Blind spot monitoring retrofit - GTI Clubsport
Qassem
Kuwait
C?ID=325382
Dear Friends,
I need you help with connecting the last wire in the circuit,
also I need your help with coding.
This is the parts:
Look what I found on AliExpress
https://www.aliexpress.com/item/32581706595/32581706595.html
this is the circuit.
https://imgur.com/a/FU2kV
Where is A200 point (Positive connection 5 (15a) (in instrument panel wiring harness)
It’s the same as fuse Sc32 wire ?? , how I can connect it ? can I just tap it to fuse from the front ??
when I did so , message appeared that the front assist is deactivated and it keep popping up in the middle cluster, so I remove it.
this is Auto scan after the canbus connection done (without connecting the fuse 32A c)
what is the address of the modules ???
is it appeared here, or I need to do fuse 32A first??
Saturday,10,February,2018,21:12:02:35129
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4409.4
VIN: WVWFM2AUXGW246170   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 32 42 44 47 52 55 5F A9
VIN: WVWFM2AUXGW246170   Mileage: 25905km-16096miles
Address 01: Engine (J623-CJXE)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 K    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091D00122464050B2000
   ASAM Dataset: EV_ECM20TFS0205G0906259K 001002
   ROD: EV_ECM20TFS0205G0906259F_VW37.rod
   VCID: 3620C89689CE44F67B-8062
Readiness: 1110 0001
   Part No SW: 0D9 300 020 K    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4904
   Revision: 06253104    Serial number: TFK01601191468
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 1D72373A0C38F7AE9A-8048
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 60246000000551
   Coding: 01FA6BA1542429720778060741C36980D62A94E0608296F7184250B9C208
   VCID: 7AB81CA6FD566096DF-802E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020014200100001005000012101402
   VCID: 6A982CE68DF6D0162F-803E
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061602803455
   Coding: 00101A46C20122F34B644000000C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 095A736AA8B07B0EC6-805C
   Component: WWS    160118  043 0551
   Serial number:         160202045705
   Component: RLHS  037 0059
   Serial number: S2Y16M02D08H10M34S06
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST000RK8J200000
   Coding: 181801
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0056
   Revision: --------    Serial number: 39291603300852
   Coding: 0001150011
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   VCID: 3D32D7BAACF897AEBA-8068
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 02011604400195
   Coding: 001C1300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A38DCA6BDD6A0969F-806E
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 29121541350443
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 373EC5928EC4BDFE60-8062
   Serial number: 003F6R1CV8AR
   VCID: 41CAAB4AD000F34EDE-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 35767000000E9650291V
   Subsystem 2 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 3586700000038644881S
   Subsystem 3 - Part No SW: -----------    HW: 480 400 202 16
   Serial number: 3516502B71EDD3E4637W
   Subsystem 4 - Part No SW: -----------    HW: 480 400 202 16
   Serial number: 3526502B71EDD3E591A
   Subsystem 5 - Part No SW: -----------    HW: 480 400 502 16
   Serial number: 3556502AD1EDD3E150D/
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160204500421
   Coding: 0410
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 3FCEADB2A6F485BEA8-806A
   Part No SW: 5G0 920 756     HW: 5G0 920 756
   Component: KOMBI         302 6420
   Coding: 47AD01083F80000801886A011400000000000000
   VCID: 699A53EA88F0DB0E26-803C
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 30011610802973
   Coding: 030100043F085900FB00027B9C0F00010001050000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 79BA03AAF8506B8ED6-802C
   Serial number: 29160000048900016026
   Coding: 2DFFFF
   Serial number: 6060799103
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00023.11.15
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 47DEB552FE24CD7E10-8012
   Serial number: 070116EA606676
   Coding: 003E0320D000040100001000
   VCID: 43C6A142CA1CE15ECC-8016
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 393AC3AAB8D0AB8E96-806C
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA01GG51
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI_VW37.rod
   VCID: 6D9227FABC18C72E4A-8038
   Serial number: 080116EA801099
   Coding: 003E0120D000040100801000
   VCID: 42C8A446D506E856C7-8016
   Coding: 029203000B010200
   VCID: 40CCAE4EDB0AFA46D1-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3G0 035 045 B    HW: 3G0 035 045
   Component: MU-H-N-RW     H50 0343
   Serial number: A688A0GB002325
   Coding: 0273000C0000000051110002001828001F0203F401200100DF
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU304VU1
   Subsystem 2 - Part No SW: V03 959 801 ED    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Component: Gracenote2  --- 4008
   Part No SW: 5G0 907 159 E    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0002
   Serial number: 151216201255
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   VCID: 302CFE8E6BAA6AC621-8064
End----------(Elapsed Time: 01:42, VBatt start/end: 12.5V/12.4V)-----------
downtime
C?ID=280813
The positive connection is the same as the fuse SC32. You can tap it there.
The front assist drops because you haven't coded the system.
Add the module to can gateway installation list. Then code the blind spot monitoring system module. Power off the car. Then power on and clear DTCs.
As you don't have A5 multifunction camera that does not need coding :)
Qassem
Kuwait
C?ID=325382
I added the lane change assist , and lane change assist 2 to the canway installation list , then how I can code it??
In the auto scan now , it says cannot be reached ??!
If they "Cannot be Reached", chances are they aren't wired correctly.
Qassem
Kuwait
C?ID=325382
Thanks Uwe,
I think the fuse wire , is not wired correctly, how I can tap the wire to fuse # 32 in fuse panel C ?
SC32 a fuse
Qassem
Kuwait
C?ID=325382
You are right , can bus high and low was not correctly wired.
Now VCDS recognizes module J1068 (the right one)
Module not coded , what I can do to code it ??!
Qassem
Kuwait
C?ID=325382
Dear Friends,
Module adapted and coded and no faults with auto scan.
I need just to take it for a spin tomorrow to test how it actually works when any car passes through my blind spot.
Hopefully no calibration needed.
Thanks for your help , you are really great guys.
During this week I will continue my first project which is KESSY retrofitting, I was waiting for some harnesses, supposed to arrive last week but it still under clearance.
downtime
C?ID=280813
Dear Friends,
I hate to be the spoilsport but it needs calibration to function correctly. And I would not leave this undone as BSM is safety system. It might like it operates correctly but in many situations it will not or it will give false information etc.
I saw this quite clearly with my retrofitted ACC before calibration. Car had a few interesting moments with suddenly braking to something like bus on a bus stop.
The BSM calibration requires special equipment so it is a dealer job. See here : http://www.vwgolf.org/calibrating_blind_spot_monitor_control_unit_j1086_j1087_-2606.html
Qassem
Kuwait
C?ID=325382
Thanks Downtime,
I will ask the dealer to calibrate, I agree with you , Safety comes first.
downtime
C?ID=280813
Thanks Downtime,
:thumbs: Yes. shouldn't be too bad for them to do. Maybe an hours work.
Oh and I almost forgot to say the most important thing. Nice retrofit, congratulations for finishing it, good job :)
Qassem
Kuwait
C?ID=325382
Thanks downtime, without your help and the guys supports , this couldn’t be done.
Also I will post and auto scan and admap in order for any one planning to do the retrofit, it would be helpful and make things easier.
Qassem
Kuwait
C?ID=325382
Tuesday,13,February,2018,17:52:35:35129
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 32 3C 42 44 47 52 55 5F
          A9
VIN: WVWFM2AUXGW246170   Mileage: 26028km-16173miles
   Revision: --H13---
          P1734 00 [002] - -
   Coding: 01FA6BA1542429720778060741C36980D62A94E0608296F7184250B9C288
   Revision: 00001K08
   Coding: 90A8DD
   Sun Roof:
   Coding: 181801
   Coding: 0001150011
   Coding: 0410
   Coding: 47AD01083F98000801886A091400000000000000
16776980 - Databus
                    Reset counter: 47
                    Mileage: 26028 km
                    Date: 2018.02.13
                    Time: 17:47:45
   Coding: 2DFFFF
   Coding: 0001
   Component: HRE_Master    H11 0071
   Serial number: 0391756389
   Coding: 01031103
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C34DABEB7E29EA68D-8068
   Lane Change Assistant 2:
   Coding: 003F0320D000040100001000
   Coding: 8103
   Coding: 003F0120DC00040100801000
   Coding: 2E0000
   Coding: 2E0000
End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.3V)-----------
this the autoscan after the blind spot (lane change assist) retrofit.
Qassem
Kuwait
C?ID=325382
;SW:5Q0-907-686-B HW:5Q0-907-686-B --- Lane Change
;Component:HRE_Master H11 0071 Coding:01031103
;EV_HREntryHella 1028 EV_HREntryHella_VW32.rod
;Tuesday 13 February 2018 17:56:28:35129
;VCDS Version: Release 17.8.1 (x64) Data version: 20171130 DS276.6
;VCID: 3C34DABEB7E29EA68D-8068
IDE02332-Deactivate production mode Deactivating 3
IDE05397-Calibration mode not activated 1
IDE80001-Analysis 1 not activated 1
IDE80004-Analysis 4 not activated 1
Elapsed Time: 00:01
;Tuesday 13 February 2018 17:56:51:35129
Elapsed Time: 00:01
This is the admap for the 3c module
GaSelle
C?ID=266649
Such a shame it´s in spanish...
