Looking forward to place an order...
somedude
Yuengling Country
C?ID=306296
Hello Ross-tech and forum users.
I was very close to buying a package a few years ago when we got my wife's Tiguan, but I didn't think I would get enough use of out it.
But now that I got a Q3, I think I can justify the purchase, especially since the new model is out!
So now I'm saving a bit and I will place an order soon, so I thought I would bug users of this forum with some questions.
I have a couple of immediate needs for the tool, on both cars disabling DRL and enabling TPMS on the Q3. If it has the right ABS module, which I'm still trying to figure out.
I have no plans to replace or upgrade stuff, but I would like to have control over some features that bug me, such as putting the radio on the Tiguan in timer mode instead of turning off. Normally, it should turn off when the key is removed and this has bugged me from day one. Of course, if it can be done.
Stuff like that, I'm sure I will find some other tweaks once I get it. I also own a Scangauge II, but that's a different class of tools, useful for real time monitoring and some OBDC code reading, unlike VCDS, which is a true tool that can also change setings.
From what I saw on the forums, there is a ton of information and codes, so I hope to be able to find what I need, when I will need it.
Thank you for the opportunity.
Bruce
Near Philadelphia, PA, USA
Hi somedude and welcome to the forum.
Once you have your VCDS tool, and you can have a full tool for as little as $199 and cover both these cars, you should come back to the forum and post the Autoscans from the vehicle on which you wish to make the mods. With the information in the scans, the community can then look and determine whether or not your desired changes can be performed. We look forward to helping you here.
somedude
Yuengling Country
C?ID=306296
Thank you Bruce.
I'm hoping to not run into nasty surprises after I get the tool...
This kind of stuff should be feasible, right?
I realize it depends on the cars, but my requests aren't far fetched, are they?
Thank you Bruce.
It's hard to say exactly what is and isn't possible without seeing scans from the cars in question because much depends on how they're equipped, and in some cases, even the software versions in the modules...
somedude
Yuengling Country
C?ID=306296
Hi Uwe and thanks for jumping in.
I'm not polishing the proverbial apple, but being a huge fan of Peter Sellers, every time I see your avatar I smile, thinking of Dr. Strangelove.
I think I was simply asking whether VCDS is capable of doing those things, but I answered that question by doing some searches.
Others have disabled daytime running lights, enabled the tire pressure monitor and then some, such as enabling the green menu in the MMI.
Much to my chagrin, I can't figure out what version of MMI I have, but I will cross that bridge once I get the tool.
It may not even be MMI, in spite of the display saying so, because this is the base model Q3 without NAV, even without the media interface. If I have my acronym right, it may be the radio based interface RCM or something like that.
BTW, do you guys also have a store in Lasndale, or just the online one?
Sure, but I can't promise you that you'll be able to do all those things in the exact cars that you have, and I would rather under-sell than over-sell. :)
Our office is there, but it's not a retail store. If a customer wishes to pick up an order, that can be arranged, but we ask that they place the order on-line so that we have it ready for them. If a customer wishes to stop in to have us check something out on their car, we ask that the make an appointment for that. Some days (or even weeks) are better than others.
somedude
Yuengling Country
C?ID=306296
I can now start posting in the main forum, like a big boy!
Got my V2 the next day!
Thanks, Ross-Tech
somedude
Yuengling Country
C?ID=306296
Until I get the activation code, here is my auto scan with the VIN obfuscated (sorry - paranoia).
I'd be very interested if I could enable TPMS and Passenger side mirror tilt when backing up.
Thank you very much
Thursday,20,April,2017,17:51:05:35103
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: WA1ECCFSXHR0xxxxx   License Plate:
Mileage: 1960km-1217mi   Repair Order:
Chassis Type: FS (8U0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 5F 62 6D 72
VIN: WA1ECCFSXHR0xxxxx   Mileage: 1960km-1217miles
Address 01: Engine (CCT)       Labels: None
   Part No SW: 8U0 907 115 L    HW: 8U0 907 115 J
   Component: 2.0l R4/4V TFSI  06 0002
   Revision: PAH05---    Serial number:
   Coding: 0123010A190F01A0
   Shop #: WSC 00049 770 00119
   VCID: 40DA496FE68B52F76D9-8014
   Part No SW: 09G 927 750 NL    HW: 09G 927 750 NL
   Component: AQ 250 6F           2696
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 00049 770 00131
   VCID: 084A914F8E3BAAB7659-805C
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CF    HW: 5N0 614 109 CJ
   Component: ESC-EBC460iV1 H12 0013
   Serial number: A01DDR6
   Coding: 42FF269F492143702077420964C592C20424D000508B4883
   Shop #: WSC 00049 770 00154
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 71BCDCAB91218B7FD27-8024
   Part No SW: 8U0 820 047 G    HW: 8U0 820 047 G
   Component: J255  Klima Man     0030
   Revision: 00H02001    Serial number: 00000000000000
   VCID: 392C248B8551033F2A7-806C
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
   Part No SW: 8X0 907 063 AG    HW: 8X0 907 063 AG
   Component: BCM PQ35  M   113 0821
   Revision: AB113821
   Coding: AF000A0FA80336C4A4184BC121440D4D50FF66AA016F9523E40A06840045
   Shop #: WSC 00049 770 00015
   VCID: 015C8C6BA1019BFF227-8054
   Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119
   Component: WWS316 161110  H38 0090
   Serial number:         161202235421
   Coding: 0047F7
   Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0004
   Serial number: 50080466
   Coding: 02006E
   Subsystem 3 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
01134 - Alarm Horn (H12)
                    Reset counter: 75
                    Mileage: 82 km
                    Date: 2017.03.19
                    Time: 11:47:58
                    Voltage: 9.10 V
                        Term 50 On
Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
   Part No SW: 8U0 959 655 A    HW: 8U0 959 655 A
   Component: AirbagVW-AU10 H53 0723
   Serial number: 003LQD12VCBY
   Coding: 303932313231413130304A55304C38553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 002001
   ROD: EV_AirbaAU10SMEAU316_002.rod
   VCID: 45D4587BF52977DF5EF-8010
   Subsystem 1 - Part No SW: 8U0 959 339     HW: 8U0 959 339
   Component: BF-Gewichtss.  H02 0020
   Serial number: 5810000R160000FXJ7
   Component: S.Sens.Fahr.V
   Serial number: 3574MSME7953485BZZZ4
   Component: S.Sens.Beif.V
   Serial number: 3584MSME1D644B5CZZZ9
   Serial number: 3516KSME4A652040ZZZK
   Serial number: 3526KSME056E0F40ZZZY
   Subsystem 6 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME490E1140ZZZZ
   Subsystem 7 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3565USME58121140ZZZP
Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
   Part No SW: 8X0 953 501 D    HW: 5K0 953 569 AL
   Revision: FF010018    Serial number: 20161215100521
   Coding: 1984204000
   VCID: 3B203E8383ED312F38B-806E
   Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
   Serial number: 09 12 2016  C0014777
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8U0 920 930 H    HW: 8U0 920 930 H
   Component: KOMBI_MEDIUM  H05 0540
   Coding: 32CF00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 3C223D9F86E33617311-8068
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8U0 907 468 AS    HW: 8U0 907 468 J
   Component: GAT 4CAN 2L M H13 0090
   Revision: 1R190044    Serial number: 4441R16B3002B7
   Coding: F3460A5A050B0D610253
   VCID: 1370B623CB7D196F80B-8046
   Subsystem 1 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS11.403  H03 0004
   Serial number: 0000FST001BLWSL00000
   Coding: 101E00
   Subsystem 2 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 33342I01145831018801
   Subsystem 3 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS11.403  H03 0004
   Serial number: 0000FST001BLWTM00000
   Coding: 001E00
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00015.11.16
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_SK12.rod
   VCID: 52FE73273467D067CBD-8006
   Component: IMMO          H05 0540
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 K    HW: 8X0 959 793 K
   Component: TSG FA        H11 0415
   Coding: 011E03200000000000
   VCID: 55F4883B0509C75F2EF-8000
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.377 1501
   Revision: 1BH04843    Serial number: 00163140160701
   Coding: 0000258
   VCID: 42DE4367E88740E77BD-8016
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 K    HW: 8X0 959 792 K
   Component: TSG BF        H11 0415
   VCID: 54F2753F0EF3DE57D91-8000
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
   Serial number: 161206-0002-130
   Coding: 16C7A41010022400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 44D2457FFE134ED7491-8010
   Part No SW: 8U1 035 187 B    HW: 8U1 035 187 A
   Component: RMC Cnct Sir  H62 0170
   Coding: 01000600028051070023000102010000010000
   VCID: 382A218FB25B1A37D59-806C
   Subsystem 1 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
   Component: DUBasic AU316  H43 0018
   Serial number: AUZ8ZDGCS038WS0
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010E03200000000000
   VCID: 4FF87A5327D5BD8FE43-801A
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 8U0 959 107 A    HW: 8U0 959 107 A
   Component: HDSG-Modul    H02 0552
   Revision: 15001001    Serial number: 328601189
   Coding: 183307C102
   ASAM Dataset: EV_HDSGAU316 001001
   ROD: EV_HDSGAU316.rod
   VCID: 3D24309B9DF93F1F06F-8068
   Component: TSG HR        H08 0415
End----------(Elapsed Time: 01:15, VBatt start/end: 12.5V/12.5V)-----------
Since you ordered your HEX-V2 directly from us, you should not need an activation code; it should be pre-registered to you. I see a registration request from you. Is the software giving you an indication that it needs to be registered?
[Select]
[52-Door Elect, Pass.]
[Coding]
[Long Coding Helper]
Click on Byte 4.
There should be an option for Reverse Gear Mirror Dipping
But I'm not certain your car supports it.
somedude
Yuengling Country
C?ID=306296
Thanks Uwe,
Sorry about that, I followed instructions on the forum, thinking it needs to be registered.
I didn't try anything to be honest, I am a bit afraid to do anything without homework.
I will, however, try.
Thanks Uwe,
No worries. It happens with some regularity that we get registration requests from direct customer whose systems should have been pre-registerd, and I've been scratching my head wondering why. Usually I don't have and open channel with them like I do with you, so I just approve their requests. But in your case, I figured I'd ask. Anyway, unless you see something that indicates you only have a certain number of unregistered uses left, there's no need.
somedude
Yuengling Country
C?ID=306296
[Select]
[Coding]
Click on Byte 4.
Thank you.
It turns out I didn't need any registration, it just worked and registered the VIN.
I was able to find and set the options for mirror dipping.
There were three bits, I set all three.
Much to my delight, when I put it in reverse, the mirror dipped.
Then much to my dismay, the mirror refused to return to normal once I padded 10 mph or when I turned ignition on.
I may have to do some research on how to set it properly, but it almost feels that it worked.
I also tried going into the MMI and ABS to see if I can enable the green menu or TPMS, but no lock there, I have to research some more.
Also, one ECU was not found and I already posted my scan, but it also asked for some additional info (sorry, I forgot what) that I don't know how to pull. I will post details, but right now I need some shuteye.
Thank you very much for everything.
somedude
Yuengling Country
C?ID=306296
Sorry, one more: I found this on audizine:
Enable Hidden menu in MMI
[5F - Information Electr.]
[Adaptation - 10] -> Channel 6
change 0 to 1
I understand 5F and the bit toggle from 0 to 1.
I also assume channel 6 would be bit 6, but what's "adaptation"? Is that the byte?
Is the numbering the same, in other words, fist byte is 0 and not 1 and first bit 0 like it normally would?
Just scared that I might mess things up...
somedude
Yuengling Country
C?ID=306296
change 0 to 1
Please ignore me, I found the Adaptations button... Duh...
