Required RPM at idle speed,1200.0, /min
IDE06040,High fuel pressure: regulator output value,-0.3880, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06043,Cylinder head temperature: actual value,28.1, °C
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,19, hPa
IDE06098,Sensor control factor: output value,1.00000,
IDE06112-ENG57549,Cylinder shut-off test-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0041115, V•ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0087929, V•ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0057266, V•ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0046059, V•ms
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,0,
IDE06255,Vehicle lateral acceleration,0.00, g
IDE06256,Vehicle lateral acceleration: raw value,0.00, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,1,
IDE06307-MAS00108,Stop prevention history data-Day,7,
IDE06307-MAS00109,Stop prevention history data-Hours,12,
IDE06307-MAS00110,Stop prevention history data-Minutes,3,
IDE06307-MAS00111,Stop prevention history data-Seconds,42,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Driving situation,
IDE06308-MAS00106,Start request history data-Year,2063,
IDE06308-MAS00107,Start request history data-Month,3,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,15,
IDE06308-MAS00110,Start request history data-Minutes,3,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Restriction in the start system,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Cat. heater,
IDE06386,Oil level: static measurement,0.000, mm
IDE06387,Oil level: last valid dynamic value,0.000, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06391,Oil temperature sensor 2,-273.1, °C
IDE06393,Oil level: dynamic average value,131.068, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06431,Result: aging test: O2 sensor 1: bank 1: before cat converter,Test off,
IDE06431-ENG130130,Result: aging test: O2 sensor 1: bank 1: before cat converter-Test_Program_Channel 115,235,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,0,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,-0.031, m/s²
IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
IDE06495,Results of testing of crankcase ventilation successful,0,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06567,Start-stop function deactivation frequency counter,12,
IDE06568,Stop prevention by driver frequency counter,60,
IDE06569,Vehicle stopped frequency counter,161,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,11.6, °C
IDE06610,Vehicle standstill with stop frequency counter,14,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,130,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,4,
IDE06706-ENG57549,ACC variants-Bits 0-7,0,
IDE06707-ENG57549,CCS Switch-Bits 0-7,1,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,1,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06726,Timing deviation after chain replacement: intake bank 1,-0.94, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,0.87, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738-ENG57549,Chain elongation: no. of valid initial values: intake bank 1-Bits 0-7,1,
IDE06740-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 1-Bits 0-7,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06742-ENG36870,Chain elongation: initial values valid: intake bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06744-ENG36870,Chain elongation: initial values valid: exhaust bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06758,Air mass since engine start,0.4327, kg
IDE06794,NG to gasoline split factor,0.000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06950-ENG57549,Load request from external load manager-Bits 0-7,0,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,1202.0, /min
IDE06970,Desired braking torque: driving assistant,0.0, Nm
IDE06975-ENG57549,Regeneration stages-Bits 0-7,0,
IDE07001,Piston-cooling jets: activation,0,
IDE07031,Oil pressure switch for piston-cooling jets: status,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,15,
IDE07078,AVS result of last switch-over: intake,15,
IDE07164,Number injections,1962,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07225-ENG57549,Transfer electric drive to combustion drive-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07234,Status bid for valid static oil level,0,
IDE07235,Status bid for dynamic oil level,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG57549,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07548,Engine temp. mangmt. actuator: specified value of angle,61.95, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,61.73, %
IDE07550,Engine temp. management actuator: raw value,2495.8, mV
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07553,Engine temperature management actuator: after-run stop,3950.0, mV
IDE07554,Engine temperature management actuator: stop open,144.4, mV
IDE07573,Throttle valve adapter: actual value,5.922, %
IDE07615,Operating of tank: empty or reserve,OK,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07666,Target torque of elec. motor: coordinated output signal,0.0, Nm
IDE07667,Desired torque of regeneration,-34.0, Nm
IDE07724,Coolant temperature at engine outlet: calculated,31.7, °C
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE07963-ENG57549,Cam piece counter position malfunction-Bits 0-7,0,
IDE08071-ENG57549,Remote start cancellation reason store 1-Bits 0-7,0,
IDE08072-ENG57549,Remote start cancellation reason store 2-Bits 0-7,0,
IDE08073-ENG57549,Remote start cancellation reason store 3-Bits 0-7,0,
IDE08074-ENG57549,Remote start cancellation reason store 4-Bits 0-7,0,
IDE08075-ENG57549,Remote start cancellation reason store 5-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09319-ENG57549,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG57549,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,1.22, g
IDE09532,Correction factor for fuel mixture,1.00000,
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09693-ENG57549,Charisma driving program: system status-Bits 0-7,0,
IDE09694-ENG57549,Charisma driving program: act. value-Bits 0-7,2,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,0,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,2,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-0.81, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,0.79, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-1.01, °
IDE09932,Intake camshaft bank1: adaption value sensor tolerance,0.64, °
IDE09942,Long-term adaptation of mixture formation FSI: additive,-0.19, %
IDE09943,Long-term adaptation of mixture formation FSI: multiplicative,0.96448,
IDE09944,Long-term adaptation of mixture formation MPI: additive,0.00, %
IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,1.00000,
IDE09977,Control module temp.: max. value,55.6, °C
IDE10040-ENG57549,Outlet camshaft bank 1 active operating mode-Bits 0-7,6,
IDE10041,Intake camshaft bank1 active operating mode,6,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10120,Chain elongation inlet: mileage of the last adaptation,1, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,1, km
IDE10302,Time since engine start,55.0, s
IDE10303,Integrated air masse at first engine start,0.4971, kg
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.53, V
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,85.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2063,
IDE10989-MAS00107,Immobilizer: historic data-Month,3,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,15,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,3,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10994,Poor start counter at start-stop,0,
IDE11081,AVS operating state: inlet,1,
IDE11083-ENG29792,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,10.957, l
IDE11372,Camshaft angle adaptation: inlet deviation,0.000, °
IDE11541-ENG57549,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function restriction,active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Diagnosis of air system,not active,
IDE11577-MAS04870,Stop process prevented 2-Test of thermostat not complete,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,active,
IDE11577-MAS06604,Stop process prevented 2-Start-stop sensor system,active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration operation,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-Event memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Adaptation active,not active,
IDE11577-MAS13644,Stop process prevented 2-Motor protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel salinization protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust emission control diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in the start system,not active,
IDE11635-ENG57549,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG57549,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,-0.00159,
IDE12355,ESI: consumption equivalent of the engine control module,0.00000184,
IDE12453,Knock sensor based camshaft angle adjustment: counter,0,
IDE13012,Tank breather valve: activation duty factor,0.000, %
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,2181038080,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13772,Engine protection torque limitation,1000.0, Nm
IDE80106,Analysis 106,00 03 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 C0 00 00 00 00 00 00 01 17 00 76 00 0A 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,32.0, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,588.3, °C
MAS16074,Temperature in pre-cat bank 1: model value,350.9, °C
MAS16088,Lambda driver request: specified value,1.0000,
MAS16089,Lambda component protection: bank 1: specified value,1.0000,
MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
MAS16097,Tank ventilation factorial fuel amount: actual value,0.000,
MAS16098,Tank ventilation relative mixture proportion: actual value,0.00, %
MAS16301,Sensor adaptation: status with engine running,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,235.84, °C
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.12, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,11.05, kg
ENG26434-ENG57549,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG26435-ENG57549,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG26436-ENG57549,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG26437-ENG57549,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,1,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,0,
ENG121429-ENG57549,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG57549,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG57549,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG101413,Calibration Identification,5NA115A 0004BXBA,
ENG99697,Calibration Verification Number,53 F9 6A DB,
ENG08794-ENG57549,Com st X Set1 Val1-Bits 0-7,0,
ENG08795-ENG57549,Com st X Set1 Val2-Bits 0-7,0,
ENG08796-ENG57549,Com st X Set1 Val3-Bits 0-7,0,
ENG08797-ENG57549,Com st X Set1 Val4-Bits 0-7,0,
ENG08798-ENG57549,Com st X Set1 Val5-Bits 0-7,0,
ENG08799-ENG57549,Com st X Set1 Val6-Bits 0-7,0,
ENG08800-ENG57549,Com st X Set1 Val7-Bits 0-7,0,
ENG08801-ENG57549,Com st X Set2 Val1-Bits 0-7,0,
ENG08802-ENG57549,Com st X Set2 Val2-Bits 0-7,0,
ENG08803-ENG57549,Com st X Set2 Val3-Bits 0-7,0,
ENG08804-ENG57549,Com st X Set2 Val4-Bits 0-7,0,
ENG08805-ENG57549,Com st X Set2 Val5-Bits 0-7,0,
ENG08806-ENG57549,Com st X Set2 Val6-Bits 0-7,0,
ENG08807-ENG57549,Com st X Set2 Val7-Bits 0-7,0,
ENG08808-ENG57549,Com st X Set3 Val1-Bits 0-7,0,
ENG08809-ENG57549,Com st X Set3 Val2-Bits 0-7,0,
ENG08810-ENG57549,Com st X Set3 Val3-Bits 0-7,0,
ENG08811-ENG57549,Com st X Set3 Val4-Bits 0-7,0,
ENG08812-ENG57549,Com st X Set3 Val5-Bits 0-7,0,
ENG08813-ENG57549,Com st X Set3 Val6-Bits 0-7,0,
ENG08814-ENG57549,Com st X Set3 Val7-Bits 0-7,0,
ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,8,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,25,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,4,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,37,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,209,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,0,
ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,1,
ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-32768.0, Nm
ENG111582,DrivingProgramSwitch_sport_mode_activated,False result,
ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG114220,Effective_injection_duration,11.586, ms
ENG111593,Emachine_achievable_enginetorque_maximum_value,0.0, Nm
ENG111594,Emachine_achievable_generatortorque_maximum_value,0.0, Nm
ENG112932,Engine_oil_temperature_measured_value,-273.1, °C
ENG111034,Engine_temperature_modelbased_substitute_value,24.8, °C
ENG112302,EngineCoordinator_activation_within_quasistationary_limits_of_ElM,False result,
ENG112302-ENG127289,EngineCoordinator_activation_within_quasistationary_limits_of_ElM-Test_Program_B TRUE UBYTE,0,
ENG111568,EngineCoordinator_intervention_request_actual_value,0,
ENG112301,EngineManagement_activation_limited_reduction_of_efficiency,False result,
ENG112301-ENG127289,EngineManagement_activation_limited_reduction_of_efficiency-Test_Program_B TRUE UBYTE,0,
ENG111610,Epm Ca S phi Adap Ref Pos O1 mp 0,67.81, °
ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG26780,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
ENG26808,Fl Lvl vol Tnk Plaus Old,43.000, l
ENG111608,Fuel_consumption_actual_driving_cycle,0.06, l
ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,0,
ENG112667,Generator load normalised value,16.10, %
ENG112931,Generator_load_from_CAN,292.168, W
ENG112929,Generator_torque_request,2.4, Nm
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,28.6, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou*sec O2 Sens Mon Con Enc Cou B 1,00 05 00 69 00 00 00 05 00 00 00 00 00 01 00 05 00 00 00 00 00 01 00 05 00 15 00 04 00 02 00 03 00 00 00 05 00 00 00 00,
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2063,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,3,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,15,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,3,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2000,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,1,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,7,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,12,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,3,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,1,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2000,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,0,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,14,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,9,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,1,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,37,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG127733,Life_cycle_data_system_failure,not active,
ENG111606,Load value: unrestricted commanded value,31.45, %
ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,1,
ENG26325,Mo F Strt st Strtr Blk Err Msg,0,
ENG111571,Mode_control_activation_P1_mode,False result,
ENG111571-ENG127289,Mode_control_activation_P1_mode-Test_Program_B TRUE UBYTE,0,
ENG107660,Mode_control_commanded_dragmoment_for_em,-32.0, Nm
ENG107661-ENG57549,Mode_control_operating_status_hybrid_system_bitcoded-Bits 0-7,0,
ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
ENG107663,Mode_control_torque_electrical_auxilary_systems_requested_value,0.0, Nm
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG26996-ENG57549,OEM2RB VW Byp flg E Hmnplt u8-Bits 0-7,0,
ENG108262,Powertrain_overall_gear_ratio,1.00,
ENG111605,Pressure_before_throttle_valve_actual_value,998.13, hPa
ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,32.8, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,32.8, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,0,
ENG08688,Thr Vlv u Sens1 B1,0.708, V
ENG08689,Thr Vlv u Sens2 B1,4.291, V
ENG01775,Top_speed_limitation,180.000, km/h
ENG109528,Torque_coordination_idle_speed_control_torque_actual_value_air_path,0.0, Nm
ENG109529,Torque_coordination_idle_speed_control_torque_SET_path_actual_value,0.0, Nm
ENG109533,Torque_distribution_Emaschine_combustion_engine_driver_request,7.0, Nm
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,0,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,4,
ENG111604,Turbocharger_inlet_pressure_corrected_value,486.95, hPa
ENG119911,UEGO r Lam S1 B1,1.0020,
ENG01774,Velocity_limiter_setpoint,511.992, km/h
ENG27262,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG27263,Virtual_SigXSet_TiEngOff_tiDiagRef,69, s
ENG27264,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,528922, s
ENG27265,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8171078, s
ENG27266,Virtual_SigXSet_TiOff_tiStrtEnd_Off,65535, s
Elapsed Time: 01:02
Engine map, at temp
;SW:5NA-907-115-A   HW:06L-907-309-B ---  Engine
;Component:R4 2.0l TFSI  H30 0004, Coding:012A00122424010F24000000000000000000000000000000
;EV_ECM20TFS0115NA907115A,001005,EV_ECM20TFS0115NA907115A.rod
;Monday,13,November,2017,16:32:22:47536
;VCDS Version: Beta 17.10.0 (x64)  Data version: 20171026 DS283.3
;VCID: BC3B37BD37D297CA201-80E8
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VV1B7AX6JM018053,
IDE00019,Voltage terminal 30,14.680, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,718, /min
IDE00025,Coolant temperature,85, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,362, s
IDE00083,Throttle valve position (absolute),11.0, %
IDE00084,Absolute load value,18, %
IDE00085,Normed load value,2.7, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,28.0, Nm
IDE00102,Control Module temperature,19.3, °C
IDE00148,Median injection timing,0.9692, ms
IDE00150,Pressure in brake booster,15.00, hPa
IDE00151,Oil fill level,83.264, mm
IDE00152,Oil warning threshold,60.832, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,461.1, °C
IDE00172,A/C compressor torque,30.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-23.83, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-24.13, °
IDE00178,Camshaft adjustment intake bank 1: specified value,7.50, °
IDE00179,Camshaft adjustment intake bank 1: actual value,7.58, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.31, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-0.66, °
IDE00186,Fuel low pressure: actual value,0.0, kPa
IDE00187,Coolant temperature at engine start,12.9, °C
IDE00188,Fuel high pressure: actual value,6.6120, MPa
IDE00190,Charge air pressure specified value,335.00, hPa
IDE00191,Charge air pressure: actual value,992.50, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,14.2, °C
IDE00194,Coolant temperature at radiator output: specified value,102.3, °C
IDE00196,Engine oil temperature,52.2, °C
IDE00201,High fuel pressure: specified value,6.3160, MPa
IDE00202,Low fuel pressure: specified value,500.0, kPa
IDE00304,Fuel level,32.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,2.49, g/s
IDE00348,Intake air temperature,17, °C
IDE00349,Throttle valve position: normed,1, %
IDE00350,Air mass: specified value,9.3, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,0,
IDE00357,Fuel temperature,47.3, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,995.31, hPa
IDE00371,Fuel consumption,0.85, l/h
IDE00375,Generator: load signal,22.54, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,743.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,368.6, mV
IDE00394,Camshaft position: start of phase window,118.17, °
IDE00405,Crankshaft speed (RPM),708.5, /min
IDE00406,Camshaft speed (RPM),354.8, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown,
IDE00474,Ambient air pressure,99, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,4.0, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,1,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,165,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,10, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.995 Lambda / -0.020 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.760, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.000, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,78, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,55.7, %
IDE00589,Fuel pressure,6250, kPa rel
IDE00592,Oxygen sensor control status,Closed loop,  / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,-2.5, Degrees
IDE00594,Absolute intake pressure,29, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,-1.6, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,5,
IDE00604,Short term adaptation of mixture formation bank 1,1.6, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00699,ESI: minimum oil level in service interval,32.000, mm
IDE00700,ESI: maximum oil level in service interval,-32.000, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,-0.00140,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,10.0, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator power,292.168, W
IDE01266-ENG57549,Coolant shut-off valve-Bits 0-7,3,
IDE01267,Height correction,0.98260,
IDE01378,High fuel pressure: control deviation,-0.0380, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01405-ENG57549,Status of starter activation-Bits 0-7,2,
IDE01590,Status of brakes,Not operated,
IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,167,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test off,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.764, V
IDE01650,Throttle valve position 2,11, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test off,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,1,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,1,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,14640, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.56, %
IDE01870,Oxygen sensor after catalytic converter: operating status,B1-S2 OK,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,8.0000,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,3.4, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,34.143, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01887,Adaptation of Fuel Pump (FP),0.0, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.016,
IDE01891,Cold start enrichment: adaptation area 4,1.039,
IDE01892,Cold start enrichment: adaptation area 5,1.109,
IDE01893,Fuel pump: specified value,60.425, %
IDE01896,Charge pressure control: damping grtr max. threshold adaptation,0.000, %
IDE01897,Charge pressure control: damping lsr min. threshold adaptation,0.000, %
IDE01899,Load value: corrected specified value,100.01, %
IDE01900,Charge press. ctrl.: spec. value,99.6, %
IDE01901,Lost torque adaptation: idle,3.2, Nm
IDE01902,Lost torque adaptation A/C compressor,5.8, Nm
IDE01903,Lost torque adaptation driving mode,0.2, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,8.1, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.01392,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.02863,
IDE01911,Leakage air,2.8, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,168,
IDE01916,Leakage recognition from oxygen sensor control,1.0173,
IDE01917,Leakage after throttle valve,-1.000,
IDE01918,Leakage before throttle valve,-1.000,
IDE01919-ENG57549,Leakage recognition: status-Bits 0-7,220,
IDE01922,Vehicle distance driven,96, km
IDE01923,Control module distance driven,95639, m
IDE01924,Load shift flaps: actual value,0.000, %
IDE01925,Load shift flaps: specified value,0.000, %
IDE01926,Adaptation of load shift flaps,3.765, V
IDE01927,Result of load shift flap adaptation,ADP is OK,
IDE01927-ENG129325,Result of load shift flap adaptation-Test_Program_Channel 514,2,
IDE01928,Close cam shaft angle at quantity control valve,28.4, °
IDE01929,Open cam shaft angle at quantity control valve,30.0, °
IDE01930,High pressure regulation: adaptation value,-0.250, MPa
IDE01932,High pressure pump injection volume,-32.97, mm³
IDE01975,Numb.of misfir.: cylinder 1,48,
IDE01976,Numb.of misfir.: cylinder 2,72,
IDE01977,Numb.of misfir.: cylinder 3,207,
IDE01978,Numb.of misfir.: cylinder 4,59,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,255,
IDE02117,Relative load value,16.59, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.03, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,107,
IDE02757,Number of automatic engine starts,11,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,9,
IDE03010-MAS01627,Number of prevented stop processes-Steering,36,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,49,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,1,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,48,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,24,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,1,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,1,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,27,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,3, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,1,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,12,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,30, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,11,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,9,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,2017,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.488, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.508, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG57549,Adaptation status for transmission neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3789.8, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver door status-Dsplb Drv Door Act Opn,1,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,not active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,-0.029, m/s²
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,227,
IDE03700,Status adaptation dew point end,ADP is OK,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,2,
IDE03709,Angle difference actual-specified camshaft adjuster,0.27, °
IDE03711,Mass flow through throttle valve,9.1, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,33.838, %
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,10,
IDE03813,Test of secondary air system: result,Syst. OK,
IDE03813-ENG129327,Test of secondary air system: result-Test_Program_Channel 239,228,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,328.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,300.4, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,28.168, %
IDE03830,Status of adaptation of on-demand fuel pump,Test off,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03932,Charge pressure actuator: specified position,150.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3497.0, mV
IDE03935,Charge pressure actuator: adaptation for upper stop,687.0, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03952-ENG114938,Intake manifold pressure plausibility check recovery conditions-Bhepl psr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.96448,
IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,1,
IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,0,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04002,Charge press. ctrl.,BP_A act:99, kPa
IDE04083,Coolant temperatures,ECT 1:87 °C / ECT 2:14 °C,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,1064.6, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,100.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,97.38, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,-1.17, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,1.17, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-14.36, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3423.6, mV
IDE04409,Intake manifold pressure: corrected,300.94, hPa
IDE04410,Intake manifold pressure: target value,316.95, hPa
IDE04414,Cat conv temp: modeled,390, °C
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04630,AVS valve stroke position: current,false,
IDE04630-ENG06942,AVS valve stroke position: current-Test_Program_Xaied Fa Ehan Adc jnotd jb n 0 A1T UBYTE,0,
IDE04637,Engine temperature management actuator,0.00, %
IDE04638,Transmission coolant valve,False result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04685,Setpoint generation interior torque,27.9, Nm
IDE04689,Starter control: Start interruption status,Correct result,
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-3276.8, Nm
IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04814,Transmission oil cooler valve,False result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,980.20, hPa
IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
IDE04887,Powertrain target torque,1.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,5.8, Nm
IDE04909-ENG57549,Operating mode of hybrid system-Bits 0-7,0,
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE05128,Intake air temperature in intake manifold bank 1,17.3, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,528978, s
IDE05140,Intake manifold pressure raw value,302.11, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
IDE05215,Tank vent valve diagnosis result correlation factor,0.00,
IDE05221,E-machine torque actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05260-ENG57549,Gear position sensor: current value-Bits 0-7,0,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05262,Gear position sensor: gear position valid,False result,
IDE05262-ENG127289,Gear position sensor: gear position valid-Test_Program_B TRUE UBYTE,0,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,9.0, °C
IDE05438,Rear cat conv temp main cat conv model value,395.3, °C
IDE05442,Roadway slope angle acceleration interface: calculated,-0.0031, rad
IDE05444,Air filling: specified value,16.83, %
IDE05445,Pressure before throttle valve of pressure sensor,992.50, hPa
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,700, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00488,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,784.91, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05474,Main cat converter OSC age correction factor,1.44531,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05479,Misfire recognition reference moment,5.653, %
IDE05482,Tank venting adaptation factor,1.295,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05488,Coolant temperature modeled value,24.4, °C
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05593,Secondary air injection sensor 1,993.87, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,1.688, %
IDE05809,Counter: implaus. short-term adapt. values: misfire detection,0,
IDE05928,Fuel consumption since DTC memory last erased,16.141, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05943,Release for supply to fuel pump,On,
IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,135,
IDE05950,Charge pressure control adaptation value 1,-8.4375, hPa
IDE05951,Charge pressure control adaptation value 2,0, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,0, hPa
IDE06015,Time since term 15 OFF StartStop,65535, s
IDE06017,Camshaft position deviation from reference position,-0.15, °
IDE06020,Intake air temperature in intake manifold bank raw value,17.5, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,720.0, /min
IDE06040,High fuel pressure: regulator output value,-0.4220, MPa
IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06043,Cylinder head temperature: actual value,87.5, °C
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,15, hPa
IDE06098,Sensor control factor: output value,1.00128,
IDE06112-ENG57549,Cylinder shut-off test-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0042114, V•ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0038139, V•ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0039162, V•ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0042816, V•ms
IDE06198-ENG57549,Tank vent valve: diagnostic status-Bits 0-7,0,
IDE06255,Vehicle lateral acceleration,0.00, g
IDE06256,Vehicle lateral acceleration: raw value,0.00, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,1,
IDE06307-MAS00108,Stop prevention history data-Day,7,
IDE06307-MAS00109,Stop prevention history data-Hours,12,
IDE06307-MAS00110,Stop prevention history data-Minutes,3,
IDE06307-MAS00111,Stop prevention history data-Seconds,42,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Driving situation,
IDE06308-MAS00106,Start request history data-Year,2063,
IDE06308-MAS00107,Start request history data-Month,3,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,15,
IDE06308-MAS00110,Start request history data-Minutes,3,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Restriction in the start system,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Cat. heater,
IDE06386,Oil level: static measurement,0.000, mm
IDE06387,Oil level: last valid dynamic value,0.000, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06391,Oil temperature sensor 2,-273.1, °C
IDE06393,Oil level: dynamic average value,131.068, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06431,Result: aging test: O2 sensor 1: bank 1: before cat converter,Test off,
IDE06431-ENG130130,Result: aging test: O2 sensor 1: bank 1: before cat converter-Test_Program_Channel 115,235,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,-0.031, m/s²
IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
IDE06495,Results of testing of crankcase ventilation successful,4,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06567,Start-stop function deactivation frequency counter,12,
IDE06568,Stop prevention by driver frequency counter,60,
IDE06569,Vehicle stopped frequency counter,161,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,33.3, °C
IDE06610,Vehicle standstill with stop frequency counter,14,
IDE06647-ENG57549,Start-stop switch status-Bits 0-7,1,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,130,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,4,
IDE06706-ENG57549,ACC variants-Bits 0-7,0,
IDE06707-ENG57549,CCS Switch-Bits 0-7,1,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,1,
IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,255,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06726,Timing deviation after chain replacement: intake bank 1,-0.94, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,0.87, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738-ENG57549,Chain elongation: no. of valid initial values: intake bank 1-Bits 0-7,1,
IDE06740-ENG57549,Chain elongation: no. of valid initial values: exhaust bank 1-Bits 0-7,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06742-ENG36870,Chain elongation: initial values valid: intake bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06744-ENG36870,Chain elongation: initial values valid: exhaust bank 1-Test_Program_Sw SVW b Vld ag Cm In Ex Adp Ini Lyr VERB COMPU UBYTE,0,
IDE06758,Air mass since engine start,2.4452, kg
IDE06794,NG to gasoline split factor,0.000,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
IDE06947-ENG57549,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06950-ENG57549,Load request from external load manager-Bits 0-7,0,
IDE06956-ENG57549,Driver-side belt buckle status-Bits 0-7,2,
IDE06957,Unfiltered clutch input rpm,712.5, /min
IDE06970,Desired braking torque: driving assistant,0.0, Nm
IDE06975-ENG57549,Regeneration stages-Bits 0-7,0,
IDE07001,Piston-cooling jets: activation,0,
IDE07031,Oil pressure switch for piston-cooling jets: status,0,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,15,
IDE07078,AVS result of last switch-over: intake,15,
IDE07164,Number injections,20285,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07225-ENG57549,Transfer electric drive to combustion drive-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07234,Status bid for valid static oil level,0,
IDE07235,Status bid for dynamic oil level,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG57549,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07548,Engine temp. mangmt. actuator: specified value of angle,48.05, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,48.47, %
IDE07550,Engine temp. management actuator: raw value,1991.8, mV
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07553,Engine temperature management actuator: after-run stop,3950.0, mV
IDE07554,Engine temperature management actuator: stop open,144.4, mV
IDE07573,Throttle valve adapter: actual value,1.609, %
IDE07615,Operating of tank: empty or reserve,OK,
IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
IDE07620-ENG57549,Status momentary default during stability intervention-Bits 0-7,0,
IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07666,Target torque of elec. motor: coordinated output signal,0.0, Nm
IDE07667,Desired torque of regeneration,-25.0, Nm
IDE07724,Coolant temperature at engine outlet: calculated,87.9, °C
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07840-ENG57549,Status plausibility accelerator pedal to brake pedal-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE07963-ENG57549,Cam piece counter position malfunction-Bits 0-7,0,
IDE08071-ENG57549,Remote start cancellation reason store 1-Bits 0-7,0,
IDE08072-ENG57549,Remote start cancellation reason store 2-Bits 0-7,0,
IDE08073-ENG57549,Remote start cancellation reason store 3-Bits 0-7,0,
IDE08074-ENG57549,Remote start cancellation reason store 4-Bits 0-7,0,
IDE08075-ENG57549,Remote start cancellation reason store 5-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG57549,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09319-ENG57549,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG57549,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,1.28, g
IDE09532,Correction factor for fuel mixture,1.00000,
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09693-ENG57549,Charisma driving program: system status-Bits 0-7,0,
IDE09694-ENG57549,Charisma driving program: act. value-Bits 0-7,2,
IDE09695-ENG57549,Charisma driving program: target value from coordinator-Bits 0-7,0,
IDE09696-ENG57549,Charisma driving program: CAN output value-Bits 0-7,2,
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG57549,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-0.83, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,2.18, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-1.01, °
IDE09932,Intake camshaft bank1: adaption value sensor tolerance,0.64, °
IDE09942,Long-term adaptation of mixture formation FSI: additive,0.66, %
IDE09943,Long-term adaptation of mixture formation FSI: multiplicative,0.96448,
IDE09944,Long-term adaptation of mixture formation MPI: additive,0.00, %
IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,1.00000,
IDE09977,Control module temp.: max. value,55.6, °C
IDE10040-ENG57549,Outlet camshaft bank 1 active operating mode-Bits 0-7,8,
IDE10041,Intake camshaft bank1 active operating mode,8,
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10120,Chain elongation inlet: mileage of the last adaptation,1, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,1, km
IDE10302,Time since engine start,410.2, s
IDE10303,Integrated air masse at first engine start,2.4658, kg
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.53, V
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,85.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2063,
IDE10989-MAS00107,Immobilizer: historic data-Month,3,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,15,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,3,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10994,Poor start counter at start-stop,0,
IDE11081,AVS operating state: inlet,1,
IDE11083-ENG29792,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,11.137, l
IDE11372,Camshaft angle adaptation: inlet deviation,0.000, °
IDE11541-ENG57549,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function restriction,not active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Diagnosis of air system,not active,
IDE11577-MAS04870,Stop process prevented 2-Test of thermostat not complete,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start-stop sensor system,active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration operation,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-Event memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Adaptation active,not active,
IDE11577-MAS13644,Stop process prevented 2-Motor protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel salinization protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust emission control diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in the start system,not active,
IDE11635-ENG57549,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG57549,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,-0.00549,
IDE12355,ESI: consumption equivalent of the engine control module,0.00000040,
IDE12453,Knock sensor based camshaft angle adjustment: counter,0,
IDE13012,Tank breather valve: activation duty factor,11.694, %
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,2181038080,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13772,Engine protection torque limitation,1000.0, Nm
IDE80106,Analysis 106,00 03 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 C0 00 00 00 00 00 00 01 17 00 76 00 0A 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,32.0, l
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,388.6, °C
MAS16074,Temperature in pre-cat bank 1: model value,451.3, °C
MAS16088,Lambda driver request: specified value,1.0000,
MAS16089,Lambda component protection: bank 1: specified value,1.0000,
MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
MAS16097,Tank ventilation factorial fuel amount: actual value,0.125,
MAS16098,Tank ventilation relative mixture proportion: actual value,2.11, %
MAS16301,Sensor adaptation: status with engine running,0,
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16543,Bank 1 heated oxygen sensor downstream of catalytic converter: exhaust gas temperature calculated,387.53, °C
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
ENG119898,Actual_section_of_standard_test,0,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,2.04, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,11.05, kg
ENG26434-ENG57549,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG26435-ENG57549,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG26436-ENG57549,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG26437-ENG57549,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,1,
ENG121428-ENG57549,AVS_counter_error_debonce-Bits 0-7,0,
ENG121429-ENG57549,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG57549,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG57549,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG101413,Calibration Identification,5NA115A 0004BXBA,
ENG99697,Calibration Verification Number,53 F9 6A DB,
ENG08794-ENG57549,Com st X Set1 Val1-Bits 0-7,0,
ENG08795-ENG57549,Com st X Set1 Val2-Bits 0-7,0,
ENG08796-ENG57549,Com st X Set1 Val3-Bits 0-7,0,
ENG08797-ENG57549,Com st X Set1 Val4-Bits 0-7,0,
ENG08798-ENG57549,Com st X Set1 Val5-Bits 0-7,0,
ENG08799-ENG57549,Com st X Set1 Val6-Bits 0-7,0,
ENG08800-ENG57549,Com st X Set1 Val7-Bits 0-7,0,
ENG08801-ENG57549,Com st X Set2 Val1-Bits 0-7,0,
ENG08802-ENG57549,Com st X Set2 Val2-Bits 0-7,0,
ENG08803-ENG57549,Com st X Set2 Val3-Bits 0-7,0,
ENG08804-ENG57549,Com st X Set2 Val4-Bits 0-7,0,
ENG08805-ENG57549,Com st X Set2 Val5-Bits 0-7,0,
ENG08806-ENG57549,Com st X Set2 Val6-Bits 0-7,0,
ENG08807-ENG57549,Com st X Set2 Val7-Bits 0-7,0,
ENG08808-ENG57549,Com st X Set3 Val1-Bits 0-7,0,
ENG08809-ENG57549,Com st X Set3 Val2-Bits 0-7,0,
ENG08810-ENG57549,Com st X Set3 Val3-Bits 0-7,0,
ENG08811-ENG57549,Com st X Set3 Val4-Bits 0-7,0,
ENG08812-ENG57549,Com st X Set3 Val5-Bits 0-7,0,
ENG08813-ENG57549,Com st X Set3 Val6-Bits 0-7,0,
ENG08814-ENG57549,Com st X Set3 Val7-Bits 0-7,0,
ENG01773-ENG57549,Configuration_of_cruise_control-Bits 0-7,8,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,0,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG126403-ENG57549,Cruise_control_shutoff_conditions_reversible-Bits 0-7,25,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG111031-ENG57549,DFC_status_error_debounced_counter-Bits 0-7,0,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,4,
ENG111033-ENG57549,DFC_status_tested_counter-Bits 0-7,77,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,169,
ENG111032-ENG57549,DFC_status_untested_counter-Bits 0-7,0,
ENG126404-ENG57549,Drive_train_coordinator_checked_coding-Bits 0-7,1,
ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-32768.0, Nm
ENG111582,DrivingProgramSwitch_sport_mode_activated,False result,
ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG114220,Effective_injection_duration,5.658, ms
ENG111593,Emachine_achievable_enginetorque_maximum_value,0.0, Nm
ENG111594,Emachine_achievable_generatortorque_maximum_value,0.0, Nm
ENG112932,Engine_oil_temperature_measured_value,-273.1, °C
ENG111034,Engine_temperature_modelbased_substitute_value,63.8, °C
ENG112302,EngineCoordinator_activation_within_quasistationary_limits_of_ElM,False result,
ENG112302-ENG127289,EngineCoordinator_activation_within_quasistationary_limits_of_ElM-Test_Program_B TRUE UBYTE,0,
ENG111568,EngineCoordinator_intervention_request_actual_value,0,
ENG112301,EngineManagement_activation_limited_reduction_of_efficiency,False result,
ENG112301-ENG127289,EngineManagement_activation_limited_reduction_of_efficiency-Test_Program_B TRUE UBYTE,0,
ENG111610,Epm Ca S phi Adap Ref Pos O1 mp 0,69.19, °
ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG26780,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
ENG26808,Fl Lvl vol Tnk Plaus Old,43.000, l
ENG111608,Fuel_consumption_actual_driving_cycle,0.23, l
ENG106769-ENG57549,Gearbox_heat_request-Bits 0-7,0,
ENG112667,Generator load normalised value,22.54, %
ENG112931,Generator_load_from_CAN,292.168, W
ENG112929,Generator_torque_request,4.0, Nm
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,9.0, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou*sec O2 Sens Mon Con Enc Cou B 1,00 05 00 69 00 00 00 05 00 00 00 00 00 01 00 05 00 00 00 00 00 01 00 05 00 15 00 04 00 02 00 03 00 00 00 05 00 00 00 00,
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2063,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,3,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,15,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,3,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2000,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,1,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,7,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,12,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,3,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,1,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2000,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,0,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,14,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,9,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,1,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,37,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG127733,Life_cycle_data_system_failure,not active,
ENG111606,Load value: unrestricted commanded value,17.79, %
ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.008,
ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,1,
ENG26325,Mo F Strt st Strtr Blk Err Msg,0,
ENG111571,Mode_control_activation_P1_mode,False result,
ENG111571-ENG127289,Mode_control_activation_P1_mode-Test_Program_B TRUE UBYTE,0,
ENG107660,Mode_control_commanded_dragmoment_for_em,-24.0, Nm
ENG107661-ENG57549,Mode_control_operating_status_hybrid_system_bitcoded-Bits 0-7,0,
ENG111581-ENG57549,Mode_control_start_order_combustion_engine-Bits 0-7,0,
ENG107663,Mode_control_torque_electrical_auxilary_systems_requested_value,0.0, Nm
ENG112668,O2 sensor_controller_bank_1_p-rate,-0.00662,
ENG26996-ENG57549,OEM2RB VW Byp flg E Hmnplt u8-Bits 0-7,0,
ENG108262,Powertrain_overall_gear_ratio,1.00,
ENG111605,Pressure_before_throttle_valve_actual_value,992.50, hPa
ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,32.8, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,32.8, %
ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG01786-ENG57549,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,0,
ENG08688,Thr Vlv u Sens1 B1,0.547, V
ENG08689,Thr Vlv u Sens2 B1,4.454, V
ENG01775,Top_speed_limitation,180.000, km/h
ENG109528,Torque_coordination_idle_speed_control_torque_actual_value_air_path,0.0, Nm
ENG109529,Torque_coordination_idle_speed_control_torque_SET_path_actual_value,0.0, Nm
ENG109533,Torque_distribution_Emaschine_combustion_engine_driver_request,3.0, Nm
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,0,
ENG01785-ENG57549,Transmission_state_of_drivetrain_coordinator-Bits 0-7,4,
ENG111604,Turbocharger_inlet_pressure_corrected_value,299.53, hPa
ENG119911,UEGO r Lam S1 B1,0.9885,
ENG01774,Velocity_limiter_setpoint,511.992, km/h
ENG27262,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG27263,Virtual_SigXSet_TiEngOff_tiDiagRef,69, s
ENG27264,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,528922, s
ENG27265,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8171078, s
ENG27266,Virtual_SigXSet_TiOff_tiStrtEnd_Off,65535, s
Elapsed Time: 01:02
J519 Adaption channel map
;SW:5Q0-937-087-AR   HW:5Q0-937-087-AN ---  Cent. Elect.
;Component:BCM PQ37BOSCH 034 0243, Coding:
;EV_BodyContrModul1UDSBosc,018001,EV_BCMBOSCH_018.rod
;Monday,13,November,2017,16:29:37:47536
;VCDS Version: Beta 17.10.0 (x64)  Data version: 20171026 DS283.3
;VCID: 8B59A46122FC607259B-80DE
IDE01550-Service position,178.999822 °,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,not installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,0 s,11
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 1A 12 06 9A 00 00 00 04 4C 00 4C 14 00 64 08 0A 1A 13 07 9A 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not_installed ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,0 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,0.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,0.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remotestart,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,40.999959 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,255 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG141956-Assistance light functions-Humidity sensor,not installed ,9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,DISKRET ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,30 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,30 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,10 %,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,19.999980 °,2
IDE10299-Alternating park position 2,34.999965 °,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,0 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,0 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,0 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,0 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,0 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,0 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,0 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,0 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
MAS05055-lower turn position,42.999957 °,2
MAS05056-upper turn position,178.999822 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2512 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,Yes ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,6 s,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Not deactivated ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,64.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,64.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,64.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,64.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,57.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,42.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,27.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,22.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,15.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,48 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,47 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,13 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,13 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,54 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,26 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Nebellicht links ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Blinken links aktiv (beide Phasen) ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,26 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Nebellicht rechts ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 02 64 03 00 80 08 00 0D 00 00 00 23 23 00 3E 18 04 64 05 00 80 08 00 0D 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,25 00 00 48 08 00 7F 00 00 00 00 00 00 00 00 00 25 00 00 47 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-101.5 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,1.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,10.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,1.00 s,62
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141954-Networking-A/C electronics,installed ,8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
ENG122979-ENG99457-Networking-Head area heater,not installed ,8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
ENG122979-ENG141969-Networking-UGDO,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,not active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-OCU-,not installed ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,not active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,0 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,0 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,0 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,not active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,not active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Contact control ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,not active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
Elapsed Time: 01:56
Eric
HC800000
   Part No SW: 5NN 907 426     HW: 5NN 907 426
   Component: AC Manuell el H34 4301
   Revision: 20K05000    Serial number: 00000D00019381
   Coding: 00020004200110001000000000000006
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACManuePrehVW37X 002021
   ROD: EV_ACManuePrehVW37X_002_VW37.rod
   VCID: 8D5DAA795CE86E4247F-80D8
   Yes:
I guess that's better than "No:"! :)
Rev and component look weird too, but then again so does the P/N in a way. Let's be on the lookout for next time we see one of those, debug 1024.
JSWTDI09
Las Vegas, Nevada
C?ID=96924
I'm not sure what all of this means but I am happy to see that you are working on this car. I own a 2018 Tiguan (US) and I would love to see more complete info. I sent you some controller maps and my autoscan a while ago. I would love to see label files for the engine (DGUA) but I am also eagerly awaiting more info on the transmission and the CECM coding/adaptations. Keep up the good work!
Let me know if there is anything else I can do to assist with this vehicle. I have a HEX+CAN cable and a HEX-NET interface.
Have Fun!
P.S. The new Beta 17.10 now has a label file for the HVAC in my car- but it still says "Yes:" (whatever that means). However my car seem to have different part numbers for HW: and SW:.
Here's mine:
   Part No SW: 5NN 907 044 A    HW: 5NN 907 044 A
   Component: AC Automat    H35 AC Automat    H35 43014301
   Revision: 20K08000    Serial number: 00000D00033377
   Coding: 00020004200118001005000012111406
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: N/A
   VCID: CAD825E56DCD4C7AA2D-809E
   Yes:
Eric
HC800000
Hmm, when you posted a scan with the release, it was fine:
   Component: AC Automat    H35 4301
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 4A90627FED7F401614-801E
Now it can't even find a ROD. I'd like to see the complete autoscan with 17.10 to figure why the latter part happens.
Actually let's do some troubleshooting. Your 17.8 scans with HUC and HN 4401 were fine; your 17.10 scan with HN 4407 has issues, glitches in SW version/component/revision.
Can you post up the following scans:
-HUC with 17.10
-HN 4407 with 17.10 (you've already done it, just not posted complete)
-HN 4407 with 17.8
This should let us see whether the issue is with VCDS or the codeblock, and if VCDS, whether it affects both HUC and HN or just HN.
Regarding label files, don't get too hung up on them missing with UDS modules. They were very important in the days where pre-UDS modules didn't have any means for the user of figuring out basic settings, selective output tests, and to some extent adaptations and measuring blocks. Now all of the above are already documented in the ROD file. What's left is basically security access and coding. With your hexnet, as I've mentionned previously (but not in your Tiguan thread, granted), you now have access to experimental coding coming from the ROD file even if there is no label file. Look for those modules with *, | or . before the label file name:
* means no coding from label file but experimental coding available
. means no experimental coding available but label file has coding info
| means both infos are available
Looking at your scan with 17.8 (it's possible there's more experimental coding available with the beta!), you have * for 08, 3C, 5F. Your 09 has no coding, most likely what you want to do is done through adaptations. I took a look at your 19 and it looks like the Beta should cover it with experimental coding (assuming the coding lengths match). That leaves auto trans and engine.
And yes, I wish we had more security accesses documented through labels (like your 09), but those are hard to find! :)
MasterTommy
Amsterdam
C?ID=295586
09 has no coding on a tiguan AD, everything is in the adaptations.
JSWTDI09
Las Vegas, Nevada
C?ID=96924
Thanks for that info.
-HUC with 17.10
-HN 4407 with 17.8
OK Here is the complete autoscan with HN 4407 with 17.10
Tuesday,31,October,2017,12:43:46:29381
VCDS Version: 17.10.0.2  HEX-NET CB: 0.4407.4
Data version: 20171026 DS283.3
VIN: 3VV3B7AX0JM03xxxx   License Plate: Sxxxx
Mileage: 1741km-1081mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 3C 42 44 52 5F 6C 75
VIN: 3VV3B7AX0JM035049   Mileage: 1741km-1081miles
Address 01: Engine (J623-DGUA)       Labels: None
   Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H30 0004
   Revision: 1DH30000
   Coding: 012A00122424010F34000000000000000000000000000000
   Shop #: WSC 00066 790 00451
   ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
   ROD: EV_ECM20TFS0115NA907115A.rod
   VCID: BC34733D3719E2CA201-80E8
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 B    HW: 09G 927 158
   Component: AISIN AQ8     206 3380
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00443
   ROD: EV_TCMAQ450031.rod
   VCID: B2285D05E55D24BAFAD-80E6
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 52037000001741
   Coding: 0BFA6BA454231B71C5770204A2CC49D0D62AD8A34045927010415058C2824200002764121A1C230A35351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: F6A0A11549B5789A165-80A2
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0447390592
   Coding: 132C0C0723
   VCID: BE3079352105F0DA0E5-80EA
   ROD: N/A
   Yes:
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0243
   Revision: --------    Serial number: C86427071701A4
   ROD: EV_BCMBOSCH_018.rod
   VCID: 8B56E0E12237157259B-80DE
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170703  034 0373
   Serial number: 17063021013450
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Serial number: 71895971
   Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H02 0233
   Coding: 3200000110FF8728749C8145004097
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM060HKZ
   Coding: 8CCCFC00000000005000001AC20800000065
   VCID: 8542D6D9045363020FF-80D0
   Occupant Detection:
   Serial number: IBH000000000007J7GCL
   Coding: 303351
   Subsystem 2 - Part No SW: -----------    HW: 480 001 106 17
   Serial number: 3570000000097410C42B
   Subsystem 3 - Part No SW: -----------    HW: 480 001 806 17
   Serial number: 3580000000009B55252C
   Subsystem 4 - Part No SW: -----------    HW: 480 402 906 17
   Serial number: 3510001C725E6142B2B1
   Subsystem 5 - Part No SW: -----------    HW: 480 402 806 17
   Serial number: 3520001A7264428183D-
   Subsystem 6 - Part No SW: -----------    HW: 480 400 507 17
   Serial number: 3550001B32610AE6345-
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 507 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001B12610AE3B7E9
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 03071708491275
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 875EDCD13E5F71127D3-80D2
   Part No SW: 5NA 920 850 B    HW: 5NA 920 850 B
   Component: KOMBI         370 0310
   Coding: 0BA4091A2388CF0502882A0954000000A0000000
   Shop #: WSC 00066 790 00274
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 10071700841250
   Coding: 030100347F085900FA0002481C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: B32658011A472DB2F1B-80E6
   Subsystem 2 - Part No SW: 5NN 959 442     HW: 5NN 959 442
   Serial number: 1701703390500348BH2B
   Coding: 280000
   Serial number: 1114343504
   Serial number: 17000172077013
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: F1AA920920DB5FA2C37-80A4
   Component: HRE_Master    H12 0080
   Serial number: 0446829195
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: BD327E392C03EBC217F-80E8
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0445410148
   Coding: 010111
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 7038721402262
   Coding: 003013200000028000000000
   VCID: C5C216D944D3A3024FF-8090
   Serial number: 00000000000006981153
   Coding: 011000
   Revision: 00000000    Serial number: 0001810381
   Coding: 01000010004000
   ROD: EV_SteerAssisVWBSMQBA_009.rod
   VCID: C0CC07CD5BF1862A7C9-8094
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 8038722500295
   VCID: C4C40BDD4FE99A0A581-8090
   Serial number: 00000000000006922623
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     721 0842
   Coding: 02730600BE00000051220001001808001F0500C40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: AE104975F165005A9E5-80FA
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT2085716
   Coding: 0123060120002017300040
   VCID: B93A6A29382BD7E23B7-80EC
   Component: OCULowMQBUS   007 0570
   Coding: 02230602C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: C3C608C14AE79D3261B-8096
End----------(Elapsed Time: 03:28, VBatt start/end: 12.4V/12.3V)-----------
Here is the scan with HN 4407 and 17.8
Tuesday,14,November,2017,07:44:51:29381
VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4407.4
Mileage: 2295km-1426mi   Repair Order:
VIN: 3VV3B7AX0JM035049   Mileage: 2295km-1426miles
   Revision: 1DH30000
   VCID: 3C34F33DB71962A696-8068
   VCID: 3228DD05655DA4D64C-8066
   VCID: 76A02115C9B5F8F6A0-8022
   Coding: 132C0C0723
   VCID: 3E30F935A10570B6B8-806A
   VCID: 4AD8A5E5EDCDCC1614-801E
   VCID: 0B5660E1A237951EEF-805E
   VCID: 054256D98453E36EB9-8050
   Occupant Detection:
   Coding: 303351
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Coding: 0410
   VCID: 075E5CD1BE5FF17ECB-8052
   ROD: EV_GatewNF_VW37.rod
   VCID: 3326D8019A47ADDE47-8066
   Coding: 280000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71AA1209A0DBDFCE75-8024
Address 3C: Lane Change (J1086)       Labels:* None
   Coding: 01011103
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3D32FE39AC036BAEA1-8068
   VCID: 45C296D9C4D3236EF9-8010
   Coding: 011000
Address 44: Steering Assist (J500)       Labels:. 5Q0-909-143.clb
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 40CC87CDDBF10646CA-8014
   VCID: 44C48BDDCFE91A66EE-8010
   Coding: 091000
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2E10C9757165803628-807A
   VCID: 393AEA29B82B578E8D-806C
   ROD: EV_OCULowMQB_VW37.rod
   VCID: 43C688C1CAE71D5ED7-8016
End----------(Elapsed Time: 01:44, VBatt start/end: 12.3V/12.2V)-----------
The HUC with 17.10 autoscan will have to wait until tonight when I get home from work. I can't (won't) install any beta software on my company laptop and I don't have an OTG adapter with me for my tablet with 17.10 on it. I will add this scan to this post later.
JSWTDI09
Las Vegas, Nevada
C?ID=96924
OK, I finally got a chance to do an autoscan with the HUC and 17.10.
Here is is:
Wednesday,15,November,2017,07:57:43:49225
VIN: 3VV3B7AX0JM03xxxx   License Plate: Sxxxxx
Mileage: 2355km-1463mi   Repair Order:
VIN: 3VV3B7AX0JM035049   Mileage: 2355km-1463miles
   Revision: 1DH30000
   VCID: 3C7C34A7B7ABEECAA01-8068
   VCID: 32601A9F65EF28BA7AD-8066
   VCID: 76E8E68FC907749A965-8022
   Coding: 132C0C0723
   VCID: 3E783EAFA1B7FCDA8E5-806A
   VCID: 4A90627FED7F407A22D-801E
   Yes:
   VCID: 0B1EA77BA2851972D9B-805E
   VCID: 050A914384E16F028FF-8050
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   VCID: 07169B4BBEED7D12FD3-8052
   ROD: EV_GatewNF.rod
   VCID: 336E1F9B9AF521B271B-8066
   Coding: 280000
   VCID: 71E2D593A06953A2437-8024
   Coding: 01011103
   VCID: 3D7A39A3ACB1E7C297F-8068
   Coding: 010111
   VCID: 458A5143C461AF02CFF-8010
   Coding: 011000
   VCID: 40844057DB438A2AFC9-8014
   VCID: 448C4C47CF5B960AD81-8010
   Coding: 091000
   VCID: 2E580EEF71D70C5A1E5-807A
   VCID: 39722DB3B899DBE2BB7-806C
   VCID: 438E4F5BCA559132E1B-8016
End-------------------------(Elapsed Time: 06:24)--------------------------
I hope you find this info helpful. Let me know if I can do anything else for you.
Have Fun!
Eric
HC800000
So clearly an issue with 17.10 or its ROD data. We're going to investigate that. Thanks!
Eric
HC800000
JSWTDI09
Las Vegas, Nevada
C?ID=96924
OK, I have downloaded and uncompressed the new dataset. I should have a chance to do the scans tomorrow, so you will have the before Monday.
JSWTDI09
Las Vegas, Nevada
C?ID=96924
Don, if you're able, please try dataset 283.4:
Make an autoscan with HN using both Wifi and USB please.
Here you go:
Autoscan w/ 283.4 - HN w/ WiFi
Saturday,18,November,2017,09:33:57:29381
Data version: 20171026 DS283.4
VIN: 3VV3B7AX0JM03xxxx   License Plate: HN-WIFI
Mileage: 2491km-1547mi   Repair Order:
VIN: 3VV3B7AX0JM03xxxx   Mileage: 2491km-1547miles
   Revision: 1DH30000
   Coding: 132C0C0723
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   ROD: EV_GatewNF.rod
   Coding: 280000
   Coding: 01011103
   Coding: 010111
   Coding: 011000
   Coding: 091000
End----------(Elapsed Time: 01:38, VBatt start/end: 12.2V/12.2V)-----------
Autoscan w/ 283.4 - HN w/ USB
Saturday,18,November,2017,09:28:55:29381
VIN: 3VV3B7AX0JM03xxxx   License Plate: HN-USB
   Revision: 1DH30000
   VCID: 3C34F33DB71962CAA01-8068
   VCID: 3228DD05655DA4BA7AD-8066
   VCID: 76A02115C9B5F89A965-8022
   Coding: 132C0C0723
   VCID: 3E30F935A10570DA8E5-806A
   VCID: 4AD8A5E5EDCDCC7A22D-801E
   VCID: 0B5660E1A2379572D9B-805E
   VCID: 054256D98453E3028FF-8050
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   VCID: 075E5CD1BE5FF112FD3-8052
   ROD: EV_GatewNF.rod
   VCID: 3326D8019A47ADB271B-8066
   Coding: 280000
   VCID: 71AA1209A0DBDFA2437-8024
   Coding: 01011103
   VCID: 3D32FE39AC036BC297F-8068
   Coding: 010111
   VCID: 45C296D9C4D32302CFF-8010
   Coding: 011000
   VCID: 40CC87CDDBF1062AFC9-8014
   VCID: 44C48BDDCFE91A0AD81-8010
   Coding: 091000
   VCID: 2E10C9757165805A1E5-807A
   VCID: 393AEA29B82B57E2BB7-806C
   VCID: 43C688C1CAE71D32E1B-8016
End----------(Elapsed Time: 01:47, VBatt start/end: 12.1V/12.2V)-----------
Have Fun!
