Vehicle Speed Shows 5 km/h while standing still
da40flyer
C?ID=195337
I have completed an engine swap putting a 2.0TSI with DSG into my Lotus Exige.
Many of the stock VW components were not ported over, one being the ABS and wheel speed sensors.
I have an APR stage3 kit with tune installed. The tune changes the rev limit to 7100RPM.
The vehicle runs great with the exception of 2 things:
1. the standing rev limiter hits at 1700 rpm versus the 3800 rpm it is supposed to be. This happens with the APR tune as well as the stock tune.
2. the engine only revs to 6400 rpm and hits the limiter in Tiptronic mode, instead of the 7100 rpm programmed into it.
In VCDS, the DSG shows the vehicle speed correctly, as expected.
But in the ECU it shows the vehicle speed as being 5 km/h while standing still. See photo below.
Now since I do not have the ABS or the wheel speed sensors, I would expect this to always be zero.
Any ideas why this may be showing 5 km/h? We think this may be causing the issue with the rev limits.
vajyLkn7oFtbv5U4krExwDq4JKrgPMvYRGQl_1OTZy_no11nEGWrb111M-yZMBWeEZchq8-g369ZDq2y94yJ6CcpOTRIWhIVNwDD3OHjiG2P7PGGkT51VsJwiEgiJJ5Z38Z-ky22jnNAfjWC5yyX89yXFXUTHtRTwDs3qR6JmWsqOmxSouafdX8usjt4tIWvo02Jc58vG7mRzD2Zm8cnncYixVYj1hzMehCHmGzN-WUvdkMlNqJPR74ctDWCiEQnSJce6Zx37c40wPn7zGPN314DzqnO6Mzxbpfv_Bpt6Zm8sgleQm9gkT5a-Hjr4JEeeKZ4J7kr0prZ8NRdtziV4Y-wt9AX4--3cCHwhvEI5cvn2nXatf4il-SANW_JoPn5a87Hc-ZKPofPsL1ijq8pG5ZXI1bi90vQzFyYwAdMr-Odj0w7S3SrNtaRIRdTFQ21PFbLBLdAZV48O8R-E6ZYfZ7XFl1Xc9dg8N4Kr30jIWVxJwyv-yvR4TTwZ9UeDQIAV9g_6tcn9UOIi6zK6UOaxRkTUtNQHWtkmOERl3zsRSeZ15u1KyFTfqsPYE9uoUswPx1m8T6a9_5xSxAupWsnhaz-9sKGCH4gC7We1YpHvQMtsbiuRc8pNrJabpTQHD8RyyAaQYmx4R0HacEUmsuT-Q_sITzIxF0mtHEO6hsEqg=w1458-h820-no
Monday,01,May,2017,19:04:02:24527
VCDS Version: 17.1.3.0 (x64)
VIN:    License Plate:
Chassis Type: WC (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 56 62
          65 72 77
VIN:
02-Auto Trans -- Status: Malfunction 1010
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Cannot be reached 1100
1C-Position Sensing -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 FE    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2    3952
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404010A1C070160
   Shop #: WSC 08252 444 178642
   VCID: 73E52CE812EAE7D9E4-8026
11 Faults Found:
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 000 - Signal too High - MIL ON
                    Fault Status: 11100000
                    Speed: 255.0 km/h
                    Temperature: 24.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 12.319 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - MIL ON
049493 - No Communication with Instrument Cluster
               U0155 - 000 -  - MIL ON
                    Speed: 255.0 km/h
                    Temperature: 24.0°C
                    Temperature: 25.0°C
                    Voltage: 12.319 V
049489 - No Communications with Airbag Control Module
               U0151 - 000 -
049682 - Steering Column Control Module
               U0212 - 000 - No Communications
                    Speed: 255.0 km/h
                    Temperature: 24.0°C
                    Temperature: 25.0°C
                    Voltage: 12.319 V
049448 - No Communications with Parking Brake Control Module
               U0128 - 000 -
001152 - Coolant Fan Control Circuit 1
               P0480 - 000 - Electrical Malfunction
                    Speed: 255.0 km/h
                    Temperature: 24.0°C
                    Temperature: 25.0°C
                    Voltage: 12.319 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 000 -
                    Speed: 255.0 km/h
                    Temperature: 24.0°C
                    Temperature: 25.0°C
                    Voltage: 12.319 V
009216 - EVAP Leak Detection Pump Control Circuit
               P2400 - 000 - Malfunction - MIL ON
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 000 - Malfunction / Open Circuit - MIL ON
                    RPM: 1293 /min
                    Load: 8.2 %
                    Speed: 255.0 km/h
                    Temperature: 24.0°C
                    Temperature: 25.0°C
                    Voltage: 12.573 V
Readiness: 0010 0101
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 3509
   Revision: 05351112    Serial number: 00001010310666
   Shop #: WSC 44551 111 44551
   VCID: 254102B0ECBEC969BA-8070
6 Faults Found:
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
                    Fault Frequency: 9
                    Reset counter: 40
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller
                    Fault Frequency: 9
                    Reset counter: 40
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster
                    Fault Frequency: 9
                    Reset counter: 40
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor
                    Fault Frequency: 9
                    Reset counter: 40
18290 - Powertrain Data Bus
            P1882 - 000 - Missing Message from Electric Parking Brake Controller
                    Fault Frequency: 9
                    Reset counter: 40
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527)
                    Fault Frequency: 9
                    Reset counter: 40
Address 03: ABS Brakes
Address 08: Auto HVAC
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 0000000000000000009802059400800440517C8840600D605C8060200040
   Shop #: WSC 08252 444 183854
   VCID: 4189B620D8D60549A6-FFFE
30 Faults Found:
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 241
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:00:04
                        Term 15 Off
                    Voltage: 12.35 V
                    Reset counter: 241
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:00:04
00532 - Supply Voltage B+
                    Reset counter: 26
                    Voltage: 12.30 V
                    Reset counter: 26
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 241
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:01:46
                    Voltage: 12.05 V
                    Reset counter: 241
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:01:46
00984 - Left Tail Light (M4)
                    Reset counter: 237
                    Mileage: 37717 km
                    Date: 2027.14.22
                    Time: 08:38:36
                    Voltage: 13.85 V
00985 - Right Tail Light (M2)
                    Reset counter: 237
                    Mileage: 37717 km
                    Date: 2027.14.22
                    Time: 08:38:36
                    Reset counter: 237
                    Mileage: 37717 km
                    Date: 2027.14.22
                    Time: 08:38:36
                    Voltage: 13.95 V
                    Reset counter: 237
                    Mileage: 37717 km
                    Date: 2027.14.22
                    Time: 08:38:36
                    Reset counter: 241
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:01:44
                    Voltage: 12.05 V
                    Reset counter: 241
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:01:44
                    Reset counter: 241
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:01:44
                    Voltage: 12.05 V
                    Reset counter: 241
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:01:44
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
                    Voltage: 14.20 V
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
01503 - Bulb for 3rd Brake Light (M25)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
01505 - Bulb for Blinkers; Rear Right (M8)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
01506 - Bulb for Rear Fog; Right (L47)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
01800 - Light Switch (E1)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
02235 - Stationary Cornering Lamp (Left) (M51)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
02236 - Stationary Right Cornering Lamp (Right) (M52)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
02198 - Bulb for Tail Light 2; Left (M49)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
02199 - Bulb for Tail Light 2; Right (M50)
                    Reset counter: 238
                    Mileage: 37750 km
                    Date: 2027.14.29
                    Time: 17:38:56
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 251110F1000082
   Coding: 469006
   Shop #: WSC 05314 000 00000
   VCID: 3467EFF49764A0E13D-FFFE
20 Faults Found:
                    Fault Status: 00110100
                    Reset counter: 29
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:00:39
                    Reset counter: 29
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:00:39
                    Fault Frequency: 0
                    Reset counter: 0
                    Raw, Form. N/A: 000 000 000
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
00484 - Vehicle Position Recognition Control Module (J603)
                    Fault Frequency: 0
                    Reset counter: 0
                    Fault Frequency: 0
                    Reset counter: 0
03272 - Control Module for Audio Interface
                    Fault Frequency: 0
                    Reset counter: 0
02001 - Data-Bus Automatic Distance Regulation
                    Fault Frequency: 0
                    Reset counter: 0
Address 1C: Position Sensing
Address 25: Immobilizer
Address 2E: Media Player 3
Address 44: Steering Assist
Address 46: Central Conv.
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: 6FED2098BEC2C33900-803A
02174 - Analog/Digital clock
                    Reset counter: 241
                    Mileage: 37751 km
                    Date: 2028.14.31
                    Time: 00:01:45
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 56: Radio
Address 62: Door, Rear Left
Address 65: Tire Pressure
Address 72: Door, Rear Right
Address 77: Telephone
End-------------------------(Elapsed Time: 03:24)--------------------------
The behavior you're describing might just be the ECU's fall-back when it has no clue.
I doubt it will help, but I would fix the Gateway's installation list to reflect the modules that are actually there.
Hello OP.........
It very most likely is.
Couple options........
Take an ABS controller + SAS and add to the car with the inputs merged to control the wheel spin signal for good hole shots or have APR edit the data in the stack to change the limitations for when the ABS speed signal is missing to the engine controller under the ESP section in stack and steering angle sensor.
Where are the pictures of this thing..........? Post some please! :rolleyes:
Spacewalker
Poland
C?ID=159607
so many "cannot be reached" .... first fix this, then do MB
da40flyer
C?ID=195337
Gateway fixed to reflect what is actually there. No change in how it acts.
Jack,
I cannot add back the ABS as that part of the harness has been removed. But I will speak with APR on your suggestion and see what they say. APR has already gone above and beyond to help me, as this sort of custom work is not their business model. I have to say, some really great folks there.
Here is a link to a write-up I did on the build: http://www.lotustalk.com/forums/f157/exige-vw-2-0-tsi-dsg-conversion-build-399546/
Page 5 of the post has an in-car video on track...
-David
da40flyer
C?ID=195337
Another Idea:
Looking at the schematics, it appears that the ABS receives the wheel speeds from the sensors and then provides this info to the ECU on the drivetrain CANBUS.
If that is true, could I simply create another micro controller which reads the vehicle speed from the DSG and then creates the appropriate CAN messages for the individual wheel speeds from that data, and puts them out on the drivetrain BUS?
Another Idea:
In principle, that should be possible. But one would have to know the message IDs and formats, something that isn't documented anyplace that I know of.
FWIW, I suspect the ABS module only puts a single vehicle speed on on the CAN bus; not all four individual wheel speeds.
da40flyer
C?ID=195337
I had to do a similar project in order to remove the center console gear select lever and replace with buttons to select P, R, N, D, S, M. The buttons look way cooler :)
With that I had to sniff the BUS to get the data. As you said, the CAN data is not documented anywhere unfortunately...
I thought I read somewhere that it uses the front left sensor for vehicle speed. But simple enough to write out all 4 just in case....
da40flyer
C?ID=195337
We can't read the DSG vehicle speed as it is not broadcast on the bus. So, we added code to the existing custom gear select controller so it now sends out a can message telling the ECU that the vehicle speed is always zero.
With that, the standing rev limiter works correctly, and the overall limiter now revs to 7000 rpm, as it should.
But from this change we have created a new problem... it does not blip the throttle on downshifts any longer... probably because the ECU thinks the vehicle isn't moving...
A vicious circle :banghead:
Eric
HC800000
I'd be surprised if the DSG didn't respond to PID 0x0D over OBD2... and then you could rebroadcast that on the powertrain bus since apparently you now know how to do the hard part :) Unless you're already using OBD2 for logging reasons, or the DSG doesn't know the vehicle speed either.
I would add the abs module and sas, with a cluster to emulate the signals and get you the packets needed on broadcast.
It's not that much wiring.
Spacewalker
Poland
C?ID=159607
.....but ABS need talk to another module .....so add another module
then "another module" must talk to extra module ...so add extra module too
after that "extra module" need talk to another new module .....so add another new module
da40flyer
C?ID=195337
Here is the new plan:
Going to calculate the vehicle speed from RPM, Selected Gear (we know the gear ratios), and Tire Circumference. Then we will put that out on the bus as the vehicle speed and see how she acts....
Hey Space Ace..........not that many modules speaking to the ABS and options can be coded out.
For me........... I'd a done it just to have the HH and launch control platform.
I would of tied all the speed inputs together so they read the same speed up and down & so the ESP didn't interfere.
To me some things just make sense to have.
OP does the car have working Launch control and HH already?
da40flyer
C?ID=195337
No. I did not include any of it since I always turned off the traction control with the stock setup, and don't need any sort of launch control.
Well the point is you could have the launch control and HH while still completely disabling the ESP by tying the speed sensors together and it would report the speed of the car up and down shift points.
Was just a thought........and HH comes in handy for creep.
da40flyer
C?ID=195337
I just conducted the first test with the additional coding. We calculate the vehicle speed from gear ratio and rpm and then write that out on the bus as the ABS wheel speed. All appears to work correctly!
The standing rev limiter works, the overall rev limiter hits 7000 rpm, and it now blips the throttle. :thumbs:
The issue now at hand is tiptronic shifting. If I am easy on the throttle and pull an upshift, all works perfect. If I am hard on throttle, rev'ing quickly, it doesn't grab the next gear.
I did redo the DSG Reset in VCDS. Could this be due to having removed vehicle power overnight/couple days and DSG needing to do some additional re-calibration of some sort?
da40flyer
C?ID=195337
Haven't been able to nail down the issue.... may be because of constant mismatch between ECU speed and DSG speed... don't know...
So going to try @eric 's suggestion and make a PID request for the DSG speed and write that out as the ABS speed.... would certainly be less coding if it works...
@Eric, are you certain that 0x0D will return DSG speed and not the speed from the ECU (wheel speed sensors)?
It may very well return both; look at the IDs of the responses to determine which is which.
