2014 Mk7 Golf Cruise Control Retrofit Issues
GeoDCS
Ireland
C?ID=49190
Hi all,
We do a lot of cruise control retrofitting but yesterday was our first attempt at a Mk7 Golf. All went smoothly until the activation stage. I followed the guide on the wiki which was basically the same as lots of other models but ended up with no cruise working and a fault code in 01 Engine.
I suspect the issue is something to do with regular CC vs ACC.
All feedback appreciated.
George
Autoscan:
VCDS Version: Release 15.7.4 Running on Windows 10 x86
Data version: 20160216
Tuesday,12,April,2016,12:48:33:36034
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEW199121   Mileage: 37814km-23496miles
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 7635
   Revision: 84H22---
   Coding: 01110012032511092000
   Shop #: WSC 12244 002 104857
   ASAM Dataset: EV_ECM16TDI01104L906021M 002012
   ROD: EV_ECM16TDI01104L906021M_VW37.rod
   VCID: 2F6DF4EB76918E46D7-807A
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 37814 km
                    Date: 2016.04.12
                    Time: 12:42:49
   Revision: 00000000    Serial number: 63043000000600
   Coding: 01FA8AA1242909750378060241C42580512490C06082A4F300400068C002
   VCID: 7BF510BBF269A2E62B-802E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   ROD: EV_ACManueBHBVW37X_SE37.rod
   VCID: 3561C68394CDB4969D-8060
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011331500983
   Coding: 03000842C201005B4BE44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 79F90AB3F85590F639-802C
   Slave 1:
   Component: WWS    131103  042 0551
   Serial number:         131106040006
   Component: AirbagVW20    014 0385
   Serial number: 003F6R027VKP
   VCID: 4189A253D005083631-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 310 13
   Serial number: 357670000008E9501E0-
   Subsystem 2 - Part No SW: -----------    HW: 480 002 310 13
   Serial number: 358670000000E9501E0T
   Subsystem 3 - Part No SW: -----------    HW: 480 400 511 13
   Serial number: 3516502BF1050642230S
   Subsystem 4 - Part No SW: -----------    HW: 480 400 511 13
   Serial number: 3526502B51050645C29/
   Subsystem 5 - Part No SW: -----------    HW: 480 400 711 13
   Serial number: 3556502AD1118A32A267
   Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
   Revision: --------    Serial number: 07111304220240
   Coding: 1600
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 76E3018FC94BFF8E54-8022
   Part No SW: 5G0 920 851 A    HW: 5G0 920 851 A
   Component: KOMBI         152 2210
   Coding: 27A402002300000800080800040000
   VCID: 264311CF596BCF0E24-8072
   Part No SW: 5Q0 907 530 N    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1164
   Revision: --------    Serial number: 0001221931
   Coding: 030000040B087300EF000048080E00010001000000000000000000000000
   ROD: EV_GatewLear.rod
   VCID: 3C77D3A7B7E765DE62-8068
   Subsystem 2 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Serial number: 4528841703
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 06111302090906
   Coding: 003003208001040100001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 3E73D9AFA1FB77CE4C-806A
   Coding: 0103
   ROD: EV_SteerAssisMQB.rod
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 03111301100112
   Coding: 003001208001040100801000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 3D71DEA3ACFD6CD655-8068
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-ENT1.clb
   Part No SW: 5G0 035 867     HW: 5G0 035 867
   Component: MU-E--ER      636 5800
   Serial number: 06091300010433
   Coding: 02730000FF0000004011000100000000000000060000010000
   ASAM Dataset: EV_MUEnt4CLGE 001025
   ROD: EV_MUEnt4CLGE_SK37.rod
   VCID: 69D95AF388F52076C9-803C
End-------------------------(Elapsed Time: 02:39)--------------------------
There's nothing obvious here that jumps out at me... :(
DV52
C?ID=194404
GeoDCS: You are clearly a professional and it appears also well experienced in this type of retrofit, so I'm hesitant to make comment. But, without wishing to seem impertinent and just on the off-chance that it might have been missed - was the black/white wire shown in the WD below fitted between 01-Engine and steering wheel control modules?
GeoDCS
Ireland
C?ID=49190
Hi Don,
No problem at all. It's always good to start with the basics! Yes I fitted the additional wire from the steering wheel controller pin 5 to the engine ECU pin 46.
George
GeoDCS
Ireland
C?ID=49190
It is certainly strange. I checked all of the control modules in the car to make sure that I wasn't missing a cruise control related coding option. But turned up nothing.
Hopefully we will get another Mk7 with cruise into the workshop before too long so that I can have a look at the coding on that. Otherwise I'm not sure where to go with it.
DV52
C?ID=194404
GoeDCS: I've got a mk7 with CCS. Here are the pertinent screens shots related to CCS from my car:
For the 01 Engine module on my car:
Address 01: Engine (J623-CHPA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 G HW: 04E 907 309 A
Component: 1.4l R4 TSI H08 5272
Revision: WAH08---
Coding: 01250032242405082000
The code string from your engine module (from your autoscan) is 01110012032511092000, or displayed differently the code is:
So it looks like Byte 5, Bit 5 is set (which it should be)
For the 16-Steering Wheel module on my car
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Revision: -------- Serial number: 08011304220489
Coding: 0500
We have the same series module - the code for your 16-steering wheel is 1600 and the code for mine is 0500. So, on your car Byte 0 has a value of Hex16 which is binary 0001 0110. The upper-nibble value for this Byte suggests that you engage CCS via the turn indicator stalk. Is this correct? If this is not the case (i.e. you use the CCS steering wheel buttons) why not try changing the value of this Byte to Hex06 (even though this means "Cruise Control not installed", it's the setting that is used on my car - which has CC factory fitted
GeoDCS
Ireland
C?ID=49190
Hi Don,
Thanks for the helpful reply. The kit we got from VW has the cruise buttons on the indicator stalk. Where are they on your car (which presumably has a factory fitted setup)?
I haven't tried any other coding options in 16 steering wheel controller (didn't even occur to me to try) but I will certainly give it a go.
George
DV52
C?ID=194404
Hi Don,
George
George: on my car, the CCS is enabled via the steering wheel buttons.
PS: Hmm........ is CCS a defined term on this forum?
GeoDCS
Ireland
C?ID=49190
Ok so just to follow up on this. We got the car back in this morning and tried every possible combination of coding without success. So in the end I had to admit defeat and undo the retrofit.
NEtech
C?ID=56995
Just a note, was is pin 46 ?
If the diagram Don showed is correct for your car, it is pin 56 (94 pin connector).
m_bolc
San José, Costa Rica
C?ID=230356
GeoDCS: as you have been through quite a bit of these retrofits: Does the 8v/MQB A3 behave the same as this MK7 Golf? I want to retrofit CCS to my own car, but I don't know if me, myself and VCDS would be successful.
Do I need the dealer's help with connecting the car to have SVM performed? Can I perform the retrofit entirely on my own?
mirceaciuciuc
Romania
C?ID=173624
Hello guys,
Golf MK7, same problem with the fault code on engine regarding coding of ECU in powertrain data bus after retrofitting CCS.
Engine code is CRBC, pinout conected from steering wheel controler pin 5 to engine controler pin 46 for this engine ECU.
All coding done like in the ross tech wiki page.
I will post an autoscan later on.
Any ideas someone? GeoDCS have you sorted out in the end?
Kind regards
mirceaciuciuc
Romania
C?ID=173624
Thank you for your reply. CCS in this case is MFSW based,not on turning stalk. Main difference in this is the coding for steering wheel module that i have sorted out it should be CCS not installed.
The engine for that guide is gasoline 1.2 tsi that involves replacing accelerator pedal. For 2.0 cr CRBC engine is this necesary to?
I want to mention that the speed limiter function is functioning properly but the cruise control function icon appears with the “attention” mark on the display and it does not function at all.
golfi_vend
Tartu, Estonia
C?ID=195131
Acc. pedal is needed to be changed only if kick-down is missing.
Point of my post was that You need to have FEC enabled and transfered to gateway for Cruise to be working. As Cruise is now SWAP function, meaning You have to pay VW. Swap codes are only included in VW retrofit kits and can only be activated via online connection through ODIS to VW motherserver.
mirceaciuciuc
Romania
C?ID=173624
Got it now. Is the swap code universal valid or do we have to buy a retrofit kit from the dealer to have this swap code.
Meaning, can the dealer use any swap code from any retrofitting kit to enable this function?
golfi_vend
Tartu, Estonia
C?ID=195131
As the document included with my cruise kit contained random numbers and letters, I only guess it's specific and 1 time usable, then tied to car VIN.
PS! After FEC was implemented, PR code also changed when viewing VIN in PL24. It was 8T0 - No Cruise to 8T6 - Cruise with speed limiter.
http://forums.ross-tech.com/showthr...ruise-Control-retrofit/page3&highlight=cruise
Seems like Don can help You also. Contact to him seems quicker via WeChat.
kamold
Australia
C?ID=241363
Just a heads up, Don is away on holidays until the beginning of March.
NZDubNurd
New Zealand
C?ID=230482
Was that booked and approved in advance??? I hope someone booked a locum.
I didn't get the memo.
kamold
Australia
C?ID=241363
He certainly didn't seek my approval....he replied to a message from me with some lame excuse about being in Vietnam and on vacation... ;)
