Component protection
TASKIN52
Turkey
C?ID=283106
Hello there. Is it possible to open component protection with vcds? If so how?
DV52
C?ID=194404
Taskin:hi and welcome to the forum (I note that you are a "new user"). That's a very good question which I'm positive that someone here will easily answer after we see what type of equipment is in your car. Can you post up a copy of your auto-scan please
TASKIN52
Turkey
C?ID=283106
I have 2016 golf7. For example, can I run this with the active info display taxis without vcds without this?
Moved to Pre-Sales Support.
VCDS does not do Component Protection. I don't think there is any real solution for component protection in the aftermarket. Some tools claim to do it on some modules, but my understanding is what they do is a work-around that has negative side effects.
TASKIN52
Turkey
C?ID=283106
Good cruise Control takarsam rosstech enough to do the encoding found on the wiki
andyhud
C?ID=32695
Nope, you can't do it in VCDS.
TASKIN52
Turkey
C?ID=283106
Ok, Thank you
Jeff V.
C?ID=236576
Do you know why that is? Is it due to some kind of encryption or key/signature system that's not practical to reverse engineer? I've been curious about this since I bought my car. I can't find ANY explanation for how the system works outside of the factory SSPs, and nobody is even willing or able to say what's so difficult about cracking it. If it's simply a matter of it being based on something like a public key encryption system, why won't anyone just say so?
