Please help !! 2010 1.4 tsi Ibiza Cupra Stutter !
Smurfyboy
New Member
H10-003940 (NRRT)
Hi guys new to the forum,
Had a little 1.4 tsi Ibiza Cupra 2010 DSG model,
Gradually developed a stutter/hesitation under light or part throttle/acceleration.
On full throttle it pulls well,
As these engines are renowned for misfires i replaced all 4 plugs and coils
This has not solved it,
Its like its kangarooing down the road sometimes,
Any advise on what to try log ?
I have VCDS, just unsure the best way to diagnose this,
I've read it could be N75 valve orN249 valve but dont know how to check,
I have uploaded a clip to Youtube of the fault happening,
Smurfyboy
New Member
H10-003940 (NRRT)
The first auto scan i did came up with this,
Tuesday,23,May,2017,16:59:46:39766
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: VSSZZZ6JZAR152041   License Plate: HY60 WGW
Mileage: 106630km-66256mi   Repair Order:
Chassis Type: 6J (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZAR152041   Mileage: 106630km-66256miles
Address 01: Engine (J623-CAVE)       Labels: 03C-907-309-V1.clb
   Part No SW: 03C 906 027 AE    HW: 03C 906 027 AD
   Component: 1.4l R4/4V TS H10 9971
   Revision: L2H10---    Serial number:
   Coding: 00250012002400000000
   Shop #: WSC 01223 210 88101
   ASAM Dataset: EV_ECM14TSI01103C906027AE 001007
   ROD: EV_ECM14TSI01103C906027AE.rod
   VCID: 6492A5CDBED20A47A91-8030
4543 - Supply Voltage for Fuel Injector Group A
          P2146 00 [096] - Open Circuit
                    Mileage: 106144 km
                    Date: 2017.05.07
                    Time: 08:06:39
                    Engine speed: 1452.00 /min
                    Normed load value: 52.2 %
                    Vehicle speed: 14 km/h
                    Coolant temperature: 18 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.465 V
                    Unlearning counter according OBD: 7
                    Mass flow through throttle valve: 320.7 kg/h
                    Median injection timing: 6.903 ms
                    Engine operating condition: full load
                    Engine operating condition-Test_Program_Channel 87: 7
4063 - Cylinder 4
          P0304 00 [096] - Misfire Detected
4057 - Cylinder 2
          P0302 00 [096] - Misfire Detected
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
Smurfyboy
New Member
H10-003940 (NRRT)
I then cleared those codes and drove car around for a few days ,
It was still stuttering and driving like a kangaroo and the fault was happening all the time
I performed another auto scan and only one code was there this time,
The date and time matched when it threw on the epc light for 1 sec and lost power but it sorted itself right away,
The latest scan says this
Friday,16,June,2017,18:07:34:39766
VIN: VSSZZZ6JZAR152041   License Plate: SMURF
Mileage: 107540km-66822mi   Repair Order:
VIN: VSSZZZ6JZAR152041   Mileage: 107540km-66822miles
4544 - Supply Voltage for Fuel Injector Group B
          P2149 00 [096] - Open Circuit
                    Mileage: 107474 km
                    Date: 2017.06.15
                    Time: 07:54:41
                    Engine speed: 2241.50 /min
                    Normed load value: 74.9 %
                    Vehicle speed: 15 km/h
                    Coolant temperature: 63 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 13.994 V
                    Unlearning counter according OBD: 33
                    Mass flow through throttle valve: 174.2 kg/h
                    Median injection timing: 5.314 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
Ashraf6119
C?ID=174194
Could you please post the full Auto Scan..........Also any recent work done or any service done...? Have you checked the Cylinder Compression Test
Smurfyboy
New Member
H10-003940 (NRRT)
Surely it wouldn't be intermittent if it was losing compression,
It also wouldn't pull anything like it does,
I have attached the part of the scan that shows the fault ?
What else are you hoping to see on the rest of the scan as it showed no other codes ?
No work done or recent service,
As i says above only things changed since fault occurred has been 4 new plugs and coil packs
Started off happening once every so often now i have to basically drive around it by either acceleration pretty harshly or barely touching accelerator as anything in between its like riding a kangaroo.
Any idea how to check for a faulty N75 valve or N249 ???
What have you done to track down the "Supply Voltage for Fuel Injector Group B - Open Circuit" fault?
Smurfyboy
New Member
H10-003940 (NRRT)
Nothing at all,
I wasn't sure where to begin as it previously had the same code for Group A but cleared and never returned,
Same with that one,
What would you recommend,
The car performs fine under full throttle its only light acceleration or cruising lightly
Smurfyboy
New Member
H10-003940 (NRRT)
Anyone know how to check the N75 & N249 valves ?
Or is it a case of replace and hope :(
