Audi A4 (8K) cruise control retrofit problem
Pekka Perkeles
C?ID=288400
We purchased a cruise control unit from the local Audi dealer for a 2009 Audi A4 2.0 TDI.
Now, the engine accepts coding, but steering wheel controller does not ("coding rejected Error 31: request out of range").
Could it be that the steering wheel controller hardware (8K0 953 568 D) does not support cruise control? The car does not have a multi-function steering wheel.
Here's the auto scan:
Friday,16,June,2017,11:11:35:57012
VCDS Version: 17.1.3.0 (x64)
VIN: WAUZZZ8K39A235164   License Plate: xxxx-xxx
Mileage: 135490km-84189mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 69 72
VIN: WAUZZZ8K39A235164   Mileage: 135490km-84189miles
16-Steering wheel -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAGC)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MG    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H01 9978
   Revision: 11H01---
   Coding: 0104002C18072920
   Shop #: WSC 21788 002 104857
   ASAM Dataset: EV_ECM20TDI03L906022MG A01009
   ROD: EV_ECM20TDI03L906022.rod
   VCID: 76DA745DC91989F1C3-8022
4332 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 135496 km
                    Date: 2017.06.16
                    Time: 09:56:44
                    Coolant temperature: 18 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 11.740 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    ACCI a Des: 0.000 m/s²
                    Acceleration: 0.000 m/s²
                    ACCI st State-Bit 0: 00000000
                    Cruise Control System (CCS): status-Bit 0: 00000100
                    ACCI st Brk Err mp-Bit 0: 00000000
4984 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [101] - Electrical Fault
                    Mileage: 135496 km
                    Date: 2017.06.16
                    Time: 10:07:50
                    Engine speed: 849.00 /min
                    Normed load value: 38.4 %
                    Voltage terminal 30: 11.980 V
                    Crankshaft speed (RPM): 849.0 /min
                    Vehicle voltage terminal 30: 11960 mV
                    Coolant temperature: 18.5 °C
                    Glow status-Bit 0: 00000000
                    Glow status-Bit 8: 00000000
                    Preheat time: 0 ms
                    Fuel temperature: 17.5 °C
4985 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [101] - Electrical Fault
                    Mileage: 135496 km
                    Date: 2017.06.16
                    Time: 10:07:50
                    Preheat time: 0 ms
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [101] - Electrical Fault
                    Mileage: 135496 km
                    Date: 2017.06.16
                    Time: 10:07:50
                    Preheat time: 0 ms
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
   Component: ESP8 front    H04 0240
   Coding: 168500
   Shop #: WSC 61000 205 76828
   VCID: 7CCE6675FF35D3A1B5-8028
   Part No SW: 8K0 907 064 M    HW: 8K0 907 064 M
   Component: BCM2 1.1      H80 0145
   Coding: 030200
   Shop #: WSC 06325 000 00000
   VCID: 3A42A06DB5812D91E7-806E
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000018560008
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000025204014
   Part No SW: 8T1 820 043 T    HW: 8T1 820 043 T
   Component: KLIMA 1 ZONE  H06 0150
   Revision: A0000000    Serial number: 01240420091409
   Coding: 34000000
   VCID: 42B2D88DDD516551BF-8016
                    Fault Status: 00100001
                    Fault Frequency: 7
                    Reset counter: 165
                    Mileage: 135460 km
                    Date: 2017.06.15
                    Time: 15:08:57
                    Temperature: 25.0°C
                    Temperature: 83.0°C
                    Load: 100.0 %
                    Absolute Pres.: 30.0 bar
                    RPM: 1960 /min
                    Speed: 96.0 km/h
                    Current: 0.410 A
                    Temperature: 38.0°C
   Part No SW: 8K0 907 063     HW: 8K0 907 063
   Component: BCM1 1.0      H26 0253
   Revision: 01026001    Serial number: 00000000256083
   Coding: 6900C0B10034A7000001000000005F5F0014260800000101000000
   VCID: 6CEE56358F55432125-8038
   Component: WWS 270409  H06 0070
   Serial number: SWF09040275208
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10455414
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 Q    HW: 8K0 941 531 Q
   Component: E1 - LDS  H07 0090
   Serial number: 00000000002004090697
                    Fault Status: 00101100
                    Reset counter: 137
                    Mileage: 134203 km
                    Date: 2017.05.18
                    Time: 13:35:00
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EFD0260JT
   Coding: 30343435363030303030554A304C384B3053
   VCID: 41B0D781D0577E49A6-8014
   Serial number: 6334MSME48150C058
   Serial number: 6344MSME440435699
   Serial number: 6352QSME47273C3AP
   Serial number: 6362QSME3A224614A
   Serial number: 63732SME3D224010O
   Serial number: 63832SME5B274700-
   Part No SW: 8K0 953 568 D    HW: 8K0 953 568 D
   Revision: --------    Serial number: 90319IDK000GB
   Coding: 000001
   VCID: 3B4CA569BABB1499FC-806E
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 900 C    HW: 8K0 920 900 C
   Component: KOMBIINSTR.   H18 0224
   Revision: 00000000    Serial number: 9DS33DR49
   Coding: 0F00100002000008010000
   VCID: 2A62902D45219D1197-807E
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G0941980B7
   Coding: 000303
   VCID: 4BACF5A9EA1BA4194C-801E
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
   Serial number: 19071CB1170309
                    Fault Frequency: 16
                    Reset counter: 125
                    Mileage: 133384 km
                    Date: 2017.05.02
                    Time: 09:05:00
                    Fault Frequency: 16
                    Reset counter: 125
                    Mileage: 133384 km
                    Date: 2017.05.02
                    Time: 09:05:00
   Part No SW: 8K0 959 793 E    HW: 8K0 959 793 E
   Revision:             Serial number: 0000008828868
   Coding: 011002204000410001
   Revision: 00002001    Serial number: 0118131259
   Coding: 0100062020390040012002
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 72
                    Mileage: 133384 km
                    Date: 2017.05.02
                    Time: 09:25:26
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 72
                    Mileage: 133384 km
                    Date: 2017.05.02
                    Time: 09:25:26
                    Reset counter: 165
                    Mileage: 135496 km
                    Date: 2017.06.16
                    Time: 08:34:49
   Part No SW: 8K0 959 792 E    HW: 8K0 959 792 E
   Revision:             Serial number: 0000008809776
   VCID: 41B0D781D8577E49A6-8014
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000357763
   VCID: 335C8D4992EBDCD924-8066
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
   Component: Concert3      H02 0310
   Revision: 00000005    Serial number: AUZ5Z6I1205234
   Coding: 05000480040201000119070000
   VCID: 44BEDE95C7456B618D-8010
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
03138 - Input AUX IN
                    Reset counter: 72
                    Mileage: 133384 km
                    Date: 2017.05.02
                    Time: 09:13:04
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101011410
   Coding: 010002204000210001
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 B    HW: 8K0 907 383 B
   Component: Anhaenger     H08 0080
   Revision: 1A002002    Serial number: 00000119179749
   Coding: 0100000000000000
02565 - Trailer; Right Turn Signals (M63)
                    Fault Status: 11101010
                    Reset counter: 106
                    Mileage: 134605 km
                    Date: 2017.06.03
                    Time: 09:06:00
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000101011417
End-------------------------(Elapsed Time: 02:06)--------------------------
PetrolDave
Westbury, UK
C?ID=1423
Certainly on the previous 8E/8H platform cruise control wouldn't work with an SCSM that didn't support an MFSW - I had to replace the SCSM to get cruise working on a 2005 8E B6 S4 I used to own.
Hopefully someone will be able confirm if this is also true on the 8K platform...
m87a
Bosnia and Herzegovina
C?ID=156900
8K0 953 568 D doesnt support cruise control you need one of the following
KOSTAL:
8K0 953 568 B: CCS, MFSW, Board Computer (only for audi A5, to 2009?* different airbag connector?*, also without index to index C, does not fit A4 8K!)
8K0 953 568 GB: no CCS, Board Computer, no MFSW
8K0 953 568 E: CCS, Board Computer, no MFSW
8K0 953 568 F: CCS, MFSW, Board Computer, no ACC!
8K0 953 568 G: CCS, ACC, MFSW, Board Computer, ...
FL:
8K0 953 568 J: no CCS, Board Computer, no MFSW
8K0 953 568 K: CCS, Board Computer, no MFSW
8K0 953 568 L: CCS, MFSW, Board Computer, no ACC!
8K0 953 568 M: CCS, Board Computer, MFSW, ACC
VALEO (from 1/2011):
8R0 953 568 H: no CCS, Board Computer, no MFSW
8R0 953 568 J: CCS, Board Computer, no MFSW!
8R0 953 568 K: MFSW?, CCS, Board Computer, no ACC
8R0 953.568 M: CCS, Board Computer, MFSW, ACC
FL:
8R0 953 568 N: no CCS, Board Computer, no MFSW
8R0 953 568 P: CCS, Board Computer, no MFSW
8R0 953 568 Q: CCS, MFSW, Board Computer, no ACC!
8R0 953 568 R: CCS, MFSW, ACC, Side Assist, Board Computer
8R0 953 568 S: CCS,Board Computer, MFSW, ACC
Steering column lever and steering column stalks must be from the same manufacturer!
8R0 ... = VALEO
8K0 ... = KOSTAL
4G0 ... = VALEO
4G8 ... = KOSTAL
also coding
01 (engine control unit)
byte 6 bit 0 Activate
16 (steering column control unit)
byte 2 bit 2 activate
i'll ask Dana to make a table from this data ;)
Pekka Perkeles
C?ID=288400
8K0 953 568 D doesnt support cruise control you need one of the following:
I've now purchased that one.
also coding
Thank you.
I will install new hardware next week and try coding again. Do I need an updated VCDS/definitions?
Dana
Western PA, USA
Thanks! I was off the week you posted and just noticed this thread. Our B8 CCS Wiki page is limited at this time:
http://wiki.ross-tech.com/wiki/index.php/Cruise_Control_Retrofitting_(8T)
.. but I should be able to create a page (like the Golf based modules) with a chart. Feel free to bump this back up or PM me.
The current version of VCDS should work fine. I would change that #16 coding from 000001 -to- 000005 using the Long coding helper when the new module is installed.
